It seems I have a problem!!! I have those standard 9 pin tube sockets, like this one (http://www.vintageamplifiersupplies.com/media/miclex9pin.jpg) - I thought I could buy the screws to hold it easily. Guess what, can't find them anywhere!!! they should be 2mm, you can find a lot of screws from 3mm up...
Where can I find those screws to hold those sockets to the enclosure!?
You could try a model shop, radio controlled model shops usually do packets of small screws, washers and nuts etc.
Very strange problem, I dare say. Try to make the holes bigger with....... a drill! :icon_biggrin: Or use smaller screws, as it is said above.
Quote from: Zapp Brannigan on May 17, 2010, 09:24:58 AM
Yeah that's what I'm after but cannot find the right screws...
You could probably buy the proper-sized hardware (which might be #3 or #2 screws, not sure what size that is in metric), but it might be cheaper in the long run to buy a tapered reamer and just enlarge the holes to fit whatever hardware you commonly use. There's plenty of extra metal there, but take care not to go too fast or the reamer can "bite" into the metal and tear it.
Quote from: Renegadrian on May 17, 2010, 08:56:15 AM
they should be 2mm - I don't think it's a true - I use M3 screws for these sockets, you just have to search for the screws with smaller (narrower) head.. T.
The 9-pin socket should take a #4 screw with a small head. That's been true since the 7-pin came out in the 1940s.
This works out to 2.85mm. The #4 fit was always loose, I would think a 3mm screw would go in the hole.
Unfortunately the guys who make sockets don't use them. Often the threads fit but the head butts the side of the socket. When electronic parts were sold everywhere, it was easy to find small-head screws.
And looking at your picture, that socket does not have the dent next for the screw-head. There should be a good semi-circle, about a mm clearance all around the hole.
Model-shop for small screws.
Get the screw in crooked then tighten carefully to indent the shell for the screw head.
Most of the time I used a #4 but sometimes I can use a #6 depending on the head style.
Andrew
Quote from: PRR on May 17, 2010, 05:04:07 PM
Yeah, my sockets have that little space, a little semi-circle...They look like the ones of my second link below.
See, I'd really love to screw those MFs down with the right screw and bolt, like this (http://www.diystompboxes.com/smfforum/index.php?topic=63479.msg683833#msg683833) or this (http://farm3.static.flickr.com/2596/4079939969_612bb99693.jpg)
THX for all your replies!
The cheap slotted panhead in the picture is getting hard to find, except by stripping old US tube gear or raiding old junk-boxes.
Not an endorsement, just saying:
Hoffman (http://www.hoffmanamps.com/) has 4/40 x 1/4" or 3/8" Phillips screws and KEPS nuts. I have used them on recent-production 9-pin sockets (also from Hoffman) and everything fit fine and looked great. He will ship outside the US. He has no minimum order. In the US he charges actual shipping and ships quick, but Customs Forms are a pain so he will add a few bucks to ship to Rome(?) and it won't be so quick.
But you should be able to find tube-socket screws locally. A hardware store with small sizes, or a local tube-amp supplier.
Allen head (hexagonal socket) screws should be available in most places and they have the advantage that you do not need any extra clearance for the screwdriver which in this case happens to be a hex key. And they do look cool. You can get ball-end allen screwdrivers for cases where you have to come in at an angle.
Make them work overtime without any extra pay :P :P :P ;D :D
There is a reason slot head screws are going bye bye. Go with atleast Phillips heads or Robertson and make life easier/safer for you and your pedal finishes.
You can find machine screws at most hardware stores. If not Digikey carries both slot(if you are still inclined to use these) and Phillips head machine screws, nuts and washers in stainless and plated finishes. You get 100 screws for around a few bucks.
Andrew
