Hey guys,
Can anyone help me source a 6mm 250k trimmer. Its for a Phase 90 I'm building. I am talking about something like this: https://www.bitsbox.co.uk/index.php?main_page=product_info&products_id=2309 (https://www.bitsbox.co.uk/index.php?main_page=product_info&products_id=2309)
I ordered 2 online that looked correct in the photos, but hadn't any dimensions in the description. They're way too big to fit on the board. I need the correct spacing, as with the 6mm version linked.
PS. I am in Ireland/UK.
Steve.
It may take a while to get there, but Tayda has you covered 8)
https://www.taydaelectronics.com/250k-ohm-trimpot-variable-resistor-6mm.html
Thanks. Hmm, was hoping to have it for a gig this weekend. The 250k trimmer I do have now is about the size of a penny, maybe a bit smaller. I might try just wiring it in somehow, and seeing if I can make it fit lol.
Yes Raff!
The trimmer is set and forget so just wire in a standard pot, adjust till desired phasiness, then remove the pot and measure the resistance between lug 1 and 2.....then measure between lug 2 and 3. Then simply find two resistors that closely match your measurements and solder them in place of the trimmer....so one end of both resistors will connect to the same place the middle lug on the trimmer would go.
I only use trimmers for prototyping these days. Putting one on a board just seems a waste of money/components
Ciaran
Quote from: YellowBoy on March 07, 2018, 01:11:30 PM
If you need it for this weekend that's definitely the way to go.
Do a search for Piher trimmers. They make a 6mm model. I believe they're widely available in the EU.
https://www.mouser.com/ds/2/325/11-PT6v03-4455.pdf (https://www.mouser.com/ds/2/325/11-PT6v03-4455.pdf)
Try Thonk.co.uk
Sent from my F5321 using Tapatalk
Quote from: PMowdes on March 08, 2018, 03:00:48 AM
Try Thonk.co.uk
Or Tayda
You could also try a 200k or 500k trimmer in there (from bitsbox), the trimmer in a phase 90 sets the point at which the phasing starts to work, depending on your transistors its usually near the middle of the sweep so I think you'll be OK, I've used a 200k before. The second trimmer if you have one sets the amount of feedback through the script switch mod
Here's an interesting article and circuit analysis https://www.electrosmash.com/mxr-phase90
Thanks guys, all very helpful. I think I should be ok now. Cheers all!
