DIY Stompboxes => Building your own stompbox => Topic started by: Sody54 on June 20, 2007, 03:23:41 PM
Title: Phase 90 not phasing
Post by: Sody54 on June 20, 2007, 03:23:41 PM
Well, I was going to try and have the first pedal related post..oh well...
I've got my phase 90 up and running.  I seems to have a problem somewhere though.  The only phasing I can get out of it is when I adjust the trim pot.  It won't do it on it's own.   I had to make a couple of substitutions on my build.  First was the 5.1 zener.  The closest I had was a 6.2.  The second was the 4125, I used a 3906.  I also used J201's.
Any ideas out there in this fresh new landscape?
Title: Re: Phase 90 not phasing
Post by: Toney on June 20, 2007, 03:32:21 PM
 Try a lower Zener/ test the Fets for a low voltage matched group...the trick is getting a 'em with Vgs(off) of  less that 3v.
I think the original Zeners were more like 3.3v..so yeah, I'd definitely start there.
Post by: Sody54 on June 20, 2007, 04:01:37 PM
Thanks, I'll try that.  I used the 6.2V because it was the lowest one I had.  Guess I need to go find some more.....Have to build me an FET tester now too I guess.
Thanks for the tips.
Post by: KarenColumbo on April 05, 2021, 02:53:47 AM
"Karen was here"
Post by: jimilee on April 05, 2021, 05:43:25 PM
Are the j201s matched? I'm interested to see if you can get it working. Those are a considerably higher output tranny the 5457s or the 5952s.
