I've had the idea to try a PT2399 chorus ever since I modded my Clari into a Clari Cubed. The challenge with the PT2399 is to get the delay time as short as possible while still having some wiggle room for the LFO injected into pin 6. I've tried PNP, NPN, FET and LDR - fail! The delay time is either too short for the LFO to have any wiggle, or too long and latency is obvious.
So, screw using pin 6, just ground the MF for the shortest possible delay time and instead modulate the vref at pin2. Shortest possible delay with as much LFO wiggle as you want. In fact it has to be tamed down or you're into tape wobble type effects.
I'm still testing this for any failure modes, but so far it seems very stable. Some values may change a little as I fine tune it. TBH I haven't paid any real attention to the filtering caps and their values, as at the speeds this is running at there is no hiss anyway. Those familiar with the PT2399 family of delays will recognise homage to Rebote and the Clari in the input buffer and output section respectively.
(http://i210.photobucket.com/albums/bb292/frequencycentral/LittleAngelMiracle.png)
Where's the submini? ???
Just kidding. I love it! Great idea. I can't wait to hear clips.
I dig the Vref approach!
Something this easy begs to be tried this week
Interesting. I like the simplicity of the circuit. A board wouldn't even be necessary, unlike most other chorus schemes floating around out there. What opamps did you use?
Quote from: frequencycentral on August 09, 2010, 08:13:21 AM
...and instead modulate the vref at pin2.
:icon_eek: Wow, how did you came to this idea? That's cool! :)
Few 2c notes:
- You could go with normal non-inverting input buffer with same part-count
- There's a small DC on mixing resistors (5V - Vref)
- Depth will probably slightly influence speed
- You could still have some small blocking cap (1uF?) at Vref pin as datasheet calls for
T.
That trick is also done in the payback :icon_surprised:
These might be noob questions but here goes...
Why did you put a Depth pot value of 470K? Why not put it at 500K? I dont know too many places where you can get a Linear 470K pot other than for a Wah.
Also, igerup... what do you mean by a "A board wouldn't even be necessary." How would you build the circuit?
I'm using a NE5532 dual opamp. I used a 470k because here in the UK that's what we use, 500k seemingly being a value available in the US but not here. 500k will work just fine.
How did I come up with the the idea? Well, as I said, I've been trying PNP, NPN, FET and LDR methods into pin 6 but I just couldn't get the resistor value down low enough. So in sheer desperation I thought about actually modulating the +5v feed into pin 1, as I'd notice the delay time 'swoops' if you quickly turn power off and on again - I didn't try it but it got me thinking outside the box. Then I just figured WTF I'll just plug the LFO dirctly into the vref - wobble wobble wobble!
So I'm now waiting for you clever guys out there to suggest any improvements.......
Quote from: Govmnt_Lacky on August 09, 2010, 08:51:49 AM
There's few enough parts for this not so very complex circuit (lets face it, compared with some other projects on this board it really isn't. No offense meant to frequencycentral with this statement, though) that it can safely be built using the PTP (point-to-point) method. If you have the courage :icon_wink: to do it is another matter alltogether.
I suppose you guys want soundclips yeah? ::)
OK yet another genius idea from the robot perf boy 8) (I think he is really an alien)
How does this one sound Rick ?
Obviously pretty good if your posting it,and I still have to build one of your phasers first :icon_evil:
I want your time machine that gives you all the time to do these projects Rick....
Yes time definately is my biggest constraint.. so If you could post that clip now I can still hear it while I'm at work :icon_twisted:
Nah, take it easy. I assume it sounds just like all other pt2399 chorusing I've heard.
So, I wonder what the delay time of a PT2399 is with pin 6 grounded?
Quote from: ~arph on August 09, 2010, 10:13:21 AM
Well played! :icon_mrgreen: T.
Quote from: frequencycentral on August 09, 2010, 10:17:00 AM
Make recording of some "pop" (e.g. switch some DC at input) and measure distance between original peak and delayed peak in this recording. T.
I thought it needed at least 100R or so to keep too much current from running out.
You can check it of course if you play a short note/tick through it without modulation and then record that and measure the peaks.Beaten by T.
Soundclip!
http://dl.dropbox.com/u/967492/Little%20Angel%20Demo.mp3
Signal path:
Keyboard player playing two chords on a guitar >>> Tele Custom bridge pup (HB) >>> Little Angel (on breadboard) >>> Harley Benton VJ clone >>> Shure SM58 >>> Wavelab
No other processing.
Nice!
That actually sounds different then modulating pin 6. It has more of a vibe feel to it.. come to think of it.. how does it vibe without the clean mixed in?
That sounds GREAT !!
Nice one Rick !
Sounds great! Is the sound at 0:11 (the first time the effect is used) at the slowest speed?
Quote from: frequencycentral on August 09, 2010, 10:43:20 AM
Oh, that sounds promissing*! And I'd say that delay time is pretty short actually (just short enough for proper chorus)! Please, measure it if you have a minute.. Thanks a lot! T.
*to be specific: I miss slower speed and at the slowest speed on the demo I'd say modulation sweep is not ideal**..**EDIT2: Maybe just increasing of the LFO -> Vref decoupling cap value (10uF on the schemo) would help it.
Whats your voltage out the 7805 ?
I have everything except that to try this...
Also hows the volume ?
I noticed no volume pot is it more than unity ?
I'm going to try this tonight with my favorite sine LFO..
EDIT: The 7805 puts out 5V
By the way, you do realize a lot of boutique builders will now start modulating pin two right? :icon_mrgreen:
No relation between voltage and delay time by any chance I suppose?
Quote from: ~arph on August 09, 2010, 10:48:38 AM
Wet only, a little latency is discernable when playing: http://dl.dropbox.com/u/967492/Little%20Angel%20Wet%20Only.mp3
Quote from: mth5044 on August 09, 2010, 10:53:13 AM
Wet/dry mix, slowest speed, maximum depth, though easy to tweak for even slower and deeper: http://dl.dropbox.com/u/967492/Little%20Angel%20Slowest%20Speed.mp3
Quote from: Brymus on August 09, 2010, 10:57:05 AM
Voltage out of 78L05 is er, 5 volts. Unity gain. I tried a mix pot earlier in the experiment but it screwed with the unity, so I dropped it and went for fixed resistors.
Quote from: ~arph on August 09, 2010, 11:05:58 AM
They will have to ask my permission first surely? :D
Nice clips, Rick!!! I have to try it soon!!! (hopefully in September...)
Genius work, you have just released another simple (beginner) chorus for this world. Simple design and sounds fantastic, almost like if you were young.
Cool! I'm also curious to know the delay time.
Sounds good, I'll have to have a play with that. Presumably the modulation still works if you stick a resistor between pin 6 and ground, so this could also be used to modulate any PT2399 based delay.
You could modulate Vref and delay time :o :icon_eek:
I had gotten a Belton Brick based delay/reverb to sound pseudo chorus-y by starving the voltage. I didnt investigate further because if you starve it too far, the chip freaks out and makes random, awful noises. It kind of made it sound like a Deluxe Memory Man.
There is no reason you couldnt do the same thing to those reverb modules, which probably are just a bunch of PT chips in the brick.
Quote from: slacker on August 09, 2010, 12:47:14 PM
exactly. nice to know there's a super simple way to voltage control these... great job, rick! :icon_mrgreen:
That is frighteningly good for two chips.
A new chapter in modulation pedals, I hope :)
Quote from: frequencycentral on August 09, 2010, 09:05:42 AM
OK ;)
(http://thmq.mysteria.cz/diystompboxes.com/LA_Thmqs_Notes.gif)
It's just a quick draft adressing my previous notes mostly, consider at least non-inverting input buffer and "No DC" mod.
About the LFO buffer - it would be maybe cool to adjust LFO out to work around 2.5V (~PT2399 V
ref), then decoupling 10uF cap (which makes shape of sweep dependant on speed in IMO not very pleasant way) could be removed.
T.
EDIT: GIF slightly updated (+"Placeholders for.."), you may need to refresh page..
Thank you Tomas! I will try these mods soon. I have already added the 'no DC on output' mod, as well as adding a 100R to ground from pin 6 instead of directly grounding it, on Arnoud's advice. Interesting that you suggest non-inverting input buffer, I was under the impression (perhaps mistakenly?) that the output of the PT is inverted, therefore assumed that the inverting buffer I lifted from the Rebote 2 was appropriate? It's important to be mixing in-phase signals here, so I'll try it and report back. As for the LFO, I'm going to have to experiment some more to get it wobbling either side of 2.5v, but yes it will be worthwhile as the 10uF coupling cap certainly does affect the waveform. I see you added LPF's similar to Rebote, probably a good idea. I am also considering adding a 'bright' pot/cap to ground from pin 14. Maybe I should also try adding the wet/dry blend pot back in now there is no DC there!
I've seen some different cap values for the 9 - 10 and 11 - 12 connections( datasheet ).
I recall seeing a schematic that had a switchable parallel cap at the pin 9 -10 cap. I believe it was labelled HP/LP. So that cap supposedly has influence on the bandwith.. I'm curious what different caps do there.
I'm interested in everything pt2399 related as there might be improvements to my 4xpt2399 series delay. (which I still plan to release here)
Quote from: frequencycentral on August 10, 2010, 06:34:06 AM
Thank you Tomas!
My pleasure! :)
Was there audible difference? Did you measure delay times with 0 and 100R by any chance?
Both in and out LPFs of PT2399 are inverting so at the output you should be back at the same polarity (if delay line itself does not change it of course - you could actually check it as a part of delay time measuring experiment :)).
There should be no difference for effect itself - you take dry and wet path from the same point so phase at this point is not relevant. It can by only important for the "outside world" (rest of you setup) in some special circumstances (like processing signal splited for more amps) that phase of passing dry signal is not inverted.. it's sort of "good practise" I'd say..
Btw. Rebote 2 inverts phase twice (at input and at output), so it's (-1)*(-1)=+1 again :)
Btw2: Electric Mistress does not care ;)
Yes, it is again case where proper filtering may be important for "outside world" in some special circumstances.
Again, Electric Mistress does not care ;)
Why not? :)
Even the "wet/dry blend pot" is one of the features I have found useless on chorus (..and phaser ..and flanger) for me (when it's there I just set it 50:50)..
T.
Quote from: Thomeeque on August 10, 2010, 07:49:23 AM
.....as well as adding a 100R to ground from pin 6 instead of directly grounding it, on Arnoud's advice.
Non that I could hear. I haven't done any measurements yet........
Why not? :) Even the "wet/dry blend pot" is one of the features I have found useless on chorus (..and phaser ..and flanger) for me (when it's there I just set it 50:50)..
I'd agree with you there, I have no use for wet/dry mix pots, and leave them 50/50. But others may find it useful, so there will be extra pads on the PCB for that option.
if only we had a more detailed technical data on the PT2399...
PT2399 DataSheet for those that need it.
http://www.datasheetcatalog.org/datasheet/PrincetonTechnologyCorporation/mXyzsyzt.pdf (http://www.datasheetcatalog.org/datasheet/PrincetonTechnologyCorporation/mXyzsyzt.pdf)
Funny...I was just searching around for a simple chorus to try out. I think I'll have to build this and see how it goes!
Thanks for the excellent design (and for the expert tweaks here and there).
Also a PT2399 is cheaper than say a MN3007. And the BOM is smaller than a Zombie.
Having some PTs handy, I think I am gonna get into it. (already working on a vero layout, FIY)
I think it would really benefit any potential builders to wait a while until this design 'stabilises'. I'm hoping to breadboard Tomas's mods later this week - that will be the version to build. BTW, I was 3/4 of the way through a perf/PCB layout when Tomas posted his mods.
I was driving around doing chores earlier, just idly wondering if it would be worthwhile replacing the 2n3904 with an extra opamp stage, then running the two LFO opamps from the 5v supply rail to easily get the LFO wobble bang in the middle of 5v and ground. Then, if we're adding an extra opamp for the LFO, why not add a second dual (or a single quad) and use the spare as an output buffer? This moves away a little from the (desirable) simplicity of the original concept.........Tomas?
I was just looking over the data sheet,
Nothing new to you guys ,I was just noticing that the lower the delay time the lower the THD,which is good IMO especially in this instance.
What would changing out the 100R at pin 6 for a 1-5K pot do to the effect sound ?
It would increase the delay(a little) but is would it sound bad ?
Might it add more(usable?) sounds to the palatte ?
I will try to breadboard this, this week,ahead of other stuff since its so simple.
Maybe I can accidently find something useful to contribute, or at least verify it works for me.
Quote from: frequencycentral on August 10, 2010, 01:32:45 PM
Just make two layouts:
* Little Angel
* Medium Angel
:icon_mrgreen:
I really dig the simplicity of the first posted schematic. It sounds great. Of course, improvements are always welcome, but I sure do love a small, tidy layout.
And I thought the Vref on the chip was buffered...? Even if it isn't, I have no idea how you are getting adjustment in delay times by modulating Vref.
Quote from: Brymus on August 10, 2010, 01:45:45 PM
Look at the data sheet:
1.08k = 40.6ms
4.9k = 86.3ms
..too long for chorus. But.....
0.5k = 31.3ms
0.1k = ?
0.0k = ??
....so for chorus it is desirable to get the delay time as low as you can go.
Quote from: JKowalski on August 10, 2010, 02:31:23 PM
Yeah, the block diagram on the data sheet shows the vref only connected to the opamps. But it works........
So maybe a 1k pot might be useful then,?
I will try myself and report back.
FWIW I havent done anything with LFO's or modulation of any kind yet so this is new to me. :icon_redface:
And really thanks for posting another useful circuit Rick,and for everyone helping (Tomeque,ect)
Cool project!
Okay, now this is funny:
http://www.taydaelectronics.com/servlet/the-63/PT2399-2399-Echo-Audio/Detail (http://www.taydaelectronics.com/servlet/the-63/PT2399-2399-Echo-Audio/Detail)
Okay.. Seems about right.
http://compare.ebay.com/like/260453494074?ltyp=AllFixedPriceItemTypes&rvr_id=122814086475&crlp=1_263602_263632&UA=WXF%3F&GUID=cb6d3f2a10c0a041b291fd31fff7dccf&itemid=260453494074&ff4=263602_263632 (http://compare.ebay.com/like/260453494074?ltyp=AllFixedPriceItemTypes&rvr_id=122814086475&crlp=1_263602_263632&UA=WXF%3F&GUID=cb6d3f2a10c0a041b291fd31fff7dccf&itemid=260453494074&ff4=263602_263632)
Not bad. About what you would expect...
http://compare.ebay.com/like/270597040866?ltyp=AllFixedPriceItemTypes&rvr_id=122835671300&crlp=1_263602_263632&UA=WXF%3F&GUID=cb6d3f2a10c0a041b291fd31fff7dccf&itemid=270597040866&ff4=263602_263632 (http://compare.ebay.com/like/270597040866?ltyp=AllFixedPriceItemTypes&rvr_id=122835671300&crlp=1_263602_263632&UA=WXF%3F&GUID=cb6d3f2a10c0a041b291fd31fff7dccf&itemid=270597040866&ff4=263602_263632)
WTF?!? ??? :icon_rolleyes: :icon_mrgreen: :icon_mrgreen: :icon_mrgreen:
I buy mine fom Tayda, so cheap you can buy a half dozen without breaking a sweat....
....which affords one the luxury of doing unlikely things to the wrong pins (without worrying about toasting it) in the hope of discovering something new!
Quote from: DougH on August 10, 2010, 03:14:43 PM
that's for 460 pcs :)
Just breadboarded the first version and it sounds pretty good, the chorus is quite subtle on the slower setting but it's a nice sound definitely worth exploring. Thanks for sharing it Rick.
I wouldn't say the delay time is significantly shorter than you can get by modulating the resistance on pin 6, but it does the job a lot simpler.
That should work fine, you'll need to use something like an LM358 for the LFO though, a TL072 style opamp won't run off 5 volts. If you're doing that I would change the LFO for a standard 2 opamp type, like in the Echo Base, that will give a "better" triangle output and uses the same number of parts as buffering the LFO you have already.
i cant wait to give this one a try, its #3 on the list
Quote from: frequencycentral on August 10, 2010, 02:52:03 PM
0.5k = 31.3ms
That's actually 0.5
R, so I think that's their way of saying it's as low as you can go!
Quote from: anchovie on August 10, 2010, 05:17:20 PM
0.5k = 31.3ms
That's actually 0.5R, so I think that's their way of saying it's as low as you can go!
Damn, you're right! I completely mis-read that! Thank you!
Quote from: armstrom on August 10, 2010, 03:35:56 PM
Collective buy?!
So, assuming the PT is running close to the fastest it can. At 5 volts. The datasheet says it can handle 6.5 volts absolute maximum. The question is, if we give it 20% more volts (ie 6 volts) are we also then going to over-clock it into 20% faster delay time? Theoretically we could shave off 6.4ms........?
hey rick, what about setting the resistance to ground of pin 6 variable instead of being shunted to ground? would it get it closer to a modulated delay something?
Quote from: Mugshot on August 10, 2010, 09:47:08 PM
Yes, but slacker's Echo Base does modulated delay better, and with multiple repeats and a host of other useful functions. But with Little Angel I think having any more than the absolute minimum resistance between pin 6 and ground is missing the point. Little Angel is a chorus, so it's desirable to keep the delay time as short as possible.
Quote from: frequencycentral on August 11, 2010, 05:22:29 AM
and... what about feedback,
maybe a small, frequency controlled feedback may add interesting effects
Quote from: culturejam on August 10, 2010, 02:27:41 PM
* Little Angel
* Medium Angel
Or maybe Little Angel and Little Devil? Then Rick could retrospectively enter the 666 competition (as he made the rules up as he went along anyway) and win himself a Murder One!
Oh hang on....from the 666 comp thread.....
Quote from: frequencycentral on August 03, 2010, 08:32:43 PM
Quote from: trad3mark on August 03, 2010, 08:05:27 PM
Thanks rick. :) The overall prize aside, can we expect any "work" from you???
Nothing demonic sorry. I'm working on angelic!
*****CLANG**** The penny drops.
I love the sound of the clips, Rick. Not usually a fan of chorus but I really like the organic-ness of this. I take your point about Echo Base doing modulated delay better , but I think I'd like a variable R at pin 6 so that I get a really really nice sounding chorus (primarily) with the added bonus of mod delay (secondary).
Good work, sailor. As always.
Quote from: markeebee on August 11, 2010, 06:24:50 AM
Hahahaha - well spotted sir!
I think this project will continue on two seperate paths:
- I'm determined to keep the super simple version as close to the original schematic as possible, there should be an entry level chorus build available. I am avoiding 'feature creep' like the plague. I've just completed the layout for this version, including the most basic of Tomas's mods.
- The 'elite' version could have wet/dy mix, bright cut, feedback, variable delay time, improved LFO, differential output buffer.........anything else? But it's going to take a while to get there.
I'd increase the max available depth of the effect. What you have now I'd say is in the middle of what I'd want.
Quote from: ~arph on August 11, 2010, 07:03:47 AM
That woud just require the 100k at pin 2 to be reduced to say 47k.
Yes, I know, but I'd include that in the minimal version so it's a bit more versatile without increasing circuit complexity ::)
Oh my goodness, you're right. :icon_redface: :icon_redface: :icon_redface:
I didn't see that... I just checked the "quantity" at the top. My bad.
And sorry for the thread derail. :icon_redface: Carry on...
Quote from: ~arph on August 11, 2010, 07:38:58 AM
A switch a one more res. should keep it simple yet
Fresh from the breadboard:
- Tomas's suggested 1uF cap to ground from pin 2 stops the modulation!
- The minimum useable value for the resistor at pin 2 is 33k.
- Just for giggles, I implemented a feedback loop and got a very metallic sounding pseudo reverb.
I'm with Rick on this one: keep it as simple as possible for now, as this could definitely be the easiest chorus build around.
...but once that's verified then let the feature tweaks commence to see how far we can take this thing!
Rick, would you say your initial schematic is ripe for people like myself to perf to our hearts content (you had suggested waiting earlier)? Thanks again!
Quote from: p_wats on August 11, 2010, 10:42:28 AM
I just updated the schematic and reloaded it into photobucket, it should show up in post #1 of this thread if you refresh. It says version 2 on it. At this very moment a friend of mine in NJ is populating a PCB made from my layout. Once he verifies it I will post it.
no version 2 even on refresh... :icon_frown:
Quote from: Renegadrian on August 11, 2010, 12:49:35 PM
Yeah I noticed that. I deleted the original and loaded the new one under the same name, so it should be showing up. Probably an issue with photobucket. If it doesn't refresh in a few hours I'll upload it under an new name and repost it. I just didn't want to confuse the thread with many different schematics.
Quote from: frequencycentral on August 11, 2010, 12:59:25 PM
Nice! Works for me now. This will have to go to the top of my list...
Hmm, still not refreshing for me...
(http://i257.photobucket.com/albums/hh218/reverse_engineer/angel2.jpg)
Very inspiring, great work. I love this chip. Pin 2 is still sort of a mystery to me. What exactly does this do?
awesome!
add a blend pot and a square/triangle option and a delay time pot and you pretty much have the pitch pirate.
does this mean i can modulate pin 2 on my next pedal?
;D
This mutha is a verified, working beast of a chorus. :icon_mrgreen:
With the depth control very low, the effect is quite subtle at lower LFO speeds. With the Speed slow and the depth cranked, you get classy shimmery (ever so slightly metallic) chorus tones. But still kinda unique. And with the Depth and Speed both high, the overall effect is more like a vibey chorus. There is a bit of a pulse and throb at that setting.
Very versatile and highly recommended. I simply cannot believe something this simplistic (parts-wise) can sound this big and great.
Super kudos to Rick. ;D
This is the simple version, as built by me earlier today and verified just now. I'll play around some more with the settings and see if there are any dead spots, but my initial tweaking yielded only positive results.
(http://i257.photobucket.com/albums/hh218/reverse_engineer/angel3.jpg)
Verified schematic and layout:
(http://i210.photobucket.com/albums/bb292/frequencycentral/LittleAngelMiracle-1.png)
(http://i210.photobucket.com/albums/bb292/frequencycentral/LittleAngelPCB.gif)
(http://i210.photobucket.com/albums/bb292/frequencycentral/LittleAngelPnP.gif)
One important note that might save people some time:
The orientation of the voltage regulator on the layout is correct for the 78L05 version.
I love you, Rick. I just do.
And now you've all tried that..
try this: remove the 1n cas between 13-14 and 15-16: no audible difference -> saves two components
Make the two caps between 9-10 and 11-12 -> 220nF
Make the two caps to ground from 7 and 8 small.. say 10 - 22 nF
sounded a bit better to my ears.
Still I think it's not really chorusy sounding, more vibey...
Little mod for anyone who's interested try changing the resistor connected to pin 15 to 22k, that makes the wet side a bit louder and sounds more chorusy to me. It might mess with to overall level though.
I would caution that it might be harmful to the chip to exceed Vcc at any pin, including pin 2. It might be worthwhile to add a clamping zener from pin 2 to ground, or else limit the LFO output in some other way.
Quote from: culturejam on August 11, 2010, 02:28:06 PM
And super kudos back at
culturejam for etching, drilling, populating and testing the PCB layout all in one day!
Sounds great! Anyone know how to go about adding a level or blend control into this?
Something I just noticed is that the Depth control also has an affect on tone. As Depth is turned down, mids are accentuated, and I think maybe highs are attenuated just a hair. With Depth more than about half-way, tone does not seem to be affected (ie - it sounds like the bypassed tone, just modulated).
There are some really cool sounds in this thing, although I probably wouldn't classify it as true chorus. It's got chorus settings, and it's got vibe settings. And it also does some other stuff.
With both Depth and Speed at minimum, it just makes the guitar sound a little bigger and fuller.
I had a partially gutted enclosure already painted and it had two knob holes drilled....
All I had to do was solder a few wire, slap on some stamp artwork, and take photos. :icon_mrgreen:
(http://i257.photobucket.com/albums/hh218/reverse_engineer/Little_Angel_01.jpg)
(http://i257.photobucket.com/albums/hh218/reverse_engineer/Little_Angel_02.jpg)
(http://i257.photobucket.com/albums/hh218/reverse_engineer/Little_Angel_03.jpg)
Quote from: culturejam on August 11, 2010, 04:57:56 PM
Cheers! That was fast! :icon_cool:
The length of the delay can describe the difference between phase shift to chorus to flange then on to real delay. I wonder if increasing the resistance on pin 6 a little might move the whole thing into flange territory?
Quote from: soggybag on August 11, 2010, 01:57:33 PM
According to the datasheet pin 2 is the vref for the internal opamps.
Quote from: dmc777 on August 11, 2010, 03:40:52 PM
You could add blend control by cutting the traces to the left of C12 and C15. Take a suitable pot (10k or 22k maybe?), connect C12 to lug 1, C15 to lug 3, connect lug 2 to ground via a 100k resistor. Take you output from lug 2.
Quote from: soggybag on August 11, 2010, 07:26:32 PM
Increasing the resistance on pin 6 will take it further away from chorus into short delays. The PT2399 really has too high a minimum delay time to do flanging, as flanging requires shorter delays than chorus. Maybe something interesting to try would be to feed the dry signal through a second PT2399 set to a very short fixed delay, that way the modulated delay would wobble either side of the fixed delay. Perhaps it would sound like flanging, but with ~30ms latency.
What's happening here when you're modulating the VRef on pin 2? Seems like this shouldn't change the delay time. Is it effecting the signal passing through the two internal op-amps, creating a sort of phase shift on these?
Quote from: soggybag on August 11, 2010, 08:10:02 PM
Search me! I was hoping some clever guy would come tell us. My instinct tells me that the internal VCO must also be referencing the vref. The datasheet should be called
'101 things you'll never know about the PT2399 and other mysteries'.
looks to me like you are wobbling the Vref only on the filters. Since they are all inverting, they all wobble the signal back and forth, so you are getting a phasing of the filters moving away and towards each other...
I don't know. Makes sense to me... like wwobbling an all pass filter.
EDIT: BTW, awesome idea! I've been looking for something kewl like this... I've been trying to figure out something awesome to make for my bass with the delay. This overqualifies, IMHO. Most delays cater to guitar, and well... bass acts a bit differently ;D
Quote from: Earthscum on August 11, 2010, 08:17:55 PM
There is way way way more wobble available than a few dozen all pass filters could muster. This is not phasing. I have a 14 stage phaser on my other breadboard (http://www.diystompboxes.com/smfforum/index.php?topic=84968.msg719516#msg719516) that can't do these tricks.
Search me! I was hoping some clever guy would come tell us. My instinct tells me that the internal VCO must also be referencing the vref. The datasheet should be called '101 things you'll never know about the PT2399 and other mysteries'.
Thanks for the reply, as long as we're all in the dark I'm OK. The use of pin is still a total mystery.
Quote from: frequencycentral on August 11, 2010, 08:26:04 PM
Nice... did I miss sound clips somewhere in the thread, or do you have any? I'm really curious now. I'd go breadboard it, but my roomie camped the TV as soon as he got off work like a baby. That's where all my stuff is at, and don't wanna bug him.
funny, i breadboarded this last night (it's morning here), and thought the 500K depth pot wasnt really useful so changed it to 250K, but thought the minimum depth was still lacking prominence of the chorused signal, so i thought maybe trimming the 100K minimum depth resistor to 47K would give me a more prominent chorus. and then here im reading it was already changed to 33K! :icon_lol:
i also tried bridging pins 16 and 14 of the PT chip with a 47K resistor for feedback, but wasnt convinced. will try insteda the 33K minimum depth mod later tonight. nice one Rick!
Clip!
http://www.archive.org/details/LittleAngel-Pt2399-basedChorus
Here's what's up:
Same basic progression each time.
First clean >
Speed 12:00 / Depth 2:00 >
Speed 12:00 / Depth MAX >
Speed turned from min to much higher / Depth MAX >
And then I just move around and try to show the main types of tones you can get. I think I did a total of maybe 8 settings or so.
And then clean again.
Straight into Garage Band through a UX1 with a hint of (software) reverb.
From that sound of the most recent sample, given how it is phasing the midrange, I'd guess that the delay is under 20 ms.
Holy wow! Ok, I hear what you're talking about now. That's definitely a mod I'll be using... and refusing to my buddies! I gotta keep my rig sounding the kewlest... ;D
Hats off to both of ya!
This is very cool. Breadboard time!
And give the changes in post #81 a try 8)
Quote from: ~arph on August 11, 2010, 02:53:42 PM
I could remove the 13/14 cap without trouble, but removing the 15/16 cap caused noise. Haven't played with the other values yet.
Quote from: slacker on August 11, 2010, 02:59:27 PM
Yes this certainly works! Although the effect is now higher than unity, but easily tamed back.
You can make it more vibey if you apply some of that modulation to pin six too ;D
The 22k in the input stage mod works really well too..
Quote from: ~arph on August 12, 2010, 07:57:52 AM
Which resistor are you referring to? By that I mean which part number on the Little Angel schematic are you referring to?
It's R5 on the layout, the 10k connected to pin 15 of the PT2399.
This just keeps getting better and better....
Nice build and clips Forrest !!
how about a Vero layout? ;D
Hope this isnt a dumb question :-[
But what about adding the Taptation controller that TTG just released ?
Would that allow the phasing/modulation to be "controlled" a bit more ?
EDIT posts = 1111 ;D
Quote from: slacker on August 12, 2010, 01:18:46 PM
Quote from: Talison on August 12, 2010, 02:40:54 PM
I was working on it, but Rick adviced it's better to have a definitive version and not a work in progress.
As soon as we can say "that's the final version" I am gonna finish my vero layout.
Quote from: Renegadrian on August 12, 2010, 06:00:20 PM
I think what we've got now is close enough already. After all, a verified PCB layout now exists, so why not a vero?
So that's the
LITE version wrapped up, give or take a few values here and there. So what features do we want in the
ELITE version?
Quote from: frequencycentral on August 12, 2010, 06:06:31 PM
So that's the LITE version wrapped up, give or take a few values here and there. So what features do we want in the ELITE version?
Adjustable max delay time. ;D
Thanks for this cool project Rick.
P.S. I also believe that you are an alien
All right, I'll post it in some days then!!!
Another idea for the ELITE version:
How about a toggle switch to apply the LFO wobble to pin 6 as well as pin 2?
And what about having a trimmer + resistor in place of the 100K resistor to ground on the output? Could be like a "level" control of sorts to help match unity volume. Unless you already have output volume control via op amp in the works for the Elite.
Why not a set of filters to pass the mids and/or bass through un-modulated with a blend control ?
Quote from: culturejam on August 12, 2010, 09:45:49 PM
I tried it. Didn't really do much. Gotta build a second LFO for it to modulate at different speeds, then you would notice a difference.
Also, I just used a 100k volume pot and started it out on high, like 100k to ground. I ended up having to turn it down a hair (to probably about 75k) to hit unity. I'm also using a bass to test this (since that's what I'm building it for), and noticed the B and E strings don't get as much of the effect as A and higher.
I noticed, though, that my 500k pot only had about 1/8 turn as usable range... after I dropped the 33k. With the 33k in place, I was getting no wobbling. I triple checked everything, so not sure why it does this. Also, my 100k has only about 1/4 usable area. I'm done with it for the night, but if anyone has any suggestions, I'll try them out tomorrow.
Edit to add: I'm using TL072. Could this be part of it? All I have on hand at the moment is TL072's & 4's, 741's, TL082's, and LM324's.
I have given my permission for guitarpcb.com to do a run of PCBs:
http://www.guitarpcb.com/apps/webstore/products/show/1690146
(http://img204.imageshack.us/img204/6156/littleangelcopper.jpg)
Quote from: Earthscum on August 13, 2010, 12:59:07 AM
On my build, I'm noticing that in order to hear how the lower range of either pot sweep is effecting things, the other control has to be set closer to maximum. For example, the change in Speed seems very subtle for the first half turn with Depth low, but when Depth is cranked, the Speed changes are far more noticeable.
I might have figured out how changing the bias voltage effects the delay time.
If you look at the block digram in the datasheet you'll see the output of the OP1 opamp (pin 9) is connected internally to the positive input of the COMP, presumably this is a comparator of some sort. The + input of the OP1 opamp is connected to the bias voltage, so changing that will change the output of the opamp and as the output is connected to the COMP it will have an effect on the signal coming out of COMP.
If COMP is like a comparator then changing the bias voltage would change the pulse width of the output which could then have some effect further down the line in the digital part of the chip.
Or maybe not who knows :)
I don't think so. Changing Vref causes no differential voltage change at the inputs of the comparator, because both its inputs are driven by opamps biased at Vref, both of which have a DC gain of +1. This does not apply at high frequencies, but at LFO rates I think it does.
I think it's more likely that pin 2 is somehow tied to the internal VCO's circuitry.
Good point I missed that, yeah the most likely thing is that the VCO has a connection to the bias voltage.
Quote from: culturejam on August 13, 2010, 10:57:02 AM
Yep, I'm getting the exact same thing. I have to have them both within a certain range for them to be usable. If either one is out of the range, there's no audible modulation. This is actually the LFO itselfm it seems... I've tried different chips and get the same result. Tried different pots as well.
I just noticed... I'm an idiot. My 500k is audio tapered. I flipped it around the right way and now have more useable range from it.
Ok, so I figured out if you replace the 10k between pin 14 and the .01 with a 50k-100k pot, you can adjust the mix. I ended with a great mix at around 27k, This actually cured most of my problem. As well, I dropped my 33k to ground down to 27k to get that top lope at full pot rotation. I may pop in a TL074 and make an LFO buffer and output buffer/mixer. It feels like that would cure a bunch of the LFO interaction issues that I'm experiencing.
The delay output pot is actually nice... I can sweep from a perfect chorus mix to flanging sounds to a dry and subtle sound.
The LA works pretty good for bass, except like I noted before, you lose effect on the lower notes. I tried a bazz fuss before it and it really gets snazz and pizazz! This actually is a nice thing for some songs where you want the low end to sit back a bit, but your hig strings just have too much bite. This makes the high end shimmer and actually settles it into the mix a bit better. I just gotta redo the input stage to get my punch back.
Again, big thumbs up on this one! This is a kewl little project!
Quote from: Earthscum on August 13, 2010, 03:00:46 PM
I'm building another one soon for mods/tweaks testing, so I'll give this a try.
Quote from: EarthscumAs well, I dropped my 33k to ground down to 27k to get that top lope at full pot rotation.
Funny, I just mentioned to Rick that maybe 27K would work as well, since he said 22K was a bit too low. :)
Aye, I think it's probably too low for a complete build. I think the 33k is just about right... actually, I kept tuning, pulling and measuring and ending up around 29.5k for my personal lowest sweet spot. 27k seemed to begin introducing a small bit of audible lfo clicking, and lower by about about 5 k was just a bit too much for me to just slam the pot all the way.
I noticed an interaction while playing through my TKO, though. I put a 50k to ground from pin 6 (will probably go with a 10K), and when I used my mixer pot (which, BTW, should have a min setting resistor... it lets alot of hiss through at close to full wet) I could get a nice clear wet sound.
When I play my bass, the lower notes aren't coming through as well as the higher notes due to the time. For bass, this isn't necessarily bad. Basically at fastest delay, the lowest notes are mixing more readily at the output. When I set the mixer just right, I could get even mix, and tossed on a low pass before the junction from the output of PT. Now I have delayed highs, with my normal lowend punch! That's awesome for bass! The delay is a little over the top, but every part of this is a little bit of something kewl. Faux Delay, faux semi-flanger, faux Sonic Maximizer, and a space noise signal destroyer in one box. Seriously, my GF is into EBM and plays a bit of bass, and nearly started drooling as I swept through some settings.
Hit the input with a bazz fuss or other decent sounding dist, and this thing kills! Plain BF sounds gigantic. The filtering shaves off all the highs. Perfect circuit, IMHO, if ya want to add a small switchable dist. inside a box. Really, it sounded like I've never heard it before ;D
Quote from: J. Luja on August 13, 2010, 09:14:25 PM
Quote from: frequencycentral on August 13, 2010, 12:58:29 PM
As the PT can handle up to 6.5v, I'm still wondering if delivering more voltage than the accepted 5v would result in an over-clocked VCO and even shorter delay times.
actually, I can answer that. I tried that a couple years ago and according to my notes
with pin 6 grounded,
5V supply = 24ms
6V = 18ms
6.5V = 16.5ms
7V = 15ms
7.5V = 14ms
8.5V = dead chip
also current draw nearly doubles from 28mA @ 5V to 58mA @ 6.5V
hope that helps
So who's going to replace the 7805/78L05 with a 7806/78L06? :icon_biggrin:
Quote from: frequencycentral on August 10, 2010, 08:15:35 PM
:icon_mrgreen:
.....and the PCB apparently will fit in a 1590A! This might well be my excuse to try my hand at a 1590A build. solderman? danielzink? valoosj?
Quote from: frequencycentral on August 14, 2010, 06:50:23 PM
I would've never guessed that. :icon_eek:
Actually, I was thinking it would be cool to have a layout that takes advantage of 1/8-watt resistors and multi-layer ceramic caps.
Quote from: frequencycentral on August 14, 2010, 06:45:42 AM
:icon_mrgreen:
Did it work? ??? :)
I'm following the thread...yes yes.......I'm waiting for all "the dust to settle" and all the mods be sorted etc.
DZ
So... am I the first? I used this thing live, and it's so sweet!
I left to buy parts at 11:15 yesterday morning. Luckily I had an old MXR Auto-Q case that was drilled already. I actually finished, plugged it in to test, congratulated myself and my guitarist walks in. 5:00, bar opens at 6... I can't believe I actually made it, and it worked! lol.
BTW, I ended up using this thing on about half my songs last night. We had a buddy sitting in, so I had to pit the Little Angel up against a G-K Roto Sphere. Rick, this is awesome... it actually held it's own! I was able to tweak the LFO and fill the space between the dry guitar, and Brooks' RS, without making even myself cringe. I was hoping we'd have some video or at least sound samples for ya, but someone in our band forgot to charge their vid camera... ::)
Quote from: danielzink on August 15, 2010, 12:56:47 AM
I'll be testing some mods over the next few days (just etched another PCB), so we should have at least a couple of verified, working mods pretty soon.
My first test will be to add a variable delay time control, a switch to go from 50/50 to "wetter" mix, and a feedback adjust switch. I doubt all that will fit in a 1590a, but you guys who work with those often surprise me.
More details to follow shortly. :)
Quote from: culturejam on August 15, 2010, 11:39:43 AM
... I doubt all that will fit in a 1590a, but you guys who work with those often surprise me.
No doubt!!! I wanna give it a shot with the 2 pot mods I'm using. I just added a 100k pot into the wet return to cut the signal out, which intensifies the effect. Actually, more of "Effect Intensity", then. The only other thing I did was took the 100R and tied it between the wiper and lug to ground of a 10k pot, and tied the other lug of the pot to pin 6. At max delay, the 10K is still a bit too much, but it helps increase the intensity of the effect for bass by delaying the lower frequencies enough to cause an audible shift. I'd suggest a 5k. At one side, you have straight 10k resistance, which you could just tailor with a resistor strapped across wiper to lug, and on the other end of rotation, you have the 10k with the 100R across it, so effectively just a little under. I did this on purpose so WHEN I build my GF's, I can just order one of the PCB's and use the mod instead of a resistor. Don't have to drill extra holes, which is kinda what I think modding a circuit like this is about... using what 'you got' (or the designer's layout) and doing what you can with
it ;)
I'm populating the second board now. But I'm out of 220K resistors, so I'm going to try some different values and see what happens.
Quote from: Earthscum on August 15, 2010, 10:59:03 AM
...someone in our band forgot to charge their vid camera... ::)
And that was the best performance ever...Classic... ;D
I got showed up by our 'walk-in', Brooks, lol.
Actually, I forgot my fuzz and the extension cord... our guitarist, Fred, forgot to charge his camera, and our drummer AND Fred forgot the signal cables for the monitor amp up in Cheyenne. We pulled it off. It was a good show, blisters and all.
Testing is underway...
So far, 5K is definitely a good option for the Delay Time control. Too much more than that gives very noisy repeats. Unusably noisy.
One issue I'm having, however, is that on this build, if I hit notes pretty hard, I get some clipping/farty sounds. I've tried LF353 and 4558 for the op amp, and I've tried two different 2399 chips. Same result.
I've noticed, however, that the different op amps had different min/max LFO speeds. Interesting. The 4558 goes faster (with every other value in the LFO being the same). I'm out of NE5532.
I'm using a pair of 182K resistors in place of the pair of 220K in the LFO. That's the closest value I have.
Here's the mods I used last night. TI TL072BCP, Mylar Films on the .1uF's in audio path, ceramic for the others. Poly caps for the .01 & .001's. I may have used a ceramic across the inverting feedback on the LFO... it was acting strange. I'm gonna use a poly for that and see if it acts more normally next time I crack it open.
(http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=43552&g2_serialNumber=2)
1 - I changed the 470k pot to 100K. It gave me more useable range on the pot. This is probably due, as noted by culturejam, to the difference in OP Amps on the LFO... just a guess.
2 - The variable delay helped thicken up the low end with the extra shift in time... also adds a bit to the tricks you can get it to do!
3 - The "Wet Out" pot helps keep this out of flanging territory. I was getting too much wet signal and loosing the effect when the delay increased. This lets you drop the delayed signal a bit more into the background so you can still keep the nice chorusing effect. Also, within the usable (to you) range, you'll find a whole set of different tones available.
4 - The 10K on the output is just for trimming back the volume if you find, like with my setup, that the overtones really drive hard and throws your sound too far above everyone else when the pedal is engaged.
These pot mods use the existing (if you etch a PCB) resistor pads. You just solder the resistor between the center and outer lugs right on the pot. The output mod (referring to the layout http://i210.photobucket.com/albums/bb292/frequencycentral/LittleAngelPCB.gif (http://i210.photobucket.com/albums/bb292/frequencycentral/LittleAngelPCB.gif) ) you just cut the trace between the R14 pad and the C12/C15/OUT trace. If you drill a hole right next to the pad (to the right, under the right pads of C12 and C13), you can run a wire through from the top, fold it over and solder right to the R14 pad. Wire the other end to the output pad, run the output from your center lug and you're set!
I don't wish top be a party pooper but...
I have to report that I do not believe this will fit into a 1590A.
The board is exactly as wide as the outer dimensions of the enclosure. While you could perhaps lean the board I do not believe you would have room for the footswitch and especially jacks with a leaning board.
I will say it will fit a 1290 very nicely however.
If someone can prove me wrong...(Daniel Z. ?) .. I will certainly tip my hat to you! :icon_biggrin:
It took all damn day, but I figured out what was wrong with my second build. I had the wrong value caps connected to pins 9/10 and 11/12. I had 100pf when it should be 10nf. Whoops!
With 100pf there, hitting the strings hard caused a crackly-static sound. With 10nf, it's gone.
What exactly do those caps do? The pins on the data sheet are marked OP1 in and out (pins 9 and 10) and OP2 in and out (pins 11 and 12).
That's one of the things I was asking about in this thread: http://www.diystompboxes.com/smfforum/index.php?topic=86258.0 (http://www.diystompboxes.com/smfforum/index.php?topic=86258.0)
I think maybe it filters out the digital signal? I'm thinking about dropping some .015u's in place and see if it takes that bite off my sound on bass. ir maybe .022's. I definitely gotta swap some values in the input filter... again, I'm playing bass. I DEFINITELY don't have bass loss! At least not in the way that any signal is getting a noticeable bass cut. I actually have all the punch with the effect in, unlike other chorus' that seem to have some low end loss in the circuits. Simple IS good for Bass.
Quote from: Earthscum on August 16, 2010, 06:12:51 PM
The Princeton "data sheet" has one example circuit with 0.1uf in those spots. Hmmm.
With a 10K pot as the Delay Time control, only the last bit of the sweep introduces nasty noise in the wet signal. Bigger values (longer delay times) bring in a lot more noise.
So yeah, with a chorus-like modulation effect, the 5K DT pot works great. But I'm wondering now, as us DIY folks often do, if I up the value of the OPF1/2 caps from 10n to 47n or 100n...will that allow for cleaner longer delay times. Or maybe the HPF pin caps. I'm assuming that means "high-pass filter".
It really pisses me off that Princeton is so stingy with their info. >:(
Okay, here's the good data sheet:
http://www.princeton.com.tw/downloadprocess/downloadfile.asp?mydownload=PT2399_1.pdf
So apparently, the OP1/OP2 are internal op amps. And here's what the sheet says:
"OP amplifier 1 input/output. This pin can be used as modulated/Demodulated integrator by connecting capacitor
OP Amplifier 2 input/output. This pin can be used as Modulated/Demodulated Integrator by connecting Capacitor"
It would help if I understood what a "modulated/demodulated integrator" did. :)
I'll probably just dick around with cap values and see what happens. ;D
Hey, I've retraced the PCB to tonepad's layout style and made a PDF with 6 ready to print boards.
Click on the image to download:
(http://img210.imageshack.us/img210/6448/littleangelchoruspcblay.jpg) (http://www.sendspace.com/file/hjpmd1)
Regards,
Fernando.-
Thanks for this nice layout!
Quote from: Slade on August 16, 2010, 10:08:40 PM
What software do you use for that style layout?
Thanks.
was also thinking about that?.. It's not DIY layout Creator? Right? ???
It's made line by line and hole by hole with the only design program I use... Adobe Illustrator.
I shared this proyect in a chilean forum, and as it's a "beginner's" proyect I just made an easier-to-etch-PCB and an easy to build layout with the component values on the layout. Enjoy!
no wonder your etching technique is superb because you design them in illustrator which is vector based as opposed to photoshop pixel based..
Quote from: culturejam on August 16, 2010, 09:30:08 PM
It`s all about Delta Modulation http://en.wikipedia.org/wiki/Delta_modulation
Quote from: Lurco on August 17, 2010, 04:03:45 AM
I would say it's
mostly about delta modulation, but there's some other fun stuff going on too.
The input signal goes through LPF1 and into the inverting comparator input and is converted to a 1-bit data stream. This data then goes into OP1 through the box labeled "MOD" in the datasheet. With the external capacitor, OP1 inverts and integrates this data and is fed back into the non-inverting input of the comparator, closing the loop of the delta modulator. With too small of a cap, the differential signal at the comparator is very small, so it has a hard time saying whether the input signal is higher or lower than the reference, and the result is drastically reduced gain, except at very high slew rates, where the too-small cap is just barely sufficient to let some signal through.
Because this integrator is part of an overall negative feedback loop, making its capacitor larger reduces the integrator's gain (starting at high frequencies) but increases the gain of the A-D stage as a whole.
Finally, another area of interest is the "MOD" section, which I believe to be a SPDT switch. The pole connects to pin 8 and so the circuit becomes a switched-capacitor resistor of approximate value R=1/(fC), where f is the clock frequency and C is the capacitor from pin 8 to ground. So when the clock frequency decreases, the resistor going into the integrator increases, and the integrator's cutoff frequency decreases. Again, because this occurs in a negative feedback loop, the overall effect is the opposite, such that a decreased clock frequency results in pre-emphasis of treble at the A-D stage. Meanwhile, the output after the delay goes into OP2, which is similarly modulated by the clock, but here the decrease in clock frequency causes a treble cut, which helps you get away with lower fidelity at longer delay times.
Quote from: earthtonesaudio on August 17, 2010, 08:40:42 AM
Right. So I'll start dicking around with cap values here and see what happens. :D
Quote from: earthtonesaudioFinally, another area of interest is the "MOD" section, which I believe to be a SPDT switch. The pole connects to pin 8 and so the circuit becomes a switched-capacitor resistor of approximate value R=1/(fC), where f is the clock frequency and C is the capacitor from pin 8 to ground. So when the clock frequency decreases, the resistor going into the integrator increases, and the integrator's cutoff frequency decreases. Again, because this occurs in a negative feedback loop, the overall effect is the opposite, such that a decreased clock frequency results in pre-emphasis of treble at the A-D stage. Meanwhile, the output after the delay goes into OP2, which is similarly modulated by the clock, but here the decrease in clock frequency causes a treble cut, which helps you get away with lower fidelity at longer delay times.
I'll pop the hood on my Echobox, as I recall Brian from Subdecay mentioned something about how it was filtered. It gets about 1 second of relatively clean delay, which is insane considering the THD on this chip at that delay time.
I assume the DEM section is "demodulator". The data sheet calls pin 7 (DEM) and pin 8 (MOD) "Current Control" 1 and 0, respectively. And both application circuits have a 100n cap to ground from these pins. Again, I'll have to just goof off with changing cap values and see if I can hear anything.
Quote from: joethugs on August 16, 2010, 11:49:07 PM
sorry for the OT but does this make a difference?
Thanks for the link, the datasheet block diagram finally makes sense to me :)
I just love watching a new pedal be born ;D
Hey guys, I tried a perf/p-to-p layout for this, but it's only my second time ever going from schematic to layout, so I screwed up somewhere and I get nothing but a faint hum. Can anyone see anything glaringly wrong at a glance?
(http://www.facekick.ca/images/littleangel_layout.jpg)
Pins 3 and 4 should be grounded, not just connected to each other.
Pin 4 is the analog ground, and if it ain't grounded, you don't get sound. :icon_mrgreen:
Quote from: culturejam on August 23, 2010, 06:12:35 PM
Thanks for the catch. That's just a drawing error though, as I actually did ground pin 4 when I perfed it...so there's probably something else keeping it from working.
I think I see the problem.
The 470K resistor should connect directly to pin 6 of the op amp. You have it connected to pin 7.
Photoshop does vectors too! Even on my now-very-old photoshop 7 that can't install on windows 7. :'(
Quote from: my7of9 on August 16, 2010, 03:04:35 PM
:o Shock and disappointment! So I've shaved it down to fit. I believe a board 13 pads wide will fit in a 1590A. The only compromise it that the connection for
Depth pot lug 3 has moved from the edge of the board to, err, elsewhere. If anyone wants to etch one for me.......... :)
(http://i210.photobucket.com/albums/bb292/frequencycentral/LAC1590APCB.gif)
(http://i210.photobucket.com/albums/bb292/frequencycentral/LAC1590APnP.gif)
Wow. Great work Rick.
Has any one tried this with a bass yet?
My friend Dan McNay is playing with Ronnie Montrose and The Frank Hannon Band and asked me yesterday of an interesting bass chorus. Any cap replacements to make it more bass friendly would be great.
Rick, do you mind if I use the layout to make him one? I will get pictures for you.
[/quote]
[/quote]
I can etch a few of these and send you one next week no problem.
Quote from: Pigyboy on August 26, 2010, 03:50:38 AM
Earthscum has used it with bass and seems to like it!
That's what it's here for!
Quote from: Pigyboy on August 26, 2010, 04:03:23 AM
:icon_biggrin:
I just tweaked that layout slightly so C8, C9 and C10 can be bent over to lay flat if need be, it will show up in my post above when photobucket gets it's shit together to finally refresh.
This may be a noob question but...
If I copy the layout from Frequency above, are there any special changes I need to make in order to "size it right?" Or, is it already properly sized to populate with components?
Quote from: Govmnt_Lacky on August 26, 2010, 08:24:06 AM
Scale the PnP to a .1 inch grid in photoshop. An ICs pin spacing will match the grid when correctly sized. Is that what you mean?
I see my 'slightly tweaked' 1590A layout in my last post still hasn't refreshed in photoshop, so here's direct links in dropbox:
http://dl.dropbox.com/u/967492/LAC%201590A%20PCB.gif
http://dl.dropbox.com/u/967492/LAC%201590A%20PnP.gif
Here's a little layout note:
C11 is really close to D1 (which must be mounted vertically) and R19. So it either needs to be a smallish cap, or leave some slack on the leads so you can bend it over and lay it flat over R19.
Yeah, there's not much room there (sorry!), I didn't want to make the layout bigger just for the sake of one pesky diode. I figured people might instead mount the diode on the copper side or even directly to the DC socket. This would also allow C11 to be bent over on it's side for extra 1590A squeezage. That's what I'll gonna do.
By the way, Rick, I've played around with several values of resistors where the two 220Ks are located. I ran out of 220K, so I took the opportunity to socket those spots and test it out. I can say for sure that any value between 150K and 275K will work in either or both of those positions. Waveform and min/max speed will change, of course, but several alternative values will work in a pinch.
Also, different op amps make a subtle, but noticeable, change in the LFO waveform shape.
Quote from: frequencycentral on August 26, 2010, 08:33:49 AM
I do not have Photoshop. Any other way to ensure it prints out to correct size?
Quote from: Govmnt_Lacky on August 26, 2010, 09:28:46 AM
the hard way: trial and error ;D
i print three tries with marginally different sizes, then pick an IC socket and see on which one it fits better
You can also do it in MS Publisher, I just tested it. I made a grid 0.254mm (= 0.1") and scaled the pad spacings to that. Worked a treat.
Quote from: frequencycentral on August 26, 2010, 10:14:49 AM
I also do not have MS Publisher. As you can tell from my login, I work for the government. They do not give us cool software tools like MS Publisher. Any other ideas? Sorry to be a pain. Can anyone tell me a % to shrink this down to in order to get the sizes correct?
Any other ideas would be appreciated.
Sorry about my first reply.... Here goes again...
Hi
I m at work too(but in Central Europe). I just "open with" PAINT , did a "resize" to 50%.
I printed out and mesured,seems to be ok with 2.54 mm distance from hole to hole.
Regards Jean-Marie
(http://i210.photobucket.com/albums/bb292/frequencycentral/6.jpg)
Quote from: radio on August 26, 2010, 11:04:18 AM
Hi
Regards Jean-Marie
Jean-Marie,
Thanks. I took your advice and used Paint. I resized to about 47% and it works great.
I appreciate everyones help and I can't wait to get started on this little beauty. I have one more question:
Are there any FINAL decisions on the size of the Speed and Depth pots? I have read through the thread but I still do not see any definitive values yet.
AFAIC it's 100k lin for Speed and 470k lin for Depth. That's how I liked it. Purrrrrrrr......
Hi Rick,
How about running this at 12-18v for more headroom like the Analogman Chorus?
Sorry, Rick is unable to answer. He's too busy scratching the furniture and licking his bum.
Quote from: markeebee on August 27, 2010, 02:14:11 AM
Dude, that is funny.
Quote from: Pigyboy on August 27, 2010, 01:37:10 AM
Hi Rick,
It won't give you any more headroom in the PT2399 as that's running off regulated 5V regardless.
Quote from: anchovie on August 27, 2010, 05:19:59 AM
Hi Rick,
Hmm, That is what I was afraid of. Can anyone who has built this give it a go really loud though a bass set up and report if it loses much in the low end.
Quote from: Pigyboy on August 27, 2010, 05:30:03 AM
Someone earlier in the thread used it with bass and commented on the low end response. Start reading on page 4/5 and you should eventually find it.
Aye. I've used it at 2 shows. For bass, you want to increase the delay a little bit for sure. I like the 5k pot, but already had the 10k installed.
For bass, once you find that perfect setting for you, you go from flat to gigantic godly overtones!
I used a TL072, hence the 100k pot in place of the 470k. I haven't un-ductaped my pedal to pop in an NE yet, so can't report on that. I rode my bike to the store to buy parts, came home and had it boxed and working and ready in 5 hours, with only an hour to spare before we had to be at the bar. Used it in an outdoor setting at the last one, and it is awesome. If you are outdoors, you can increase the depth a bit more without busting through over the top of the guitars.
And, lastly... absolutely no bass cut! I breadboarded mine with .022's in the audio paths, but I built it with all stock parts plus my mods to box up. I have a "super-fat" DS-1 that is basically my big OD. It increases the bass without destroying too much of the punch, still has the DS-1 grit, but bigger. This goes in front of my LA, and I only get the most minor bass cut out of it, which actually just seems to add to the overall tonal qualities.
Of all the things I tried, the ONLY one necessary for bass is the delay mod. Just a 5k pot. I wired mine so I could (next build) use the stock jumper pads from the layout. I just used a DIP strip on this one, but kept mods simple to work with the stock PCB.
Thanks for the info Earthscum. I am gonna make some boards today and give it a go. This one is going to friend who is playing to 1000-5000 people a night so we will how the Angel does on a big stage. I have a good feeling about it.
Thanks again and a big thanks to Rick
I will report back soon but I still need to order parts :P
Seems I noticed this a bit late, but I might still make a layout, once the dust settles, as Dan said.
I think we even surprise ourselves at times, when finally cramming something in a very tight enclosure.
Oh btw Rick, the flanger pcb will probably be made in the following weeks, since the workload for my studies will not be so huge in the following 3 weeks, so I might be able to make some pedals as well! But first I need to make some layouts and etch the suckers.
Hmm, I also used a TL072 in my perf attempt without changing any other components. Could that be contributing to my lack of effect?
Sounds like resolution is needed on the great Little Angel Op amp/potentiometer debate....
Will it be the TL072 with a 100K or.... the 5532 with the 470/500K????
The debate rages on... ::)
I don't see any reason to prefer the NE5532 in this circuit, other than the fact that it's already been verified. However, if you do want to swap op-amps, the input resistance of the NE5532 is so low that a TL072 is not really a direct replacement. You'll need to reduce the gain of the audio part and mess with the impedances in the LFO part to make the performance the same with a TL072.
Here's my "Little Blue Angel". Worked the first time (with no debugging). No parts substitutions. Sounds great.
Thanks Rick!
(http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=43589&g2_serialNumber=2)
^^^^ :icon_biggrin:
Hey that's the 1590A layout! You gonna squeeze it in? ;)
Of course we want photos and soundclips.......
QuoteHey that's the 1590A layout! You gonna squeeze it in?
Don't have a 1590A box at the moment, but I do have another smallish box that should be a nice snug fit. Pictures to follow later...
Rick - I etched some extra boards. PM me with your mailing address if you want one.
Quote from: Govmnt_Lacky on August 30, 2010, 10:34:41 AM
I've tried different op amps, and it does change the shape of the waveform slightly from chip to chip. So it will be a personal choice, I think.
Haven't tried the 100K pot.
Quote from: waltk on August 30, 2010, 12:34:38 PM
Nice looking work, Walt!
Has there been a list of proven mods made yet ?
I am about to BB this,I was hoping some tweaks would have been added by now.
Is there a Deluxe Angel yet or is it still the Little Angel ?
Been off the net for a week or so,so I havent been keeping up :icon_redface:
Quote from: Brymus on September 01, 2010, 07:44:57 PM
"Archangel" is around a month or so away. Let me clear my bench..... ;D
Quote from: frequencycentral on September 01, 2010, 07:51:45 PM
sweetness !!!
damn! i'll be waiting for that... Archangel! :icon_twisted:
QuoteOf course we want photos and soundclips.......
I did a little rework to make my board a little shorter. It's in the box (which is still undecorated) with all the standard gear - led, power jack, etc. Not quite as small as a 1590A, but still fairly compact. The PT3299 draws a bit of current, so I expect the power jack will be a necessity. The depth pot (B500K for mine) is only useful in the top 20% of the range, so I'll need to tweak something to give a better range (suggestions?)
(http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=43644&g2_serialNumber=2)
(http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=43641&g2_serialNumber=2)
Quote from: waltk on September 01, 2010, 11:57:27 PM
Have you tried a C500K? Maybe that will give you more usable range.
QuoteHave you tried a C500K? Maybe that will give you more usable range.
Thanks for the suggestion. I don't have any reverse audio taper pots on hand, but was thinking I could just reduce the pot value to B100K - that would be equivalent to the top 20% of the 500K pot.
Sorry... I must have been mistaken. I thought you meant the top 20% of your pot to be the top 20% of the resistance being from 400-500K. Using a Reverse Audio pot would have "smoothed out" that last 100K of resistance over a larger part of the pot rotation.
Did you mean to say that you only get use of the INITIAL 20% of the pot rotation?
QuoteDid you mean to say that you only get use of the INITIAL 20% of the pot rotation?
Nope. The last 20% of clockwise rotation is the useful bit. Remember, the pot is only wired with lugs 2 and 3 (its a stright variable resistor), so as you turn the pot clockwise, the resistance falls to 0. So if you replace the 500K pot with a 100K pot, the full rotation would have exactly the same effect as the last 20% of the 500K pot.
Thanks to Pigyboy! Haven't had chance to hook it up yet, and I've only just ordered the 1590A.......
(http://i210.photobucket.com/albums/bb292/frequencycentral/AngelBoard.jpg)
Quote from: waltk on September 02, 2010, 12:44:40 PM
Thanks for the clarification. ;D
hey two things:
1. i put both ics in backward. is one or both fried.
2. do you ground the jacks to each other and then ground to the box.
this was the biggest solder job to date. thanks its was a blast
Quote from: clamup1 on September 02, 2010, 02:08:32 PM
hey two things:
Hey...two responses..
1) May be... May not be. Odds are that they are OK but only a voltage/operational check will know for sure.
2) You can ground everything however you like as long as you ground everything that needs grounding and have NO ground loops. Remember to ground the SLEEVES of the jacks to each other (and to the other grounds). Refer to JD's site GGG as a resource. I use it religiously for offboard wiring.
Good Luck!
The dual opamp is fried. The PT2399
probably survived.
Yup, and to the DC socket's ground. And to the board's ground: http://www.beavisaudio.com/techpages/StompboxWiring/
Thanks Rick!
Where did you find the blue PCB material?
i hope the op amp isnt fried. if i test it and put some numbers up can you guys tell me if its fried? or am i not going to get anything if its fried? i have a 3pdt in another pedal i might steal and use the schems you guys recomend. thanks for the help
Quote from: frequencycentral on September 02, 2010, 12:50:09 PM
Looks nice Rick. Glad to help out.
Quote from: Pigyboy on September 03, 2010, 04:55:54 AM
I'll hook it to the breadboard for testing it later this morning, thanks again.
Re. Depth pot value debate:
The more minimum settings shouldn't be dismissed out of hand. Take away (most of) the modulation and you've got automatic double tracking, which we don't seem to talk about much around here. ADT has the effect of thickening the sound as if two people were playing the same part in unison. You might not notice the thickening until you bypass it - then your sound will seem thin and weedy by comparison! :D Process your vocalist through the Little Angel at minimum settings - he/she/it will love you forever.
Quote from: clamup1 on September 02, 2010, 09:33:21 PM
Unfortunately, if you connected it backwards, then it's dead.
I dont know if it is particular to this circuit however, I have put Op Amps in backwards and they have survived in most situations..... Actually 1 situation since it has only happened twice! So I guess you have a 50/50 shot.
Good Luck! ;D
numbers
1-8.1
2-8.37
3-8.75
4-8.75
5-8.29
6-8.26
7-8.26
8-8.80
this is with the battery in and on the neg side.
Uhhhhhh.... Hate to say it but. THAT BAD BOY IS FRIED!!!
That is unless you ran supply power to EVERY pin. You should have Input power on pin 8 and Ground on pin 4.
i was wondering why i had power on all the pins. damn. oh well i got more coming. i was hoping i would get this one to work first time
Quoteoh well i got more coming.
5532 opamps are highly recommended (a little low on the input impedance, but a great driver on output). Not to start a debate or anything, but between these and TL072 you are pretty well covered for anything you would want to build. Someone is selling 50 5532's on Ebay for 10.99 (including shipping) at the moment. If you plan to continue building DIY stompboxes, I would just order a nice supply.
i ordered some from small bear yesterday. i should of checked out ebay. thanks for the info. ill check them next go round
Quote from: waltk on September 04, 2010, 12:16:56 AM
Thanks for the tip. I got 50 and some caps as well.
50ish pages of non sorted items later... ::)
Hmm, I can only find a link for 50 x 5532's for $14.95 + 5 shipping on ebay.
Will 5534's work as well? Is it much difference between the 5532 and the 5534?
I have a bunch of the 34's but no 32's.
A 5534 is a single op amp. A 5532 is a dual.
This is the only current auction the guy has for 5532s now.
Still a good deal.
http://cgi.ebay.com/Lot-50-NE5532-NE5532P-5532-Dual-Low-Noise-OP-Amp-/220664349135?pt=LH_DefaultDomain_0&hash=item33609ec1cf (http://cgi.ebay.com/Lot-50-NE5532-NE5532P-5532-Dual-Low-Noise-OP-Amp-/220664349135?pt=LH_DefaultDomain_0&hash=item33609ec1cf)
That's not bad. That comes out to 28 cents apiece. Tayda has them for 32 cents each, if you don't need 50. For $14.60 (after shipping) you still get 40. That's not bad, either.
http://www.taydaelectronics.com/servlet/the-93/5532-DUAL-INSTRUMENTS-LOW/Detail (http://www.taydaelectronics.com/servlet/the-93/5532-DUAL-INSTRUMENTS-LOW/Detail)
oh i used a 3904 as the tranie. i read it could be used but didnt look to see if anything else had to be changed. will it work when i get the new chip or ar there other things that need to be changed?
Quote from: clamup1 on September 06, 2010, 05:00:55 PM
The 3904 is a NPN transistor. The 'tranny' in this circuit is
not a 'tranny', it's a 5v voltage regulator.
oh i used a 3904 as the tranie. i read it could be used...
Where did you read that?
This doesn't use a transistor as the controlling element for the LFO like the designs for other PT delays use. This has 2 chips, a 5V regulator, and a handful of Resistors and caps (and whatever else you want to mod it with). The LFO connects directly to the chip.
i thought i read it in there somewhere oh well. now i need to beg the wife for more money. :icon_redface:
That is indeed an unfortunate tranny surprise.
Quote from: Taylor on September 07, 2010, 04:12:12 AM
Had a 'Trannie' surprise in a bathroom in SF one night. Indeed, unfortunate.
hey does the words on the LFO go toward the ic or away from it.
[/quote]
sorry i found the pic
i get clean sound. no chorus. its prob the offboard wiring. i hate offboard wiring
Quote from: clamup1 on September 10, 2010, 04:17:58 PM
[/quote]
I think that 7805 regulator is inverted...
Try the actual orientation
I wonder how this would sound if it had a tone control
Quote from: clamup1 on September 10, 2010, 03:53:52 PM
An LFO is not a part, it's a circuit with a number of parts that make it up. So what are you referring to when you say "LFO"? Are you talking about the thing with 3 legs and a metal tab on it? That is called a regulator, and you appear to have it in right.
thats not my pic but i put it in that way. thanks
Quote from: blooze_man on September 10, 2010, 07:06:00 PM
I'm gonna add a 'dark' pot for tone to the elite version -
"Archangel"@
clamup1: did you use a NE5532 dual opamp? The circuit values are set up to work with a NE5532. Other dual opamp type will give different results.
@ clamup1: did you use a NE5532 dual opamp? The circuit values are set up to work with a NE5532. Other dual opamp type will give different results.
yeah i used the 5532. i got everything in and its still didnt work. i get clean but no effect. ive seen 2 different ways to hook up 3pdt and cant get either one to work.
Quote from: clamup1 on September 12, 2010, 12:45:42 PM
Can you test the circuit away from the 3pdt? It
may be your 2pdt wiring that's causing the problem. Maybe.
my chips are facing the right way and i still have 8.29 on the ground. i had to buy a new solldering iron b/c the tip dissengrated so i was leaving huge solder bumps on the board. i think i have to either reetch a board or desolder and try again
clam: quick question... did you socket the IC's? If so, have you tried just swapping out IC's? There was a bad batch of (possibly counterfeit) PT's running around. I'm pretty sure that the normal DIY pedalbuilder sources are fine, I don't remember Steve or anyone saying that they came from their batches.
Quote from: clamup1 on September 12, 2010, 02:49:48 PM
Look for solder bridges anywhere where the (
red) +9v trace is close to the (
brown) ground trace. ie around C11, D1, R8, R9.
Should we Keen clam and refer him to This Page (http://www.diystompboxes.com/smfforum/index.php?topic=29816.0)? :icon_twisted:
I blew out a TL072 and got a short through the chip. I kept getting my 9V on the ground, regular VR's where they were supposed to be. I about fried my PS, and probably would have if I didn't catch the smoke from melting plastic... heat sinks are GOOD!
both ic's are in sockets. i have swapped both ic's. i got my ic's from small bear i dont think they would sell bad chips. ill check for solder bridges, it wouldnt surprise me
hey i think i fgured it out. the diode is blown or not hooked up right. im getting 8.72 on the neg side of the diode. which accounts for why i have 8.72 on the ground. i didnt know you could blow diodes. i hope this works. ive been staring at this thing for an hour.
well that didnt work. im getting almost the same mv thats coming off the end of the diode. i dont know what it is. i gotta study for a test. later
Quote from: clamup1 on September 12, 2010, 07:38:32 PM
Is the diode correctly oriented?
I just built one of these for myself, from the layout here. I used a piece of perfboard, but followed the PCB layout.
Before adding any ICs I powered everything up and tested the voltage at the correct pins. Op-amp pin 8, 5V at the regulator and PT2399. Everything checked out. When I put the chips in I wasn't getting any oscillation. After a long "close" inspection I couldn't figure it out. Came back later for a quick look and see an obvious solder bridge. Fixed that and everything started working. Never under estimate the effect of taking a break on your productivity.
I haven't given it much of a test yet. First impressions seem to say that everything is working correctly. Sounds to me like the LFO has sort of a wobble to it. Like it's not quite a triangle. This seems to change as the speed and depth are adjusted. I'll have to test it some more.
I did sub the 100 ohm resistor from PT2399 Pin 6 to ground with 82 ohm, as this was the closest I had on hand. I figure this wouldn't make much difference? I'm thinking about adding 50K pot to ground at this resistor to get regular delay and chorusy sounds. I assume this should work.
I'm starting to wonder if C11 (power filter cap) isn't bad? What typically happens to caps when they go bad?
I've had a cap that I suspected was blown and it read as a resistive short (aluminum electrolytic), but I don't know if that is typical behavior... I threw it away without an autopsy, but I'm guessing the dielectric material melted and allowed the 'plates' to make contact.
i have gone over the + rail and scraped all the melted plastic away from everything else. the diode is put in the same way as its in on the schem. i didnt check the cap. i did break both of my small drill bits so i had to use a 1/16 on the end where the pot, +,-, wires go. soldering those was fun. i also unhooked the switch and took out the ic's.
:icon_redface: im not gonna tell you what i did wrong but i got that fixed
now i get clean with ossilation, switch on have to turn my amp all the way up and only get a little bit of signal.
i have a ? about how to hook up the jacks. im not at my home computer so i cant find the website but. does the board have to be grounded to the encloser and do the jacks have to be grounded to each other.
Quote from: clamup1 on September 13, 2010, 04:28:23 PM
Yes!
Quote from: frequencycentral on September 13, 2010, 06:05:30 PM
Yes!
And furthermore, Yes! (http://www.beavisaudio.com/techpages/StompboxWiring/)
i had really cool star trek sound effects then it quit. i dont think i have this thing wired right. i have it wired like this
http://www.diystompboxes.com/smfforum/index.php?topic=970.0
no led
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Did anyone uh....replace the 100r resistor at pin 6 (or whichever is the delay time pin, totally forgot) with an LDR that's controlled by the same LFO or another lfo? Cause that could make for a pretty sweet flanger.....right?
Quote from: YouAre on September 22, 2010, 01:01:53 PM
Replacing the 100R with a LDR would increase the delay time of the PT2399 to such an extent that it would no longer be a chorus, but a delay with modulation (not a flanger). The whole concept of Little Angel was to keep the delay time to a minimum by using that 100R resistor and modulation pin 2 instead of pin 6.
Quote from: frequencycentral on September 22, 2010, 02:39:12 PM
I only suggested this for 2 reasons. First being that I'm remembering back to the echo base/other delays with modulation, that modulation is achieved by "wiggling" the delay time pot. Secondly, I just built a small clone, and i noticed that when I played around with the delay time, I either got modulation or flanging (depending on the timing cap). I also noticed that some chorus pedals out there have a "delay time" pot, I figured it might be an interesting addition.
I built this yesterday (pictures in the "pictures" forum). It really sounds nice and the PCB layout is good.
But a Vero layout ?
Olá para todos , meu nome é daniel, sou brasilieiro .
Acabo de montar o little angel chorus, fiquei surpreso com o resultado, fantastico, achei muito bom.
A unica mudança que fiz foi usar os pots de 100K, o restante dos componentes são o mesmo do esquema original.
Me perdoem por não escrever em inglês pois não domino o idioma, e não sou favoravel a o uso de tradutores.
Agora posso tocar Nirvana... rsrsrs....
Abraços a todos e muito obrigado ao pessoal do forum que me abriu uma porta para um pedal complicado de se montar.
Abraços e Felicidades..
Daniel Venticinco ;D
english please
I think he likes it! He used 100k for both pots. Now he can sound like Nirvana.....obrigado!! ;D
Yes that was the same impression I had.. Though I don't typically associate Nirvana with chorus.. ;D
fantastico!..... :icon_mrgreen:
That's spooky......here's a post I made earlier this morning......
http://www.diystompboxes.com/smfforum/index.php?topic=87287.msg733482#msg733482 (http://www.diystompboxes.com/smfforum/index.php?topic=87287.msg733482#msg733482)
Quote from: daniel_venticinco on September 29, 2010, 11:50:01 PM
Hi, everyone, my name is Daniel, I'm brazillian.
I just mounted the Little Angel Chorus, I'm surprised about the result, fantastic, I found it's very good.
The only change I made was to use 100k pots, the rest of components are the same as in the original schem.
Sorry for not write in english but I don't dominate the idiom and I don't like using translators.
Now I can play Nirvana... rsrsrs...
Cheers to everyone and many thanks to the forum staff who has opened me a door to a pedal that was complicated to build.
Hugs and congratulations!
Daniel Venticinco ;D;D
;D
Well that explains it
Slade-All Seeing All Knowing :)
built it, loved it, but tweeked it: was experimenting with different value pots off of pin 6 to go from chorus to delay and, ummm, hooked up a 24v adaptor instead of the usual. :icon_redface: poof! so a quick check of everything tells me that the only components i used not rated for that much were the two 10uf in the LFO & the NE5532. I can't find anything on the 2399. did i nuke that as well? i built this on perfboard and i'd like to think i don't have to redo all that. i replaced the 5532 and it passed signal again, but there's a loud buzz. i only have one more 2399 so i don't wanna swap that in if there's something else wrong.
pop out the PT chip and turn the unit on and make sure you are still getting 5V on your regulator. I believe the lower rated regs can only tolerate 15V (don't quote me on that). Your regulator may have saved the PT, dunno... I'd assume I blew the PT if the reg works.
you are correct sir! 5.05V on the regulator (powerful ratshack rated for 35V). swapped chipped, beautiful again. bummer about the PT tho, really wanted to make another one of these and didn't wanna spend any money for awhile. oh well. thanks again, both to you for the help and frequencycentral for this sweet little circuit! ;D ;D ;D
I think the regulator should have survived. 78L05 are rated for 35 volts. But that doesn't mean the PT2399 survived too. Yeah, it's still only getting 5v at it's VCC (pin 1) so would have survived in that respect, but it's REF (pin 2) may have received a big fat lot of voltage from the LFO running at 24 volts.
Ok boog, you posted while I was typing - glad it's working again and sounding sweet!
sneaky that way sometimes, like a cat with a xylophone tied around it's neck.
So... Simplified BOSS DC-2 Anyone? :icon_mrgreen:
Quote from: Scruffie on October 01, 2010, 03:19:08 PM
I spit on your DC-2 with it's HUGE PCB (http://img.villagephotos.com/p/2005-2/951008/DSC03791.JPG) and it's unneccesarily complex schematic (http://www.freeinfosociety.com/electronics/schemview.php?id=123)!! :icon_mrgreen:
Quote from: frequencycentral on October 01, 2010, 03:28:42 PM
Wellll Your Mother was a Hamster And Your Father Smelled of Elderberries :icon_mrgreen:
Quote from: boog on October 01, 2010, 03:10:45 PM
Yeah bummer. If it's any consolation, over the summer I paved my driveway using only PT2399 and LM13700 that I destroyed while originally breadboarding this circuit and Causality 4. ::)
that is unfortunate; casualty 4 is on my list, i spent the first year and a half building dirt boxes so now i've moved on to modulation. of course, i built my bench around dirt circuits so that means a whole bunch o' reinvesting.
So, I built a second LAC... this one has a horrible LFO thump! I'll play around with it tomorrow (and reread some posts). I didn't hear it until I plugged into my TKO, then I had a nice steady heartbeat. I'm gonna try running with the TL072 and see if the thumping goes away, cuz I don't hear it at all in my first build, and it's exact same components except the IC and the depth pot.... just laid out on a DIP board instead of the nice PCB. Maybe some LFO mods in my future, lol.
I'll get pics up tomorrow... it's a pretty box!
well here i was all prepped to show off my snazzy build and when i box it up i get nothing but the 'deathbuzz' again; standard troubleshooting procedures shall apply, but i think i'm doomed. so.......this lead me to a noob question: my 7805 is in one of those to-220 packages. rocket scientist here didn't heat sink it so when i boxed it, the 7805 bent over and touched the 5532, would the heat off of the 7805 zap the 5532? and isn't that tag at the top (where you mount it to the heat sink) a ground connection? so if it touched the enclosure it really shouldn't do anything?
There shouldn't be any heat with the regulator.
But shorting something out, yeah that would do it.
Don't know off hand about the tab being at ground or not.
Quote from: boog on October 02, 2010, 10:57:27 AM
.....and isn't that tag at the top (where you mount it to the heat sink) a ground connection? so if it touched the enclosure it really shouldn't do anything?
The metal tab is connected to COMMON (pin 2) and therefore is at 5 volts. You need to isolate it form the (grounded) enclosure or you'll have a short circuit. Use insulation tape.
oh bugger then; looks like i'll have to try that for round 3, so far no luck in troubleshooting and there is definately some heat being generated somewhere. lessons learned i spose.
I tried adding a 50K pot between the 100R and pin 6 of the 2399. Though this does work, you get a delayed signal, the sound was not very exciting. There is a single short delay and the modulation seems less obvious. The best sounds seem to be at the shortest delay times. There might be use for a smaller pot say 1K to 10K to adjust the delay length a small amount for different sorts of sounds.
I wonder if a regeneration pot might be more useful as a sort of resonance control?
I noticed on my build that I hear some hiss/noise. Not sure if this was there before I added the 50K pot or not. Though I don't think the pot itself would add any noise. I notice the noise seems to increase when I play. Have to sort this out before boxing up.
I mentioned this before but, I notice the LFO is not symmetrical. It seems a little lopsided. The lopsidedness seems to be effected by speed.
Quote from: soggybag on October 02, 2010, 02:16:39 PM
It's on my breadboard right now. :D
ok, got it sorted
Quote from: frequencycentral on October 02, 2010, 02:20:08 PM
It's hard to keep up with you Rick, you are tireless!
hey i got mine to work. i had to reetch the whole thing but i got it. now lets see if i can put a switch on it and it still work. thanks for a great pedal
hey i got a stupid ?. is this pedal npn or pnp.
It's neither... and both.
NPN and PNP are different bipolar transistor types. There are dozens, maybe hundreds, of each type in the ICs (integrated circuits) used in this project. However there is not one single discrete (by itself, not part of an IC) transistor, either NPN or PNP, used in the build.
its ok, i got it to work.
Quote from: Govmnt_Lacky on August 26, 2010, 10:35:39 AM
Just an FYI for everyone, all pcb transfers generated out of DIY layout creator are properly sized when printed at 72 dpi. You can use irfan picture viewer to print at different resolutions if you don't have a program to do so.
This is good advice, but bear in mind that in LFO's and modulation especially, as mentioned before, the two can't be used interchangeably. I can say that due to the number of tremolos I have built with NE5532 that didn't work until I popped in a TL072. Not all duals are created equal... :)
25k was i ended up using, after it falls out of 'chorus' it seemed pretty cool, though there was a snare like echo to the circuits echo. i liked the 'somethin aint right sound.' i too wondered about a resonance control, figured i'd try something out in the winter.
Quote from: Barcode80 on October 02, 2010, 09:12:06 PM
This is not my experience. For the older version, the output files are properly sized at 200 dpi. The new version (beta) outputs at 166 dpi. At least that's how it works with Photoshop.
Sorry, I mistyped. The old version outputs the image at 72 dpi. The print size I've found to be best is 200.25 dpi. Perfect fit every time. Thanks for the correction, don't know where my mind was!
Quote from: Earthscum on October 02, 2010, 12:53:48 AM
Word of advice: choose your pot and board locations carefully. I am getting LFO bleedthrough from the pots to one of the audio paths in the board. Fun fun fun! ;D
I'm lazy, so I'll probably just do a ground plane shield between the back of the pots and the board... worked decent on testing, we'll try it tomorrow, along with some shielded cable in/out. I'm tired of soldering on this thing, hehe. I wanna move on to my next project (probably a wah).
I took a risk since some people have verified the layout and built it up completely without testing. I will play through tomorrow and ensure it wasn't a mistake!
(http://i85.photobucket.com/albums/k42/goodoldpatrick/100_1009.jpg)
(http://i85.photobucket.com/albums/k42/goodoldpatrick/100_1010.jpg)
Ok I went thru the whole thread and I think if I want to build the standard two knob version I use the layout on page 9. Yes Rick?
Thank you
Super, smashing, lovely.
(http://juansolo.demon.co.uk/stompage/images/angel-o.jpg)
(http://juansolo.demon.co.uk/stompage/images/angel-i.jpg)
Quote from: Pigyboy on October 03, 2010, 02:38:54 AM
Thank you
Yeah, that's the 1590A layout. Both layouts I've posted follow the schematic and part values in post #1.
Nice to see some finished build photos!
Still unsure about good pot values for this build.
Can someone help me out with what potentiometer values work best in this circuit? I know Rick used 100K for Speed and 470K for Depth but I have also read that some poeple liked 100K for both.
I am getting ready to build this too and Rick suggests the 470K. I should have it done tomorrow sometime I hope so I will post my results.
Strangely enough, I used the NE5532 with a 500k pot for depth and a 100k spot for speed, but I'm experiencing that all the depth and speed both are bunched at the end of the pot's rotation. I'm assuming I will need to go with the 100k depth. THoughts?
Quotebut I'm experiencing that all the depth and speed both are bunched at the end of the pot's rotation. I'm assuming I will need to go with the 100k depth. THoughts?
Rick had a good point with this post:
QuoteRe. Depth pot value debate:
The more minimum settings shouldn't be dismissed out of hand. Take away (most of) the modulation and you've got automatic double tracking, which we don't seem to talk about much around here. ADT has the effect of thickening the sound as if two people were playing the same part in unison. You might not notice the thickening until you bypass it - then your sound will seem thin and weedy by comparison! Process your vocalist through the Little Angel at minimum settings - he/she/it will love you forever.
The ADT you get with the depth pot turned down all the way is a cool effect in it's own right. Yet you don't seem to significant chorus effect 'til you get to the last 20% of the pot rotation. My solution was to change the depth pot to 100K, and add an SPDT switch and a 470K resistor - so that in one switch position, it's like having the 470K depth pot turned down all the way (you get ADT). In the other switch position it's like having the full rotation of the depth pot cover the top 20% of the 470K pot (from the original schematic).
Quote from: waltk on October 03, 2010, 11:13:21 AM
Phew! At least someone read my ADT post! :icon_eek: Nice mod Walt!
Quote from: frequencycentral on October 03, 2010, 11:35:45 AM
That's basically the trick I take advantage of with the added 5k delay pot. The effect disappears on the lower notes on bass, so increasing the delay a small amount covers a bit more range of effect.
I gotta get pics up for ya... even though I'm not done. I think I gotta re-etch a new board. I yanked the whole thing out and found I'm getting LFO thumping through the board itself. ugh!
I am a bit confused ???
So, the way that the 470K depth pot is wired on the Little Angel, (with lugs 2 & 3 connected and Lug 1 open) as the pot is turned CCW or down, does the resistance go UP or DOWN?
QuoteSo, the way that the 470K depth pot is wired on the Little Angel, (with lugs 2 & 3 connected and Lug 1 open) as the pot is turned CCW or down, does the resistance go UP or DOWN?
As you turn the pot "down" (CCW), the resistance goes up - to 470K ohms if you're using a 470K pot; to 100K if you're using a 100K pot. As you turn the pot "up" (CW), the resistance goes down to zero ohms - regardless of what value pot you are using. So simply replacing the 470K pot with a 100K pot (wired the same way - lugs 2 and 3), and using the full rotation, is exactly like using the top (CW) ~20% of the 470K pot.
The switch on my build is wired so that the resistance is either 470K (simulating having a 470K pot turned all the way down), or somewhere between 0 and 100K depending on the rotation of the pot.
Quote from: waltk on October 03, 2010, 03:01:45 PM
I see now. I originally thought you were putting the 470K resistor IN SERIES with the 100K pot. I see now that it is EITHER/OR.
So you get the max ADT with one side of the switch, and the FULL pot rotation of the 100K with the other side of the switch. Good deal! :icon_cool:
(http://img687.imageshack.us/img687/8623/littleangelchorus.jpg)
Quote from: Earthscum on October 03, 2010, 11:43:13 PM
Oh EarthScum that is beautiful. Looks like you have signed up to do a screen printing tutorial!
Must see the gut shots on this one! Absolutely beautiful!!
oh yeah... forgot about the Gratuitous Gutshot! ;D
(http://img684.imageshack.us/img684/5223/littleangelchorusgutz.jpg)
Not the smartest layout decision... more like experimenting, since I know it's gonna be around to fix. Testing out a couple things: solid core wire layout, Krylon paint and etching primer. Probably won't do the wire trick again... looks nice, but it's a pain to do.
I recently switched to solid core wire, and I will likely never use stranded again. It's just so much tidier...
Quote from: Earthscum on October 04, 2010, 09:27:40 AM
Is that the millenium switching array in there?
Earthscum, are you finding that an increased delay time results in noise/hiss?
Beautiful build Earthscum!
Quote from: culturejam on October 04, 2010, 03:03:26 PM
Actually, I did notice that a little bit, but this build is fairly hissy all around. MY slap-together works great, even with wires crammed in every orfice of the board.
And, yes... that's a millennium. I used a blue LED and ended up using 51k as a drop resistor... never saw that before. All other LED's (except clear yellow ones) had NO light at all, but this setup I used the 51k (not 5.1k!) and had to use a 100k parallel to the LED to get the fet to turn all the way off. Usually I'm sitting on a 3.3k and somewhere around a 4.7k parallel. I thought it was my fet... nope. diode? nope... just the blue LED. Not alot of current through it, so I'm definitely not complaining!
Quote from: Earthscum on October 04, 2010, 06:27:03 PM
Thanks for the lowdown David. Where are you getting your momentary switches? Oh, and how about the screen printing tutorial? :P
What band do you play in anyways?
Cheers,
Chris
With Ultra Bright Blues I always found the millenium only worked with 10k & 10k for both resistors or else the LED just blew up.
Quote from: Pigyboy on October 04, 2010, 06:42:25 PM
Cheers,
Chris
This one is DPDT latching, mechanical true bypass.
Been getting requests for that lately... probably be more of a bill of materials, and how to use them... the actual screening is easy... just feel, patience, and getting your hands on. Care and handling of materials is actually more crucial... but, I may do a PDF writeup for the DIY'er who's like me and tries to dive in head first.
And, band is in the sig ;D
You know I had looked at and pondered your sig but didn't click it but now I clicked it an dyou FB like button too. Great name, kind of Ween-ish!
fixed it! :icon_smile:
(http://i868.photobucket.com/albums/ab246/boogaldige/101005_165957.jpg)
(http://i868.photobucket.com/albums/ab246/boogaldige/101005_170512.jpg)
really gotta get a camera
Govmnt_Lacky ,por favor poste seu esquema, achei interessante os controles que vc adicionou ao seu projeto.
please post your schema, I found it interesting that the controls you added to your project.
Daniel.
Quote from: daniel_venticinco on October 05, 2010, 06:11:37 PM
Daniel.
The white & blue one is mine. I have the pot mods posted on
page 8 (http://www.diystompboxes.com/smfforum/index.php?topic=86297.140).
I think I have a new mod...
taking the LED+ from the regulator. I have a pedal that turns on, but no sound... the 9V got too low, but it is still powering the LED. Shouldn't be hard by any means, but at least you will be able to tell when your audio is shut down (when the PT is no longer getting voltage from the reg).
Govmnt_Lacky
Desculpe-me pela confusão, não havia visto que o projeto com os mods seria o da pagina 8, obrigado por esclarecer para mim.
mais uma vez me perdoem por não conhercer bem a lingua inglesa.
Sorry for the confusion, had not seen the project with the mods would be on page 8, thanks for clarifying for me.
Once again forgive me for not Getting started and the English language.
thanks.
DAniel
Earthscum! thats a beautiful and very clean@@@@ no Doubt your room is very Clean!
anyone worked up a vero layout for this yet? i've tried my hand at it and it was an epic fail...
I just did this up, and can't help but think I might be able to make use of more depth for a bit more versatility. How might I go about accomplishing that with this circuit?
By the way, I really love the design, and I think it'll have a permanent place on my board. I love the subtle shimmery-ness I can add to my sound.
2-5k pot with the 100R as a limiting resistor works great. I use 10k, but I'm a bassist with a weird sense of sound.
Page 8, second post down has the mods that I find useful and use.
Quote from: Earthscum on October 14, 2010, 12:31:29 AM
Yea, actually I did do those mods, I used a 5K with a 100r limiting resistor, but that seems to affect the delay time, not really the depth.. Unless I've done it wrong somehow..
Also, the level mod you showed doesn't seem to work for me.. It doesn't seem to adjust the output signal at all.. I need to look at that again, but I think I did that right also.
Whenever I hear 'not enough depth' I think maybe there's something wrong, as I tweaked the design for what I considered gave just a lttle too much depth. Is the opamp Ne5532? Anyway, reducing R13 or replacing R13 with a jumper will increase the depth to too much/way too much respectively.
I am using an Ne5532, and I've actually got a 30K resistor in place of R13. I'm probably just looking for more versatility than this pedal should have.
I'll try a few different values though. Thanks.
Works Great! Just the basic build no mods and it is sweet. Into the 1590A tomorrow and pictures. Thanks Rick!
Damn! I was hoping to complete the first 1590A build. I'm just in the process of producing the etched enclosure. I'm about two days behind you.....
Great project!
Has someone made a vero layout in the meantime? Renegadrian talked about that, but it seems he never finished it?
+1....great sound on that clip rick.....very cool project..... :icon_cool: :icon_cool: :icon_cool:
been following this thread, waiting for the dust to settle on the inevitable mods.... 8)
i'd like to see a vero too...coz im too lazy to 'print, saw, etch, n drill'.... :P rob....
Ok, It fits in the 1590A. Is this the first finished mini-box build? It gave me fits getting it in there. It won't fit with sockets or anything taller than 7 or 8 mm above the board. It does fit clean and it sounds beautiful. I will make a clip today. Looking forward to Rose (my wife) using at her next gig with her new Taylor ;D. That is if she doesn't want to use it to sweeten up her Little Angelic voice. I think I will get her to help make the clip doing a proper guitar and vocal demo.
(http://i852.photobucket.com/albums/ab86/pigyboy_2009/LittleAngel2.jpg)
(http://i852.photobucket.com/albums/ab86/pigyboy_2009/LittleAngel1.jpg)
(http://i852.photobucket.com/albums/ab86/pigyboy_2009/LittleAngelGuts.jpg)
What? No battery? :icon_wink:
Here's mine!
(http://dl.dropbox.com/u/967492/LA%20Front.jpg)
(http://dl.dropbox.com/u/967492/LA%20Guts.jpg)
Wow Rick! . Looks great. I couldn't get mine in the box with the sockets. What kind of jacks did you end up using?
Hey
I'm mewby, and tried a veroboard layout for the Little angel circuit. It's my first time going from schematic to vero layout, so I invite anyone to examine or try it. I will order the material just tomorrow, so i can try not before 10 days. Can anyone see anything wrong?
sorry....
http://www.aronnelson.com/gallery/main.php/v/diyuser/angioletto.gif.html?g2_imageViewsIndex=1
cuts under the ic?... ;) .....
Quote from: igerup on August 09, 2010, 08:45:54 AM
Interesting. I like the simplicity of the circuit. A board wouldn't even be necessary, unlike most other chorus schemes floating around out there. What opamps did you use?
i was looking forward to this interesting boardless version of this build ??? :icon_mrgreen:
Of course....
cuts under the ics....
Quote from: Mr. Slave on October 17, 2010, 02:28:43 PM
sorry....
I find vero really hard going, but I spotted a couple of errors (there might be more, I didn't check it all):
- IC2 spacing incorrect, should be 4 x 4.
- C6 should be from pin 8 to ground.
It would also help if you used the correct DIYLC part for the electo caps, to avoid incorrect orientation.
New vero with corrections
http://www.aronnelson.com/gallery/main.php/v/Schematics-etc/angioletto.gif.html
Thank you Rick....
c5 should be to ground . ;)
cuts under c12?????why!.
i think we would all be better off doing the pcb. looks like it might end up big , and maybe problematic, etc..
nice to see mr slave have a go at it though!..it took me a while to get used to converting from schematic
to vero, you didnt choose an easy one by the way!.... :icon_mrgreen: rob.
Thank you Rob
"c5 should be to ground"...that was an oversight
"cuts under c12?why!" ... I moved everything but the cuts under c12
...soon correct layout...
If I even see the word 'vero' I break out in a rash :icon_eek:
Quote from: Pigyboy on October 18, 2010, 06:50:53 AM
:icon_mrgreen:
Y'know, I've started a few vero layouts (to benefit all mankind), I place half a dozen components then I think to myself "@#$% this @#$%ing mother@#$%er !! If people are 'individual' enough to want to use @#$%ing vero over a superior media they can just make their own @#$%ing vero layouts !!" I HATE vero with a vengence.
Help us Renegadrian! You are our only hope....
erm...perf? :icon_mrgreen: only joking..... 8)
i'll get my coat.......... ;)
I'm all a rash ;D :icon_redface:
http://www.aronnelson.com/gallery/main.php/v/Schematics-etc/angioletto_001.gif.html?g2_imageViewsIndex=1
:icon_mrgreen: funny...
rob has left the building....with his coat on.... :P
i'll put this on here on mr slaves behalf...to cover his rash. :icon_mrgreen:
(http://dl.dropbox.com/u/7464107/embarrassed_pic.jpg)
Quote from: frequencycentral on October 18, 2010, 07:11:17 AM
+1 ;D
Ahhhhhhrghhhhhh :o
the last one:
http://www.aronnelson.com/gallery/main.php/v/Schematics-etc/angioletto_002.gif.html?g2_imageViewsIndex=1
A guy over at FSB just posted a pretty neat looking vero layout (unverifed), I'm sure he won't mind if I post it here:
(http://www.sabrodesign.com/wp-content/uploads/2010/10/Little-Angel.gif)
FSB?
Quote from: Pigyboy on October 19, 2010, 02:37:01 PM
FSB?
Either front-side bus if you're talking about a computer, or more likely the other DIY stompboxes forum whose name we don't mention :)
Free Stomp Boxes.org
Thanks guys,
Acronyms and politics are not my strong suit :-X
I am having a little trouble with this circuit on the breadboard. It seems that my supply voltage, which is 9v volts from a One Spot power supply, drops down to 6.3v. I believe I have located the issue to be the 78L05 regulator. The one I am using is to-92 package and I am using the PCB layout as a guide for hooking it up.
Anyone have a suggestion to correct my problem. I am seriously excited to try this circuit as soon as I get past this issue.
I'm confused. the 78L05 should drop the 9 volts down to 5 (or 6 with tolerances). Am I misunderstanding your question?
Yes, the regulator does drop the voltage it outputs to 5 volts, but when it is in the circuit, my supply voltage to the rest of the circuit drops down to about 6.3v. That means that the voltage fed to pin 8 of the dual op-amp (NE5532 in my case) is only at 6.3 volts when it should be 9. In addition, the voltage fed to the non-inverting input on one side of the op-amp is also not what it should be.
Something is pulling my voltage down, but I can't quite figure out what it is. When I remove the 78L05, the supply voltage is back to 9 volts, when the regulator is in the circuit, it reads 6.3v. I have tried another regulator and also another PT2399 with the same results.
I just thought someone might have had a similar issue, or be able to point me in the right direction.
Quote from: Pakaloabob on October 24, 2010, 11:03:14 PM
Sounds like you need to start checking resistor values and solder bridges on or around your voltage regulator. R1 shorted to the ground post of the regulator?
Good Luck ;D
Well, it turns out all I had to do was run the circuit off a battery instead of a power supply. :icon_redface:
I really wish I knew why the power supply wasn't working properly for this circuit. If someone has any idea, I would love to hear. At any rate, things are working fine off the battery so I won't get too worked up.
Quote from: Pakaloabob on October 25, 2010, 08:06:43 PM
just as a note : i had the very same problem with a 'zombie chorus' worked fine on a battery, but wouldnt 'chorus' on my psu...
i ended up having to put a regulator on the dc socket..and it worked fine...hope this helps....
Thanks, Rob.
At least I know I'm not completely crazy if it happens to someone else.
Another funny thing I noticed is that I can play with it running off a battery, change to a power supply and get no modulation, then remove the power suppply and reattach battery and still get no effect for a little while. If I leave it for a few minutes it will work fine on the battery!
Is it possible that the LFO somehow latches until the proper voltage is applied?
Like I said in an earlier post, for some reason my power supply does not provide 9 volts when attached to the Little Angel circuit, but a battery does. Since the PT2399 voltage is regulated, only the dual-opamp would be affected by this voltage drop. Which is why I think the LFO is the issue.
I wish I had another power supply to test with. I was planning on building the AMZ power supply. Maybe this will be the motivation I need.
This is driving me crazy - if anyone can help , I would appreciate it immensely.
I'm using Ricks schematic Version 2 updated 11/08/10 , all components stock .
The vero layout is from Harald Sabro Bolstad , posted on this forum by ( I think ) Rick .
I have altered the layout only slightly , to avoid any jumpers running under ICs .
I've checked for shorts throughout , and for continuity everywhere I can see .
The test results are :-
By-passed - normal output
Effect - sounds normal , perhaps a tiny volume drop
Audio probe - as effect on pin 1 opamp then the same at pin 15 PT2399 , no sound anywhere else on this IC . A gentle thumping sound from pin 7 on the
opamp , varying with speed pot - I guess this means the opamp works .
Voltages -
IC 1 1) 5.21 V
2) 4.87 V
3) 4.77 V
4) 0.00 V
5) varying 2.5 - 3.5 V
6) " 2.5 - 3.5 V
7) " 1.4 - 7.8 V
8) 8.56 V (normal output of my PSU )
IC2 1) 5.01 V
2) varying 2.49 - 2.54 V
3) 0.00 V
4)0.00 V
5) 5.01 V
6) as pin 2
7 + 8) 0.001 V
9 - 16) all as pin 2 , i.e.minor variation around 2.5 V
Also , I pulled the 2399 from another pedal that was already working , thinking that the new one was a duffer - no change .
I know the answer must be right in front of me , but I'll be damned if I can see it - HELP !!!!!!!!!!!!!
My first guess with vero would always be microscopic continuity on the cut tracks - check it out with a continuity probe.
Already done that (several times ) but I'll do it a few times more . I was hoping something in the voltages might give us a pointer - the fact that I get a signal on pin 15 but nowhere else makes me think the fault is in that area - I'll keep on digging !
RESULT!!!!!!
The 100R from pin 6 to ground was OC at the ground end - it was the last one in the drawer and had been cut short previously , so I missed it , hidden between 2 other wires .
Anyway , it now works - and might I say how lovely it sounds !
Thanks , Rick - you're a genteman and a scholar , as we used to say !
OK, I built this Lil' Angel on PCB for a 1590A. Only wired it for wall wart power from DC jack. I get bypass no problem, when I engage the circuit, it seems like the depth pot does not work at all (no change in modulation) however, the speed pot seems to do something when I crank it between 80-100%. I get a subtle vibrato effect. I used 100KB for both pots. Here are some voltages.
Opamp (5532)
Pin1) cycles on and off from 0V to ~1.4V (This looks wrong)
Pin2) 2.8-3.2V
Pin3) 2.8-3.2V
Pin4) 0
Pin5) 4.75V
Pin6) 4.9V
Pin7) 5.2V
Pin8) 9.18V
2399
Pin1) 5V
Pin2) 2.4-2.5V
Pin3) 0
Pin4) 0
Pin5) 2.6V
Pin6 - Pin8) 0.7V
Pin9 - Pin16) 2.4-2.5V
Voltage converter seems to work correctly.
Any help is appreciated. Thanks.
I've just got this going , having got stuck and posted the voltage readings .
Looks like you're using pins 3-2-1 for LFO - your readings tally with mine except for pin 1 , which looks very low .
Could be a low-value resistor shorted to ground - I see a 4k7 in that area - try looking around there .
Quote from: Govmnt_Lacky on November 01, 2010, 09:35:38 PM
Opamp (5532)
Pin2) 2.8-3.2V
Pin3) 2.8-3.2V
Pin4) 0
Pin5) 4.75V
Pin6) 4.9V
Pin7) 5.2V
Pin8) 9.18V
2399
Pin1) 5V
Pin2) 2.4-2.5V
Pin3) 0
Pin4) 0
Pin5) 2.6V
Pin6 - Pin8) 0.7V
Gonna triple check for solder bridges and component values today. Then, hook this up to a DC power supply and post new voltages.
Stand by... 8)
Ok... Some things to note about my build.
I used 100KB pots for both Speed and Depth.
I wired the Speed pot backwards (I used lugs 1 & 2 so when I go full CCW I get max speed)
New voltages (I think)
NE5532 (swapped out a new one)
Pin1) 2.7-3.2V (ONLY when Speed pot is at 0-20% rotation. Above 20% rotation, it is 0-1.4V)
Pin2) 2.7-3.2V
Pin3) 2.7-3.2V
Pin4) 0
Pin5) 4.7V
Pin6) 4.8V
Pin7) 5V
Pin8) 9V
2399
Pin1) 5V
Pin2) 2.45V
Pin3) 0
Pin4) 0
Pin5) 2.5V (DOES NOT LOOK RIGHT COMPARED TO nickd POST. SHOULDN'T IT BE 5V?)
Pin6) 0.7V (THIS LOOKS WRONG!)
Pin7) 0.7V
Pin8) 0.7V
Pin9-16) 2.5V
Voltage converter is good.
Checked for values and solder bridges. None to be found.
Things that look suspect to me are Pin 1 of the opamp and its relation to the Speed pot. Also, Pin 5 and Pin 6 of the PT2399.
Any help is appreciated. THANKS!
Just checked my voltages on the working version - your 2399 is pretty well the same as mine , but your pin 1 ( my pin 7 ) is still off .
Must be somewhere around the LFO ( only my humble noob guesswork ) . Keep on digging - its in there somewhere !
The voltages I posted were for the non-working version . My pin 5 now shows 2.5 V , so all your 2399 voltages look OK . Still looks like the LFO area is the prime suspect .
Where's Rick when we need him ! ( only joking ! )
Quote from: nick d on November 02, 2010, 11:01:07 AM
Do you still get the voltage change (2.5-3.5V) on Pin 6 of the 2399 like in your original post?
Wired up the Speed pot correctly (Lugs 2 & 3) and I still get the same outcome. Seems like I only get voltage wobble on Pin 1 of my 5532 if the Speed pot is at 80-100% of the pot rotation. Below 80% and the voltage lays at 0 and intermittently peak to ~1.5V! ???
Also, I still only get 0.7V on Pin 6 of the 2399. Is that correct?
I read in past pages of this thread that some people have found that the 5532 only likes a 470K pot for Speed. Should I try a TL072 as the LFO?
Please help :'(
Just done a run-thro on my voltages .
PT2399
1) 5.02 V
2) 2.5 slight wobble
3) 0V
4) 0 V
5) 2.22 - 2.5 V (didn,t spot the small variation before )
6) 0.75 V
7)0.66 V
8) 0.66 V
9 - 16) As before
NE 5532
The only significant difference is pin 1 ( opamp LFO output - pin 7 on my layout )
I have a varition from 1.4 - 7.4 ( lo-speed ) to 2.5 - 3.5 ( hi-speed )
Hope thats clarified the picture - that LFO voltage still looks way off , or is that a red herring ?
Stick at it , you'll get there .
Quote from: nick d on November 02, 2010, 12:04:09 PM
NE 5532
Did you use the 470K for the Speed pot?
Used a DMM to check for solder bridges over ENTIRE circuit - NONE
Checked ALL component values against layout - ALL good except for using 100KB pot for Speed.
Swapped ICs - swapped both AND installed a TL072 for LFO.... no change.
Still getting the strange voltages on Pin 1 of the LFO. With the Speed pot set between 0-80%, I get intermittent voltages ranging from 0V to 1.5V (Sometimes I see larger values however, my DMM on "flashes" them and I can hardly read them fast enough.
When the Speed pot is set to 80-100%, I get a solid voltage swing from ~2.5 to 3.5V.
According to nick_d's input, when the Speed pot is CCW, I should get a solid voltage swing between ~1.4 to 7.4V.
Getting desperate :-\
Looking at the speed pot on the schemo - you say 2.5 - 3.5 V at hi-speed , the lower end of the range seems to be where it goes wrong .
The unused pot connection - is it left open or tied to the wiper ? I tied mine to the wiper , after reading "The Secret Life of Pots ".
I am having the exact same problem! I'm getting all the voltages you are getting... I've done all the solder bridge checks, component values, wiring, orientation etc etc and I'm stumped if I know the answer. My voltages sway like yours do as well...
Quote from: nick d on November 02, 2010, 01:44:35 PM
I left it open (Lug 1). I will try tying it to the wiper and report back the results. Cross your fingers please :-X
EDIT: I am out of 100KB 9mm pots so I am going to have to use 100KA pots. I hope they work!!
Mine was also left open...
EPIC FAIL!! >:(
I tied the open lug (Lug 1) to the wiper (Lug 2) on both pots and the voltages on Pin 1 of the LFO are STILL not right!
I am left with one final obvious option. Swapping the Speed pot for a 500KB. If that does not work it will have to sit on the shelf for a while because I honestly cannot think of anything else to try.
That's a bummer ! Running out of ideas here - it has to be around the LFO - if you are 100% sure there are no shorts , try searching for open circuits . Thats what I had on pin 6 , almost immpossible to see , found it after 3 days of hair-tearing ! DON'T LET IT BEAT YOU !
Thanks Nick. I am sure there are no shorts because:
1) I checked ALL AROUND the board traces with a DMM and found nothing.
2) I would think if it was shorted, I would get NO voltage.
As it stands now, it appears that I get the higher frequency LFO sweep (2.5 - 3.5V) but when I back the Speed pot down, my lower/wider sweep (1.4 - 7V) is non-exsistant!
I will have to plug it in tonight and see if any of my tinkering has changed anything. I also had a problem with the Depth pot and the fact that it appeared to have NO effect on the circuit.
I will post more info about what I found later tonight. Thanks for all the help nick ;D
Just plugged my Little Angel in and it is still NOWHERE NEAR the "lushness" that I can hear on the sound clips! I am gonna try one more 2399 in the circuit and then it is off to the shelf cause I am out of ideas on this one ??? >:(
HAS ANYONE GOTTEN THIS TO WORK WITH THE 100k POT FOR DEPTH INSTEAD OF 470/500K?
Sorry to hear you've not had a good result on this , I know you put in a lot of time and effort . Just listened to those clips again - mine does not sound QUITE that good - that could be down to Tele Custom + VJ clone v my cheap SG clone + Kustom 10 W SS amp , and of course my appalling guitar technique .
As regards the 100k/470k , minimum pot resistance = max depth , so should not be an issue ( I think ) .
Better luck next time !
Quote from: Govmnt_Lacky on November 02, 2010, 06:46:50 PM
Hey Lackey,
Get your meter and check that the diagonal trace that runs beneath R20 & R16 is not shorting to the pad that connects R16 to C13 on the 1590A layout. I was checking the boards I made again for shorts and I found it shorted on one board.
Quote from: Pigyboy on November 03, 2010, 05:53:51 AM
Thanks Pigyboy. I checked that trace and it checked GOOD. I also ran over every trace again with the DMM and found no bridges. I checked component values again, all good. Looked over the offboard stuff, all good. I still have not tried a third PT chip so that is the last resort before scrapping and re-boarding.
For those of you joining late, I posted some voltages however, I have STILL NOT received any replys with voltages from a "known good" working unit. I have had a reply from nick_d but he even says that his Angel does not sound as lush as the sound clip from Rick.
It appears that the lo-speed setting on my Speed pot (higher resistance) is nonexistant. When I turn the Speed pot (100KB) all the way up I can get a subtle vibrato but that is only at the top of the rotation. MY Depth pot seems to have no effect at all.
I did put this on an oscope and I could see some signal change with adjustment of the Speed and Depth pot however, it was very... very small.
Basically, I need someone to post voltages of a good, working unit that sounds like Rick's sound clips.
Thanks a ton to all who have helped so far... :)
I know it doesn't help you much, but as I said before I'm having the exact same problem. The same is said about my speed pot - the only time I can get an effect is with full speed, full effect. I've posted somewhere else about voltages and emailed FC - the creator of the pedal and asked for his advice and voltages so I'll post them here when I'm done. I gave up on it today after wasting another few hours on it! Then I built an unsuccessful Bazz Fuzz - keeps getting a glitchy signal so I'm going to re-wire again. Here's a thought that just came to me actually... maybe you stripped off some excess stranded wire when stripping the covering off? I know I did with the Bazz Fuzz - which is probably why I get glitch signals. Try rewiring? I will do this at the weekend as I've probably wasted enough time on it for now - I'll let you know if it works for me.
Quote from: jable1066 on November 03, 2010, 12:13:58 PM
Thanks jable. I would appreciate that if you get a response from FC or if you find an issue. As far as my Angel is concerned, my Depth pot is useless (to my ear) no matter what I do. My Speed pot ONLY changes the modulation when it is at 80-100% of the pot rotation and even then it just sounds like a subtle vibrato.
On a side note... the pedal does give a slight volume increase when engaged. And also, when I put a 440Hz/100mV square wave into the pedal, on the oscope I can see there are "spikes" that roll along the peaks that adjust with the pots. This is great but, it does NO GOOD if you cannot hear it through the amp >:(
Hi , just read some recent posts re Little Angel . Having listened to the clips again and compared them to my results , I would like to chip in with a couple of observations.
Overall , the sound I get is pretty much the same ( making allowance for differences in guitar , amp , and playing technique ) . Having said that , there is one bit at about 0.50
that is quite noticeably different .
On the controls , depth does pretty well nothing below 70% , and at low speeds the effect is very subtle , but still noticeable compared to dry.
My overall impression is that I have built a worthwhile pedal . If you consider the simplicity of the circuit , and the fact that the 2399 was designed never intended
to be a chorus pedal , the end result , I think , pretty good . I could probably spend a bit more money and buy a Behringer pedal that MIGHT sound a bit better
but that misses the point - we are DIY builders , trying out new ideas , and thats the way I like it .
( STOP IT Nick , you are starting to preach ! )
In conclusion , not perfect , not bad , on to the next one !
Thanks Nick. I just want mine to sound like the sound clip form Rick and no matter where I put the knobs and no matter what position they are in, I could not duplicate the lush tones that are on that clip. That is how I know something is wrong. It is not a matter of gear. The difference in that clip and what I hear goes way beyond gear setup.
This has got me thinking ( a dangerous practice ! ) - component tolerances.....
The shorter delay , the better the chorus - but the limit is 100R . So , if I use a resistor , 5% , which is at the bottom of the range = 95R , and you happen to get
one thats 105R , my delay will be shorter and so sound better . This could happen by random chance , or by selection .
This would apply in any circuit where values are critical . So , by careful component selection or using trimmers , you can fine-tune the circuit .
This is a well-known idea , and could well be more trouble than its worth , but its worth bearing in mind . Hmmmmmmm.......
Here are voltages just taken from my Little Angel, which sounds the same as the breadboarded version I did you soundclips on. Speed at 3 o'clock, Depth at 12 o'clock:
NE5532
1: 0.13 to 4.9
2: 2.9 to 3.2
3: 2.7 to 3.1
4: 0v
5: 4.79
6. 4.9
7: 5.14
8: 9
PT2399
1: 5
2: 2.38 to 2.42
3: 0
4: 0
5: 2.75
6: 0.61
7: 0.88
8: 0.88
9 through to 16: 2.41 (slight movement)
It's pretty hard taking voltages from a moving LFO, guess accuracy depends on the resolution of the DMM, but you get the idea.
I really like mine. I have a half populated CE-2 PCB (3 times the size of the LA PCB!) which is looking sadly at me - it knows it isn't getting finished anytime soon now. Yeah, Little Angel isn't the best chorus you can build I'm sure. But it is the simplest. I dare anyone to design a lower parts count chorus. :icon_biggrin: I said early on in this thread that there would one day be an 'elite' version - that's still the plan, but the original Little Angel has always been a " how-few-parts-can-I-use-to-make-a-chorus?" concept.
I could of course be talking total crap , but who knows ?
Did someone say Arch Angel ? 8)
The wait is agonizing...
Ok... I just swapped out the 2399 and there was NO CHANGE >:(
Thanks for posting the voltages Rick but, I sadly admit defeat. Either this Little Angel I built is the most subtle chorus ever (does not even come close to sounding like your sound clip) or I need to just scrap this build and try again some other time. Now, I used 100K for both pots but.... when I set my pots to 3 oclock and 12 oclock as you said, my pedal sounds like nothing more than a VOLUME BOOSTER.
Hey, GL... try using a mixing mod on the output, either cut dry or cut wet, or maybe a blend pot between the two caps. I notice the effect more or less, depending on the blend. Also, I'm starting to think that the 100R from pin 6 may be small enough to show differences between chips, so you may be getting a bit less or more delay than others. On bass, I can say for sure that I needed a little more delay to get the lower notes to express properly.
And all of this effects how much of the LFO I hear. At shows, I usually have to run wet while I tune my LFO, then drop out the wet to my preferred level for that stage. At practice, I do the same thing, but that's just because I don't have a big enough STFU stick (drummers are annoyingly loud sometimes!)
So far, I'm totally happy with this, but I don't know how much I like the LFO part... but I can't come up with anything better myself, so I'm not complaining a bit.
A couple pages back I mentioned that my Little Angel build did not play well with my One Spot power supply but worked fine on battery.
I recently acquired a new power supply - Danelectro DA-1 that came free with a Vox V845 wah I got online (great deal BTW)
Little Angel likes the Danelectro power supply!
But again, if I try the One Spot, the circuit doesn't work. Hook up the Danelectro PSU again and wait a few minutes, success!
Has anyone else experienced, or heard of something like this? Should I open a new topic to fish for some comments?
I got a Soundlab 450 , which will run 6 pedals with no problems . Puts out 8.6 V , not used any thing else apart from
unregulated 9 V wall-warts , used on synth-type stuff with on-board 9-V regulators . Never use batteries , 'cos I don't like them going flat on me .
I've used Little Angel , BSIAB 2 , Phozer 2 , Tonebender , and others , never (touch wood !) had any problems .Am I just lucky or what ?
Video Demo of the Little Angel built by El Musico Loco.
Thanks for the great design Rick!
http://www.youtube.com/watch?v=oxyk3c9YXQM
Hm....This looks like a fun build. Anyone able to do a demo of it doing Paradise City chorus tone, or at least verify that it can do that?
It surely! Thanks for the supplementary amount of motivation.
(I mean the sound sample :D )
I got 2 PCB s on the way for this modulation effect.
If I should succeed with both ,I have one I ll try to tweak
a little bit.
Regards JM :)
Hi everyone,
I think I stumbled onto something here. The first of these I built with a 5 volt L78L05 positive voltage regulators and all worked fine and then I built 2 with a L78L06 6 volt regulators. The first one started to work but then stopped and the PT2399's were getting hot but I didn't pay attention to it. I couldn't get it to work again so I built another and again it didn't work. I put in a 5 volt L78L05 this morning and it fired right up. I think this may be G-Lacky's problem so check it out if you are having problems.
Chris
Quote from: Pigyboy on November 16, 2010, 03:38:00 AM
Hi everyone,
Chris
Sorry Chris.... I wish it was that easy over here. I just checked and the regulator is a KA78L05AZ from Fairchild and it is reading 5.01V on the output. I am going to check the "stupid" things again before I shelf this thing! >:(
Hey Greg,
Check it all out again and feel the chip for heat. If it is getting hot at all swap the regulator. I would swap it out just to be sure and check your pinouts for the regulator just to be sure. Good Luck. This thing drove me crazy but it is great when it works.
Chris
This may be an odd request but....
Could someone post a picture of this chorus on an oscope? I set mine up as follows:
Frequency: 440Hz
Amplitude: 80mV
Wave: Square wave
I could really use a "working unit" to compare to.
When I engage the circuit, my square wave become more "sawtooth-like" with "spikes" in the middle of the peaks and valleys. These "spikes" never get larger or smaller however, they do change with the pots. When I turn the speed pot, the spikes move more rapidly/slowly back and forth along the peaks and valleys. When I adjust the depth pot, the "distance" in which the spikes travel along the peaks and valleys becomes longer or shorter.
Confirmation with a working unit on an oscope will give me a bit more sanity. ;)
How did this turn out, BTW?
I just breadboarded mine, and it sounds good, but I'd like to give it a bit more "thickness". It seems a little subtle to my ear, for some reason. I already tried lowering R12 to 2K to try and get it slower.
From looking at the datasheet I think you can manipulate the delay by changing R6. Yes ???
PigyBoy, how would you say this design is for hitting the "Paradise City" intro tone?
Quote from: azrael on November 17, 2010, 12:16:43 PM
Hi Azrael,
Do you mean the 'bmwaaa-bb-bmwaaa-bb-bmwaaa-bmwaaa-bmwaaa' part at the start of the song? ;D
Hmmm...wait, I'm evaluating your use of onomatopoeia..... :icon_lol:
Not how I would characterize it, but....I believe we're talking about the same thing? The very first guitar part of the song. :D
Quote from: BoxOfSnoo on November 17, 2010, 09:01:48 AM
Heh heh... Mr. DMM tells me that I needed to *RAISE* R12. I changed it to 7.5K and it's pretty sweet about there. The delay pot is handy just for tweaking that extra little bit of space in it. Now if I can figure out how to give it a tiny bit of regen I'll be ready to perf this baby!
Quote from: azrael on November 17, 2010, 02:12:48 PM
I think you can get that tone with this box.
Anybody want to make me a board? Or tell me where I can order one with the info provided here?
Quote from: kristoffereide on November 21, 2010, 04:09:52 PM
Here: http://www.guitarpcb.com/apps/webstore/products/show/1690146
Has anyone seen the problem of the PT2399's latching up and not turning on the effect? I am not sure if this is due to a bad set of chips. I was using a 6 volt regulator and found the chip and the regulator getting hot so changed to a 5 volt regulator and it seemed to work but now I am getting reports that the same problem is intermittently re-occurring.
Any thoughts?
Thanks,
Chris
Hmmm. I've read similar in one of the other recent PT2399 design threads. There could be a number of culpits:
- Bad set of PT2399, as you say.
- Speed that the PT2399 is running at, ie 100R resistor. As the data sheet shows only minimal ms difference between 0.5R and 1K, maybe we should try a higher value and see if the bug goes away.
- Some PT's don't like their vref being tampered with? Not sure of the solution if this is the case, as the Little Angel depends on this to get the effect.
That's the issue I came across with the Sewer Pipes. It wouldn't let me use anything less than 560R. When I would turn it on, I would get a small double-pop and then only the OP Amps would be working. I don't think I even hand anything coming out of the mod/demod sections. Even just setting up the chip for a normal datasheet delay yielded the same results. I swapped in other PT's and got the same thing, then I tried the ones from different source and they worked fine with the 100R.
The ones that don't like short delays are the ones I got from Tayda, but they are different than the first one I got from them. The 2 I originally used are from Steve (smallbear), and the first one I got from Tayda, and they have no problems with the 100R at all. The one from Steve have a nicer case, while the ones from Tayda look more like National chips... square, boxy, dull case. If I get a hankerin, I'll post pics of the different ones. Just gotta get into a case for a pic of one of them.
Thanks for the input FC &ES -
So in the end did they all work by raising the resistance to 560R? Does it affect the effect?
Ya know, I use a 10k pot with a 100R limit on mine, and I usually find it turned up to about 1.5-2.5k minimum for bass, so I don't think a 560 would make too much of a difference... maybe just a little bit of tone change.
I really wish they'd make a chip like the 2399 that does .1-5mS and 4-40ms or so. The 2399 effectively covers most of the longer range, and can easily do longer with multiples, but short delay lines are still kind of a pain.
If you look at the latest datasheet it recommends not using less than 1k resistance off pin 6 at power on, the old ones never had this warning. http://www.princeton.com.tw/downloadprocess/downloadfile.asp?mydownload=PT2399_1.pdf (http://www.princeton.com.tw/downloadprocess/downloadfile.asp?mydownload=PT2399_1.pdf)
I think it depends on the individual chip as to whether it will work with less, I've got 2 Echo Bases both built with 3 year old PT2399s from Smallbear. The first one I built never has any problems no matter what the resistance is but the other one occasionally locks up if I turn it on with the delay time on minimum.
Thanks Ian, I hadn't seen that particular datasheet with the below 1K warning. The difference between 100R and 1K in terms of delay time is about 8ms. So I guess we say the value for R1 needs to be 1K to avoid lock-ups. Can anyone comment on the audible difference between 100R and 1K?
Tonal difference is all I noticed, and it was slight. It definitely increases the perceived depth of the effect, IMO, but not bad. my Sewer Pipes is where I really noticed tonal change concerning the delay. Between about 220R and 1.2k there was more change, and after that the waves become too separated. I don't remember that much change in the LA...
The LFO section of my LA went kaput for some reason, or I'd just check it out for sure since I have the adjustable delay. If I get it working, I'll get back to ya.
Thanks to you all for the new info. I will build another today and use the 1K and report back what happens.
cheers,
Chris
Quote from: Pigyboy on November 29, 2010, 03:39:26 AM
cheers,
Chris
Definitely interested in your findings! Please let us know! ;D
Quote from: frequencycentral on November 28, 2010, 06:51:53 AM
I tried it on my breadboard... you can kinda hear that it's doubling, though just barely. My circuit seems to work with a 100R, but I also added a delay time pot as well for longer delays.
If your PT2399 won't work with 100R you can still get a decent sound out of it with 1K, but it will be different.
Just finished this with the 1590 layout! Had a problem (small bridge between pin 5'n'6 of IC2) but it was an easy fix and now it sounds great! Thanks Rick for the killer pedal!! Hopefully someday I'll be able to contribute with a sweet design of my own. Pics as soon as the enclosure actually gets here 8)
Le sigh, I walked away to eat lunch and when I come back it doesnt work?
Ne5523 - Very close to ricks readings
PT2399
1-5.01v
2-2.32-2.42
3-0
4-0
5-5.01
6-.58
7-0
8-4.58
9- 4.84
10-.35
11 thru rest 2.41
*frustrated*
Sounds like the PT2399 has locked up. Switch it off and on again and it'll probably work. Also try a 1k resistor for R1 instead of 100R.
It worked! Kinda :)
I turned it off and on and the effect came on, I then soldered in the 1k at R1 and its back to not working city. With a voltage readout similar to the one I described.
I spoke too soon, it works now.
Right before it kicked in the modulation I very slightly turned down the voltage to the pedal. I read earlier in the thread that the "Onespot didn't play well" with this circuit. I wonder if thats my problem. Thanks for being quick on the draw rick, I'll play around with this until its stable.
Although it is an annoying problem I'm glad I am not the only one who has experienced the issue of the PT chip locking up. At least it is well documented in this thread so others will know to try other power sources. For me, the Danelectro power supply works well.
BTW - this sounds really cool distorted with both speed and depth around 8 and ripping tritones. really agressive. kinda like...a little demon :icon_twisted:
Bahhhh I fixed the little bugger after having problems with it and it keeps like not working. I'll switch it off and on and it'll not work then after a while it will work. However, one thing I noticed which is definately the route of the problem (I think it'll be safe to assume it is anyway) is... my voltage regulator and PT2399 are getting MEGA hot. Anyone know why these could be getting hot? I don't have a 78L05 to hand... I only have a 7805 which is too huge to fit in my socket :( So I'll have to wait till tomorrow to go buy one from the electronics shop near my house. I've reflowed and cleaned up the board probably 4 or 5 times now, somehow without lifting traces but it probably can't go on for much longer...
Quote from: Govmnt_Lacky on October 04, 2010, 08:02:26 AM
What are the level mix and delay pots?????
Delay just gives me a range from the 100R to 10k. When I was breadboarding, I figured out that this circuit needs a little bit more delay for bass guitar. The mix pot is a 100k in series with the 10k wet side output resistor. When you increase the delay, it really starts to cut across the dry signal, and with bass, you don't want a full-out delay, or your guitarists start running all over you (gotta keep the punch and presence up so they actually sound like they might actually be playing in time :icon_twisted: ).
Page 8 has the mods.
In these mod: the pots market for DELAY, MIX and LEVEL are the correct positions?
(http://img138.imageshack.us/img138/4184/littleangelchorusmodcir.jpg)
Quote from: Brymus on November 03, 2010, 04:22:14 PM
Hi Rick, something new about the arch angel?
I´ve made a layout for the mod of this pedal; it is correct?
(http://img697.imageshack.us/img697/9370/littleangelchoruslayout.gif)
UUUUPSS!!! some mistake; here are the correct layout, you see an error? please post it! thanks:
(http://img27.imageshack.us/img27/9370/littleangelchoruslayout.gif)
Have just looked at it, not really checked anything, but the value seems to be missing from the "Level" pot (in the BOM).
(and there seems to be an awful lot of white space, it'll never fit a 1590A ;))
Hey guys,
Any chance someone's got a working perf layout for this? I tried, but something's not right...I'll probably just grab a PCB from the guitarpcb.com sale, but It would be cool to be able to perf it too...
In Perú there are no standar cases for FX you must make yours!!!!! I make the cases for tree dimencions: 10x12x5 cm; 8x12x5cm and 15x12x5cm These are the standar for me!!!!! when I finaly made the pedal I post the interior and the made of these mod for your pleasure!!!!! OK I forgot to put the value of this pot an here is the new layout; please a look ofr another error!!! tnaks a lot!:
(http://img696.imageshack.us/img696/9370/littleangelchoruslayout.gif)
Quote from: p_wats on December 10, 2010, 03:14:43 PM
Hey guys,
A PCB layout
IS a perf layout too. ;) Many of the PCB layouts I have posted I have actually built on perf.
Quote from: GodSaveMetal on December 10, 2010, 03:15:47 PM
No offence meant. Would be lovely to see a enclosure building tutorial, I can get the materials, just don't know how to make them. Well searched the forum a bit and found links to two articles, more always welcome :)
ps. Documented the links on my enclosure tutorial (http://www.rumbust.net/tiki-index.php?page=Enclosure+Tutorials) page on my wiki.
I may be wrong, but I see no sense in those long traces leading to Speed pot. And not only them. But well, I'm not an expert, and I didn't create a single layout myself. Just wanted to share thoughts.
Quote from: frequencycentral on December 10, 2010, 03:34:32 PM
Hey guys,
A PCB layout IS a perf layout too. ;) Many of the PCB layouts I have posted I have actually built on perf.
Yeah, I'm usually able to work with the PCB, but the dual opamp is throwing me off here. That latest PCB layout (with the mods) is a bit easier to wrap my head around, so maybe I'll try that.
Quote from: meffcio on December 10, 2010, 05:09:17 PM
Yeah, as I look at it a little more, there's really a lot of lost space on that one. Move things around just a little in the top two rows and make them one. Remove the extra (ground loop inducing) ground connection (out -) and you save a column. Getting a little creative on that left side should allow you to get rid of another column.
At the bottom there's a lot of traces just to get the speed and depth connections up close. Feels unnecessary as other pot connections are all over the place (more or less). You could remove at least one row there.
But I'm just a compact design loving guy :)
This was a fun build - sounds cool. But i am a bit baffled as to why all my pin readings look good with the exception of pin 6 of the 2399 which is reading 2.2v. This seems a bit high. Any guesses as to why this might be? I am running 9v directly to the +Vcc of the 5532 instead of 5v but it is rated for much higher so i dont think this would be a problem.
IIR 2.2v at pin 6 sounds about right assuming R1 has a value of 1K, but too high if R1 has a value of 100R. I think the voltage at pin 6 is entirely dependent on the value of R1. Not sure what you mean about running 9v directly to the +Vcc of the 5532 instead of 5v, as this is how the circuit was designed in the first place.
Here's another (unverifed) layout, with onboard pots, designed to fit in a 1590B. You can either buy board mount pots, or solder resistor legs or solid core to standard pots. There should be space to 'lay down' all the electro caps so they don't foul the pots which will overhang the PCB. A LED resistor is included on the board. A few components have moved here and there. I've also change a few values: R1 is now 1K instead of 100R as some folks were finding the PT2399 locking up with the lower value; C1 and C3 are 0.1uF instead of 0.01uF. I've performed these changes to my Little Angel, 1K is cool with me, and (unless I'm imagining it) there's a little less hiss with the caps values. Finally, Slade built a Little Angel recently and used rev log pots, which he reported gave a nice even taper. I'd recommend the layout is checked against the schematic before etching/building as I am only human.
(http://dl.dropbox.com/u/967492/Little%20Angel%20OBP%20PCB.gif)
(http://dl.dropbox.com/u/967492/Little%20Angel%20OBP%20PnP.gif)
has the latest pcb of little angel been verified yet?
this is an excellent layout
Quote from: frequencycentral on December 20, 2010, 06:49:14 PMas I am only human.
I thought you were the perfborg from outer space ;D
Finally built it!!! I used the vero you can find at page 19 or HERE (http://www.sabrodesign.com/wp-content/uploads/2010/10/Little-Angel.gif). Yeah I should have finished mine before, then this one came up so I just used that!
I really like the LA!!! Simple but charming, you cannot stop those arpeggios!!!
Also I made a simple DELAY MOD - just a 1k res from pin 6 that goes to a 25-50k linear pot (I guess 25 is the best value, but I have none of them handy ATM) at pin 1, pin 2 and 3 to ground. So when pot is at its min it's stock, else It can be a nice "slapback" fx or a good short delay, try like "every breath you take" with it!!! I love it!!! Gotta box it up!!! And try it with my bass too!!!
Thank you Rick!!! ;D
Now I have a 20k linear for the delay - it works better than the 50k. Also subbed the 500k pot for a 100k as someone suggested. Now it would be fun to add a speed LED. How can it be added?!
Hi Adriano, glad you like it. To add a rate LED, tap off from the output of the LFO opamp (via resistor, 1k maybe). On the vero layout you used, that would be pin 7 of IC1. (On my PCB layouts it would be pin 2 of IC2).
Quick question:
I built a Little Angel using the vero layout http://www.sabrodesign.com/wp-content/uploads/2010/10/Little-Angel.gif (http://www.sabrodesign.com/wp-content/uploads/2010/10/Little-Angel.gif) and it worked fine for a minute, but then it stopped working altogether.
The only deviation I made from the original design was to use a 1n4007 diode instead of a 1n4001. Don't think this should matter, but maybe?
Voltages check out on the PT2399 except pin 5, which reads much lower than it should (about .5v instead of the 2.6 or so that it should be).
I have no idea what happened. Any guesses?
The diode is not mandatory, it's just for polarity protection - as you can see, it is just between positive and negative. maybe you put it backwards!? You can just get rid of it, it has no relation to the sound path.
I used that layout too - just a couple of changes like R5 position and so on, but yeah it should work - check 7805 orientation, and voltage at pin 5 (I got 4.9V from mine)
Quote from: dylar on January 20, 2011, 02:18:50 AM
Quick question:
You're possibly locking up the PT2399. Note the layout just above - R1 is 1K and R8 on your layout is 100R. Raise R8 (on your layout) to 1K.
Another quick test is to kill the power for a couple of seconds and then try again. If it comes back then that's your problem.
I finally built one of these (on a board from gutiarpcb.com). Very subtle, but I like the thickening of the sound almost more than the outright chorus. Combine that with a delay pot instead of R1 (I used 25K, because I don't mind very dirty repeats) and it's a lot of fun.
Otherwise, I ditched the depth pot (jumpered the connection), as it's already subtle enough.
I also messed around with the value of R18 (a pot was suggested, but I found a really low value resistor was all I needed here).
I'm hoping to box it up tonight with a "Noise Ensemble" (another PT2399 circuit posted here recently). Woo!
Quote from: frequencycentral on August 09, 2010, 09:05:42 AM
I'm using a NE5532 dual opamp. I used a 470k because here in the UK that's what we use, 500k seemingly being a value available in the US but not here. 500k will work just fine.
Is that metric electronics vs US Imperial electronics? Or do we just have controls here that "go to 500..." :icon_wink:
This is strange, but while I was messing around with mine today I swear I had it doing multpiple repeats. Then when I finished the soldering it was back to a single repeat.
Anyone else found that too or any ideas on how to keep the multiple repeats?
Hello, someone can sell me 2 or 3 1590A?
I live in Brazil and has nowhere to buy here.
Thanks, sorry my english.
Quote from: frequencycentral on December 02, 2010, 02:09:08 PM
What is the procedure to switch off and back on. Are you just referring to removing power?
Quote from: bdevlin on February 08, 2011, 04:59:13 PM
Yeah! For a couple of seconds.......
Quote from: frequencycentral on February 08, 2011, 05:02:38 PM
Okay then. Maybe we have some factual evidence to help some people with issues. My chips from eBay do not work. But I just popped in the chip out of my PT80 which came from SmallBear and it works. Pin 5 on the Small Bear reads 2.4V but on the eBay chip (Raycon??) it reads 5v.
And oddly enough, the eBay chips work in my PT80.
I definitely recommend trying several PT2399s. The first one I used didn't modulate that well, but the second was great!
Also, I found it very ditch R13 entirely, as it seems to increase the depth available---from drunken sailor warble to slight shimmer (FC, does that make sense?).
However, mine is a little noisy. Anyone else experience this?
I've had a batch of 3 PTs that dont modulate in a LA. They do work in an Echobase, so a little swapping was required.
So glad I found this thread! I perform as a solo acoustic act and love the chorus in my Fender Acoustasonic Jr, but don't use it for most gigs. Just bought a Fishman SA 220 and love it but have been looking for a Chorus pedal to add in. Gonna check my inventory and get this puppy built.
Quick question:
I found a few errors in the Parts List for the following: C6 & C8 should be 100nF/.1uF
Quote from: bluesman1218 on February 09, 2011, 01:51:41 PM
The original schem at the first page calls for 10nf, so it it correct. I used the same layout and it works fine.
Concern so called Depth issues. As an experiment I put a 50k trimpot in parallel with R13. There are some interesting results as you lower the trimpot. I also wired in a Mix pot off of R18 but as of now I find it seeming sort of redundant with the Depth control.
My little angel work.
Pedal simple with great sound.
I put a 1k pot in place of the 100R resistor to control the delay time, did not see much difference, tomorrow replace for a pot of 10k. (any ideas??)
Now I need to get a cabinet.
Thanks to all who participated in this project.
Sorry my english.
Does it matter if I use all of cps of 100nF ceramic?
The polyester caps are very large.
Quote from: rmachado on February 11, 2011, 01:44:24 AM
You should be ok, as long as you don't care about the cork-sniffers frowning at you. When that happens give them this link (http://www.diystompboxes.com/smfforum/index.php?topic=36392.msg762125#msg762125) and tell them those shells were used hunting their kind.
Although to be fair, there are times when ceramic versus film will change the sound of a circuit, not always for the worse though.
All the caps I used are ceramics! it works so good! I have a 20k linear pot for the delay with a 1k in series (so when the pot is at 0 the minimum value is still 1k)
I'm not a cork sniffer but I do think using ceramic caps make the circuit have a lot of hiss. At least it did in the last one I built. I had used all film caps in the others and the latest seems more hissy with the ceramics. I did have to change the amp I test my stuff thru as the Peavey Classic 50 went back to our practice studio and now now I am using a Marshall Artist 30 tube amp to test at home. I would like to know it anyone else has this experience with the hiss.
Cheers,
Chris
Quote from: Pigyboy on February 11, 2011, 07:44:25 AM
Cheers,
Chris
I've got hiss without the use of ceramic caps.
Quote from: p_wats on February 11, 2011, 10:19:07 AM
Cheers,
Chris
Hey P_wats
Try a different amp if you can. I built another Angel today with film caps for a present for someone and both it and the other I have with ceramics are totally silent when I run them thru a Behringer powered speaker I have here. I have never liked this Marshall Artist 30. It has always been very trebly and also I just noticed I can really hear the effect oscillating when I am not playing much more than through the PA speaker. I didn't have this problem with the Classic 50.
would some kind soul work out the caps part list for me in terms for big bear electronics? they use mf, pf - not uf or nf. i know i'll screw it up if i do it myself! thanks,
Quote from: davepedals on February 20, 2011, 10:24:25 PM
http://www.justradios.com/uFnFpF.html (http://www.justradios.com/uFnFpF.html)
fantastic...thanks! so what caps should I use? ceramic, poly film, silver mica? any one of these quieter? I cannot find a 470k pot at small bear, is 500k ok?
thanks!
a good start:
ceramic for anything small, poly film for anything over a nf, electrolytic for anything over 1uf
Dave, Small Bear lists many of their caps as mF. On their site, this designation means Micro-Farads; 10-6 farads. This is the same as the standard designation - µF. This causes some confusion as in the SI system, the prefix µ typically designates micro (10-6) whereas m designates milli (10-3), but Small Bear does not hold to this convention! On the Small Bear site mF is really µF: microfarads.
Note pF is picofarads and stands for 10-12 farads and nF is nanofarads and stands for 10-9 farads.
Hope this helps!
ok thanks for that info! i've found about 4 different images now for this chorus, some show the components a bit differently for the caps. is there a correct caps list anywhere? specifically I need to know which caps (and how many) are electrolytic. also some images show a 470k pot, other's show both pots as 100k, this has me confused a bit. does the pcb from tonepad come with parts list and parts placement printed on the board?
it's been awhile since i've done a build but in the past i've built at least 100 projects.
many thanks!
Quote from: davepedals on February 21, 2011, 10:29:28 PM
The two 10uF capacitors, the 100uF and the 47uF are electrolytic. You can tell on the schematic in the first post, the ones that are polarized are the electrolytic ones. You should always use the schematic as the definitive source for information, rather than relying solely on a layout it will help you considerably in the future! Use layouts more for parts location rather than parts identification.
However, a good verified layout is valuable. check this post out: http://www.diystompboxes.com/smfforum/index.php?topic=86297.msg723128#msg723128 the round purple ones are electrolytic.
There was a discussion earlier on about the 470k pot (or 500k) where many found that a 100K would perform just as well, and make more difference over its whole travel. The 500K in its higher resistance ranges was more like doubling rather than a separated chorusy sound.
many thanks!
I don't know of a Tonepad project for this... ???
Quote from: Barcode80 on February 22, 2011, 07:10:21 PM
many thanks!
Neither do I. I think he means guitarpcb.com, who no longer stock it.
BTW, when
Slade built an Angel he used rev log for both pots and reported a nice even taper.
yes i meant guitarpcb.com. too bad they no longer offer it! thanks for all the info!
Hey guys...greetings from brazil...
First of all...Congratulation on the schematic, Rick...my new favorite box...
Now...i was wondering if its possible to add a rate led to pin 6 of PT, for delay mod...
thanks again for this wonderfull little box...
Edu Gomes
Hi rick and everyone! i would like to build this box :D but one more question has anyone tried it with high gain? is it quite? because robote delay is very noisy :(
Quote from: askwho69 on February 26, 2011, 12:00:20 AM
You may have a problem with your build. Mine is quiet as a mouse. It doesn't get any noise except on the longest delay times.
mmmhhh maybe ... it hizz like cracking! try to figure itout
Holy ###t!!!! this pedal is amazing!!!!
Rick, thanks a lot for this chorus!!!!! :)
Спасибо огромное! ;)
Quote from: Xide88 on March 01, 2011, 03:40:09 PM
Your welcome!
Did the vero board build and I have a ton of crackling. So much that I can't hear the chorus effect. VCC voltage is 4.97 on PT2399 and 5.4 on NE5532. I had the rate LED wired and it worked intermittently, but disconnected it. I'll hook it back up when the pedal is working. I'm not a circuit guy, just a builder, so if anyone has any suggestions, I would really appreciate it.
All solder joints are good, no bridging to adjacent traces, all trace cuts are clean and non-conductive, no components touching ground that shouldn't be grounded. I have swapped both chips and it's the same problem with all of them.
BTW, I got the last 2 boards from GuitarPCB and they'll be here soon. I will probably do a fresh build on them.
Quote from: bluesman1218 on March 01, 2011, 11:34:16 PM
This does not look correct. You should have about 9V at Pin 8 of your 5532.
Quote from: Govmnt_Lacky on March 02, 2011, 08:19:52 AM
Correction - 8.65v at pin 8 of 5532 and 8.64v at Q1
Are there other readings I should be looking at?
Thanks for bearing with me.
Steve
BTW, here's a pic of the enclosure. Quickie paint job and decal for the alpha build.
(http://i83.photobucket.com/albums/j310/bluesman1218/Vintage%20Tone%20Amps/AngelChorusEnclosure.jpg)
Recommend you follow this link:
http://www.diystompboxes.com/smfforum/index.php?topic=29816.0
Repost after reading through the link and following what it says. You will get it fixed 10x faster!
Good Luck ;D
Quote from: Govmnt_Lacky on March 02, 2011, 04:12:21 PM
Good Luck ;D
Thanks, GL. I printed and read through the debugging pages (helped me eliminate DC hum), but didn't see this one. I'll go through RG's steps and take it from there. He is such a terrific resource to all of us hobbyists.
RG Keen Debugging checklist
1.What does it do, not do, and sound like? Constant crackling and can't hear effect. When turned off (true bypass) all is well, so I don't think it's an off-board wiring issue.
2.Name of the circuit = Little Angel Chorus (VERO layout)
3.Source of the circuit (URL of schematic or project) = Vero Layout I used http://www.diystompboxes.com/smfforum/index.php?topic=86297.msg737758#msg737758 (http://www.diystompboxes.com/smfforum/index.php?topic=86297.msg737758#msg737758)
Original layout/parts list http://www.diystompboxes.com/smfforum/index.php?topic=86297.msg723128#msg723128 (http://www.diystompboxes.com/smfforum/index.php?topic=86297.msg723128#msg723128)
4.Any modifications to the circuit? N
5.Any parts substitutions? If yes, list them. no.
6.Positive ground to negative ground conversion? Don't know
Voltage readings
Voltage at the circuit board end of the red battery lead = 8.34
Voltage at the circuit board end of the black battery lead = 0
Q1 78L05
Out = 4.97
In = 7.94
Grnd =0.01
IC1 NE5332
P1 0 P4 0.01 P7 varies
P2 3.35 P5 varies P8 8.20
P3 2.93 P6 varies
IC2 PT2399
P1 4.97 P4 0.01 P7 3.23 P10 2.48 P13 2.48 P16 0.01
P2 2.47 P5 0.95 P8 3.28 P11 2.48 P14 2.48 P17
P3 0.01 P6 2.32 P9 0.27 P12 2.10 P15 0.08 P18
Z1 (zener)
A (anode, the non-band end) = 0.01
K (cathode, the banded end) = 8.12
Voltage on all Electrolytic caps is higher on (+) pin than on (-) pin
I have PCBs coming and will do a fresh build on them. Until then, I would love to get this working. Any help would be greatly appreciated, as I'm not a circuit design guy, but can follow directions and build.
Steve
Can you post a pic of the board and the inside of the build?
Chris
Quote from: bluesman1218 on March 03, 2011, 05:21:00 PM
5.Any parts substitutions? If yes, list them. Vero listed 7 – 100nF caps. Since this count/value didn't match Rick's original, I used .1uF values.
Really?!? Now THAT'S the reason it doesn't work! lucky you it didn't explode...why did you use
.1µ instead of the
100n!!!
That can be dangerous...I warned you.
Quote from: Renegadrian on March 03, 2011, 06:32:28 PM
Really?!? Now THAT'S the reason it doesn't work! lucky you it didn't explode...why did you use .1µ instead of the 100n!!!
As I said, I'm not a circuit guy and unless the circuit was changed for the vero layout, I didn't understand why the values would differ from Rick's original circuit. If I'm missing something, please let me know.
Bluesman, he's just messing with you (a rite of passage, but perhaps a little unfair).
.1uf (also written .1µ or rarely .1mf) is the same value as 100nf.
This page will help you get familiar with the conversion between uf, nf, and pf. Luckily it a base 10, metric thing, so it's pretty logical and simple once you get used to it.
Quote from: Taylor on March 03, 2011, 07:03:03 PM
Thanks, Taylor, I had a brain fart. All values are correct and I have fixed the original request above.
Quote from: Pigyboy on March 03, 2011, 05:49:11 PM
Chris
Here's a shot of the board with the same orientation as the vero layout diagram. I'm not really happy with it, but I would like to get it working. BTW, the LED is disconnected temporarily, hence the loose yellow wire.
(http://i83.photobucket.com/albums/j310/bluesman1218/Vintage%20Tone%20Amps/AngelChorusInterior.jpg)
BTW, I made this cable so I don't have to keep hooking up the batttery in the pedal. It's also a handy backup on stage if you use batteries when performing live and one fails.
(http://i83.photobucket.com/albums/j310/bluesman1218/Vintage%20Tone%20Amps/9vAdapter.jpg)
+1 on the battery cable! I have several of them.
The pic of the board doesn't help, it looks like the vero layout but how can we see if there is something wrong?!
I dont have my numbers handy HOWEVER,
A few things stick out to me. Particularly your voltages on IC1 Pin 1 and IC2 Pins 15 & 16.
You may want to construct an AUDIO PROBE and use it to track down some of your problems. Just go to the search function above and search for "Audio Probe." Its a simple item to construct and is invaluable in troubleshooting.
Good Luck ;D
Quote from: Renegadrian on March 04, 2011, 07:23:02 AM
Re: cable - I always stock the hard plastic 9v snaps instead of the ones that bend and break from repeat use.
Re: pic - I just right click on it, <Copy Image> and paste it to MS Photo Editor to enlarge and scroll. I'll see if Photobucket has a way to show a larger one if you click on it.
Quote from: Govmnt_Lacky on March 04, 2011, 08:26:42 AM
Good Luck ;D
Thanks, GL.
I just built one the other day and will give it a shot. Should I trace from the ICs using those pins as starting points? Sorry for the question, but even though I don't follow circuits, I'm good at following directions and eventually it sinks in.
Steve
Quote from: bluesman1218 on March 04, 2011, 08:41:55 AM
Just start with the probe at the circuit's audio input and use the layout/schematic to follow the audio flow through the circuit. It is not ALWAYS going to sound loud and perfect however, as long as you are getting SOME SOUND you can be fairly confident that it is OK.
If you run into something that does not look or sound right, just create a new thread particular to your build and list all of the items from the debug thread that I referenced earlier + your questionable audio probe results. You will get lots of help as long as you follow these two rules:
1) You use the debug thread
2) You put some effort into finding the error/problem.
Good Luck ;D
Quote from: Govmnt_Lacky on March 04, 2011, 09:24:37 AM
Good Luck ;D
Thanks, that's my goal.
My Little Angel seems to have Speed and Depth controls that both can adjust speed depending on where they are set. The only changes I have to the "official" circuit are the Mix control at R18 AND....I put a 50k trimpot in parallel with R13 that effectively reduces R13. Wondering if that is why I am getting my results. I can't help but notic that lug 2 of Depth and lug 3 of Speed are only separated by C10. Any thoughts???
Bluesman,
I am a new member but I was just scanning the posts on this project.
Thought I would let you know the following...
I just had some similar trouble in a project that used an NE5532 on a 9 volt supply. The Texas Instruments datasheet says this opAmp needs a 10volt supply minimum (+/- 5 volts). Other manufacturers (OnSemiconductor) lists +/-3 volts. Out of 12 chips, I found 2 TI chips that didn't work on a 9 volt supply. When I used a 9 volt battery giving only 8.4 volts, 2 more showed limited function.
http://focus.ti.com/lit/ds/symlink/ne5532.pdf
http://www.onsemi.com/PowerSolutions/product.do?id=NE5532
-gopher
Never mind my last post....user error. I will toss in however that I give a thumbs down to the Delay mod. Unless you do not have a delay pedal and want some slapback. Otherwise, if you want a Chorus pedal stick to the basic layout.
OK, so I did a fresh build on a PCB and it worked right off the bat. Very cool. Now I have to re-read the thread for some fine tuning. I don't have a whole lot of depth or usable speed. I have tried 2 of my 3 PT2339 chips. I think there were some posts about this, now to find them.
I'm guessing the problem in my vero build was the traces and/or micro solder bridge(s). I'm much happier with the PCB build and will probably stick to PCBs in the future.
Man, don't give up on vero! I am so fond of it...the quickest way to build for me...Glad you made it with the LA.
Quote from: bluesman1218 on March 07, 2011, 10:15:43 PM
I built mine with 100K pots in BOTH positions and I am in agreement with you. When I first fired it up, I was kinda disappointed. It did not have much Depth at all and the Speed was something to be desired. Then I talked to another forumite and he told me that this is a fantastic Chorus to use for playing single note phrases or leads... HE was right! This is not going to sound like a CE-2 or Small Clone if that is what you are looking for. But it really fattens up and puts a great "voicing" on single note playing! ;D
Quote from: Renegadrian on March 08, 2011, 06:56:47 AM
I have plenty of boards and I'll likely use them. In all honesty, part of the problem was the iron I was using. Pulled an old one out and much better results. This was also my first time with vero. I'll build a few simpler circuits and get the hang of it. It just seems a bit limiting on layout when trying to keep a small footprint.
Quote from: Govmnt_Lacky on March 08, 2011, 07:56:01 AM
I'm just using it to thicken my sound on my solo acoustic rig and from the clips I've heard, it's exactly what I'm looking for. In all fairness, I think my speed pot may be audio taper (had it in inventory) and that may be the problem. I'm ordering parts for inventory and I'll check that first.
Quote from: bdevlin on March 06, 2011, 02:30:17 PM
I'd say definitely otherwise, it's definitely not a delay replacement! Just give it a tiny bit of delay and it widens the sound considerably. I put a 5k pot in and that's loads of delay for this purpose - I usually have it only cracked open about 20% or so.
Quote from: bluesman1218 on March 08, 2011, 08:27:34 AM
Really?! Let me firmly disagree on this one...my layouts prove it.
Quote from: Renegadrian on March 08, 2011, 12:01:26 PM
I'm definitely open. Do you have some layout samples you'd be willing to share. Admittedly, layout is a weak spot for me.
Steve, just check my directory in the gallery! :icon_wink:
Quote from: Renegadrian on March 08, 2011, 02:35:44 PM
Got it, Adriano! Still learning my way around here. Gracie!
IT"S.... A.... LIIIIIIVE!! Rick had me check R7, and it was way off (used my good DMM this time). Replaced it and my voltages were in line, but still no chorus. As a last resort, I cleaned/touched up all my solder joints and now it works! I still want to get more effect at 12 o'clock with both pots, but I'm so pysched that I have chorus.
Think I'll invest in a better soldering station. Circuit Specialists has a real nice one for $30. Thanks to Rick, Pigyboy, Government Lackey, and Chris for all your help.
Quote from: bluesman1218 on March 09, 2011, 05:33:40 PM
:icon_biggrin: :-*
WooHoo!
Hats off to Mr. Holt!
Here's mine:
(http://img687.imageshack.us/img687/3817/tomatripascercadetallep.jpg)
The L7805 it's too big I change it by the 78L05 tiny one!!
There is a detail of the pot PCB:
(http://img143.imageshack.us/img143/3406/tomaladosoldaduraydetal.jpg)
I made this in all of my pedals!!!!!
I just built one of these on vero and I have it hooked up without a footswitch and I get sound through, only issue is its just my clean sound.
Any ideas on what to do next? I am newbie to troubleshooting and Im not sure how to measure the voltages across the ICs :(
Thanks for your help and patience...
Quote from: LaceSensor on March 16, 2011, 05:06:23 PM
Got a DMM (multimeter)? Hook up the black probe to ground, then use the red probe to check the voltage of each pin of both chips.
This thread is your best friend: http://www.diystompboxes.com/smfforum/index.php?topic=29816.0
Hi
I got 0 when I tried that so figured Id done something wrong :S
Sorry for the newbness and thanks for your reply.
I think Im just gonna rebuild this from scratch.
I cant figure out what I did wrong, and I have made other pedals successfully :icon_redface:
I have a problem with the PT2399 it sens probably sensitive to statics; some of the IC's I tried do not make the effect; and others make the effect in some level; some high and others a bit low!!!!! I've lucky with the first it's loud; and I prove a second one no effect; others less or more effect!!!!! that would be happends!!!! do anybody have this problems????
Hi, is there a pcb for this layout with all the pots, I'd like to make this version,
I hope their is one, thanks for any help with this
Yep I'm the author of that layout here.s the PCB:
(http://i.imgur.com/0Zfj3.jpg)
Just read the tread for further modifications!!!!
Awesome man, thank you so much, did you build it yet with your pcb
Does everything work Ok
Another nice layout GSM. You might want to edit your Capacitor values as some of them look to be missing information OR are labeled wrong (pF instead of uF)
Quote from: ronnie on March 17, 2011, 10:13:56 AM
Awesome man, thank you so much, did you build it yet with your PCB
Does everything work OK
I don't build this yet but is based on the idea of Earthscum!!!!!! but the version whit two potentiometers it's great; prove this a notice what happends!!!!!!!!!!!!
Another oops!!!!! some tipping error labeled on C6 is 0.1uF the correction is in this layout:
(http://i.imgur.com/qGgJV.gif)
Thanks Govmnt_Lacky for your observations!!! something else please!!!!!
Hi, i make the chorus but don't works, only sound the clean guitar. I used this PCB by Slade on page 8
(http://img210.imageshack.us/img210/6448/littleangelchoruspcblay.jpg)
This is may board
(http://s1d5.turboimagehost.com/t1/6497698_P1020015.JPG) (http://www.turboimagehost.com/p/6497698/P1020015.JPG.html) (http://s1d5.turboimagehost.com/t1/6497707_P1020016.JPG) (http://www.turboimagehost.com/p/6497707/P1020016.JPG.html)
And this are my values compared to the frecuency central ones.
Power supply 8.93V
Tester range 20VDC
TL072
1: 1.4 to 7.3
2: 2.7 to 3.3
3: 2.6 to 3.3
4: 0v
5: 4.79
6. 4.95
7: 4.95
8: 8.93
PT2399
1: 4.95
2: 2.2 to 2.5
3: 0
4: 0
5: 4.94
6: 0.55
7: 0
8: 4.55
9: 4.78
10: 0.33
11 through to 16: 2.4 (slight movement)
Frecuency central
NE5532
1: 0.13 to 4.9
2: 2.9 to 3.2
3: 2.7 to 3.1
4: 0v
5: 4.79
6. 4.9
7: 5.14
8: 9
PT2399
1: 5
2: 2.38 to 2.42
3: 0
4: 0
5: 2.75
6: 0.61
7: 0.88
8: 0.88
Quote from: ppaappoo on March 19, 2011, 05:47:57 PM
This is may board
My advice would be to GET RID of that 100 ohm resistor off of Pin 6 of the PT2399 (the one between the 2399 and the voltage regulator) and replace it with a 1K ohm resistor. There has been discussion in this thread about the 100 ohm resistor causing problems.
Good Luck ;D
OK that's 100R resistor causes problems????? if i changes with the 1K you proposed will work fine????? I probe the original layout and changes the PT2399 and It's fine with the 100R resistor!!!! the IC will be that causes problem????? It is wright o no????
Quote from: GodSaveMetal on March 19, 2011, 07:30:24 PM
You need to go back and read Replys 435 through 450. Might clear it up for you.
Good Luck ;D
Power supply 8.93V
Tester range 20VDC
TL072
1: 1.4 to 7.3
2: 2.7 to 3.3
3: 2.6 to 3.3
4: 0v
5: 4.79
6. 4.95
7: 4.95
8: 8.93
PT2399
1: 4.95
2: 2.2 to 2.5
3: 0
4: 0
5: 4.94
6: 0.55
7: 0
8: 4.55
9: 4.78
10: 0.33
Frecuency central
NE5532
1: 0.13 to 4.9
2: 2.9 to 3.2
3: 2.7 to 3.1
4: 0v
5: 4.79
6. 4.9
7: 5.14
8: 9
PT2399
1: 5
2: 2.38 to 2.42
3: 0
4: 0
5: 2.75
6: 0.61
7: 0.88
8: 0.88
I had a similar problem with my last build. Here's what it boiled down to for me -
1. make sure the 100R is 1k - it has to do with the PT2399 locking up
2. check the 330K behind the voltage regulator - mine drifted in value
3. check the 1meg from pin 7 on the opamp
In bypass. everything was fine, but no signal at all with the effect on. I found that when I touched the back of the PCB in the output path, I got hum .
I also a - touched up my solder connections
b - checked every solder joint and trace for continuity and solder bridges
The end result was #3 above
#2 above took care of my voltage readings
Hope this helps. I was very pleased with the build once it was working.
i changed R1 (100R) to 1K and the effect becomes to work but the depth pot only acts at the end, i used a 470k one
Quote from: ppaappoo on March 19, 2011, 09:27:07 PM
i change R1 (100R) to 1K and the effect became work but the depth pot only acts at the end. i use a 470k one
This was also addressed in this thread. Some people (including me) opted to use a 100K pot because the effect was only working during the last little bit of the 470K pot rotation (the last 100K or so)
Rick however, voiced his opinion about this saying that he liked the "doubling" effect that the 470K pot gave when it was in use.
It is all in this thread.... just gotta find it. ;)
Good to hear you got it working though ;D
yes, i'll change the depth pot and adjust R1 to my teste.
So, for the next builders:
DEPTH POT ---> 100k
R1 ---> 1k to 10k or 22k
Quote from: ppaappoo on March 19, 2011, 09:34:57 PM
yes, I'll change the depth pot and adjust R1 to my taste.
DEPTH POT ---> 100k
OK OK!!! that's fine are you sure for change the 100R for that's values??? what happends??? now your pedal is in functions???
1K for R1 it's ok,you olso can use a 5k pot in series with 1k resistor to make a delay control.
the chorus works! thanks to all
I have a question, what type of wave generated by lfo?
if someone had a function generator may inject a specific signal on pin 2 of the pt2399, and compare how respond the chorus.
Quote from: ppaappoo on March 20, 2011, 02:17:11 AM
thank ppaappoo I made other PCB for probe this and other modes; my 5 pot mode!!!!!!!!!!!!
today I will inject a triangular signal on pin 2 of pt2399, but I have a doubt about the voltage range supported by the ic.
Quote from: bluesman1218 on March 19, 2011, 08:42:53 PM
Power supply 8.93V
Tester range 20VDC
TL072
1: 1.4 to 7.3
2: 2.7 to 3.3
3: 2.6 to 3.3
4: 0v
5: 4.79
6. 4.95
7: 4.95
8: 8.93
PT2399
1: 4.95
2: 2.2 to 2.5
3: 0
4: 0
5: 4.94
6: 0.55
7: 0
8: 4.55
9: 4.78
10: 0.33
Frecuency central
NE5532
1: 0.13 to 4.9
2: 2.9 to 3.2
3: 2.7 to 3.1
4: 0v
5: 4.79
6. 4.9
7: 5.14
8: 9
PT2399
1: 5
2: 2.38 to 2.42
3: 0
4: 0
5: 2.75
6: 0.61
7: 0.88
8: 0.88
Hi thanks for your input
Can you clarify what you mean by checking the 1M and the 330K? Do you simply mean checking their resistance is accurate?
I did indeed use a 1k rather than the 100R resistor mentioned.
Quote from: LaceSensor on March 22, 2011, 06:35:28 AM
[/quote]
[/quote]
Yes, that's what I meant.
it's possible a softless lfo? like a sine wave or just modify the current lfo to make it more soft on the peaks?
thanks
hello, how I can do to increase the volume of the signal delay? o maybe add a mix control.
Quote from: ppaappoo on April 05, 2011, 05:35:05 PM
Check Post #562 on this page. I'm thinking of using this version for my next build of this pedal.
Quote from: bluesman1218 on April 05, 2011, 06:13:18 PM
OK, thanks. I'm working in this chorus http://www.diystompboxes.com/smfforum/index.php?topic=90835.0
Quote from: slacker on August 11, 2010, 02:59:27 PM
Little mod for anyone who's interested try changing the resistor connected to pin 15 to 22k, that makes the wet side a bit louder and sounds more chorusy to me. It might mess with to overall level though.
Quote from: bluesman1218 on March 22, 2011, 08:01:45 AM
[/quote]
[/quote]
You tried to change the PT2399?? I change it with the original values and work fine with the new IC!!!!! some PT2399 can be failure!!!!!!!!!!!!!
Quote from: frequencycentral on April 05, 2011, 06:30:23 PM
(http://s1d2.turboimagehost.com/t1/6721324_LittleAngelMiracle-11.jpg) (http://www.turboimagehost.com/p/6721324/LittleAngelMiracle-11.jpg.html)
If you swap the positions of the caps into the resistors' spots at the mixing section, and just put a 20k pot in where the caps were, outer to each cap, and wiper to where the caps used to tie together in the board, you have an adjustable mix. I would probably 'fly' in 4.7k's from either leg and use a 10k, though to limit the amount on either side. Or breadboard and find that sweet mix... 3.3k from the dry side and 5.6k from the wet into a 10k? Just ideas for ya.
on a side note, I keep ignoring this thread when it comes up because it makes me want to build an 'Uber-Angel', a bit of tweak-ability on everything. I already have two extra knobs on my angel, don't need more... but I got etch-happy and have a spare couple boards I really want to use, and maybe together... parallel, in the same box. It would be easy to do using what I described above to mix, then just a buffer and a mix to get them back to a single signal, a level pot, adjustable delays on both... ugh. Rick, I think an Angel might get a Rack... and I still want to make another Toe Jam, gotta finish my friend's Rat, rework a couple distortion designs... my girlfriend doesn't think I love her as much as the circuits. :icon_confused:
Oh yeah, Rick, I forgot to mention that I've been having no problems firing up ANY PT with 820R so far. 680R was kind of a crap shoot... out of the batches of newer ones, I wouldn't trust one that worked to keep it up forever. My first PT's still fire up fine with the 100R, as I'm sure all yours do too.
Quote from: GodSaveMetal on April 05, 2011, 10:07:51 PM
Before building, I ordered 3 PT2399s after reading the thread. Everything works fine once I fixed these problems.
Quote from: bluesman1218 on April 06, 2011, 09:14:55 AM
I have a problem with one of my PT2399 how to fix em`??? yeah the other sound normal with no changes??? my PT2399 is wrong??? there is no effect with it the sound pass normal!!!!
mictester over at the other place has developed a little sub-circuit to prevent the PT2399 from locking up:
"The PT2399 datasheet warns about having a low value resistor from pin 6 to ground during the power-on reset that the IC does automatically. The reset lasts 400 ms. I keep pin 6 with a higher value resistor for longer than the reset period. I tried it, and the three ICs I tried it with did not lock up. With the 2N3904 I used, the delay was pretty much identical to that from a 100R resistor. "
It would appear to be verfied twice. Should solve people's problems with some PT2399 not liking this circuit.
(http://dl.dropbox.com/u/967492/Pin6Fix.jpeg)
Quote from: GodSaveMetal on April 06, 2011, 06:26:07 PM
some PT2399 don't work with the 100R resistor to ground in the pin 6, try with 560R.
Modest request :icon_redface:
Could someone post a link to a good, recent demo for this pedal WITHOUT ANY OTHER EFFECTS IN THE CHAIN?
I still feel that my build sounds VERY, VERY Subtle compared to some of the demos I have heard however, most of those were used with delays, reverbs, etc.
I used 100K for both pots but others have done the same and their demos sound FAR better than my Angel.
Quote from: Govmnt_Lacky on April 09, 2011, 04:10:09 PM
This one (not my demo) seems to be Little Angel only: http://www.youtube.com/watch?v=tsbcD4txfZg&feature=related (http://www.youtube.com/watch?v=tsbcD4txfZg&feature=related)
Rob.
I searched through the last 10 pages but didn't see anything... is there a vero layout for this?
Quote from: cgibsong002 on April 10, 2011, 02:58:58 PM
page 4! ;)
Quote from: ppaappoo on April 10, 2011, 03:55:15 PM
page 4! ;)
there was a pcb layout there but not a vero.
Quote from: frequencycentral on April 10, 2011, 05:32:38 PM
awesome thank you so much. is this the modified 'fixed' version?
Here's the version with mictester's "lock-up" fix (yet to be verified): http://www.sabrodesign.com/wp-content/uploads/2011/04/LittleAngelRev1.gif (http://www.sabrodesign.com/wp-content/uploads/2011/04/LittleAngelRev1.gif)
What is the group choice schematic to follow? Ricks original (version 2) or Earthscum's (post 141) ?
Bob
Does the polarity protection diode need to be a 4007 can it be a 4001?
Thanks in advance
It can definitely be a 1n4001. Not sure why 4007 was chosen, probably was just the part that somebody had lying around. The only difference AFAIK is the amount of reverse voltage it can take, and the 4001 is good for 35 vRMS, which is more than it will ever see.
Quote from: Taylor on April 13, 2011, 02:13:09 AM
Yup!
Hi, I have made this circuit couple days ago but it doesn't work properly. There is some change in the signal but no effect. Only when i'm turning the depth pot sound is a bit modulated. I changed the resistor from pin6 of PT2399 to 1k an then to 4k7 and only I had one repeat and nothing else. I checked for short circuits and cold joints and didn;t find any. The chip as well as the op-amp are ok. Any idea what's the problem?
If you're getting a single delay the PT2399 part of the circuit (ie the audio path) is working. Sounds like your LFO is not functioning to me.
check the speed pot connection.
disconnect the depth pot an place a led to see if the lfo works
I think you are right. Pots are fine. The led connected instead of depth pot didn't do a siongle thing. I kinda know what the LFO is but how to make it work? I think i'll use the osciloscope and if it'll showa that the LFO's not working I don't know what to do next.
Hey, I'm planning to build this soon with Earthscum's mods. Can the circuit, however, work with line levels? After I saw ADT mentioned in this thread, I'm tempted to use it as an insert on vocals :icon_smile:
So I've been through my stash of PT2399 and found one that locks up intermittently. So I'm gonna forego the wedding tomorrow ( :o ) and add the Pin 6 Fix kludge:
(http://dl.dropbox.com/u/967492/Pin%206%20Fix.gif)
The fix itself is verified but I wanna try it for myself. The layout above should sit in my 1590A Angel between the 9mm pots and the main PCB, I'm gonna bend C1 over to make the whole kludge flat. I guess also I should do a new layout incorporating the fix sometime. I think I could squeeze it so it's still a 1590A-able layout, or just 'spread out' so it's only 1590B-able. What do people think?
I thought the lock-up fix was solved with a 1K resistor off of Pin 6 of the 2399 chip instead of the 100R. ???
Then again, I cannot see the picture in your post so..... ::)
Apparently the '1k at pin 6' fix works for some PT2399............and other PT2399 will work fine with 100R at pin 6. But mictester's pin 6 fix will make each and every little PT2399 in the whole wide world work in the Little Angel. With the added benefit that the resistance to ground from pin 6 is about 100R, which IMO is preferable to the extra latency that the '1k at pin 6' fix adds.
Quote from: frequencycentral on April 28, 2011, 03:24:43 PM
Thanks for the UNIVERSAL FIX 2399!!! it is a great idea!! I have some Pt's that don't fix for the LITTLE ANGEL chorus!!! I will tried this for every Pt's!!! great!!!
Rick - why don't you use vertically mounted resistors and diode? They would still be shorter than the electrolytic, anyway, unless it's one of those extra-tiny ones.
I've also been wondering about this - I want to build the Little Angel with Earthscum's 10k+10R mod at pin 6 - can this be combined with the anti-lockup mod?
Quote from: egasimus on April 29, 2011, 07:43:42 AM
Risk of grounding against the enclosure in 1590A builds. The electrolylics are layed out so as to be bent over and layed flat.
Sure, just add the pot in series between the 47R and pin 6.
Halleluyah! Heil to the PT2399 unlocker! Heil to Frequencycentral! You're the greatest :icon_biggrin:
Hey guys... desperate need of some quick help here. I'm actually building this as a project for my circuits class. We weren't allowed to do pcb so I used the bolstad vero layout. Bypass is good, and when switched on it sounds basically exactly the same as bypass, with a touch more noise. It seems as if my switch or something were shorted from input to output but i dunno. What is this 'lock-up'? I tried reading through all the pages about the pt2399 locking up but i haven't a clue what that means. would that cause a problem like i'm having? i originally used the 47 ohm that it called for, and then switched to a 470 ohm since i don't have a 1k. I figured I'd ask here before keep switching out resistors.
here are my values
5532 (Volts)
1. 5.19
2. 4.92
3. 4.79
4. 0
5. 3.65
6. 3.09
7. 8.80
8. 9.46
PT2399
1. 5.02
2. 2.40
3. 0
4. 0
5. 1.30
6. 2.36
7. .55
8. .69
9.-16. 2.42
2N3904
C. 1.69
B. 0.00
E. 0.00
Regulator
9.46 =IN 5.02=Out
Quote from: cgibsong002 on May 10, 2011, 01:17:05 AM
Hey guys... desperate need of some quick help here. I'm actually building this as a project for my circuits class. We weren't allowed to do pcb so I used the bolstad vero layout. Bypass is good, and when switched on it sounds basically exactly the same as bypass, with a touch more noise. It seems as if my switch or something were shorted from input to output but i dunno. What is this 'lock-up'? I tried reading through all the pages about the pt2399 locking up but i haven't a clue what that means. would that cause a problem like i'm having? i originally used the 47 ohm that it called for, and then switched to a 470 ohm since i don't have a 1k. I figured I'd ask here before keep switching out resistors.here are my values
5532 (Volts)
1. 5.19
2. 4.92
3. 4.79
4. 0
5. 3.65
6. 3.09
7. 8.80
8. 9.46
PT2399
1. 5.02
2. 2.40
3. 0
4. 0
5. 1.30
6. 2.36
7. .55
8. .69
9.-16. 2.42
2N3904
C. 1.69
B. 0.00
E. 0.00
Regulator
9.46 =IN 5.02=Out
Try the 1K resistor. If that does not work, then you may want to try a different 2399 chip.
Good Luck ;D
didn't have a 1K so soldered two 480's in series... figured that was close enough (unless there's some magic number about the 1K mark). still nothing. tried two other different pt2399's... still nothing. tried a different power source, nothing..
wth??
Quote from: cgibsong002 on May 10, 2011, 02:13:04 PM
wth??
Can you post a link to the layout you are using?
I don't remember a 3904 being in Rick's circuit ???
Also, I think that at least helf of your LFO should be wobbling and it is not by looking at your readings.
Quote from: Govmnt_Lacky on May 10, 2011, 02:43:49 PM
He's using Sabro's vero. Sabro updated it with the 3904 based Pin 6 Fix.
+1, there should not be static voltages on pins 5, 6 and 7 of the NE5532. That's your problem.
I posted these voltages earlier in the thread. Note the voltages of the LFO part of the NE5532. By the way, the vero uses the 'other side' of the NE5532 for the LFO to the PCB version I built.
NE5532
1: 0.13 to 4.9
2: 2.9 to 3.2
3: 2.7 to 3.1
4: 0v
5: 4.79
6. 4.9
7: 5.14
8: 9
PT2399
1: 5
2: 2.38 to 2.42
3: 0
4: 0
5: 2.75
6: 0.61
7: 0.88
8: 0.88
9 through to 16: 2.41 (slight movement)
Yeah. I just unsoldered both IC's and the tranny so I could put in sockets. I tested multiples for all three components, with nothing changing. I also put in the 1K resistor, as well as tried it with my power supply, a battery with 8V on it and a battery with 9.25 on it. Nothing.
So yeah, I'm getting static voltages on pins 1-3. Now that I know this is an issue, where do I look to fix it? I can't find any issues on my board unless there's some damn micro traces. Which reminds me... I'm never using vero again. Looks good on paper. Sucks dick building it :icon_evil:
If you are using Sabro's vero, it's pins 5, 6 and 7 you need to get moving, not 1, 2 and 3. Check for shorts. Triple check all track cuts for micro bridges. Quadruple check all values. Make sure the IC is actually the right way around. Check off board wiring to speed pot. Etc
Quote from: cgibsong002 on May 10, 2011, 06:45:19 PM
Yeah, I hate the stuff. I don't understand people's attraction to it.
Did my 1st build on vero and couldn't get it to work. Must've been micro solder bridge? Some folks love it, not me... yet.
Govmnt_Lacky "I don't remember a 3904 being in Rick's circuit"
That was from the fix added on this page
Quote from: frequencycentral on May 10, 2011, 06:57:29 PM
wait.. i'm not quite sure I understand. My values kind of match up with yours as far as pin 1-pin 1, pin 2- pin 2, etc. go. am i supposed to get similar values to you, except 5,6,7 will oscillate? Or should all my pin values be opposite of yours.. i.e. on the other side of the op-amp. and my 5532 is definitely in the right orientation. started popping as soon as i plugged it in with it flipped.
ok my pots. looking at them from the bottom, it goes 3, 2, 1 left to right, correct? then I shorted 1 and 2 together on each pot
My PCB layout uses pins 1,2 and 3 for the LFO, Sabro's vero uses pins 5, 6 and 7 for the LFO. Look carefully at the orientation on each layout. If you've had your NE5532 in the wrong way around at any point it will be dead now.
Your pots should be fine.
Quote from: frequencycentral on May 10, 2011, 08:01:55 PM
it appears to still be fine, but i've got plenty so no worries.
i'm baffled right now about the jump across R10. My meter is telling me I have continuity across there... but the gap across my cut is huge. I haven't used the continuity function much, but is there something i'm missing here? is this my problem or is there something i'm not seeing in the circuit where there should be continuity there?
Uhh... I just noticed. On the vero layout there's an R22 parallel to the 1n4148. However it is not listed in the parts list. May have just found the culprit?
EDIT: Ok.. so after reading through every single page, I think I found my answer on like the last page. Is R22 supposed to be the 68K resistor?
EDIT EDIT EDIT: >:( >:( ??? Still no good. It has to do with this continuity I have across the 1M resistor... because if that was shorted then it would pretty much just go from input through a 100K resistor back to output (I think?). But I don't see how, I've completely mutilated that cut and it's still reading 0 on my continuity meter.
nope.. i'm an idiot. i finally looked over the schematic and realized the 1M ohm resistor was grounded from input. so when my effect is switched off the input is also grounded which is why i was getting continuity across that gap.
so now i'm still stuck. could this possibly have to do with lock-up, or not likely since i never get any chorus effect?
Quote from: cgibsong002 on May 11, 2011, 03:29:15 PM
Just keep in mind that this is NOT a CE-2 or a Small Clone ;)
The chorus effect is VERY subtle.
Good Luck ;D
Quote from: Govmnt_Lacky on May 11, 2011, 03:32:50 PM
Is it? I never thought so. Have a listen to my soundclips.
Quote from: frequencycentral on May 11, 2011, 03:46:03 PM
I listened to A LOT of sound clips however, I could never get my Angel to sound like some of them. I have consulted quite a few people about this and most of them agreed. I even went as far to ship my build to another continent and have someone else give it a go (Thanks again Chris ;D) He told me that it sounded just like his.
To me it just sounds subtle. Compared to a CE-2 or a Small Stone that is.
Can you link a particular sound clip that is a good example?
Don't get me wrong... it still has its place in my pedal chain! ;)
Quote from: Govmnt_Lacky on May 11, 2011, 03:57:33 PM
http://www.diystompboxes.com/smfforum/index.php?topic=86297.msg722615#msg722615
oh believe me... I'd know if it was working right, lol. There wouldn't be 30 pages if it sounded like a clean input.
and ok... i've literally double and triple checked the whole pedal. i ran along every single trace with a blade to make sure there were no bridges. i double checked every value and positioning of every component. I have no clue what else I can do. Has anyone verified this layout?? If so, how would I know if I maybe have a bad cap or something? Can't see what else it would be aside from those two options.
Quote from: frequencycentral on May 10, 2011, 06:59:16 PM
:icon_eek:
Hallelujah! It turns out my 100K pot was bad. Replaced it and we're all good now! My report was technically due yesterday, but whatever. Sounds good! I'm going to try dropping the 1K down to the 47R now.
hi rick!..
which layout is the best for this, page 4?..........i love it..i was looking for an alex lifeson type chorus and this sounds like its it!...(think red barchetta)
is this cool with an overdriven type sound too?..
i have a spare 2399 laying around and right fancy this!!!!!....nice!.
Quote from: deadastronaut on June 05, 2011, 08:06:38 PM
hi rick!..
Yup, page 4. Or the 1590A layout on page 9.
Although I'll be doing a new layout for LA's 1st birthday, incorporating some improvements like the pin 6 fix and seperate vref.
Cool I have 4 PT2399 on order, now I need a crap load of low profile and love voltage caps, for some reason my 450volt caps don't fit well in a pedal...
cool....so when is little angels birthday?...is it on the 28th..like mine!.it'll make a good prezzie... :icon_wink:
(did you get that printer btw?)..mines great!..
I'm so looking forward to that. The Little Angel is on my project list. Also on my layout making list though, since you'll probably want to keep it simple, and I want the mods ITT :)
Quote from: iccaros on June 06, 2011, 11:44:17 PM
... and love voltage caps ...
Where do you buy those :icon_eek:
(originally posted this in the Echo Base topic... silly me)
So I made a new layout for the Little Angel. It includes the dry/wet mod and the potentiometer on pin 6 mod. It should theoretically fit into a 1590a, too, although I haven't tried it - I can't source a 1590a box, and I don't have much time or money on my hands for the time being, either. But I think I'll find a couple of minutes to prepare and post the layout, if you're interested. This week, that is.
of course!..nice one!.... :icon_cool:
Well I was gonna save this as a surprise for LA's 1st birthday in August, but........
(http://dl.dropbox.com/u/967492/LA%20Birthday%20Edition/LA%20Birthday%20PCB.gif)
(http://dl.dropbox.com/u/967492/LA%20Birthday%20Edition/LA%20Birthday%20PnP.gif)
I wanted to keep it 1590A-able, but also add good things like the Pin 6 Fix and a seperate vref for the audio path. Here's the lowdown:
- Pin 6 Fix: D1/C16/Q2/R21/R22
I did add a little Pin 6 Fix subcircuit to a PT2399 that I know won't work without. It still has issues, but I think raising R22 to 100R and C16 to 47uF will sort it - Audio vref: R23/R24/C17 - suggested by merlinb as a way to reduce noise dumped into the older version's 5v vref supply by the PT2399
- C4 changed to 3.3nF - might be a bit darker but will be less hissy
As it's planned to be 1590A-able, hopefully all the electro caps should be able to be bend over 90
0 to lie flat against the PCB. C16 might be the trickiest.
I PM'ed this layout last week to a couple of people who expressed interest in verifying it, so you never know, it could be verified within a day or so. The layout does need a little tidy up, as I notice the pad sizes are not all the same size.
whhhooohooo...happy early birthday LA.... :icon_cool: :icon_mrgreen:
nice one rick..
Here is a little demo of my pedal. I added a 0.1uf cap across the 47uf one (in parallel) to get rid of some excess hiss.
Never mind the playing, just demoing the pedal :)
@jvanoorrt:
nice. its great to see and hear this....thanks!.. :icon_cool:
i didnt hear any hiss on ricks original recording though?....hmmm..
Well, I did have some hiss. I also placed the additional cap across the 47uf one and after the recording also replaced the 1nf cap that connects leg 15 and 16 of the pt2399 with a 3.3nf cap. Makes the sound a tad darker, more in line with the dry signal, and removes the leftover hiss.
Very satisfied with this pedal. :)
Quote from: jvanoort on June 23, 2011, 06:18:35 AM
you should be, sounds great!...i was waiting for the rat to go on with it!...mild overdrive type..sort of alex lifeson style. ;)
Ah, I might do that in another demo, but I prefer chorus in an otherwise clean signal :-)
Hello guys! I'm from Brazil, and it's my first time here. I found this topic and I liked a lot. Than, I decided to make a Little Angel. I've got the components and I build it, but didin't worked. I plugged my guitar, and befote I turn on the Little Angel, the sound's guitar is normal, but when I turn on, I don't hear any noise more. I've verificad, there is no point of short circuit. This is the model that I follow: http://imageshack.us/photo/my-images/39/111xl.gif/. I think I made a mistake somewhere, but someone but someone has already built this circuit and it worked correctly?? One more doubt, I just find this layout: http://imageshack.us/photo/my-images/4/layout1111.jpg/ . I tried to print several times, but the size was not the same as the circuit, so I did another by following links from this, only then could the actual size for the components. At least that part I know is right because I checked several times. I'd like to know how you get to print the same size as real. If I do not think the problem the way I did, I do it again with the original layout. Later I'll post some pictures of this project, other guitar pedal and also my amp, I did it by myself, all are very simple but work fine. Please help me! See you later, thanks a lot!!!
Quote from: WiLL_GS on June 25, 2011, 10:56:39 AM
Try here and then repost:
Good Luck ;D
I'm back! I found the problem, there were some poins of short circuit. I turned on and worked. But, I think that the sound wasn't good as a delay. Is someone has the same pedal build?? I 'd like to hear the sound, and compare whith the my. I 'll poste the sound of my, then you listen and tell me to know what you think of this. Here the video of my amp: http://www.youtube.com/watch?v=Y_j7QtAaLX4
I connect my guitar on this amp, using other pedal as a preamplifier(that has a fuzzy efect too), and I get a good result. Thanks!!
I'm back again!! Today I recorded the sound of the Little Angel. I don't know if the sound is normal, I think that there is something wrong. This is the link of the sound of the Little Angel(only this) : http://www.4shared.com/audio/F5Pk6aIe/4_online.html . There is more one: http://www.4shared.com/audio/K4kVwhRR/sound2.html. Now I mixed the sound of my fuzzy and the ange: http://www.4shared.com/audio/lEgE96wL/fearfuzzydelay.html. PS: I don't play guitar very well, nay, I'm very bad Oo. Now some pictures of them(I put them in a pack .rar to facilitate) : http://www.4shared.com/file/E303rpDQ/Pictures.html . All files don't have any virus!! Please tell me what you think about the sound, and the pictures to =]. Bye.
(http://i852.photobucket.com/albums/ab86/pigyboy_2009/100_1549.jpg)
Verified!
Not too hissy and works with all the PT2399's I have here even with R22<100 ohms.
I used a 2N5087 instead of a 2N3906 and two tiny 4.7uf in parallel for C16. Also went with the film 180nf caps as all the .1's I have are too big or ceramics. I socketed R22 and using a 51 ohm resistors slows down the delay time a bit more. I think I will try a 100KC (as per Slade) for the speed pot to see what if I can spread the range adjustment out.
Thanks Rick!
Cheers,
Chris
Nice to see it verified so quick, thanks Chris. ;)
Just finished my LA the other day and I'm pretty satified with it. I'm able to get lots of different cools sounds from it. I wanna give your birthday edition a go since I like this last one so much. And great job on making it super simple! Are there any other mods I can try besides the adjustable delay time and wet/dry pot? :)
could this still be a delay too!?..
So is there an updated schematic with these fixes...?
If so I might do an Onboard Pot 1590B with room for battery PCB...
i dunno about the birthday version, but i did a vero of the original and just finished troubleshooting it last night and am loving it!!!! great sounding pedal!!!!!
Quote from: Scruffie on June 29, 2011, 12:00:23 PM
Schematic for the Birthday Edition:
(http://dl.dropbox.com/u/967492/Little%20Angel%20Miracle%203.PNG)
R2 and R6 don't seem to be doing anything... did you mean to add the extra shunt capacitors to make second order filters?
Quote from: frequencycentral on June 22, 2011, 01:30:17 PM
As it's planned to be 1590A-able, hopefully all the electro caps should be able to be bend over 900 to lie flat against the PCB. C16 might be the trickiest.
I am a little confused Rick .
Is R1 just bypassing D1 ? and why ? and why isnt it on the schematic ?
Shouldnt R1 be in series with D1 ?
That last sound clip that was posted by Jvanort sounded really good,thanks for the demo.
I hope to finally get mine built next week.
OK I see it on the schematic now,doh.
So the diode is just polarity protection for the gate of the npn,and the 68k limits the current,is that about right ?
I remember now some people were having trouble with the 100r ,so thats a work around to keep the shortest delay time possible I'm guessing.
Quote from: Brymus on July 01, 2011, 12:07:59 AM
The 68k+47u causes the transistor to switch on slowly at power up, which prevents the PT2399 from going into latch up.
The diode allows the cap to discharge quickly at power down, so the circuit is immediately ready for the next power up (otherwise the PT might latch up is someone switched the power on/off too quickly)
Thanks for the explanation Merlin !
I breadboarded this,well 3 times actually double checking all my connections.
And I could not get any chorus,any warble to be accurate.
Turning the rate pot would yield a wah like effect while turning it,but turning the speed knob gave no change.
I tried different IC's,my PT2399's are a year or two old at least,I can get delay from it by increasing the 100R just no chorus.
Its like my LFO isnt oscillating I tried TL072, RC4558 and (NE5532 the only one to yield the wah sound) the rest had no modulation.
I get 2.5V at pin 2 but its stable doesnt wiggle at all.
Any suggestions ? 4 hours of this and I put everything back in the bins ,I will try again this weekend. :icon_redface:
I tried again same result,used all metal film resistors this time and a different layout on the breadboard.
I noticed the schematic says 2n3904 the PCB /layout says 2N3906
I tried with just the 100r to ground and actually had some modulation it was slight but the speed knob did affect the speed and the depth made the effect more or less noticable.
Absolutely no where near as modulated as the sound clips that are posted though.
With 2n3904 the 4148 got really hot,so tried 2n3906 the 4148 wasnt hot but still no modulation just a very slight reverb and a couple db of boost.
I seriously have tripple checked the values and connections ,just cant get it working.
Quote from: Brymus on July 01, 2011, 07:19:52 AM
It should be 2N3904 (or any NPN). Sounds like your diode is backwards.
You could also add a 10k resistor + LED from the output of the LFO (pin2) to ground, that way you get a visual check that the LFO is working (cuz is flashes...).
I finally just got back to this after getting it to work the other day with Rick's new layout. I built it with a pnp as per the pcb layout and it did fire up so I changed the transistor and it is still working the same but like Brymus mentioned it is not like the others I have here. There is no depth or lushness though all the knobs work. My PT is getting a little hot but not too bad. Gonna look at the two pedals side by side and see if I can get anywhere.
Quote from: merlinb on July 01, 2011, 07:48:15 AM
thanks again Merlin ,thats a great idea.
I will try it later when I can.
I left it on the breadboard this 4th time, ::)
OK the 10k isnt needed since its at 2.5 v ,still no flash just constant dim light.
Ive tried 4 different op amps ,two types of NE 5532,no LFO :icon_frown:
Its wired right to.
Any ideas ? anyone,maybe a diferent LFO set up IDK ?
Quote from: Brymus on July 01, 2011, 05:09:32 PM
Try different pots... you may have fried a lug? I have a non-functioning LFO section I gotta troubleshoot tonight, and probably upgrade with the new parts.
I built a new seperate LFO with a TL072.
Got it modulating between 2V and 3V,but when I connect it to pin 2 it just stabilizes to 2.5V
There is a slight modulated effect but still not anything like it should be.
Is there an internal cap on the 2399 that stabilizes the Vref ?
Everything is exact to the schematic .
Any ideas ?
I wonder... try firing it up with a 2k or larger pot (set above 2 k) with a 100R in series to ground. Then after a second or 2, turn the pot down. See if that works. I wonder if the transistor isn't trying to compensate for the warble for some reason? That's the last place I can think of.
Quote from: Earthscum on July 01, 2011, 08:43:10 PM
I used a 100k pot,that gave me a nice adjustable delay/reverb but still pin 2 stays right at 2.5 v,it only moves a couple hundreths of a volt when turning the speed or depth knobs.
If I connect my LFO to pin 6 I get a weird pitch shift tune/detune effect on the repeats though
You do need the resistor! If you just hook an LED up to the output of the LFO it will stop it oscillating!
Straight from Merlin's Pdf:
"A significant source of noise is due to the internal clock modulating the power supply rail.
The following advice may be used to minimise this noise:
• Leave the digital ground (pin 4) unconnected; it is already connected to the analog
ground internally via a ~10Ω resistance."
2 thoughts here:
First, for the people still getting noise, maybe try cutting the trace between pin 3 and 4. If it does bad things (I doubt it), then you can always solder bridge it back together. I think that ground may be for connecting to the other digital grounded circuits, such as whatever you are using the clock out from Pin 5 to drive, so that it acts as line noise canceling circuit. Another thought on that is maybe playing with a cap from Pin 4 to ground or another pin, maybe even + supply? Anyways...
Secondly, "A significant source of noise is due to the internal clock modulating the power supply rail." I wonder if the weak signal isn't coming from the supply compensating through such a large cap to ground. Maybe use a smaller cap to ground and see if the LFO signal improves? Maybe a 10uF Tant if you have one.
ETA: Just had a head-slapper. If anyone has this breadboarded, maybe try connecting the delay resistance to pin 4, leaving pin 4 unconnected from ground. Looking at the suggested circuits on the datasheet, those are the only 2 pins that are labeled as eventually terminating at a digital ground. Since there's no other circuitry that requires the digital ground's rail, we can leave it unconnected from anything else in the circuit. Thus, the digital ground and the delay resistance will be coupled together, and isolated from Analog ground by 10 ohms. It makes sense to me in a wierd way.
OK can someone check their chips with a capacitance meter?
With no power I get 3.74 uf between pin 2 and ground,definitely enough to kill the chorus effect.
As noted on the first page, 1uf will stop the modulation.
WEIRD PART:
With power on it measures 374 uf exactly 100 times more,and it varies a bit too.(the Vref might be messing with my meter IDK)
All (4) of my PT2399 are 2-3 years old from Tayda,stamped with the PTC logo.
EDIT: This was measured with nothing but the meter + IC connected at pin 2,and the rest of the circuit still set up.
Quote from: Brymus on July 03, 2011, 01:21:11 AM
In circuit your meter is registering the impedance to ground from pin-2, which includes the LFO capacitors, so it's a false reading. There is no internal capacitor on pin 2.
QuoteI built a new seperate LFO with a TL072.
How / where are you measuring those voltages?
Brymus... try the pin 4-6 fix. I know 95% for sure that it shuts up the chip up, and my SPRV is more stable. I think we've all missed a big part of the PT2399 design, isolation of digi and analog grounds. My thinking is that your chip may be sensing the warble through the delay pin and compensating for it somehow. I fixed my LFO problem, lol... new battery, but it seems like my LFO is a bit more "active" in the circuit, if that makes any sense. It's gonna take some more checking, but I think the digital ground thing may be what stabilizes quite a few of these anomalous glitchy builds that obviously should have worked just fine.
Quote from: Brymus on July 01, 2011, 05:07:23 AM
Any news on this Brymus?
I want to build the new layout so I am keeping an eye on this ;)
Quote from: merlinb on July 03, 2011, 04:06:24 AM
There was nothing connected at pin 2 ,I unhooked the LFO from the circuit when I measured the capacitance at pin 2.
So any capacitance couldn't have come from the LFO on another board that was disconnected at the time.
I was disconnecting the lead from pin 2 to my LFO and measuring the voltage there on the flying lead from the LFO board,not pin two.
With my DMM connected to that and ground it would fluctuate between about 1.8 and 3.1/3.2 VDC the speed knob would make it bounce between voltages faster or slower.
I can change the voltage divider and other resistor/s to get a greater voltage swing but am unsure what is safe to apply at pin 2 ?
Since the Vref is supposed to be 2.5V,I thought 2-3V was right.
I had a show Saturday afternoon ,and DIYSB was down all day today for me. ( ? any one else ? )
So I havent tried anything else,I am thinking anout getting new chips and trying again.
I mean I can get delay,lots of delay ,and reverb from the chip by changing the 100R resistor to ground.
So the chip isnt latched up,if its delaying right ?
I appreciate the help and reply's if anyone has any ideas ,it is still on my breadboard.(both the LA and the seperate LFO)
I will post the voltages in my next post if that will help.
Hi, is the new layout OK to build yet ? Thanks.
Archangel????? :icon_mrgreen:.....
On a second look my build of the birthday angel works but not really right and my experience with the angels is if it don't work and there are no visible mistakes is build a new one. Even if the birthday version works I didn't do a good enough job on the build to cram it in a little box either,
So I built a new one from the original 1590A and built one of mctesters fix boards and when I hooked it up using the 5 volts supply line it didn't work and made the 2399 & the 7805 hot real fast. I measured 40 mV at the output to pin 6. When I hook it up to the 9v line I am getting 29mV and everything works without getting too hot. I don't know what the math is here but maybe someone can help out here with what is going on.
Here is a little trick with the 100uf cap
(http://i852.photobucket.com/albums/ab86/pigyboy_2009/100_1699.jpg)
I shoehorned it between the two IC's and took the connections from corresponding points on the top of the board.
You can also see I socketed R1 to see if the circuit would work with out the fix....
Cheers.
Chris
@chris
did your original page 4 version work ok?..still waiting to build this... :)
Quote from: deadastronaut on July 26, 2011, 10:02:17 AM
@chris
The one from page 9 for the 1590A's definitely works with the pin 6 fix (like the one pictured above) I am not sure if anyone got the BDay version to work totally right yet. Turns out the sound out of mine is really weak compared to the one above.
@chris
me too hahahha wanting to make this REALLY!!! @@ but im so confused which the best layout and verified with no mistakes... man its hard to scan on this threadtoo many pages!! like reading a whole book!
thinking about bread boarding this, so i can tinker with it, will an 072 be ok, instead of 5532 ?...
Quote from: askwho69 on July 26, 2011, 11:52:33 AM
@chris
There might be a new layout today if this last bit of the puzzle goes well :icon_wink:
cool, :icon_cool:
edit: would an 072 be ok?..
Another Layout for the Birthday Edition! Not my neatest and 3 jumpers but it seems okay and there should be plenty of space for components.
Onboard Pots (Mounted on the back) to fit a 1590B with battery.
Unverified
(http://i898.photobucket.com/albums/ac182/Scruffie_Crow/LAChorusSS.gif?t=1311710749)
(http://i898.photobucket.com/albums/ac182/Scruffie_Crow/LAChorusPCB.gif?t=1311710727)
54.61 x 52.07mm
Enjoy.
Quote from: deadastronaut on July 26, 2011, 01:58:02 PM
cool, :icon_cool:
I got a 072 to modulate as an LFO.
But no matter what type of IC or LFO I used I couldnt get the Vref to fluctuate at the 2399.
So all I got was delay.
I am waiting to get some different 2399s and try again,because I love the soundclips.
How well does this function as a vibrato, is it worth adding pads to the PCB to lift the 10k off the input out the circuit with an SPST?
Sorry if this has been answered but yeah... 35 pages to read through.
^ no idea , but i like the idea of having the delay option/switch too...as bryan said!..if it can be done... ;).. options!..
:just got an ne5532 to try... ;)
Quote from: deadastronaut on July 28, 2011, 04:38:03 AM
which layout did you try rob?
Can someone explain what R7 - 330k does in the circuit? I dropped it to 27k then 1.2k and it still works good but is way less hissy. The only problem is I need to have them boxed up to really tell it is less noisy. Going to try to jimmy-rig another in a box today to check the 330k side by side with one of a lower value R7....
Quote from: Pigyboy on July 31, 2011, 05:34:15 AM
It doesn't do anything,* really it should have been replaced with a wire link from the start.
*in alternative circuits it would serve to reduce the output offset of the opamp, but that is no important in this case, so it just adds noise.
It will latch up sometimes with a straight jumper but seems to be all right with the 1.2k....I just want to hear it next to one with a 330k so hear the difference...gonna play around and post what I find.
Quote from: Pigyboy on July 31, 2011, 05:58:22 AM
Whatever is causing it to latch up, it isn't that resistor! It's completely unrelated to the PT.
Ok, I changed C5 & C6 to .47uf film caps and it really cleaned everything up. I jumpered R7 - 330k and on mictesters pin 6 fix I changed R1 from 47R to 1R2 and R2 from 2K2 to 68K and it has not got hot or latched up. It still has some background but it is acceptable I think. I don't have any other chorusy type boxes here to compare it to...success!
Does this make sense...
I noticed when the PT latches up if I unplug it and short the +/- of the power jack then plug it back in it works every time. So I wired the red battery terminal lug of the power jack that I am not using to the ground lug. When the power jack is unplugged the + shorts to the - and resets the chip...seems to work everytime...this is using mictesters pin 6 fix set-up on the 1590A build.
While I am thinking about it I recall people having problems with the sound being distorted or farty...I am pretty sure if you change C5 &C6 to .47uf film caps it will fix this. I have one here that sounded shite with ceramic .1's and totally cleaned up with the change. Hope this helps...
Quote from: Pigyboy on July 31, 2011, 01:30:39 PM
Yes that would make sense. Mictesters fix only works provided you leave the unit unpowered for several seconds before powering up again, since the 47u doesn't discharge enough via the diode to allow immediate reset.
Also, when a PT goes into latch up once it will usually do it again even when the pin 6 resistor is more than 1k (something inside seems to burn out and it can't drive as much current at start up any more). You usually have to make it several k after that to avoid further latch ups, which explains why increasing R21 helped.
Just finished my little angel (birthday edition). The effect works butit is very subtle like Pigyboy noticed first. Any suggestions on this?
(http://thumbnails54.imagebam.com/14341/b4f723143407023.jpg) (http://www.imagebam.com/image/b4f723143407023) (http://thumbnails51.imagebam.com/14341/e9d361143407032.jpg) (http://www.imagebam.com/image/e9d361143407032)
Quote from: tuckster on August 03, 2011, 03:23:19 PM
wonderful layout! mine sharing ? i like on board stuff
:D
Yes od course but I don't know if there are any mistakes in it. Just wanted to wait until someone found out whats the problem with the new circuit :D I only steal circuits, unfortunately I'm not able to fix designes by myself.
Made a little discovery. All my angels always turn on without latching with the depth knob maxed. Any ideas?
A quick question.. if it latches, does it make a terrible noise?
Could be that I'm latching up one of my builds when the modulation gets out of hand or the input signal gets too high (too much feedback)
EDIT: I'm not talking about a LA
What are you referring to? When my angels latch they just sound a little different without the effect....and they get hot!
Quote from: Pigyboy on August 09, 2011, 11:07:48 AM
Cool, that's the anwser I was looking for.. I was talking about a very noisy stuck oscillation kinda problem. Now I think of it.. I think I had a similar sounding issue with my belton reverb brick.. if the input level got too high it went into horrible oscillating noise.
Sorry for the interruption, please do continue...
so the one knob cheap chorus needs to be look?
Quote from: Pigyboy on August 09, 2011, 10:42:43 AM
Hello Everybody,
My name is Tim and Chris from el musico loco introduced me to this forum. I bought one of the Angel choruses he sells. Unfortunately the one I have has the latching problem described above. I found out that when the depth knob is maxed out and you put the power on the angel will work fine(every-time you do that). But when I have my favorite setting (both knobs approximately at 12 o'clock), the angel will latch up.
I have allot of contact with Chris about this problem, but he said to me it is smart to post the problem here at the forum so maybe one of you guys could help us out here.
The first thing I'm going to do is putting a new PT2399 in, because maybe this is a bad chip, who knows?
Many thanks!
Tim
Quote from: rhcp_schipper on August 11, 2011, 11:34:33 AM
...I found out that when the depth knob is maxed out and you put the power on the angel will work fine(every-time you do that). But when I have my favorite setting (both knobs approximately at 12 o'clock), the angel will latch up.
Has anyone bothered to probe Pin 2 of the PT to see what resistance/voltage range it falls into when it is working/latching?
Welcome aboard Tim! How often is it latching?
I have one here that seems to start chorusing when I plug a 12volt adapter into it and keep chorusing when I swap it right over to a 9 volt...
Quote from: Pigyboy on August 11, 2011, 12:10:16 PM
Mine keeps latching every time I put power on it, with my own settings! Even when I power it up at 12 volts the angel latches!
The only way to make it chorus is to max out the depth knob, and than put the power on. There is no other way.
After you power it on with the depth maxed then it works normally?
Quote from: Pigyboy on August 11, 2011, 02:00:20 PM
Yes! But when I dial in my own favorite setting, and power it off and back on again, it latches! So each time I power up the Angel I have to max out the depth knob, and than bring the power on to get it working properly! After I've done this I can dial in my own settings and use it.
Quote from: rhcp_schipper on August 11, 2011, 03:02:45 PM
I read through this entire thread last night as I've just received parts to start building this.
There is a fix posted here http://www.diystompboxes.com/smfforum/index.php?topic=86297.msg774512#msg774512 (http://www.diystompboxes.com/smfforum/index.php?topic=86297.msg774512#msg774512)
There's a fair bit of info about the latching issue earlier in the thread.
[edit]
Just re-read the last few posts. Curious about this.
Quote from: merlinb on July 31, 2011, 05:39:41 PM
If the fix is in the build from the start, would there be any reason for it to ever latch up? Assuming (for simplicitys sake) that the cap in the fix is fully discharged between any switching off/on (accidental or otherwise) while depth is below 1k.
All the chips seem to react different even with the fixes. Seems I read back somewhere that they work every time with a battery. Lots of the older ones seem to be fine but lately lots have been reporting iffy ones. I think Tim's discovery is on the right path....Rick!?
Quote from: sundgist on August 11, 2011, 03:29:53 PM
Things are complicated by the modulation of Vref, because that also affects the internal pin 6 circuitry, so it depends on how the LFO starts up. Best bet would be to improve the latch up fix by putting the 47R resistor in series with the emitter instead of collector, and increasing the charge time (increase the 68k to 220k say). Alternatively, put a couple of diodes or an LED in series with the emitter and eliminate the 47R resistor completely; this will increase the time before the transistor starts conducting.
Thanks Merlin,
I'll try to build a little pin 6 fix board with your suggestions. It may take me a day or two so feel free anyone else...
Quote from: merlinb on August 11, 2011, 05:18:17 PM
As far as I recall reading the latching only occurs at power up. Has anyone experienced it during use?
Supposing pin 2 was held at 2.5v until the cap at pin 6 had charged fully before letting the lfo do it's thing. Would this make things more foolproof?
My thinking is that this would allow the chip to start in ideal conditions.
Quote from: sundgist on August 11, 2011, 05:57:51 PM
That would probably work, but seems overcomplicated to add start-up circuits to both pins. The whole thing can be made fool proof if the pin-6 latch up fix is improved. As it is, it's a bit borderline. The transistor+LED version I'm using works every time even with PTs I have thoroughly burnt out in the past.
Hello you guys,
Again I had a bit of a struggle with getting my angel to chorus! Even with the little fix of setting the depth to max and then power it on wouldn't help.
Now I discovered that when I put both the speed and the depth to max it will chorus like it has to do.
Thought I share with you all.
Rick (F.C.),
I built one of these (b-day edition) for our bass player, including a few mods here and there to get the sound he was looking for.
In the process, I think I've found an error in your b-day edition PnP file. The problem appears to be R21/R22. On the PnP, they form a divider at the collector of Q2. According to the schematic, it should be R21 to ground off pin 6, then R22 in series to the collector of Q2.
I can verify your layout works with this corrected and adding in a couple of Merlin's tips. (I added his suggestions of an LED on Q2 emitter and changing the 68k at Q2 base to 100k. So far, so good.)
Damn, yeah you're right. Thanks for your sharp eyes and heads up. I'll correct it ASAP.
Corrected: http://www.diystompboxes.com/smfforum/index.php?topic=86297.msg790099#msg790099
Refresh your cookies, pour yourself another glass of milk. If the PnP says 'RH + KH 4EVA' in the top left you're seeing the corrected layout. ;)
Nicely done! Thank you, Rick. I really like your layouts.
I'd be interested to hear if this fixes the latch up issue without needing the LED on Q2's emitter.
Just wanted to say thanks, Rick, for a nice piece of work. I was sitting around yesterday playing through mine, switching guitars every so often and wondering what a lfo with several waveforms to select from would sound like in this circuit. Not that it sounds bad now, I like it as well as most other choruses I have played. Just one of those occupational hazards we all go through, wondering what mods can be done and will it add that something extra to the sound we look for. Then just for the heck of it I plugged in the P-bass. Took it into the shop today and had a couple other bass players I know try it out. All our responses were the same, somewhat along the line of OMFG!! :icon_eek: Now I gotta build a couple more. :icon_smile:
Thanks Rick
Bob
Quote from: frequencycentral on August 29, 2011, 02:38:58 PM
If the PnP says 'RH + KH 4EVA' in the top left.....
You plum. Congratulations.
Quote from: markeebee on September 02, 2011, 09:39:56 AM
Plum? Peach! Thanks, it's tomorrow. ;)
Hey!
Can anyone help me?? I made little angel using following layout:
http://www.diystompboxes.com/smfforum/index.php?topic=86297.msg726268#msg726268
but all I can get out of it is clean signal with about 0,5 s delay and some noise. Any idea what's the problem.
If it's passing audio, and with delay too, the issue must be the LFO not working. Poke about around pins 1 to 3 of IC2, and the components in that area, as well as your wiring for the two pots, orientation of C9 and C10.....
Actually there was nothing wrong except me being unable to recognize alphabet. :icon_redface: So there was 100K instead of 100R. But thanks anyway. You made me re-read the schematic. Chorus is working well.
did someone try to replace the LFO section by a different function generator, something in the idea of the EHX pulsar, square wave, sawtooth, and asymmetrical setting?
i'd be curious to know how this would sound like
Hey everybody!
Did anyone tried a substitute for the pot values? 8)
Pin 6 fix - Is this what Merlin was describing?
(http://i415.photobucket.com/albums/pp231/robmdall/Pin6Fix.jpg)
On the original the operating voltage on pin 6 was ~.7 volts. Do we need to match this voltage with the diode/LED on the emitter or can we use any generic red LED?
hey hey.
So my L.A.'s been sitting halfway built for far too long now [along with (no joke) 13other pedals :icon_redface: ]
Last package of parts arrived today thou, gonna head out and fetch em tomorrow and start finishing the projects.
So went through the thread again and as usual the info is all over the place and spread around.
Quote's below from what I reccon is the only needed info. To help next random person from reading through the
whole thread again for the X'th time.
I dont remember now but can posts here on the forum be edited "forever" ? so the first post easily can be updated
with the newest version of the schem / layouts avalible etc? that might [if possible] be a good thiing to do ;)
From what I can tell the pin 6 fix still is no unilateral successful fix?
the PT2399's acting somewhat different and reports beeing all over the place as to why and when it looks up.
But.. it does help thou?
[I got a few of em to try with (in a couple of other delay pedals) so hope Ill find one who works, just curious mostly]
Quote from: robmdall on October 25, 2011, 01:27:10 PM
I guess so, sort of anyway, check quote's below.
Quote from: frequencycentral on June 29, 2011, 04:08:04 PM
Quote from: frequencycentral on April 09, 2011, 08:53:22 AM
Hey guys,
isn't the layout wrong about C17? In the schematic, there is a 47uF cap, in the layout a 10uF. I have to say that I'm not really into this whole schematic-thing. Does it make the sound different?
I'm talking about the birthday-edition, to prevent confusion.
Greets
Yeah, you're right C17 should be 47u according to the schematic. In this case it doesn't matter, either value will do the same job, with no effect on the sound.
Welcome to the forum :)
Ok, in this case I'll continue soldering ;) Thanks!
And Thanks! :)
Hi there, I just finished putting this: http://www.sabrodesign.com/wp-content/uploads/2011/04/LittleAngelRev1.gif together and it passes audio when bypassed (duh!) and when active but nothing happens. I can hear a tiny change in the guitar tone but the knobs don't do anything and there's no chorus going on.
I tried powering on-off a few times, shorting out, powering on with the depth maxed out and everything I've read that works for some people but nothing works for me.
I've checked the circuit 5 times and it is soldered 100% like the schematic. I've made lots of pedals and all of them work.
Any update on the lock up ?
Quote from: geiristudio on November 09, 2011, 08:14:21 PM
i used that layout and it worked perfectly the first time, and 8mos later still hasnt locked up or anything. check your circuit again or try a different pt2399
Quote from: Seven64 on November 09, 2011, 08:32:40 PM
I build that layout a few weeks ago, it does lockup from time to time, but I think that my be due to the PT2399 I used (a recent order from Tayda). The layout works great though, and when it locks up all I do is power off/on and it works again.
- MikeT
I'm either changing the PT2399 or building another circuit to see if it works. I'm 100% sure that the one that's locking up is correct so it might be the IC.
Quote from: mthibeau on November 09, 2011, 10:09:04 PM
i heard an audible differance between the tayda/futurlec/smallbear pt2399's and op-amps in this circuit. i have kept the tayda in the circuit, but admittedly i havent played on the pedal for prolonged amounts of time (prolly has <6 hrs total)
- MikeT
I changed the IC, no change. The circuit is definitely right in every way and nothing is touching that isn't supposed to touch. I've tried all methods posted here and nothing works.
Is there anything I can do ? This is very strange. I know how to build a pedal and this just won't work. I've done more complicated vero layouts than this.
Has anyone had success running this thing at 6 volts? I'm thinking I'm gonna up the 78l05's ground reference with a diode and get about 5.7v out of it. Probably not worth it for the 1ms less time it will get me, but I'll gain a little headroom too I guess.
Tomorrow I'll be building my vero layout with treble pre/de-emphasis and a little extra treble roll-off to kill a little hiss. I'll post when it's verified.
I breadboarded the Birthday Edition schematic tonight, it sounds awesome! It reminds me of an old Ibanez I had years ago. Thick and chewy, with lots of character. Easy to put together from that nice schematic, too. Thanks Rick! (and thanks to PTC, Small Bear, and the everyone at the forum!)
Just wanted to say thanks to Rick and all those who have contributed to this lengthy thread. This was my third build (in this lifetime) and I finally got around to plugging it in and having a test run, having built the board a couple of weeks ago. Sound came out, which is always good, but no chorusing. :(
This is where re-reading the thread helped enormously - the more I read, the more I understood what each part of the circuit was doing. And it became apparent that I wasn't getting any LFO to pin 2. Lo and behold, I found a track-cut that wasn't... :-[ (I veroed.) Soon remedied: now I have a sweet little chorus which I am once again motivated to drill a case for! And some ideas for mods, perhaps...
Thank you all again. Here's to the next one! :)
there is an error on the layout. It says Q2 should be a 3906 pnp, but it should be a 3904 npn, correct?
Edit: guess this was updated
I've finished making a little angel ... and the sound is GREAT!!! .... thanks rick :icon_cool:
I love the way it sound :icon_biggrin:, but I have a little problem with LA chorus, sometimes willing to work and sometimes don't want to work .... when not working I have to unplug the power first and plug in back. And I did change the value of R1 to 1K, C1 and C3 already changed to 100nF, but still sometimes work well sometimes don't work anyway. anyone can give solution to my problem? ???
a few posts up there is a circuit you can add in to prevent lockup
I've read from previous pages and I found to avoid the lockup from PT2399 is by substituting the value of resistor R1, capacitor C1 and C3 with the value that I mentioned above. Is there another trick that I missed? please let me know .... ???
Don't know if anyone else has mentioned this, but if you are getting intermittent operation out of your LA, check what your power is reading. I found out the hard way on a used pedal board that someone had tried the 100r + huge cap trick for a noisy cheap wall wart that ended up with 8.1 vdc with only four pedals hooked up. At that voltage level both my LA and Echobase lfo's quit. Worked just fine when the One Spot powering the internal power strip did not get loaded down by the R/cap mentioned above. It went from 8.1 vdc to 9.54 vdc just eliminating that cludge. This worked both for the original with the pin 6 fix daughter board, and the birthday edition I built just to have everything on one board.
Quote from: cobexonly on January 05, 2012, 06:52:36 PM
here:
Quote from: bhill on January 05, 2012, 11:20:27 PM
nice info bro... I will measure voltage reading off my Power supply, and maybe I'll try to use battery first. Thanks ;)
Quote from: Barcode80 on January 06, 2012, 12:27:20 AM
here:
OMG :o. how could I miss something as important as this. thanks for telling me, maybe I'll try advice from bhill first, if not successful I will try this one. thank you :icon_wink:
how is this as compared to the one-chip chorus?
http://www.diystompboxes.com/smfforum/index.php?topic=92872.0
is the birthday edition verified and working?
Many times.
excuse me
i'm a new member here
sorry for out of topic here
sorry for my bad english
i want to ask this, please
Quote from: GodSaveMetal on March 17, 2011, 06:44:01 PM
Another oops!!!!! some tipping error labeled on C6 is 0.1uF the correction is in this layout:
(http://i.imgur.com/qGgJV.gif)
Thanks Govmnt_Lacky for your observations!!! something else please!!!!!
i want to ask C12 and C14
in my country, Indonesia, i didn't find 0.1pf
is that right capasitor? i just found 1pf in electronic component store in my town,or i must make 10 of 1pf strung together a series
and is that right R1 is 100k?
and sorry for out of topic
i was excited about 5 pot little chorus
thankyou
C12 and C14 are 0.1uF (otherwise known as 100nF).
R1 is 100R (otherwise known as 100 ohm). Not 100K!
Quote from: frequencycentral on January 25, 2012, 08:19:43 PM
woo, thankyou sir :)
@frequency central
I built your LA Birthday Edition and I cant tell why there is a very huge amount of volume loss/drop. Around 10 to 20% only of the input signal comes out at the output. Is this normal?
BTW, I used an Ipod for the input as I dont have an electrical guitar on hand. Did that affect the volume loss?
Thanks.
QuoteAround 10 to 20% only of the input signal comes out at the output. Is this normal?
No.
QuoteI used an Ipod for the input as I dont have an electrical guitar on hand. Did that affect the volume loss?
Try with a guitar before troubleshooting. Pickups are much different than what comes out of your iPod's headphone jack.
Here's mine. It's actually my first pedal build - thanks to Haberdasher on the madbean forums for the PCB.
Gutshot (yes, it's messy):
(http://img827.imageshack.us/img827/3197/gutshot.th.jpg) (http://imageshack.us/photo/my-images/827/gutshot.jpg/)
Uploaded with ImageShack.us (http://imageshack.us)
(http://img685.imageshack.us/img685/8813/36741107.th.jpg) (http://imageshack.us/photo/my-images/685/36741107.jpg/)
(http://img3.imageshack.us/img3/4533/71795614.th.jpg) (http://imageshack.us/photo/my-images/3/71795614.jpg/)
(http://img651.imageshack.us/img651/9974/57185777.th.jpg) (http://imageshack.us/photo/my-images/651/57185777.jpg/)
Sorry to be late to the party on this one, I don't get over here very often. Is anyone still making PCBs for the Little Angel?
Quote from: Pigyboy on July 26, 2011, 11:19:48 AM
@chris
Same problem. Weak output signal.
I've gotta build another one myself in a few weeks, we'll see how it turns out.
I guess I'll just wait then.. ;D
I am about to build this one
I noticed one thing, that there is no capacitor to ground between the two resistors that go to the opamp on the pt2399, most circuits with the pt2399 have it, so it seems this is only a 1st order low pass filter
(http://i331.photobucket.com/albums/l457/bacanador/little-low-pass.png)
Which is equivalent to this:
(http://i331.photobucket.com/albums/l457/bacanador/little-low-pass-eq.png)
So maybe there is an opportunity to eliminate a couple of resistors, (1 at the input and 1 at the output), since it seems to work fine with a 1st order filter
I simulated this in ltspice, to make sure and I got the same freq response
So in other words, it would look like this
(http://i331.photobucket.com/albums/l457/bacanador/little_angel_mod.png)
I put 33K, because it is a common on value, but 30K would be the right value to keep the frequency response exacly the same. I have not tried this, but seems like it makes sense?.
I hope it is OK to use Frecuency central's artwork, (partially), I'll take it down if it is a problem
I moved this to Little Angel Space Madness Mod (http://www.diystompboxes.com/smfforum/index.php?topic=96277.0), sorry for the clutter!
i'm going to breadboard this today , as it seems the most logical thing to do...
is this the final schematic with the pin 6 fix?..
http://www.diystompboxes.com/smfforum/index.php?topic=86297.msg815570#msg815570
is this a working model?...even when unplugged and plugged back in...or is there still gremlins?...cheers guys. :)
edit: hmmmm i have sound but no lfo at all :'(......ive gone over it a few times?...i'll check it over again...i hope this schematic is the working one.. :P
I built a birthday edition on Sunday, works perfectly.
Just built in last night WORKS perfect too :D Thanks so much for this wonderful circuit simple but beautiful
brilliant, cheers guys...thats good to know!....cool stuff rick!. :icon_cool:
still can't get my lfo to kick in on bread, but i'll persevere...i must be doing something weird!.. :P
btw can a rate led be attached to the opamp?...or would that mess with the lfo/sound/performance?....you know what i'm like with leds... ;D
edit got it, op amp pin 1 led.... ;)
Quoteop amp pin 1 led
Nice! I'll be adding that, too.
@garcho: yep!!!... :icon_cool:
i finally got it going on bread...cool. nice one rick...
now to mod and prod it... :icon_mrgreen:
i'd like a little more depth, any depth mods?...
Last night I lifted resistor R20 where R20 and C14 meet to make Vibrato sounds. Muddy fun! I'm guessing the angel is already maximized for optimal fidelity and minimal aliasing. Has anyone tried shifting the LPF cut-off with decent results?
^ got ya, just tried that....cool. lots of fun.
edit: just made a clip with full depth, but changing the 33k from pin 2 of the pt.... 33k/22k/10k/8.2...
http://dl.dropbox.com/u/7464107/33k22k10k8.2kchorus%20test.mp3
edit 2:
ok, been messing around again... i took that 10k vibrato mod, and swapped it out for a 33k... i also swapped the 33k from pt2399 pin 2 to a 22k...this gives a nice warble and isn't as drastic a tone change from bypass/on...
ive always noticed chorus's tend to be too bright imo...compared to bypass........anyway heres a clip... :)
http://dl.dropbox.com/u/7464107/chorustest2.mp3
i compare my LA in youtube my sounded too subtle? why is that? like yours rob its very subtle not like FC's demo at 1st page
Finally boxed mine up that I built and tested weeks ago (birthday edition).
(http://www.bouron.org.uk/marc/LA018.JPG)
Still sounds sweet. 8)
Hello Guys,
I have a little problem with the little angel chorus I bought from Chris(Elmusicoloco). The thing is that when I use the chorus in the fx loop of my new bought Ibanez TSA15H amp, the chorus seems to give a noticeable volume boost. I think the volume boost is there when not in the fx loop, but it is much less noticeable. Is there anyone else that has noticed this problem?
And the most important question (for me), is there a way to fix it? Asked chris, but he is to busy with business right now, and I don't have the patience.
Hope someone can help me out here.
Thanks,
Tim
Anyone? :icon_question:
Did you take a gander at the trouble shooting guide (http://www.diystompboxes.com/smfforum/index.php?topic=29816.0)?
Quote from: garcho on April 10, 2012, 01:14:14 PM
No, I don't. But the pedal works allright, the only problem that occurs is the volume boost when used in the fx loop.
Quote from: rhcp_schipper on April 10, 2012, 12:44:26 PM
Without hacking into the PCB, voltage divider on the output. Maybe use a 100k trimmer and set it just how you like it.
Quote from: frequencycentral on April 10, 2012, 02:07:35 PM
Can you please be more specific. As I said I bought the pedal from chris, I didn't build it.
Would be great is I can fix this problem.
Quote from: rhcp_schipper on April 10, 2012, 03:03:02 PM
Set up a 100K trimmer pot in a voltage divider format to set the output to unity.
Take a 100K trimmer and connect the PCB audio output to one lug. Attach the other lug to ground. And attach the wiper to the pedal output.
Adjust to taste. Set it and forget it! ;D
Look at how the MXR Dist+ Volume is wired here and just substitute the pot for a trimmer:
http://www.generalguitargadgets.com/pdf/ggg_dist_plus_lo.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
Thanks! Going to try this soon. Really hope this solves the problem.
Thanks again.
OK Guys, I am having a serious issue.
I built up the Perf layout (Revised for Chip hangup), and I cant find my Delay Pot Resistor anymore :(
I had it ok with the one I built before that had no revision for IC hangup, but I went back and redid it and now it works great but I cant get my delay knob back.
Any idea what I should do?
Its this layout - http://www.sabrotone.com/wp-content/uploads/2011/04/LittleAngelRev1.gif
Someone help!!!
i think its a case of either/ or...
with the pin6 fix...you now lose your delay pot...which was on pin 6.....
if you try switching between the pin6bfix and a delay pot.... it makes some strange noises...and of course locks up again...sometimes.. ::)
just the way it is i'm afraid...ive tried it....on breadboard.....
unless there is a cure for that which someone more knowledgable knows... :)
I get a kindof slap delay when I remove r8 from the circuit completely, when i add a pot here I get a semi evident delay pot, but it doesnt seem to change with even a B1m attached, you just get the same subtle like 5ms delay.
Need to get the Mix knob fixed I guess, this sucks!! I had really wanted the delay :(
Welp, here's my delayless but incredible still - Little Angel w/ Mix and Vibrato knob mods, I called 'er Squiddy :D
(http://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash3/s720x720/564169_10150806648570280_677875279_12001318_1234730713_n.jpg)
Sound demo this afternoon (CST USA)
Little? ;D
Just kidding i love it so much!
Well done dude ;)
I wish I had a little angel, mines as big as a house lmao :D
Thanks!! Audio demo about to be recorded
Here's my Little Angel, with toggle switch for space madness mode (labeled 'weird'). Kinda ugly, but sounds great. Looked a lot better before I wrote on it. :P Thanks for the schematic Rick!
(http://a3.ec-images.myspacecdn.com/images02/144/521f832f0d404d8b94cd46da8681673f/l.jpg)
Hey Garcho thats cool! I am actually about to experiment with the spacemaddness mod on a switch, how did you do yours up??
Here's an Audio demo for the Chorus section of my Squiddy :D
CHORUS
http://soundcloud.com/garlandguitar/squiddy-chorus-clean-chorus
MIX/VIBRATO
http://soundcloud.com/garlandguitar/squiddy-chorus-mix-vibrato
A DPDT toggle switch from the base of the 2N3904 through a 22uF cap to lug 1 of the 'depth' pot. Double throw for easy LED indicator. Cheers!
(http://a4.ec-images.myspacecdn.com/images02/54/ce5136983d4b49d8a3aa47f60dd0d28e/l.png)
Excellent - now Im ready, can I use an SPDT switch if I dont want LED?
Quote from: ggsmailroom on April 24, 2012, 12:29:38 AM
CHORUS
MIX/VIBRATO
Goodness amazing the sounds; like a BOUTIQUE pedal, wath changes of the RICK´s ones?? will you please a scheme; thanks!!!
Man you guys arent playing around with this Space Madness - it's an incredible Mod
I used a SPDT switch and a 10uf on this one - it sounds really awesome, push Depth to max and bring up your speed and it goes popping and squealing and the wave just goes bonkers!! Space Nightmare!! Noise lovers MUST HAVE!!!
Other side effects - Vibrato Knob on max brings out even wackier sounds on this, and the Rate slows down on normal settings when you have this engaged!! Put it to normal and your rates increase on normal settings :D
At top speed, it pops and scratches along with the beat of the rate with this kindof arpegiated pop/scratch that you can jam to, haha, I love it - on a Battery, it doesnt do this though - so fun mod, with a 9v adapter just watch out!, lower the speed for the safer range, around 70% speed sounds like an x men shooting you with plasma wave!!!
Now I need to get a DPDT and put LEDs on the Squids eyes!!!
(http://a4.sphotos.ak.fbcdn.net/hphotos-ak-prn1/s720x720/542132_10150816209435280_677875279_12027718_2133559312_n.jpg)
Space Madness!!!! :D
That Mr. Squiddy is amazing! I especially like the angry space madness eyes ;D.
This may be a silly question but here goes.
Would this circuit still work (but with a different sound) with all of the 0.1uF caps replaced with 0.082uF ones?
Cheers
That'll work just fine.
BTW, can everyone who's built an Angel prease send me a $? I wanna buy Greece.
i have it on breadboard.....so i'll send ya $0.50. :icon_mrgreen:
Quote from: frequencycentral on April 30, 2012, 01:55:31 PM
I don't get it! ???
I could send a €.
Would that be irony? ;)
@tasos: I'm no economist, but I think it's fair to say that Greece is not in the best of financial health. Expect to find it on an eBay listing shortly...
I'd be willing to shell out twenty bucks for a vintage Greece, say pre-Roman era.
Hi there, I did Google search and found this interesting picture
(http://3.bp.blogspot.com/-D57lLcrPz98/T5Xdz4wTUnI/AAAAAAAABSI/w_ZMqM60xH0/s1600/Little+Angel+Chorus+V4.png)
I tried to build one but no modulation at all. Please advice :)
Hello, I just build the project and I have a question ... hear the effect, but is very subtle, and only hear it if the potentiometers are set to 0.
If i increase the resistance of the potentiometer, the effect wears off ... From the comments I think I have a problem, can somebody help me plz?
Srry for my english.
@ stringline: Debugging sticky thread
@ Madness: Debugging sticky thread
Quote from: frequencycentral on June 14, 2012, 02:31:24 AM
Cool, this thread does echo effects now :icon_mrgreen:
hey rick,
i think i have a new weirdness to report...no, i haven't read thru EVERY post of the 40 some odd pages... but i did skim thru..
i built IVIark's vero layout, for version 4 with the warble switch and the chorus/vib switch.
can't get the puppy to work, right? so i breeze thru the thread, and check for solder joint issues, etc...can't find anything. jeweler's loupe, etc etc...
then i noticed that if i disconnect the ground that goes to the emitter of the 3904, and reconnect it a couple times, eventually the whole effect fires right up, and suddenly works great.
as soon as i power down, same thing exactly happens...dead. it will pass signal if the chorus switch is in chorus mode, but only appears to pass dry signal..switch to vib mode, and it's dead.
mess with the ground, 3, 4...maybe 5 times, and suddenly there's the warble again. it is WEIRD.
i've tried 12 different 2399's, a couple plain don't work at all, some sound great, some sound mediocre. i've got the 3 best sounding ones put aside, and the best sounding in the circuit.
but the lockup thing seems to be happening, and i've checked it over and over...why the heck would i have to disconnect the ground over and over? any ideas?
could it be because i don't have it boxed yet or something?
i could really use a clue here... anybody got one?
gonna keep messing with it..thanks in advance, if anyone can figure it out!!!
wellp, i boxed it cuz i like it so much, but it's got issues. i tried messing with the 3904 as i read in the thread, changed the 68k to 220k....that seemed to help a little bit.
tried replacing the 47r resistor from the collector with an led from the emitter...couldn't get it to do anything that way, so put it back.
if i plug in the input jack a couple times, it will catch and work fine until it's powered down, but then if i plug it in again, i gotta plug it in several times again.
really freakin' weird...any other ideas anyone can point me at? thinking about adding another switch so i can ground/unground the ground connection...that seems to be the issue, but i'm too newb or too stupid to figure it out.
once it's working, it's absolutely astounding...beautiful toney cct, i love the warble control...it makes it sound a lot like my old clone theory sorta..
lush. sounds good even into fuzz!! ;)
Hey Jim, did you catch any errors on the IVIark layout? I seem to remember some bug fixes on his forum.
hi rick,
i went thru the whole thread at Mark's forum (alot easier than this one, a lot shorter! ;) )
i saw the bugs in the first layout he posted, but i built the full-gospel one with the anti-lock fix, as well as the chor/vib and wobble/warble switches.
i DID change the 68k resistor to 220k as merlin suggested, and tried lifting one side of the 47r resistor and replacing with an led as suggested by merlin, but then couldn't get it to work at all.
it's REALLY weird... plug it in, dead soldier unless in chorus mode, where you can hear the dry signal and it being buffered. all the voltages seem to be in the ballpark of everything i've looked at.
i tried 12 different 2399's, one was bad, all the rest worked, tho some sounded better than others. mess with the ground 4-5 times and it comes on. every time. sounds spectacular!! once it's working, you can kick the effect in or out with impunity. i left it on all nite to see if it would mess up, worked fine this morning.
sure enough, disconnect it, reconnect it and power up, dead soldier. unplug the input jack 4-5 times, and sure enough, it works again. it's almost like ya have to "trick" the chip into working...
too much mojo for the kid to figure out here!! ;)
every thing i've tried with pt2399's seems to have some kind of issue, which is a drag, cuz when they work they sound great.
oh, almost forgot...
one thing i did find? if the effect is noisy, change out the 7805....on mine, some of the voltage regulators in my junk box made obscene amounts of noise, even ones that "seemed" to be working well... the bad ones caused hiss, weird intermittent whooshing noises, and in some cases metronome like ticking.
a good 7805 (read: brand new) fixed that.
so if anyone is having issues with noise and using junkdrawer recycles or pulls, try a fresh one.
peace!
FIY, the new Mad Professor Electric Blue Chorus employs a PT2399 as well.
Hello fellows. My first post here. Been lurkig for a while, though :icon_smile:
I've built this one, and my lord, is it sweet sounding. I've only got two problems with it:
1: the 3pdt switch pop! All the methods that I know have failed so far. I've added a "soft start" RC network for the LED, and pulldown resistors. I assume that's the role of R19, right? Well i've tried switching it for a 10M one, to no avail. Tried adding extra pulldown resistors to the input and otput. So far, I only built boosters / overdrives / distortions / active EQs, and tremoloes. Always tackled the pop problem. This one made me give up.
Ah, if it makes any difference, I did some mods to the original schematics: added a blend pot instead of R18, a delay pot instead of R1, decreased R13 to some.. 1k, I think, to get a deeper depth. A word of advice, anyone?
2: Some hiss showed up with the delay at max (50k pot), anyone tried this and did get rid of he hiss?
cheers.
did you try a different 2399? some of them seem to amplify switching transients.
they really seem to have a crazy wide set of tolerances.
perhaps (newb alert) a big ass cap, say, .22 or so, in parallel with the pulldown resistor will help?
I did try 3 other. No difference between them that I could spot. I also did try your cap-across-the-pulldown-resistor mod, although I had no idea of what this could be aimed at achieving. All i (think) I did was to direct a considerable part of the signal to ground.
@pinkjimiphoton:
try to add a electrolytic cap (200uf-2200uf), across the input terminal of the 7805 and ground. You might also try two 0.1 caps from the input and output terminals to ground (the central one). I found one day that while 7809s and 7812s can 90% times be plugged in without any extra caps, the 7805s tend to have issues, although the output voltage looks just fine. Hope this will work for you.
diggit. i just remember using big caps in a footswitch years ago that was switching wall voltage in a homebrew leslie controller i had built.
thanks for the headsup on the 05's, i'll remember it if i run into a problem. ;)
Right, it was you writing about the 05 as well. Thought I was answering to someone else's post. Long day, it was :icon_wink:
First post here so be gentle... I made a little angel from this layout : http://freestompboxes.org/viewtopic.php?f=13&t=10276
I'm losing my mind over this thing. I know i built everything right because I've gone through with a fine toothed comb many times looking for mistakes, but when i power it up its like an overdrive/distortion chorus.
Does anyone have any ideas what this could be?
I haven't read every post because its 40 something pages, but what I've read hasn't mentioned anything about overdrive/distortion being a problem.
if someone could help that would be awesome.
didn't realize i couldn't link to fsb... lets give this another try
(http://i210.photobucket.com/albums/bb292/frequencycentral/LAC1590APCB.gif)
Quote from: haveyouseenhim on July 21, 2012, 12:50:50 AM
Your first step is to realise that you did something wrong. ;D
Got voltages for us?
pt2399:
1 5
2 2.45
3 0
4 0
5 2.16
6 .66
7 .82
8 .84
pins 9 - 16 are 2.45
5532:
1 through 3 fluctuate
1 1.3 to 0
2 3 to 2
3 2.5
4 0
5 4.76
6 4.36
7 7.44
8 8.45
i was expecting that answer... i felt confident that i followed it as it shows. but apparently i goofed
any help would be greatly appreciated.
Built it for a friend the other day. Absolutely gorgeous sounding....gonna have to make one for myself now (:
:icon_cry: Please help me Rick :icon_cry: I really want this to work.
Your voltages:
Quote from: haveyouseenhim on July 21, 2012, 07:16:59 AM
pt2399:
1 5
2 2.45
3 0
4 0
5 2.16
6 .66
7 .82
8 .84
5532:
1 1.3 to 0
2 3 to 2
3 2.5
4 0
5 4.76
6 4.36
7 7.44
8 8.45
My voltages:
Quote from: frequencycentral on November 03, 2010, 03:28:41 PM
Here are voltages just taken from my Little Angel, which sounds the same as the breadboarded version I did you soundclips on. Speed at 3 o'clock, Depth at 12 o'clock:
PT2399
1: 5
2: 2.38 to 2.42
3: 0
4: 0
5: 2.75
6: 0.61
7: 0.88
8: 0.88
9 through to 16: 2.41 (slight movement)
NE5532
1: 0.13 to 4.9
2: 2.9 to 3.2
3: 2.7 to 3.1
4: 0v
5: 4.79
6. 4.9
7: 5.14
8: 9
So it seems that your voltage at 5532 pin 7 is really high. Which would suggest either a solder bridge (migh be microscopic - scrape between the pins), or an error in the value of R7 or R15.
Ah haaaa! It was r15. I used a 10m on accident. The blue and green striped om my resistors look so much alike. I wish there was a way i could thank you besides typing these words. But thank you so much. It sounds great :icon_surprised: Ive built quite a few effects, but i'm new to the whole stompbox forum thing. So its really awesome to talk directly to the designer.
My pleasure. Though I'm not a designer I'm a pretengineer...
BTW, I've got a few spare LA PCBs available @ £10 GBP each (including shipping).
you're an engineer under the age of 13? wow lol....oh thanks, i prefer to etch my own. its more satisfying that way. I have a veggie garden and the guy next door owns a plant nursery and is always trying to sell his pre-sprouted things to me. I guess he doesn't get that i like to start with nothing but a seed. Hmm i think i just got a little philosophical :D
I have an idea for a mod now that i made that pleasant mistake. I'm going to put a switch on r15 that switches between 1 and 10m. I'm going to label it good/evil. Someone try this and tel me what you think of the tone.
So through the magic of ms paint i made this:
(http://i1267.photobucket.com/albums/jj545/haveyouseenhim/LAC1590APCBwithheaven-hellmod.gif)
Basically its just switching between the 1M and 10M and the red and blue leds. Since one led draws more than the other the switch just connects the two positive leads making them steal power from each other. I'm probably going to change it to a tpdt switch so i can add some clipping diodes to smooth out the randomness of the distortion. Let me know if any of you see anything wrong with what I'm doing.
Edit: i forgot the led resistor
Hello @ all,
I´m Zottel from germany, and I´m new here at the Diystompboxes.com, but i´ve built many effects the last time.
If you are interested you can visit my Blog: http://juicypedals.blogspot.de (http://juicypedals.blogspot.de)
Now I need to build The PT 2399 little Angel "Birthday edition", but I have some trouble with the scaling when i print the PCB because it is to big.
I want to use the layout from Page 33:http://www.diystompboxes.com/smfforum/index.php?topic=86297.660 (http://www.diystompboxes.com/smfforum/index.php?topic=86297.660)
Have anyone a Adobe PDF Document with the PCB or can me help in other ways?
With kind regards, - and sorry for the bad english,
Zottel
Hi all,
Just built a LA from Rick's excellent pcb. However, I must have done something wrong as it's not working right. I'm not getting much of a chorus effect, rather a harsh loud fuzz on every note. The pots don't seem to do anything, and occasionally the PT2399 locks up. I've probed around and didn't see anything blatantly wrong. My voltages are:
NE5532:
1. 3.06
2. 3.14
3. 2.82
4. 0
5. 3.40
6. 4.27
7. 4.70
8. 9.16
PT2399:
1. 5.00
2. 2.39
3. 0
4. 0
5. 5.00
6. 0.72
7. 0
8. 4.57
9. 4.82
10. 0.38
11 2.42
12 2.42
13. 2.42
14. 4.57
15. 2.42
16. 2.42
Thanks for looking!
Yours:
Quote from: karter2000 on August 14, 2012, 03:37:09 AM
NE5532:
1. 3.06
2. 3.14
3. 2.82
4. 0
5. 3.40
6. 4.27
7. 4.70
8. 9.16
PT2399:
1. 5.00
2. 2.39
3. 0
4. 0
5. 5.00
6. 0.72
7. 0
8. 4.57
9. 4.82
10. 0.38
11 2.42
12 2.42
13. 2.42
14. 4.57
15. 2.42
16. 2.42
Mine:
PT2399
1: 5
2: 2.38 to 2.42
3: 0
4: 0
5: 2.75
6: 0.61
7: 0.88
8: 0.88
NE5532
1: 0.13 to 4.9
2: 2.9 to 3.2
3: 2.7 to 3.1
4: 0v
5: 4.79
6. 4.9
7: 5.14
8: 9
So it seems you have some way-off voltages at:
PT2399 pins 5, 7, 8, 9 ...you get 5V on pin 5? Pin 7 being ground is causing an issue elsewhere.
NE5532 pins 1, 2, 3 ...particularly concerning as these should be moving, which says the LFO isn't running.
NE5532 pins 5, 6, 7 ...pin 5 is way off, fix that and 6 and 7 might fall into line.
Solder bridges and/or incorrect resistor values is my guess.
Quote from: spampa on July 31, 2012, 09:58:41 AM
Hello @ all,
I´m Zottel from germany, ..............................but I have some trouble with the scaling when i print the PCB because it is to big.
Hi Zottel
die Maße sind 54,7x34,05mm
Kannste mit DIY Layout testen (Raster auf 2,54 stellen und Zeichnung (BMP) importieren...
Sorry for german, but this will go quicker then...
Quote from: frequencycentral on August 14, 2012, 04:12:18 AM
I've checked the values of everything, and there are no solder bridges. I'm guessing my build is really jacked beyond fixing. Probably put it down before I smash it into a thousand pieces on my workbench.
Ah, the old 'smash it into a thousand pieces on my workbench' debugging technique, never fails to satisfy. :icon_mrgreen:
Yeah, I promise I won't do anything drastic. I've learned to come back to debugging after a bit of a break. ;D
Thanks for your help Rick!
Got the same fuzzbuzz lawnmover action from mine sadly :icon_frown:
Thanks for the voltages Rick, will check em out again...
Quote from: karter2000 on August 14, 2012, 01:08:08 PM
Mine is in a big box of unfinished pedals :D time to get it out again I think I can fix it now......
Hi everybody, I have finished my little angel chorus but I think the output volume is too small. I want to push up the output gain so witch resistor I have to change? Thank for your answer!!
Quote from: Jerem on August 20, 2012, 09:17:19 AM
The output should be at unity with the input. Perhaps you have an error? How much too low is it? You could try taking voltages from your build and comparing them to mine, that way you may be able to identify where the error occurs.
Thank for your answer. The sound volume is the same when I push up the volume of my gear.
I just test the Ic of the circuit :
NE5532
pin1 : 5.14v
pin2 : 4.78v
pin3 : 4.62v
pin4 : 0.5mV
pin5 : 8.74v
pin6 : 2.9v
pin7 : 2.95v
pin8 : 2.82v
PT2399
pin1 : 4.94v
pin2 : 2.38v
pin3 : 0.5mV
pin4 : 0.5mV
pin5 : 2.48v
pin6 : 0.433v
pin7 : 0.847v
pin8 : 0.849v
pin9 : 2.38v
pin10 : 2.38v
pin11 : 2.38v
pin12 : 2.38v
pin13 : 2.38v
pin14 : 2.37v
pin15 : 2.38v
pin16 : 2.38v
Hi to all, this is my first post.
First of all sorry for my english, i'm italian.
I made an eagle layout and board of the project, here we are:
(http://i47.tinypic.com/11qtw14.jpg)
(http://i49.tinypic.com/23mq90z.jpg)
In the next days, i made the pcb and all the rest.
If someone is interested to the Eagle files, i can post on the forum.
Bye.
Axeltrance
I finished and it works, but I've some issues
1) When I turn on the pedal I hear the oscillation of LFO in my amp
2) I hear a strange response to low frequencies (low E) with some setting of Depth and rate.
Could you say me something?
the point 1) is really important to solve.
@Jimi P
Quoteif i plug in the input jack a couple times, it will catch and work fine until it's powered down, but then if i plug it in again, i gotta plug it in several times again.
I have the exact same issue! Figured I made a mistake somewhere so I'm about to put it back on the breadboard and try again, probably with some mods and somewhat controllable space madness (hopefully). Any up luck with the lock up?
Is it possible to voice this pedal for bass? I have some ideas but Im not really certain of anything. correct me if im wrong but following the revision 2 /earthscum mod schem i would have to increase the values of the .1 caps. Would I need to increase/adjust the value of the caps/resistors on pins 9-16 of the 2399?
The caps between those pins on the PT2399 are part of a complicated filter. Changing their values will do more than a simple RC would. I've had many hours of fun experimenting with those values. Do you have a breadboard?
Unfortunately i dont. I really should invest in one. when i buy the rest of the parts i do some experimenting myself. so what were your observations on changing those values?
I was reading through the thread some more and found this, which i believe tells me i should be ok following that schem and the delay mod.
Quote from: Earthscum on August 29, 2010, 08:52:43 PM
Aye. I've used it at 2 shows. For bass, you want to increase the delay a little bit for sure. I like the 5k pot, but already had the 10k installed.
For bass, once you find that perfect setting for you, you go from flat to gigantic godly overtones!
I used a TL072, hence the 100k pot in place of the 470k. I haven't un-ductaped my pedal to pop in an NE yet, so can't report on that. I rode my bike to the store to buy parts, came home and had it boxed and working and ready in 5 hours, with only an hour to spare before we had to be at the bar. Used it in an outdoor setting at the last one, and it is awesome. If you are outdoors, you can increase the depth a bit more without busting through over the top of the guitars.
And, lastly... absolutely no bass cut! I breadboarded mine with .022's in the audio paths, but I built it with all stock parts plus my mods to box up. I have a "super-fat" DS-1 that is basically my big OD. It increases the bass without destroying too much of the punch, still has the DS-1 grit, but bigger. This goes in front of my LA, and I only get the most minor bass cut out of it, which actually just seems to add to the overall tonal qualities.
Of all the things I tried, the ONLY one necessary for bass is the delay mod. Just a 5k pot. I wired mine so I could (next build) use the stock jumper pads from the layout. I just used a DIP strip on this one, but kept mods simple to work with the stock PCB.
Hello everyone. I'm trying to get this layout working with the earthscum mods
http://www.diystompboxes.com/smfforum/index.php?topic=86297.560
bypass works, engaged I get a faint guitar signal with no effect and I have 100k in R1
I'm hoping someone can look at these voltages and know whats wrong
Tim
NE5532
pin1 : 3.08-3.325v
pin2 : 3.151-3.170v
pin3 : 3.025-3.055v
pin4 : 0V
pin5 : .597v
pin6 : .877v
pin7 : 1.304v
pin8 : 9.5v
PT2399
pin1 : 5.02v
pin2 : 2.415-2.417vv
pin3 : 0V
pin4 : 0V
pin5 : 2.822v
pin6 : 2.396v
pin7 : .740v
pin8 : .812v
pin9 - 16 : 2.411-2.415v
Quote from: BarBandit on December 02, 2012, 09:21:33 PM
Tim
From my own dealings with this circuit I've learned that reversing the in and out has this effect :icon_redface:
Quote from: Perrow on December 03, 2012, 02:45:49 AM
Tim
Double checked it and I have it wired correctly
Had a loose wire and reflowed some solder now
bypass works, engaged I get a faint guitar signal with effect and I have 100k in R1
and all controls seem to work except the level pot
Tim
NE5532
pin1 : 3.08-3.325v
pin2 : 3.151-3.170v
pin3 : 3.025-3.055v
pin4 : 0V
pin5 : .597v
pin6 : .877v
pin7 : 1.304v
pin8 : 9.5v
PT2399
pin1 : 5.02v
pin3 : 0V
pin4 : 0V
pin5 : 2.822v
pin6 : 2.396v
pin7 : .740v
pin8 : .812v
Got it going.
I made the pcb with a cnc router and it didn't complete a couple traces
don't know how many times I stared right at it and didn't see it
Sounds very cool but is pretty noisy even with the delay turned down
is there a way to filter out most of the noise?
I've tried taking out the 2399 and the noise remains
It's pretty loud hissing thats not coming from my guitar(volume down on guitar)
Tim
I'm not a particular fan of the parts placement in that layout. C8 should be closer to pin 1. I would put a 100nF cap in parallel with it, too.
Try lifting Pin 4 from ground, by bending the leg before placing it in the IC socket. I've had problems with it working like this, but other people report a slight improvement in noise when you allow digital ground to flow through the internal 10 ohm resistor between pin 3 and 4.
a 100nF cap in parallel with C11 wouldn't hurt either.
is it in an enclosure already? once it's in a grounded enclosure, that will help a lot.
maybe shielded wire would help, too.
Quote from: azrael on December 04, 2012, 09:48:25 PM
Awesome thanks I will try your suggestions and report back
it is in an enclosure already
Tried your suggestions and had no change
I guess this is just a noisy circuit. Too noisy for anything I would use it for
What would be a better choice for a chorus?
Is the zombie chorus quiet?
Oh, it sucks that it didn't improve. Have you tried a different PT2399? just wondering.
You could try building a discrete 5V regulator that's better than a 7805:
http://valvewizard2.webs.com/PT2399_Data_Notes.pdf
on page 2.
I forgot to mention, I usually use ceramic multilayer caps for the 100n decoupling, they have better qualities for this purpose, I've read.
No experience with the Zombie.
Recently I've been going way over board with my power filtering but the results of getting zero hum from what are crap but cheap wall warts has been a good thing.
no really here is the power filter that goes on the front of every pedal I build... Vin > polarity protection Diode(negative side faced toward V in) > 100 resistor > 1000uf cap to ground > 1nf cap to ground > V Out to circuit.
try the above if you can... sometimes I find the hiss from really bad power supplies doesn't drop till you get to like 220uf or even 470uf.
Quote from: BarBandit on December 05, 2012, 06:43:52 PM
I guess this is just a noisy circuit. Too noisy for anything I would use it for.
It's not a noisy circuit, it's a basic op amp buffer/boost. The other half of the op amp is a standard LFO. Something is wrong with your layout or components.
Have you built this layout?
pretty noisy for me.
QuoteHave you built this layout?
I've built the circuit from the schematic a number of times, no noise. Sorry, I assumed you meant the circuit was faulty, not the layout you're using, my bad.
no worries, was just looking for confirmation that this layout was noisy
I can't seem to do anything to get rid of the hiss
Quote from: BarBandit on December 10, 2012, 03:43:08 AM
What kind of power filtering are you using?
Hey guys. I have a copy of the birthday edition layout on page 33 post 644, but I cant find a pdf. I'm having trouble figuring out the scaling.
Anyone have dimensions for the board, or a dpi I can set it to for proper printing?
If you have a drawing program such as Inkscape (free), open the pcb art there, set the background grid for 0.10 inches, scale the board so that the IC pads match the 0.10 inch grid. Not sure if there is a PDF available, someone else did a really nice layout for the Turkey Shootout contest, again not sure whether ther's a PDF.
dave
I got it. I'm using Gimp. Opening the image it seems to set it to 72 dpi, I changed that to 200 dpi, and the board prints perfect. Already etched and drilled. :D
I believe I read through most of the thread, and I'm hoping I can get a little more info.
- Is the BOM in the "birthday edition" on page 33 of the thread the latest? It look like it is, just wanna be sure.
- Can I get ADT by just turning down the speed and depth, with the latest BOM?
- And lastly, has anyone tried to put 4-5 pots in the 1590a, because I want to add the delay and mix pots back in. I'm sure I can get 4 in a 1590a... maybe even level, though if it puts out unity gain, then I don't have much need for the level pot.
Thanks for the great project, I'm so hooked on 1590a builds lately..... Now if anyone could just come up with a good 1590a verb.
Hi all,
Firstly, big props to Rick for this, thank you so much for putting the time in and giving us all something fun to make like this!
Here's the question:
I'm following Sabro's great Vero layout, but haven't got a 330K resistor for R7. Is this a pretty crucial potential divider or something? Or would I be okay to sub in a 220K or 470K (which?). I honestly don't know enough about the circuit on this one :s
EDIT:
SOLVED IT MYSELF! This resistor happens to go straight over an extra line of track I left in the vero board. Hence easy enough to add two resistors (100K + 220K) to make a very close 320K.
Sorry for the unnecessary message, this is now just a "watch this space for another Little Angel project" message
Gut shots and enclosure photos to follow shortly ;)
George
Finished!
(http://s13.postimage.org/rqcpuntkj/pedal_front.jpg) (http://postimage.org/image/rqcpuntkj/)
(http://s7.postimage.org/x2ri24zaf/Pedal_Guts.jpg) (http://postimage.org/image/x2ri24zaf/)
Ugly as anything, but it is my first pedal, and I'm amazed that it works after only a little debugging. All the ground and live wires are different colours, the board has a few crazy diagonals on it, but ultimately it works perfectly!
Problems along the way:
1. Enclosure too small, so everything is insulated with plastic and stickers :s
2. Didn't have the right resistor at one point, made it with two in series, but made a complete mess of the board while doing so.
3. Made a solder bridge across pins 13 & 14 instead of pins 3 & 4 (confused when looking at vero layout upside down I guess)
Most useful things
1. Nick D's voltages: (very similar to mine though mine are all very slightly higher)
IC 1 1) varition from 1.4 - 7.4 ( lo-speed ) to 2.5 - 3.5 ( hi-speed )
2) 4.87 V
3) 4.77 V
4) 0.00 V
5) varying 2.5 - 3.5 V
6) " 2.5 - 3.5 V
7) " 1.4 - 7.8 V
8 ) 8.56 V (normal output of my PSU )
IC2 1) 5.02 V
2) 2.5 slight wobble
3) 0V
4) 0 V
5) 2.22 - 2.5 V (didn,t spot the small variation before )
6) 0.75 V
7)0.66 V
8 ) 0.66 V
9 - 16) all as pin 2 , i.e.minor variation around 2.5 V
2. Harald's vero layout and website: http://www.sabrotone.com/?p=332 (http://www.sabrotone.com/?p=332)
- tons of useful guides/ advice/ links etc. on that website
3. A new half decent soldering iron :)
Huge thanks to Rick for this, awesome sounding pedal. I'll upload recordings tomorrow if I have time.
Hi m8s
got a couple of questions/issue with this little gem!!
I'm talking about the very first version in this thread, build a couple of them all work good, nice chorus effects and controls act as they should, voltages look good.
First issue, cannot get rid of the hiss, I've red the whole a thread couple of time, and applied almost all the suggestions found, probably some of the Anniversary version too.. ;D (and probably understood 1% of it! :icon_redface:) The only one that worked greatly is the 0.047uF between out and gnd no hiss anymore, though there's a significant drop in signal, something like 20%. Other caps values don't produce drop in signal but don't cancel the hiss.
I've tried to recover a little bit of signal decreasing the 10k res at the opamp output, no way.
So what are the right resistors, if any, I can change to recover this 20%....
Second issue, I've tried to make it in a 1590A encl with light emitting border, using an ultrabright Blue LED hooked between OpAmp Pin 1 and gnd, to flash in time with the Rate, in this case I almost completely loose the chorus effect until I increase the Led resistor to almost 100k, in this case the LED lights up just a bit! so no use of it...
Any solution to this ?
Thanks as usual for help m8s!!
Ciao
I finally got around to putting together a Little Angel, the Birthday Edition. Stock it's ok, but a little dissapointing. The speed pot is only useful through the second half of it's rotation, and the depth pot through the very end. I think I'm going to switch to a b100k on the depth pot. Have you guys had the same issue with the speed pot? I might try a b50k instead of 100k. Overall, even with the depth dimed, it's still pretty subtle compared to a Small Clone or CE-2. With my CE-2, I can dial back the depth if I need to, but with the LA I can't dial in anymore, and some of the clips posted sound quite a bit more chorus'd than what I'm getting with any PT2399. After skimming through the entire thread, it sounds like some of you guys have that issue and it's not nearly as lush as the clip on page 33.
Quote from: mremic01 on January 16, 2013, 02:17:11 PM
Hi mremic,
I'm gutted I couldn't record a sound clip before giving my LA to my cousin (21st present), but I had some pretty deep chorusing all the way up, and pretty usable speed control across the whole range (0 to 4 pretty slow, 6-8 useful and 9-10 a bit intense).
Perhaps your speed control is indicative of something wrong? I'm sure you've checked your voltages against the ones Nick D made? (I repeated them a few posts ago)
As for the depth control, there's two schools of thought on it:
1. No one's LA has depth that does much before about 50% but it having the effect on below this does make your tone warmer, and slightly doubled (not volume wise, just like to guitars playing at once) rather than chorusy
2. Those that don't like that so much have done something along the lines of 250K in series before lug one of a 250K pot: This gives you the latter stages of the depth control, but makes your total sweep the equivalent of anyone else's 50% -> 100%
Keep us updated!
Quote from: arma61 on January 14, 2013, 08:34:10 AM
Ciao
ok, just to report I totally got rid of the hiss with a 3n3 cap between pin 5 and gnd, no signal loss!!
Still waiting a suggestion for my 2nd issue :icon_mrgreen:
Thx
Ciao
Hi, can anybody send me correct voltages of ICs for little angel birthday edition?
From Rick a few pages back:
Quote from: Here are voltages just taken from my Little Angel, which sounds the same as the breadboarded version I did you soundclips on. Speed at 3 o'clock, Depth at 12 o'clock:
PT2399
1: 5
2: 2.38 to 2.42
3: 0
4: 0
5: 2.75
6: 0.61
7: 0.88
8: 0.88
NE5532
1: 0.13 to 4.9
2: 2.9 to 3.2
3: 2.7 to 3.1
4: 0v
5: 4.79
6. 4.9
7: 5.14
8: 9
These voltages that you posted are from little angel basic edition, i thought birthday edition has little different voltages, im beginner ,so i dont know much about electricity :)
i have changed 470K to 100K, my problem is i have very subtle/no chorus.
My voltages :
PT2399
1: 4.92
2: 2.45
3: 0
4: 0
5: 0.21
6: 0.86
7: 1.08
8: 1.21
9 through to 16: 2.46
NE5532
1: 1.47 to 5.3
2: 2.73
3: 2.45-2.9
4: 0v
5: 3.14
6. 3.95
7: 4.35
8: 8.50
I will be glad for any advice, thanks.
Edit: ignore this post, got it working. was either a tiny solder bridge or a slightly-loose cap. thanks anyway! time to jam :)
hi,
my signal seems to split but not oscillate. if that makes sense. accidentally moving the floating bridge on a guitar seems to compensate for what the Little Angel isn't doing.
whilst debugging opamp A earlier, there must've been a short between vertical resistors or something, as i heard the LFO clicking (i think), but now no sign of it at all. i've swapped out PT2399 for a known working chip (and the one i removed works in a different circuit), so it doesn't seem to be that.
voltages seem okay except for the 2nd half of the TL072 i'm using - which, correct me if i'm wrong, is part of the LFO, no...? the first 4 pins function fine, but i'm picking up 2.9v on pin 5, 1.35 on 6, and up to 7.6 on pin 7. pin 8 is also fine. a lot of seemingly-random fluctuation, too, with no obvious bad joints.
any idea where i should be looking? maybe that now-elusive clicking sound from earlier could offer a clue.
cheers!
What's the latest greatest version of this pedal? Schematic?
diysb wiki (http://www.diystompboxes.com/wiki/index.php?title=Little_Angel). I recommend breadboarding this and messing with it to taste, if you play mostly one guitar through one amp. Lots of fun mods, too.
Built this on strip board. Really like it. Thanks for the design to who is deserving.
Quote from: garcho on May 13, 2013, 11:42:26 PM
Cool, thanks!
What's this "Birthday Edition"?
This is my build. Based on the "birthday edition".
Mods include a mix/blend pot, 100K for depth (along with a 10K instead of 33K at pin 2).
(http://i1329.photobucket.com/albums/w553/ViktOr_Molnar/DSC01815_zps621614b0.jpg) (http://s1329.photobucket.com/user/ViktOr_Molnar/media/DSC01815_zps621614b0.jpg.html)
(http://i1329.photobucket.com/albums/w553/ViktOr_Molnar/DSC01807_zps53cbb6f4.jpg) (http://s1329.photobucket.com/user/ViktOr_Molnar/media/DSC01807_zps53cbb6f4.jpg.html)
(http://i1329.photobucket.com/albums/w553/ViktOr_Molnar/DSC01804_zps1352a926.jpg) (http://s1329.photobucket.com/user/ViktOr_Molnar/media/DSC01804_zps1352a926.jpg.html)
Quickly built my second LA those last 2 days...Great effect!
Built using standard version, vero by Sabro (it should be at page 19 if I remember correctly...) - I went straight with the 100r resistor, PT works fine...Used 2 100k-B pots. Connected a resistor (2.2k) and a LED to grd at pin 7 of the 072, nice addition! The speed LED.
Hi , i need help with my LA build. I have problem with depth of chorus, pedal is working but chorus is subtle and is hearable only if i turn speed pot to more vibrato sound.
here are ricks voltages :
PT2399
1: 5
2: 2.38 to 2.42
3: 0
4: 0
5: 2.75
6: 0.61
7: 0.88
8: 0.88
- i have on Pin5 only 0.30 to 0.90V instead of 2.75V ,the rest of pins are similar, please can somebody help me?
Hi!
To increase depth you may try to decrease the value of the resistor that goes to pin 2. With 10 kOhm you'll get deeper effect, i ended up
with 2.2K, although this way the depth pot affects also the speed rate of the LFO (due to LFO load impedance variation). With 33k the effect
didn't have enough depth (as for my taste).
Also you may try checking pin 5 with an oscilloscope - this is the internal clock generator output, but provided your effect works - the clock is present.
Quote from: Vikt0r on June 14, 2013, 09:01:51 AM
Hi!
Hi, my friend please more details of your mix/blend pot; thanks a lot it is a metal chorus ehhh!!!! great!!!
Quote from: GodSaveMetal on July 04, 2013, 09:12:34 PM
Not sure what detail do you mean..? It's a dry/wet mixing pot option. A 20K linear pot replaces R18 and R20 (according to "birthday edition" at page 33). In order to get a junction,
i moved C15 to the place of R18, C12 instead of R20. The pot is soldered to where originally C12 and C15 should have been. Watch the PCB photo - should be clear.
I noticed when I was playing around with a delay on the breadboard that a capacitor from pin 5 to ground made the delay time shorter, I'm guessing it did this by increasing clock frequency... I wonder if this could be used in a chorus/flanger to get a really short delay time?
Quote from: psychedelicfish on July 07, 2013, 05:18:08 PM
Interesting observation. Need to check this with a scope. Will see how much this is true, considering this is the clock output and the frequency should not become affected in theory.
Quote from: arma61 on January 22, 2013, 07:13:59 AM
Ciao
That's a 0.0033uF cap, right? Curious... that's the "clock output" pin. I wonder why that works....
Quote from: Paul Marossy on August 20, 2013, 03:37:34 PM
Ciao
I wonder too Paul, but it worked on that one, I have build other one with a little bit less hiss than that one (though still present) , and that 3n3 caps does almost nothing.... don't know..
Quote from: arma61 on August 21, 2013, 07:29:57 AM
Ciao
Weird.... :icon_confused:
Has anyone found trustworthy filtering for the PT2399?
I read a lot in this topic, but there are always new problems.
QuoteHas anyone found trustworthy filtering for the PT2399?
It's a chip made for mass fabbed karaoke machines and what-have-you, don't expect to find a solution...
What do you mean by 'trustworthy'?
Yes - a MAX7401. Check out rring's delay on this forum and his site, circuit salad.
found this in my ancient aol email account,
it MAY be a cure for the latchup issue... i haven't tried it yet, but figured i'd post it anyways.
fwiw, none of the other "fixes" have seemed to work for me.
anyways, from one of the gents from bob keeley's site
Subject: Re:_Jimi_Pocius_Dot_Com
Hey Pinkster,
We were doing some searching for the PT2399 latch-up issues and found your problems on the tagboardeffects website and we had the same problem as you with the latching up everytime we powered it on and only after unplugging and waiting to plug it back in did it start working again.... We may have found a fix which is a 0.01uF capacitor across pins 2 and 3 of the PT2399. Worked for us anyways.
Let me know if this fixes your problem!!
Craighton Hale
Keeley Electronics, Inc.
www.robertkeeley.com
1733 S. Fretz Ave. Suite C
Edmond, Oklahoma 73013
405-341-2025
i wonder if that would affect the modulation? most PT2399 circuits manipulate pin 6 and have pins 2 and 3 shunted to ground, pin 2 via 47uF.
@Jimi - for what it's worth, my PT2399 builds from the last year or so, including a modded Little Angel, haven't latched up once... yet. Probably will at the worst moment possible. :P
QuoteWe were doing some searching for the PT2399 latch-up issues
If I payed 200 bucks for a chorus pedal, I'd be a little peeved if I saw a PT2399 in there. Just sayin'.
i've had issues with every single 2399 circuit i've tried. some work.... the guitarpcb.com d'lay does...
but the one chip i've never got to work, and rick's little angel only seems to work when it wants to.
my rebote just plain DIED when i tried playing with starving it...
you can get some cool delay modulation by starving the 2399, but it has to be starved AFTER the 7805, if ya use a normal kind of sag, it smokes the regulator.
i'm going right now to dig out my little angel build, and try the keeley fix. if it works, i'll post immediately gary
Fack ! I really don't understand how to connect pots ! Maybe somebody can help me ? :icon_question: :P
Hi everyone, i just made the little angel with the 1590a layout. But it won't work. :'(
I have no understanding of the PT2399 whatsoever, but i think it might be "locked"? Whatever that means?
So when i use it with no power to the circuit, the sound is weak and noisy.
When i plug in the battery, the sound gets to about the same level as without any effects and it has no noise, but no chorus either.
None of the components gets hot and i can't see anything wrong with the circuitboard. No solder bridges, nothing.
there is just no chorus, thats it. ???
I do have the 100R resistor, and i did read something about having trubles with it. But if that is the case, what should i replace it with?
By the way, this is the voltage readings of the PT2399:
1- 5V
2- 2,43V
3- 0v
4- 0v
5- 5v
6- 0,69v
7- 0v
8- 0v
9- 3,94v
10-16- 2,43v
Nevermind, i don't know where they was, but there was some small bridges from my badly etched circuitboard.
I just made cuts between every lead, and it worked ;)
I'm using the layout on page 8 and audio passes through but no effect. I've looked through this thread and I'm stumped. Here's my readings:
PT2399:
5.04
.83
0
0
.42
1.94
0
.74
2.52
2.34
1.16
2.52
.34
2.5
2.52
.34
TL072:
1.41
.09
.09
0
.06
5.05
9.55
Here's a photo of my build, I've made sure that all my soldering is good.
(http://f.cl.ly/items/0O0Z22203Q1Y0N1f440z/IMG_2685.jpeg)
Quote from: pulsewidthmod on March 04, 2014, 12:55:49 AM
PT2399:
5.04
.83
0
0
.42
1.94
0
.74
2.52
2.34
1.16
2.52
.34
2.5
2.52
.34
TL072:
1.41
.09
.09
0
.06
5.05
9.55
And just as I was thinking that I'm the only one with this problem, the first post I see is from someone who has the exact same problem... Mine was working for a while, then after bumped the volume knob to 100% from a high gain distortion pedal I had in front of this one it stopped working. Signal passes through when it has power but there's no effect. Tried replacing both ICs for new ones with no luck. I don't know what else could be causing this... I checked for solder bridges a bunch of times already but still havent found any. Any help would be grately opreciated!
EDIT: I found this if it helps: http://puu.sh/7lolg.png
yep the pt2399 likes to see at least 1k on pin 6.
or it will be prone to lock up...when powering on/off...
This has to have been mentioned already, but check out figure 4 and associated text on the Elliot Sound Products page for this PT2399 delay findings. Might help with the lock up.
http://sound.westhost.com/project26a.htm
I changed R1 to 1k and added a 10nF capacitor from pin 2 to pin 3 and it looks like that fixed it! At least one of those two things did... I don't know which. :)
I will take a good look at that link though. Might help me with any future builds. Thanks!
hey y'all
i just built a birthday edition and it works pretty good but the effect is very subtle. i didn't go throught all 46 pages (but at least half of them) so i appologize if this has already been answered before, but would it be a good idea to lower R18? or would increasing R5 be a better solution?
regards
Hello everyone, I built an Echo Base delay and I'm getting a clean signal, I suspect this could be caused by the PT2399 locking up, but neither a 100R nor a 1K resistor seem to be doing the trick, can anyone tell me how to apply mictesters' Little Angel fix to the Echo Base, if I'm making any sense at all?
To test if your Echo Base is locking up, unplug the power/battery, set the time pot to maximum resistance (longest time) and then connect power. If you still only get clean signal then your problem is not caused by it locking up. The only way the Echo Base can potentially lock up is if you start it with time pot set to very short times. No one has ever reported lock up as being a problem to me.
Quotei just built a birthday edition and it works pretty good but the effect is very subtle. i didn't go throught all 46 pages (but at least half of them) so i appologize if this has already been answered before, but would it be a good idea to lower R18? or would increasing R5 be a better solution?
i need to look at the schematic but I can tell you that this isn't a "subtle" effect - if it's built right. I really doubt that you'll need to start modding values much to get super thick chorus sound, regardless of differences in personal taste. At least PT2399 super thick, anyway. I added a blend knob to mine specifically to be able to dial some back. I'd triple check your wiring and values and solder bridges, etc. or take some voltages and post them here. I bet it's an easy fix.
I just built a LA Birthday Edition but, like many others, have the problem of no real effect. I hard-wired everything with no 3PDT switch, so any problem is in the circuit for sure. I don't see any solder bridges and all the traces look good. Here's my voltages, which don't seem too much different from Rick's posted voltages:
PT2399
1: 5.12
2: 2.49
3: 0
4: 0
5: 0.91 - 1.00
6: 0.81
7: 0.84
8: 0.91
9 through to 16: 2.49
NE5532
1: 2.2 to 4.01
2: 2.91 to 3.05
3: 2.62 to 2.82
4: 0v
5: 3.16
6. 4.00
7: 4.13
8: 8.58
I'm running this off a battery right now. Any idea where I should start looking with a microscope? This is my first pedal build, ever.
Those voltages all look pretty reasonable to me. I would expect pin 2 of the PT2399 to show a bit of wiggle too - it's where the LFO (first half of NE5532) is going to (and that's clearly wiggling). You might want to trace the audio path with an audio probe to see where your signal goes (and disappears?).
BTW, what layout are you using? PCB? Vero? Some pictures of both sides might be helpful.
The PT2399 might have latched up. Can you hear any effect?
Here's the front and back (without the 78L05, as I didn't have one when I first populated the board). The 78L05 is in there now, oriented correctly, I just don't have a new pic yet.
I am not really hearing any effect. I'm using an etched PCB from the latest Birthday Edition (it had the extra "4EVA" on there, but I wiped it off when I resized the image for printing so I knew which one was the right size).
(http://i1116.photobucket.com/albums/k562/JU57US/DIY%20Electronics/20140728_224402_zpsaqhikk16.jpg)
(http://i1116.photobucket.com/albums/k562/JU57US/DIY%20Electronics/20140728_224431_zpsfa3khca9.jpg)
Sorry for the delayed response, been out of town.
hey y'all
has anyone tried jack orman's version of the circuit?
Quote from: Frances Rhodes on August 10, 2014, 06:51:08 PM
hey y'all
I am in the process of starting one...just cut the vero for it last night. It might be a few weeks before I get to it though...got about 6 others to box up and finish first...LOL...
Quote from: Justus on August 10, 2014, 01:27:54 PM
I had the same happen to me.
Effect was VERY faint, and the volume was boosted when engaged, and added alot of noise.
Basically gave up on it, ordered a new PT2399 from Banzai (the ones I have were bought on ebay). I'm etching a new board later this week, but honestly I don't feel very confident I'll get it working this time :P
Quote from: Giglawyer on August 11, 2014, 03:54:01 PM
hey y'all
i can't have any pcb made for me so all i can do is point-to-point, the first i made took me over 15 hours to get through, but i was a little disappointed with my first angel so i want to give this other version of the circuit a try very soon
I built the original layout but it did not work, I believe that is the problem with the IC PT2399. I will build the correction suggested by pin 6 Frequency Central, hopefully solve. Can I replace the 2N3904 for a BC547?
I appreciate nobody has posted in this thread for quite a while, but I have a suggestion to put forward and I have the seemingly unsolved problem with the PT2399 locking up.
I bought the kit from Bitsbox in the UK using the V4 vero layout from here: http://tagboardeffects.blogspot.co.uk/2012/02/little-angel-chorus-rick-holt.html and as many others have seen I have the problem with the PT2399 locking up and it does not appear to matter where the controls are set. One sure fire way of knowing the chip is locked is that it gets warm and the input current goes up from 39mA to 145mA and the voltage on pin 5 & 7 increases to over 4V. I've tried all the fixes I can find and am now waiting for a replacement PT2399. Bridging pins 2 & 3 together resets it every time.
Would it not be possible to design a circuit that will trigger a momentary short between pins 2 & 3 to reset the IC when it locks up by using the reference voltage on pin 5 or 7 as these both jump to over 4V when the IC locks up, the biggest voltage increase is on pin 7?
Creating a fix of this nature should enable any PT2399 to be used and the existing anti lock circuit could be done away with. Seems logical to me but I'm no expert, just putting forward an idea.
I appear to have a PT2399 that is particularly bad for lock ups so this would be a good one to test any viable solution on as all the other fixes I have tried fail to stop it. Increasing the 10uF cap in the anti lock circuit to 47uF made it better, but it still can't be trusted. I am prepared to try anything that is suggested. Obviously a momentary 'on' switch to short circuit pins 2 & 3 would do it, but that is of no use when playing a live gig it needs to be automatic.
Afraid I have nothing positive to add, but am starting to get a theory of it...
2 things:
I think modulating pin 2 could be causing "crowbar" latch up of the chip. Theory is, internally, the circuits have some capacitance. Normally the reference voltage on pin2 is half supply, so about 2.5v. When the LFO raises the voltage, anything internally with 2.5v charge gets lifted with it, potentially exceeding the power supply (2.5v+LFO increase). The same thing again to the neg supply when the LFO pulls pin 2 down. This can usually cause latch up with most MOS chips. Together with that, there could be a charge pump action going on via stray or designed PN junctions in the chip, generating excessive voltage versus supply. Since it's happening internally, you probably can't do anything about it, such as adding 2 reverse clamping diodes between pin2 and +5 and Gnd- but it could be worth a try?
The second worry, is that we don't know how much current pin6 can really, safely, sink. Recommended minimum 1k delay resistor is 2.5mA - that's about the limit for most MOS devices (such as standard gates) that aren't designed specially for higher current sinking.
Well, maybe a 3rd point, you could be too close to solar flares or the microwave...
http://en.wikipedia.org/wiki/Latchup
Thanks for the reply. I just about grasp what your saying, but is it even remotely possible to create an anti lock up circuit that will do as I suggested?
I will be away from my PC until Tuesday so cannot make any further replies until then.
Id just like to say thanks to the guys who made this and shared it.
I built mine over the week end and it fired up right away. I DIY'ed everything including etching the board. Was very pleased with the result. Got good range even if i only had 250k pot. can only imagine when i swap it to the proper 500k
Wow! 5 years old in a couple of weeks, I wonder how many L.A.'s have been built? I just listened again to my original soundclip way back on page 1, anyone who thinks this effect is too subtle might need to check their build...
Maybe a new thread for reporting completed "Little Angel" builds? I'm guessing in the thousands, I've done 2 of them.
Quote from: frequencycentral on July 26, 2015, 11:04:36 PM
Never mind "birthday edition", what about a "starting school" edition? [emoji1]
I didn't build the little one, I built the little big one :)
(http://i832.photobucket.com/albums/zz249/Perrow_MLP/Builds/Little%20Big%20Angel/DSCN3552.jpg)
(http://i832.photobucket.com/albums/zz249/Perrow_MLP/Builds/Little%20Big%20Angel/LittleBigAngelLayout.png)
Only built one, yet.
Excuse me, Little Angel's experts.
I have a some problem with my Little Angel building. I used tagboard vero layout. I built it some months ago, and I had a little background noise when I play (not so loud but I can hear it :(), PT2399 tipical noise, I think. I tried 3 different IC. With 2 I got no changing, and the third didn't work. I tried with another 78L05, too.
Somebody tried to help me in this forum, but I got nothing, yet. I checked the voltage, those are ok.
I test it out of the box, without footswitch nor led indicator and with a little bit diyng battery at the moment. After boxed and with a psu this circuit could be less noisy or not?
Seems to me some demo on youtube of this pedal play noiseless.
I really don't understand this.
Another thing. I tested the circuit after much time, and just now I notice, when I set speed and, even depth pot, to zero, a quickly detune. It is normal?
Thank you!
Quote from: Perrow on August 04, 2015, 01:56:03 PM
Nice job!
Quote from: Cjuried on September 15, 2015, 02:49:08 PM
Nice job!
^ Agreed!
Question to Perrow: Why is pin 4 on the PT2399 bent up that way? Couldn't it be inside the socket, since the trace on the PCB doesn't go anywhere?
The trace on the posted pcb-layout doesn't go anywhere, on the etched board it goes to ground :)
Ah!
Got it.
The pcb in the build also has a turkey in the upper right corner (almost shines through on the image next to the input jack) as this was a build for the thanksgiving day contest.
It's also worth noting that the labels for the pots are wrong, should've been the other way around ::)
Quote from: Hemmel on September 15, 2015, 03:08:47 PM
I thought it was peeing... :icon_biggrin:
Quote from: bluebunny on September 16, 2015, 03:09:47 AM
Someone has suggested it was "giving the finger", it sure is a conversation starter :D
I built a little angel, is very nice, but i recommend you to put a volume pot, because this chorus have so much gain and is difficult to use with distortion or drive. I like drive + chorus. xD
I used this layout, worked right for me.
(http://i210.photobucket.com/albums/bb292/frequencycentral/LittleAngelPCB.gif)
Good work for you!
Just wanted to chime in and say that I just breadboarded a Little Angel, standard edition. Works great on first breadboard and I'm getting it ready to solder it up. Thanks Rick!
Over 5 years after the original design I have just, today, found the thread & have built the Little Angel (V2) on breadboard. The only change being the use of a 1K resistor on pin 6 of the PT2399. It sounds superb (particularly since it's on breadboard - no noise 8) . Unlike most like most of the people on here I'm no expert (though I have successfully built Reverb (Equinox II), Echo, Fuzz and Tremolo effects). Big thank you to Rick for this great design.
Edit: Just modified to include the pin 6 fix (so that I get 100 Ohm at pin 6 without potential for lock up) and it sounds even better! Also put a 'rate' LED from Pin 7 of 5532 (yep, I've used opposite configuration of the dual op amp to many). Interestingly, a 3mm red LED added a bit of noise but a 3mm yellow LED is fine ???
This is also my primary chorus. but im wondering if i wish to increase rate and depth what mods should i first start with. should i change the pots to smaller value?
Does anyone have any prefab boards for either the little angel or birthday edition available at the moment?
JMK (http://jmkpcbs.com/product/little-angel/) has a board. They're in Canada, so I assume the prices are CAD. Works out at about £8 shipped back to the UK. Delyk (http://pcb.delyk.com/modulation/10-little-angel-pcb.html) has a board too. Texas this time: price is around the same. And of course, closer to home, is Fuzz Dog (http://shop.pedalparts.co.uk/Cherub_Chorus_PCB/p847124_14307825.aspx) with their "Cherub" take on the LA: about six quid delivered.
Cool thanks for that how does the cherub compare, as fuzz dog are awesome to deal with really fast delivery and sweets :), but all the write ups on the LA both editions sound very promising
Has anyone played the original version and the improved version by Jack Orman (with 6V regulator) side by side?
Quote from: Mgt280y on June 20, 2016, 04:35:25 AM
So far as I know, the Cherub
is the LA (Birthday Edition), but with options for mods. (Not to be confused with Sam's Cherub (http://www.diystompboxes.com/smfforum/index.php?topic=106854.msg968063#msg968063) chorus, btw.)
Hey guys! Newbe here reviving VERY old thread! Sorry about that, but I need a little help!
I am building my LA, and based mine on the PCB and diagrams below (as found in Page 34 of this thread).
Quote from: frequencycentral on June 29, 2011, 04:08:04 PM
Schematic for the Birthday Edition:
(http://dl.dropbox.com/u/967492/Little%20Angel%20Miracle%203.PNG)
(http://dl.dropbox.com/u/967492/LA%20Birthday%20Edition/LA%20Birthday%20PCB.gif)
(http://dl.dropbox.com/u/967492/LA%20Birthday%20Edition/LA%20Birthday%20PnP.gif)
[/quote]
My first question is that it seems that C17 is 47 uF in the schematic, but the diagram has it listed as 10 uF. I have 10 uF in mine (did not notice this until I was trouble shooting), but what should it be? 10 uF or 47 uF? Or either one?
Now, back to trouble shooting! Using my audio probe, I noticed that the signal is coming in strong at the input, and continues strong after C13 (0.1 uF in the schematic), but then becomes muted down after R16 (470K in the schematic). Is this normal? It is even further muted by R15 (1M in the schematic). This muted sound makes it all the way to the 2399 pins 14, 15 & 16... actually, I can hear the muted sound all the way to the output. I did not continue testing because my cell phone (my source for tones for trouble shooting) ran out of batteries, but I figured I had enough to start asking for help. So, what do you guys suggest I look at first? Do you need voltage readouts from the 2399 pins?
I assume that cap is part of the 'separate vref' mod shown in that schematic. I'm sure either is fine - if you have trouble with 10uf I guess just replace it with 47uf.
Just had a look through the thread and this part is for the following: "Audio vref: R23/R24/C17 - suggested by merlinb as a way to reduce noise dumped into the older version's 5v vref supply by the PT2399"
Then someone said "Yeah, you're right C17 should be 47u according to the schematic. In this case it doesn't matter, either value will do the same job, with no effect on the sound."
I'm sure either will be ok.
Great, thanks! Now I only need to figure out why it is not actually working...
I'd recommend following the troubleshooting thread and adding the necessary info like voltages on both ICs and photos etc.
Quote from: jfrabat on November 21, 2016, 09:56:49 PM
I have to say you made an excellent first post. Lots of information about your problem, even pointing out some info was missing and asking if we needed it, perfect.
No need to excuse your self for posting in this old thread, it's been revived lots of times. The thread started six years ago and while it was last alive this summer it's always nice to see it come alive :icon_mrgreen:
Welcome to the community.
welcome. I am that guy that doesn't know much but always encourages people to post pics of their builds ;D
Maybe then someone can spot something, solder bridge, wrong component, etc.
If you think the signal is getting muted way down, double check the value of the 470K. A common mistake (for me) would be to accidentally put a 4M7 right there :P
Good luck!
Ben
Hey, guys! I followed the troubleshooting guise, and, indeed, it helped. Well, sort off... I found the problem; the PT was not getting any power because of a bad solder joint on the leg that goes to the 5V source.
I am attaching some pics of my build, for reference, but keep in mind, this is all prior to everything posted in this post here. Anyway, I re-soldered the joint, and also "fixed" some others that seemed to have a similar problem (visually, anyway). I say "Fixed" because now I get almost all the battery voltage regardless of where I probe! Even the ground is showing 9V! I screwed up the soldering and somewhere there is a short... But I could not find it. So I said screw it, and will start over again. Now, a couple of comments:
- I am using a TL082CP instead of the NE5532 sinply because here in Costa Rica I am having a hard time finding the 5532. If this is not compatible (can't see why it would not, but then again, what do I know!?), I also got some MC1458P, TL072CP, LM386 and C4558C's laying around, so let me know if any of these is a better replacement
- As of now, only the battery is connected. My intention is/was (not sure yet!) to get it working, then paint the case, then install the power supply
- Yes, I am THAT bad at soldering! Feel free to point that out! LOL! (I like to think the mechanical part is more my strong point, but it's kind of hard to show that here!)
- In my defense, this is my 3rd pedal EVER. Both the first 2 are point to point (both overdrives)... This is also my first PCB done, so complete newb here!
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20161122_193323.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20161122_193323.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20161122_193134_2.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20161122_193134_2.jpg.html)
Felipe
As you admit, you need some practice with soldering. The image is not clear enough for me to be 100% but I can see joints which have not been made and multiple shorts where solder has spread to the thin box surrounding the layout. There also appears to be some unmade connections
My suggestion would be to remove all of the excess solder and then re make each connection. Work slowly and use a big magnifying glass
Good luck
QuoteYes, I am THAT bad at soldering! Feel free to point that out! LOL!
Check out this page to help diagnose where you are going wrong with your soldering. It has lots of great pics, and it tells you how to repair different types of bad joints.
https://learn.adafruit.com/adafruit-guide-excellent-soldering/common-problems
Thanks for the link, EBK.
I decided to start fresh. I will also make the holes smaller on the PCB. I used a 1/32 bit, but I think I will move to a 1/64 bit, as I find the holes are a little too big for this purpose, and that makes getting a proper solder joint right more difficult. I mai also get a soldering iron with a better tip; the one I have is a bit hard to work with!
As for solder bridges, before the "fix" I checked with the multimeter for continuity, and there was none, and except for the bad solder at the 2399 input, the rest of the voltages seemed OK. After the fix, I could not find any solder bridges, but I am sure at least one is there, as the voltage was wrong at many places.
As for the OpAmp, is there any issues with the switch?
Felipe
to check for solder bridges or breaks i use a flashlight with the component side underneath and the traces facing towards me
i put the flash light opossite me on the component side. so any bridges or breaks show up .
Choosing the right drill bit will help with the soldering. One other thing would be to watch the tarnishing of the copper traces and pads. I might be color blind but I don't see any shiny copper on that board and that makes for difficult soldering. Half the battle is knowing your handicaps and that you do. Practice and you'll be Rockin' in no time!
the opamp - your TL082 is the lower noise spec version of the TL072, more or less. the opamp is not doing anything terribly special or critical, so the swap should cause no bothers. if you get oscillator tikkings, you might try the 072 or the MC1458.
Thanks for all the help, guys. Being new to the site, I have to say you guys are a very positive group. I like that!
And yes, I do not have a lot of experience soldering, but in my 43 years of living (EXACTLY 43 years... It's my B-Day today!), I have found out that practice does make a difference, so being as bull headed as I am, I will keep at it until I get it right (or at least working! LOL!)!
Couple of questions;
1. What solder wire gauge should I use? I have 0.015" and 1.0mm at home, but the thin one (0.015") I feel is TOO thin (takes forever to get enough solder in the joint) and the thick one (1.0mm) I feel is TOO thick! Both are 64/40, by the way...
2. I am getting a new soldering iron; the one I have is a cheap Chinese one, and I feel it's too hard to work with. I have been doing some online research, and they say something with flat head is better to heat up both the pad and lead. What do you guys think of the Weller WLC-100 (http://www.steren.cr/catalogo/prod.php?f=&sf=&c=&p=3775&result=cautin)? It does not have automatic temp control, but I know Weller is suppossed to be good, and it has a flat head (and it's available locally! That's always an issue here unless you want to wait a while for it to arrive!).
That iron should be fine. It's the one I have, I think. As for solder wire thickness. I find that .032" is about perfect for our through hole pedal designs.
yes, yes, never mind all that -
Quote from: jfrabat on November 24, 2016, 10:05:18 AM
...... in my 43 years of living (EXACTLY 43 years... It's my B-Day today!), .....
- will there be cake?
[manners] sorry, how rude of me: happy birthday, welcome to the forum, will there cake? [/manners]
Quote from: duck_arse on November 24, 2016, 10:36:31 AM
Of course! And you are welcome to some! It will be served at noon here in Costa Rica!
QuoteEven the ground is showing 9V!
Very easy mistake to make in the heat of troubleshooting is forget to plug a jack in the input - assuming you have the usual TRS jack ring to ground power switching. Then indeed, you will not have ground on the pcb.
The solder is shiny, just not flowing. Even with a narrow "pencil" point tip that I use, it's wet the tip with fresh solder, apply to joint at an angle that connects the tip to component wire and copper pad, then feed in solder (not too fast) until it flows into the joint. I find I can use a pencil tip for just about everything. If it needs more contact area, I just lay the tip so its flatter across the joint.
That really thin solder wire is tricky, it can push through the holes and cause hidden shorts. 1mm is good for general work.
If the tip ever gets loose in the barrel, an oxide layer will form which makes a heat insulator. As the metal expands and contracts, the tip will come loose, so make sure it's tight before switching it on. Take it out and polish off the oxide if necessary.
Well, at least the box is coming out nicely!
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20161127_002707.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20161127_002707.jpg.html)
Once the laser printer gets fixed, I will redo the PCB. I also ordered one online as a plan B. I WILL get this pedal working one way or the other!
jfrabat - your "angel" reminds me a little of [adult_content_!!] Tori Avano [/adult_content_!!]. view that content with extreme caution.
Well, new PCB is done. I checked for continuity, and I have it everywhere it is suppossed to be, and there is none where there should not... I had to scratch the PCB to break a non wanted bridge, and made a couple more just to be on the safe side. Holes are also half the size of the previous try. Enough for the components, but with less gap. Now its soldering time. I hope not to screw up again.
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20161203_145913.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20161203_145913.jpg.html)
Capacitors, transistors, sockets and diode are in. The hole size does make it easier to solder components without making a mess. Here's how its looking prior to resistors and pots and other stuff outside the PCB:
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20161203_164610.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20161203_164610.jpg.html)
Definetely looking better than last one. Gonna check continuity now before putting in resistors. Hopefully, everything will be as it should!
Looking much better than the last one. Bit late now but you'll find it easier to solder in the components in hight order. Links, resistors and diodes first then small caps, large caps etc. Saves you struggling to hold the things in place when you solder.
You may find that a piece of sponge may help to keep the resistors in place now that the large caps are on the board
I agree that this one looks much better. There are still a few joints that look like you didn't heat the pad on the board enough, but much progress is being made. I hope it works when you finish.
OK. Finished soldering. Signal is going through (with a bit of clean boost), but no chorus effect. So I am further along, but not quite there yet...
Voltages read as follows (have not yet compared them to the others posted here):
IC1 (PT2399)
1. 5.03V
2. 2.50V
3. 1 mV (gonna call it 0, as even disconneed the reader shows that)
4. 1 mV (again, gonna call it 0)
5. 5.01V
6. 0.74 V
7. 151 mV and starts to go up
8. 126 mV and goes up
9 to 16. 2.51 V
IC2 (TL082)
1. 2.68 to 3.25 V (fluctuates)
2. 2.95 to 2.98 V
3. 2.78 to 2.83 V
4. 0 (1 mV)
5. 4.21 V
6. 4.34 V
7. 4.34 V
8. 8.65 V
Q1 (78L05)
In. 8.4 V
GND. 0 (1 mV)
Out. 5.01 V
Q2 (forgot to mention I replaced this one with a 2N2222A)
C: 78.4 mV
E: 1 mV
B: 0.68 V
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20161203_212547.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20161203_212547.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20161203_212455.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20161203_212455.jpg.html)
Let me know if you guys spot anything out of order...
By the way, I tried replacing the PT, but readings did not change.
Felipe
PT2399
1: 5
2: 2.38 to 2.42
3: 0
4: 0
5: 2.75
6: 0.61
7: 0.88
8: 0.88
NE5532
1: 0.13 to 4.9
2: 2.9 to 3.2
3: 2.7 to 3.1
4: 0v
5: 4.79
6. 4.9
7: 5.14
8: 9
So it seems I have significant diferences at:
IC1, pins 5, 7 & 8
IC2, pin 7
Battery is a bit worn; did not check direct voltage, but reading from pin 8 of IC2, maybe its time for a change. Could that be causing the issues?
I'm wondering about that copper trace across the bottom of your board that appears to disintegrate as it nears the corner. I'd have to take a look at the original pattern vs. what you ended up with. Haven't had time to look at your voltages though.
PT2399 pins 5 & 6 voltages suggest the chip is "locked up". Don't worry about the 5532, it could well be ok.
Pin 5 should be somewhere around 2.5v. Actually it's a very high frequency, the clock of the delay and your meter will average it as an about halfway voltage, but this is not related to and can differ to the 2.5V found on the other pins. Pin5 either at 5v or 0v suggests the delay clock VCO isn't running.
Pin 6 is the clock VCO frequency control current. A low voltage here suggests excessive current "might" be being drawn from this pin. Possible short to 0v or too low resistance to 0v. The PT2399 clock VCO can fail to start if Pin6 resistance is less than 1k at power on. This sensitivity does vary from chip to chip. Some examples always work, some sometimes work and some never work.
Sometimes the PT2399 can lock up due to static. You can take it out and press all the pins on some metal foil for 10seconds to clear any static charge that might be in it. That bit sounds like hocus-pocus I know, but I swear it's happened to me and this trick fixed it.
Which particular LA circuit is this built to? There have been various changes to the pin6 control.
Is that PT2399 the same part used in the earlier fail?
Quote from: anotherjim on December 04, 2016, 06:15:07 AM
I will give that a shot. The PT I started the test wit was the same one of the failed experiment. It is the one example I found locally. But I then replaced it with a new one I ordered from Amazon (or was it eBay?). I would have to re check the voltages of pins 5 & 6 to be sure they are also the same still (I just woke up!), and will do so shortly. But I will also do the metal trick just in case...
The LA is the Birthday Edition. I will repost the schematic I followed so you guys dont tneed to search back to it.
Quote from: frequencycentral on June 22, 2011, 01:30:17 PM
Well I was gonna save this as a surprise for LA's 1st birthday in August, but........
I wanted to keep it 1590A-able, but also add good things like the Pin 6 Fix and a seperate vref for the audio path. Here's the lowdown:
- Pin 6 Fix: D1/C16/Q2/R21/R22
I did add a little Pin 6 Fix subcircuit to a PT2399 that I know won't work without. It still has issues, but I think raising R22 to 100R and C16 to 47uF will sort it - Audio vref: R23/R24/C17 - suggested by merlinb as a way to reduce noise dumped into the older version's 5v vref supply by the PT2399
- C4 changed to 3.3nF - might be a bit darker but will be less hissy
As it's planned to be 1590A-able, hopefully all the electro caps should be able to be bend over 900 to lie flat against the PCB. C16 might be the trickiest.
I PM'ed this layout last week to a couple of people who expressed interest in verifying it, so you never know, it could be verified within a day or so. The layout does need a little tidy up, as I notice the pad sizes are not all the same size.
This is the one I am using
Voltages of new PT after grounding all legs
1. 5.01 V
2. 2.50V
3. 1 mV
4. 1 mV
5. 5.01V
6. 0.708 V
7. 4.58 V
8. 4.58 V
9. 4.83 V
10. 0.403
11. 0.402
12. 4.78 V
13. 2.5 V
14. 0.235 V
15. 2.5V
16. 2.5 V
I just notice if I take the chip out, ground it, and put it back in, pin 5 goes to 2.3V. When that happens, pins 9 to 18 go to 2.51V and pin 7 goes to 0.434V. But if I connect the guitar... back to square 1.
Ok, that really looks like the PT2399 is locking up.
I think this is the schematic...
Do check R21 is 2k2 (red/red/red) and R22 is 100R (brown/black/brown) - can't see those well in the photo.
To test if it's due to too much current out of pin6, remove the 100R resistor R22 (only need to take one lead out of its hole).
Without R22, it should work but with a noticeable short time delay, which will show the PT2399 is running.
I think the resistors are right:
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20161204_151748.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20161204_151748.jpg.html)
checked with the multimeter, resistance seems OK on both as well (98.9 ohms and 2.18K Ohms).
Here is another shot of the entire board, in case it helps figure out what wrong...
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20161204_151901.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20161204_151901.jpg.html)
The chip socket for the pt2399 is placed the wrong way round. The little semi circular notch should be on the left side. This is only to indicate which way round the chip should be inserted but if you haven't got that in the right way.....
Having said that, I see in a previous picture that you have the chip inserted correctly but it's worth checking
Quote from: stallik on December 04, 2016, 04:46:05 PM
To be honest, this is the first time I notice that notch! LOL! Nothing like the bliss of ignorance, right? But the chip I did insert the right way, so I do not think that is the cause.
As for the voltage, I took out my trusty multi-meter, and went to check resistances... Got some surprises. Here's the resistor list with what should be in and what I measured:
Listed Value Measured Value
R1 68K 66.6K
R2 10K 9.53K
R3 10K 9.84K
R4 10K 9.80K
R5 10K 9.79K
R6 10K 9.77K
R7 330K 321K
R8 47K
318K
R9 100K
39.7KR10 220K Did not get a measurement
R11 220K 212K
R12 4.7K 4.6K
R13 33K
66.6KR14 100K 97.8K
R15 1M
2.09MR16 470K 462K
R17 10K 9.79K
R18 10K 9.80K
R19 1M Did not get a measurement
R20 10K 9.79K
R21 2.2K 2.18K
R22 100 98.8
R23 10K 9.20K
R24 10K 9.32K
The ones that have no measure is because I was getting no indication on the multi-meter. Correct me if I am wrong, but:
47K = Yellow-Violet-Orange
100K = Brown-Black-Yellow
Is this right? If so, I got the right resistors in place for R8 and R9, right?
I did notice that the 1M resistors I accidentally put 2.2M resistors, but I also noticed my 2,2M resistors have resistance all over the place (from 700K to 3M!). I also have the wrong resistor for R13, so I have to swap out 3 resistors and see what's up with the other 2. Does this sound about right?
You might have to tried to measure resistance with power on? It has to be power off for that, and preferably with IC's removed as they can make connections to other parts of the circuit. Also any capacitors must have time after power off to discharge.
It can take a noticeable time for resistance readings to "resolve" to a true value when there are significantly large value capacitors also connected, because the meters own test voltage supply will have to charge the capacitor as well as inject its test current through the part you are measuring. You will notice then that if you reverse the meter probes , it will first have to discharge the capacitor then recharge it to the reverse polarity, taking even longer to resolve. For the small value capacitors, this can be too fast to notice, but with the larger ones over 1uF, it's a handy way to tell if it is acting like a capacitor should. Incidentally, you cannot damage an electrolytic capacitor if you connect the meter resistance test to it with wrong polarity as there is very little current.
Ideally, resistors should have at least one leg lifted out of contact so it can be measured without the rest of circuit affecting the reading, but that is tedious unless you have a good idea that its value is wrong. So we probe around with the resistors in circuit and when we find something that looks wrong, we unsolder one end and test again to be sure.
I've a suspicion that there is nothing seriously wrong with your resistors. Do check if it works without R22. If it still don't work, try again without Q2. If it still don't work, replace R21 with something higher like 47k - there should be a really obvious delayed signal out of the PT2399. If there still isn't - it's a bad PT2399.
You can't really measure resistors in-circuit. The chances that a resistor has no DC connection to anything else is slim. As Jim says, lift a leg and measure (with the power off - that would really upset your DMM!). Ideally, measuring resistors is something you do before you assemble. :)
Thanks, guys. So this means that R8 and R9 are correct. I still need to change R15, R19 (the two 1M ones, which are the green ones in the photos, which I used 2.2M instead of 1M) and R13 (I put a 68K resistor by mistake). Could these 3 resistors be the cause of my problems?
Here are the resistors in the schematic and in the picture:
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/Bad%20Resistors%202.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/Bad%20Resistors%202.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/Bad%20Resistors.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/Bad%20Resistors.jpg.html)
33K should be Orange Orange Orange (obviusly it is not! Blue Gray Orange is 68K) and 1M (the green resistors) should be Red Black Green, and these are Red Red Green (2.2M)
I will try removing R22 tonight, and see how it goes. But out of the 2 PT2399 I have tested, none have worked (different sources). I have 4 additional PT's I can test as well. Is it worth swapping it out at this time? The 2399 is already out at this time...
Keep unused PT2399 to one side for now. If a fault is damaging them, you don't want to kill them all.
Apart from a typo just then, 1M is brown/black/green, you're reading the resistors correctly.
As you have spare PT2399, you might consider something like the Deep Blue delay next, which also requires one, but doesn't press the chip to its highest speed range. Then you can check if all the PT2399's you have are basically functional before throwing them out.
68k instead of 33k for R13 means the chorus effect won't go as deep or obvious as it should be. If you don't have 33k, solder another 68k across the existing one.
Nice one Jim, I was just wondering how low the effect would be with that change to R13. The depth pots 470k so I wouldn't have thought it would remove the effect completely
I don't think 68k would stop it and will be surprised if it turns out to be the main fault, although it would be nice if that was all there was to it. ;)
Quote from: anotherjim on December 05, 2016, 10:52:27 AM
Sorry for the typo; you are right. And you make a good point about the PT2399's...
Actually, I was considering building an Equinox II Reverb (http://www.diystompboxes.com/smfforum/index.php?topic=93868.0) (it uses 2 PT2399), but the delay is not a bad option... I think a reverb is a bit more useful than a delay, so I's going that way. But theoretically (assuming the PT2399's are still good to go and not toasted!), I should have 3 of them left over, which makes the delay a very good possibility for the next build (even if the 2 used PT's are bad, I still have enough)! Still, before either, I have to get my Vulcan Rat (http://www.diystompboxes.com/smfforum/index.php?topic=116171.0) off the breadboard and into a box!
I will switch all 3 resistors (I just got some 33K's, so no problem there) tonight and test. If it does not work, I will take R22 out and try. If THAT does not work, then I will take the transistor out. If it STILL does not work, then I will replace R21 with a 47K as suggested. I will report back tonight...
Quote from: stallik on December 05, 2016, 01:58:48 PM
You know, now that you mention it, I think I am actually using a 500K pot, not a 470K... Just because I could not find any 470K locally. I will double check when I get back home tonight! But it should not make that much of a difference, right?
Quote from: anotherjim on December 05, 2016, 02:55:42 PM
So what's your gut telling you? If you had to give your best guess, what would you say it's happening?
Felipe
My gut say's the PT2399's are locking up because they don't like the 100R timing resistor.
A little backstory.
A chorus effect needs a variable delay, but it can't be such a long delay that it sounds like echo. Ideally, that's not much longer than 20ms. To get delay that in that range, the PT2399 needs to be run with a very fast clock speed. That clock is controlled by pin6 with a resistor connected to ground. The smaller that resistor is, the shorter the delay is.
It's beginning to look like recent (maybe in the last 3 years) chips run faster in the sub 1k delay resistor range than originally and cannot work with them as small as 100R as it makes them try to run faster than they can.
In the LA design, Q2 together with a 68k and 47uF have been added. The gives a time delay after power-on which allows the chip to start with the larger 2k2 resistor. Then when the cap has charged enough to switch Q2 on, it gets full speed with the 100R. This is because the PT2399 data sheet states that the pin6 resistor should not be less than 1k when power is applied.
Pots have a wide value tolerance. Measure some for fun. It's easily possible to have a 470k that is higher value than one marked as 500k. Generally, most electronics works fine if components are within +/-10% and once upon a time production circuits had to make do with 20% components. If a circuit needs a very close tolerance part, such as 1% resistors, the drawing/BOM will ask for it.
Resistors have been replaced. Nothing. Disconnected R22. Still nothing. Replaced PT back to the original. Nothing. Voltage readings with R22 unplugged:
Pin 1: 4.97V
Pin 2: 2.48V
Pin 3: 0V
Pin 4 : 0V
Pin 5: 2.73V (IMPROVEMENT!)
Pin 6: 2.4V (PROBLEM!)
Pin 7: 0.461V
Pin 8: 0.520V
Pins 9 to 16: 2.51V (with slight movement)
I do not see any obvious solder bridges near the PT:
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20161205_200519.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20161205_200519.jpg.html)
And here are the new resistors in place, in case hou spot something off (R22 is removed on purpose):
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20161205_200710.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20161205_200710.jpg.html)
Help is always appreciated!
Felipe
By the way, prior to taking out R22, the PT was getting pretty hot.. about as hot as when you touch a joint after soldering.
Felipe I think at this point it might be best to get out your multimeter and do a continuity check on every trace around the PT - sometimes when you make a PCB you can get cuts in the trace that aren't visible and can only be discovered by use of a multimeter.
Felipe,
I just want you to know that I'm still following this thread, silently cheering you on. I really want this pedal to work. :icon_smile:
Quote from: jfrabat on December 05, 2016, 11:55:31 PM
It's locking up, and probably toast. Throw it in the bin. (Although Pink Jimi claims he can bring them back to life!) This is down to the resistance at pin 6 being way too low, as Jim has said.
QuotePin 1: 4.97V
Pin 2: 2.48V
Pin 3: 0V
Pin 4 : 0V
Pin 7: 0.461V
Pin 8: 0.520V
These value might (only might) indicate the chip is ok. There could be another problem.
Quote from: chuckd666 on December 06, 2016, 12:42:33 AM
I did this before soldering components, but I will do it again to be sure all signals that are supposed to be there are, and those that are not are not there. I think I will also measure voltages without the PT in. Maybe I am getting voltage from somewhere else and that's messing things up?
Quote from: EBK on December 06, 2016, 01:24:51 AM
Felipe,
Quote from: anotherjim on December 06, 2016, 05:44:15 AM
QuotePin 1: 4.97V
Pin 2: 2.48V
Pin 3: 0V
Pin 4 : 0V
Pin 7: 0.461V
Pin 8: 0.520V
Yeah, I don't think it's toast either. It may be, but it is not going into the trash bin until I can confirm that it is...
OK, so my next steps should be:
1. Checking voltage at the socket (without PT in) to make sure no voltage from outside is hitting pin 6
2. Checking continuity
3. Taking out Q2
4. Swapping R21 to a 47K
Is this right?By the way, when I connect the guitar, I can hear the guitar playing; there is just no chorus effect of any kind. There is just a tiny little bit of clean boost. So it seems the problem is in the lower half of the schematic...
It might help to take out R20 (10k). That will disconnect the dry feed to the output then any sound your hear MUST have come from the PT2399. It may help to know that audio out of the chip first comes out from pin 12. It will also be found on pin 14.
Quote from: anotherjim on December 06, 2016, 11:43:26 AM
OK, so, the process to follow tonight is:
1. Disconnect R20 (one pin, just to break the dry feed from the output).
2. Checking voltage at the socket (without PT in) to make sure no voltage from outside is hitting pin 6
3. Checking continuity
4. Taking out Q2
5. Swapping R21 to a 47K
Is this correct?
I am posting the schematics and layout for anyone in the future who needs it as reference to troubleshooting...
Yes, and check the op-amp pin 1 with slow speed pot to see there is a constantly changing voltage to prove the LFO is running. At full depth you should hear a strong pitch warble as well as the delay.
Quote from: anotherjim on December 06, 2016, 12:57:08 PM
You lost me there... can you expand on this one?
Pin1 of the 5532 should have a constantly changing voltage. This wobbles the voltage on Pin2 of the 2399 and causes the delay time to rise and fall. It is the reason for the cyclic effect of a chorus. The speed of it is s l o w - low-frequency-oscillator - you shouldn't hear it directly. On the slowest speed setting, it's easier to see on the DMM. On fastest, the meter won't keep up but might show an average voltage instead. At any rate, it should never appear stuck at a high or low voltage.
And I assume it is the same on the TL082 I amnusing instead of the 5532, right? Or could that be the issue?
082 should work just the same.
OK, got it. Now, from what I read in your 2 previous post, in slow speed, a Digital Multi Meter should be able to pick up the oscillation, but in high speed, it will not. Now, the only issue is that I am not sure which way is slow and which is fast on my pot, as I can't test it because there is no chorus effect (I am sure there is a way, I just don't know it!). Usually I wire pots, try them, and if I need to, I invert #1 & #3 to get them moving the right way... Yeah, I know, that's probably not the best way to do it, but that's what I have done so far (I have only made 2 pedals, and one I still need to re-do because it sounds awful!).
So if I put it in a mid level, will the DMM be able to pick it up?
No sound coming out
Checked voltage at the socket (without PT in) to make sure no voltage from outside is hitting pin 6
Voltage was OK
All the leads that are suppossed to have continuity check out. Also cleaned up some areas where I had a bit of continuity where there was none suppossed to be.
Measured voltage at pin 1 of 082
Varies from under 1V to over 5V
Voltage readings at PT:
1. 5.03V
2. 2.50V
3. 0V
4. 0V
5. 1.95V
6. 2.43V
7. 0.311V
8. 0.496V
9-16: 2.51V (starts a bit higher and comes down)
Put in a fresh PT. Not much changes (except voltage at pins 5 and 6 increase slightly). Put old PT back in.
I am officially stuck! I still got plan C (the printed board from Canada), but that has taken FOREVER to arrive at the freight forwarder in Miami! Anyway, what else should I check?
Remove the transistor?
Is the PT still getting hot?
I did not leave the pedal onas long as I did yesterday, so I am not 100% sure, but it did get warm.
There's no reason for it to get warm, other than locking up. Do check out the parts connected to pin 6. Did you try lifting the 100R resistor (I think Jim suggested this earlier)? It should definitely stay cold with only the 2K2 connecting it to ground.
R22 (100R) and R20 (to break the dry feed from the output) are disconnected. Just to clarify, it is not getting hot in any way, shape or form; it is just slightly warm (normal temperature for any IC). It is not COLD, but it is not hot. But there is no signal getting through (with the dry feed disconnected).
Tomorrow (I can't work on it tonight) I will go through it once more. Maybe use the Audio Probe to see where the sound is going out... Not sure still what I should do. But definitely, the problem is in the wet signal. The dry signal is working just fine (well, it was before I pulled R20!).
Now, I know it is not the PT (or at least, not ONLY the PT) because I tried with a fresh one.
Pin # | Freq.Ctrl. V | Felipe V | Felipe NEW PT V |
Pin 1 | 5V | 5.03V | 5.03V |
Pin 2 | 2.38V to 2.42V | 2.50V | 2.50V |
Pin 3 | 0V | 0V | 0V |
Pin 4 | 0V | 0V | 0V |
Pin 5 | 2.75V | 1.95V | 2.45V |
Pin 6 | 0.61V | 2.43V | 2.43V |
Pin 7 | 0.88V | 0.311V | 0.641V |
Pin 8 | 0.88V | 0.496V | 0.816V |
Pin 9 to 16 | 2.41 (slight movement) | 2.51V (starts higher) | 2.51V (starts higher) |
Obviously the problem is coming from PIN 6. I also do not get oscillation in PIN 2 (I put the final reading, but it does move when I connect the reader for the first time).
Well, on to Plan C... I just got my JMK PCB for the little angel. Gonna use it for the third try. Third time's the charm, right? At least I got to improve my soldering skills with the prior tries!
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/IMG_20161208_223222.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/IMG_20161208_223222.jpg.html)
Is it me, or it ALMOST looks A LITTLE better than my homemade PCB?
The moment of truth? Breath is bated.
Quote from: jfrabat on December 08, 2016, 10:10:06 PM
You can hardly tell the difference... ;)
Hey, guys, could what I was experiencing be due to using 10 nF instead of 100 nF capacitors in 2 places? Building Plan C, I noticed I had more 103 caps than what I used in the new build and 2 104 caps missing. Could this the the reason it was not working? I do not know which caps were wrong, as I had already taken out the ones off the previous board...
By the way, the board is coming along nicely. My soldering skills are also improving (I feel this PCB is easier to solder than the home made ones; maybe the double side thing? Or maybe the new temperature controlled Weller iron?).
AND THE AWARD FOR THE MOST IMPROVEMENT IN SOLDERING IN 2016 GOES TO...
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/IMG_20161209_222036.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/IMG_20161209_222036.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/IMG_20161209_222054.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/IMG_20161209_222054.jpg.html)
Anyway, this is where we are at as of tonight. Tomorrow I have to buy some ceramic 104 caps (only got poly ones, and they do not fit well in the PCB), and attach the pots and leads and then is off to sound test!
Speaking of capacitors, what is the main difference between ceramic and Poly? When should I use which?
Oh, and I am missing one resistor, and I need help figuring this out. In the build manual it says R2 is CLR. What the heck does that even mean? All the others have values...
Quote from: jfrabat on December 09, 2016, 11:51:03 PM
Another thread where I gave my take on caps: http://www.diystompboxes.com/smfforum/index.php?topic=116096.msg1074164#msg1074164
CLR is a Current Limiting Resistor for an LED. Value is generally not critical. Try 4.7k, perhaps if your circuit doesn't specify.
There are often 4x 100n (or about that value) around the PT2399. I and I'm sure many others have experimented with the values. I think having lower values makes the sound noisier & grittier. I don't recall it causing total failure.
Probably too late to suggest leaving out the pin 6 100R and the dry feed mix resistor (different part numbering on this pcb?).
Quote from: anotherjim on December 10, 2016, 09:24:06 AM
I can always desolder them. Do you think its worth a shot? It's not like I can finish the board without the missing caps, which I need to get later on.
Quote from: EBK on December 10, 2016, 05:46:39 AM
Oh, OK. I do have a 4.7k already next to the LED. Which brings another interesting subject up; all my grounds are connected in the wiring, but the PCB has grounds for the DC jack, switch LED and Audio jack. I only have one ground coming in. I should use the DC jack one, right? Or is it better to undo what I have and wore everytbing to the PCB? Similarly, the LED is wired directly to the sqitch with its own resistor.
One more question; in the schematics, the pots only use pins 2 & 3 (well, I always assumed "n/c" stood for "not connected; I could be wrong!) but here they are connecting all of them to the PCB. Should I wire them up?
N/C is "not connected". Generally, however, we would tie that extra pin 1 to pin 2. Won't change anything though.
As far as grounding goes, there and endless opinions on the topic. There are definitely some wrong ways to ground things, but otherwise there is a wide murky swamp of "proper" and "good enough". I personally prefer tying all my grounds to the DC jack rather than to the PCB, but I tend to shy away from telling others they should do the same. Should sound the same either way.
But, if you say something like "ground is ground -- they are all the same," you risk being burned at the stake. :icon_lol:
Quote from: jfrabat on December 10, 2016, 10:01:56 AM
After further inspection, it looks like Pin 1 of both pots are not going anywhere on the PCB (the square pads). I'll just leave them disconnected.
If you're board-mounting your pots, then solder all three connections for a little extra mechanical strength.
If you're connecting via wires, you might in any case want to connect the unused lug on the pot to the middle wiper lug as insurance against the wiper connection going bad.
The boards are wire mounted. I will put in the jumper if I get UN-frustrated! Just finished wiring everything up, put in a fresh PT, and still, no chorus. Only the dry signal is getting through! HELP!!!!That's 3 strikes for me already!
Voltages at PT:
Pin # | Freq.Ctrl. V | Felipe V | Comment |
Pin 1 | 5V | 5.01V | OK |
Pin 2 | 2.38V to 2.42V | 2.51V | A little high; is it an issue? |
Pin 3 | 0V | 0V | OK |
Pin 4 | 0V | 0V | OK |
Pin 5 | 2.75V | 2.12V | A little low; is it an issue? |
Pin 6 | 0.61V | 2.43V | THIS IS AN ISSUE! |
Pin 7 | 0.88V | 0.864V | OK |
Pin 8 | 0.88V | 0.868V | OK |
Pin 9 to 16 | 2.41 (slight movement) | 2.51V (starts higher) | I think this is OK, right?/td] |
Obviously the problem is still coming from PIN 6. I also still do not get oscillation in PIN 2 (I put the final reading, but it does move when I connect the reader for the first time).
Another thing to note is that PIN 1 on the OpAmp is not oscillating. The second OpAmp is, though (pins 6-8). Also, no heat from PT, so that's an improvement. What do I check now? The pots? I am a bit stumped!
You could look at this as great news. It suggests that your homemade board is probably good if you are having the same problem with the fancy one.
I know you've played around with different chips. Have you tried replacing any caps? I assume you recycled these from your other board.
Quote from: EBK on December 10, 2016, 06:41:36 PM
Some of them, yeah... But the store was out of 104 ceramic caps. Only had 2 left, which is exactly how many I needed to finish the pedal. I have 104 poly caps, but they are bigger than what fits on the board. That's why I used the small yellow ones and the 2 ceramic ones (which were not yet in the picture). I have enough to swap them all out, but stuffing them in will take some creativity...
Here you can see the small sized 104 caps I used. I have 2 ceramic ones in the 2 empty slots above the PT. The poly ones I have are a little bit bigger than the green 332 that's also above the PT. The electrolitic caps I can replace with the exception of the 100uF (I think I am out of those). Should I replace the caps? Is there a way to test them?
The other thing I have not replaced are the pots. And the pot quality here is not the best; I already had issues with the pots before. I may just start with that and see how it goes. Would bad pots give me this issue? Is there a way to test them as well? They are easier to replace than the capacitors...
Bad pots would stop the LFO from working. If the speed pot is bad, it won't oscillate. If the depth pot is bad, it won't get through to pin2 of the 2399.
You could be in a position where you cannot have any confidence. Could the PT2399's all be bad? It can happen, depends where you bought them from. It has been known for fakes/rejects to get into the market.
I've found it helpful to set the chip up in a minimal circuit on a breadboard like this...
(http://i.imgur.com/k9On7wE.png)
I forgot values on the in and out caps. These can be 100nF too.
Really only have to connect the signal output to a test amplifier. Simply touching the signal input with, say the tip of a screwdriver, injects noise that comes out obviously time delayed when the delay control is set to maximum resistance. With a continuous test input signal connected, it's hard to tell if there's delay, but turning the delay time control up and down will be heard as pitch shifting.
Quote from: anotherjim on December 11, 2016, 09:10:05 AM
I built the circuit, but I get no sound at all out of it... 2 different PT's. I'm guessing that's pointing to my problem?
Have we touched upon the possibility of counterfeit PT2399 chips yet?
2 sources both counterfit?
Sent from my EVA-L19 using Tapatalk
Well, underspec/faulty/fake goods get out by the backdoor and sold as legitimate somewhere - to some distributors as well as in small quantities via e-bay, alibaba et al. I would not expect devices from "knowledgeable" dealers like SmallBear and the bigger traders (Mouser et al) to be suspicious as they likely either chose to, or have to buy from official sources.
If you assume they are first quality goods and should be ok, then you have to ask why aren't they now?
Static damage is the first suspect.
Are you still discharging the chips before use?
Low humidity where you are? This greatly increases the generation of static charge. I seldom have to worry about this - we've only had 3 low humidity days so far this winter and there's none in the forecast ahead.
Insulated flooring/clothing/work surface? Same effect.
Leaky soldering iron (the tip is not grounded)? Can damage circuits if the chips are in the sockets while soldering.
Incorrect packaging? IC's should either be in an anti-static plastic tube, pressed into anti-static foam or a piece of polystyrene WITH a metal foil surface. If anything came packaged differently - loose in an ordinary bag (anti-static bags ok - but the pins get bent) or on a plain piece of polystyrene then the supplier is very naughty indeed.
Quote from: anotherjim on December 11, 2016, 05:06:54 PM
The local dealer just gives you the IC. No packaging. The ones from amazon came in polysterene, no metal... So I guess I need to order new ones?
In that case, I would definitely suspect those you have and order from another source.
I've just seen something in another thread, made me think - jfrabat - are you using the same pots as from your first angel build? I don't think we've ever seen them in any photos, is there a chance we might see them, with their wires and solders?
and while I'm grasping at straws, can you put your meter across the pot connection ON THE BOARD (power off, as we are measuring ohms) and turn the pot shaft - does the resistance actually change? what range of reading do you get?
Quote from: duck_arse on December 12, 2016, 08:48:51 AM
Yes, they are the same pots. I will take some pictures and readings tonight.
500k pot goes from 0.6 ohms to 482K ohms
100k pot goes from 7.0 ohms to 89.8k ohms
I think I got both on backwars, though, as 0 is at full clockwise turn. Changing them is simplybreplacing pin 1 for pin 3, right?
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/IMG_20161212_185225.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/IMG_20161212_185225.jpg.html)
IF those pot resistance measures are at the board, then the pot wires and the pots are ok. and yes, swap 1 for 3 if they work backwards [but log (A /audio taper) pots will feel odd, bunched one end when reversed].
and now your pots - those rivet/eyelets holding the solder tag against the carbon track/pot wafer are not for our use! don't be poking wires and solder thru them, cause if they expand or loosen or wiggle, the pot is shot. (or that connection is shot, anyway.) and poor solder connections that close to the pot body cause many a crying builder. so wrap the wire around the lug/pin and solder, or cut a very small piece of vero or perf, solder that to the pins, and then wires into the board.
To add to what Stephen said: In the future, do not solder pots that way, but don't unsolder these now or you run the risk of destroying them.
I took the readings at the pots themselves; I will retake the readings tonight (or tomorrow night, as I have a business dinner tonight) at the board to be sure. As for the rivet, I think I now understand why I damaged so many pedals on my last build... I just thought they were poor quality! Live and learn, I guess...
New PT's on the way (Smallbear). It should take some time for them to get here, though, considering the season and the i ternational shipping.
Well, guys, I am officially stomped! New PT's arrived, but no change in behavior from the pedal! AAAARRRHHHGGG!!! >:( >:( >:(
I understand your frustration. :icon_sad: Could you post some updated pics, including all the off-board wiring? On the (somewhat) bright side, the fact that new PTs didn't change anything does narrow our focus a bit.
I'll trouble shoot it (AGAIN!) tonight, and take some new pictures. I plan to:
1. Verify that all resistors and capacitors values are what they should be
2. That all IC's are connected the right way (yeah, I have done that before!)
3. Will most likely replace the pots (I got some new better ones from Small Bear and Mammoth to replace the cheap ones I have been using; but this I am leaving for last, as the ones I got were working last time I checked)
Anything else I should look for?
OK, this is what I have so far:
I bought this (http://jmkpcbs.com/product/little-angel/)pcb from jmkpcbs.com
Here's the build instructions:
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/Build.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/Build.jpg.html)
And this is how mine is looking as of today:
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170105_183705.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170105_183705.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170105_183758.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170105_183758.jpg.html)
And the pots:
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170105_183638.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170105_183638.jpg.html)
Changes from the plan are basically replacing the TL072 for a TL082.
Voltages are:
PT2399:
Pin 1 5.03V
Pin 2 2.51V
Pin 3 0V
Pin 4 0V
Pin 5 2.93V
Pin 6 2.42V
Pin 7 0.683V
Pin 8 0.696V
Pin 9 through 16 2.51V (Some movement when you first connected)
TL082
Pin 1 4.55V
Pin 2 4.55V
Pin 3 4.41V
Pin 4 0V
Pin 5 2.86 to 2.94V
Pin 6 3.00 to 3.04V
Pin 7 2.75 to 3.30V
Pin 8 9.04V
78L05
Vin 9.03V
Gnd 0V
Vout 5.03V
2N3904
C 2.42V
B 0.447V
E 0V
I will use the photo above to go through the resistance values to make sure I did not use the wrong ones. I will also check the caps, but later on, as I have to do some stuff now... For everyone's reference, this is also stated in the instructions:
L is the + connection of the LED
I is PCB Input
G is the ground for the switch (mine is soldered to the jack)
O is the PCB Output
+ is 9V in
- is ground for DC jack
GND is extra ground for 1/4" jack
Could you post a pic of the jacks (I/O and DC) and stomp switch?
phone's too small to look it up but will the replacement of the TL072 with at the TL082 make any odds?
Quote from: stallik on January 06, 2017, 11:34:56 AM
It's compatible, but has better noise performance than the TL072, if I recall correctly. Shouldn't cause any problems here.
Quote from: EBK on January 06, 2017, 11:14:28 AM
Sure, I will post them tonight. But I am pretty sure the problem is not there, because I get the bypass signal just fine and when I activate the effect, the dry signal goes through (if I lift the resistor, the dry signal goes away). I will post them anyway, though, just in case.
Quote from: EBK on January 06, 2017, 11:36:59 AM
I think I have some Tl072 in the OpAmp kit I bought; I could change them and see what happens...
Quote from: jfrabat on January 06, 2017, 01:06:27 PM
I understand what you are saying. The thing that prompts me to ask is that, from my understanding, you are having the same or similar problems despite swapping out whole boards and tons of parts.
Occasionally, "pretty sure the problem is not there," is the reason we don't find the problem. :icon_wink:
Quote from: EBK on January 06, 2017, 01:31:42 PM
Good point!
Here are the other pictures. Mind you, there is no DC jack (yet).
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170106_193716.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170106_193716.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170106_193800.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170106_193800.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170106_193821.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170106_193821.jpg.html)
Felipe
OK, I was checking my resistors; found one inconsistency (I think; can you please verify?):
R1: 100K (OK)
R2: 4.1K (NOT REALLY USED)
R3: 10K (OK)
R4: 10K (OK)
R5: 10K (OK)
R6: 10K (OK)
R7: 33K (OK)
R8: 68K (OK)
R9: 10K (OK)
R10: 10K (OK)
R11: 10K (OK)
R12: 100 (OK)
R13: 2.2K (OK)
R14: 220K (OK)
R15: 4.1K (SHOULD BE 4.7k; AM I READING THIS RIGHT? COULD THIS BE THE CAUSE?)
R16: 220K (OK)
R17: 100K (OK)
R18: 47K (OK)
R19: 10K (OK)
R20: 10K (OK)
R21: 1M (OK)
R22: 330K (OK)
R13: 10K (OK)
R14: 470K (OK)
R15: 1M (OK)
Can you guys confirm if R15 is really wrong? Could it be the cause of my problems?
Are these two "4.1K"s measured (out of circuit) or eyeballed? (FYI, 4.1K isn't a value in E12, nor yet in E24.) Either way, they shouldn't make any noticeable difference.
I checked the bands, not the measurements....
Then they're 4.7K.
Is it worth it redoing everything off board? New pots and jacks and switch? I got enough to do it...
What's connected to the stereo output jack? If you're using it to switch on the power, then I'd expect to see the black lead from the battery connected to the ring lug (and to nowhere else). It's a bit difficult to see what's going on. Perhaps you could take a picture where we see everything: board, pots, jacks, switch?
I think I am going to redo everything today. I have a better quality wire, pots and stereo jack now, so might as well get the good ones in to match the awesome board I got. So even if the error is not there, there will be better quality compone ts used.
Here are the pics...
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170108_082851.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170108_082851.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170108_082922.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170108_082922.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170108_082928.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170108_082928.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170108_082941.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170108_082941.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170108_083008.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170108_083008.jpg.html)
By the way, I noticed I am out of 500K pots... So no can do on the remake (I could rewire, though).
Bump... Any ideas? I am flat out...
Ive been following on this for a long time and am sorry you havent gotten
this to work.
But . . . for me most of the cases were solve by simple obvious things.
You probably already have .. . but i would ask again are you sure your in and out
is not backward. i mean maybe your plugging your guitar and amp on the wrong ends
have you tried this?
Also i notice you solder your pots on the base. Ive tried this and everytime
the pot is damaged thats why i wont solder there anymore.
Quote from: maiko on January 11, 2017, 12:44:15 AM
Yup. I double checked, and I am connecting the right way in. Notice that I use different type of connectors, so it is easy to tell them apart...
I checked the pots a few replies back, and they were both OK. I was planning on changing them, but I am out of 500K pots... I may just change the 100K one, though, as I still got some of those (don't remember if I got them in B or C, though).
Are you sure you've used the right pads for the pots?
Orange and Green are in the middle position, so yeah... If the white wire was on backwards, the pods would be backwards, but it would work...
I decided to put new pots in, and try without a stomp switch (wiring the board directly to the jacks) and see how it goes. I took everything off the board last night, and will start soldering everything together tonight. Keeping my fingers crossed!
I was just about to suggest taking the switch out just direct in and out
Decided on a movie night with the wife instead, so no progress today!
OK, tried bypassing the stomp switch. Used new pots also. No change. Same issue; the dry signal gets through, but the wet signal is nowhere to be found. Used new PT (a fresh one I got from Smallbear), new TL072 (replacing the TL082 I had in, just to be sure that was not the issue), but we have no change whatsoever. Here are the pics of how it stands (notice that the OpAmp changes in one of them). If you can spot anything going on, please pointed out to me.
This is getting VERY frustrating! out of the 5 pedals I have worked on, one works flawlesly, one works, but I do not like the sound, this one dows not work, the EA Tremolo does not work, and the Vulcan Rat worked, but then something happened and it stopped working (I have yet to dive into that one to figure out why; I am sure it is something as simple as a broken wire). I cant be THAT much of a crappy DIYer!
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170122_214335.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170122_214335.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170122_214158.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170122_214158.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170122_214140.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170122_214140.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170122_214103.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170122_214103.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170122_214049.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170122_214049.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170122_214041.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170122_214041.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170122_214017.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170122_214017.jpg.html)
Could it be the ceramic caps? I read somewhere that they are not that great... What else could it be? Voltages are the same as last time I posted them:
PT2399:
Pin 1 5.03V
Pin 2 2.51V
Pin 3 0V
Pin 4 0V
Pin 5 2.93V
Pin 6 2.42V
Pin 7 0.683V
Pin 8 0.696V
TL082
Pin 1 4.55V
Pin 2 4.55V
Pin 3 4.41V
Pin 4 0V
Pin 5 2.86 to 2.94V
Pin 6 3.00 to 3.04V
Pin 7 2.75 to 3.30V
Pin 8 9.04V
78L05
Vin 9.03V
Gnd 0V
Vout 5.03V
2N3904
C 2.42V
B 0.447V
E 0V
Felipe,
I really hate to see your bad luck continue with this pedal, especially since your soldering appears to have improved so much since you started this project.
I haven't brushed up on the PT2399 lately, and I don't know for sure what every voltage is supposed to be, but I suspect you have a collection of perfectly fine chips and the problem lies elsewhere (of course, I've warned you before about "problem lies elsewhere" thinking, and I'm not heeding my own advice at the moment :icon_rolleyes:).
One thing that caught my eye, and I'm not sure if it makes a difference, is your diode D1. The spec calls for 1N4148. Yours looks different from the 4148s I've encountered before.... I'm wondering if just maybe (this is a longshot) you have the wrong sort of diode and that is messing up things with Q1 and pin 6 of the 2399.
EBK, thanks for your patience with me, and for the complement of my improving skills!
I am not a huge connoisseur in electronics, but the diode DOES say 41 and then 48 right below it... My guess is that it is a 4148 (I am assuming the 1N part; it is not written in the diode; there is something, but I cant figure it out), but I am not 100% sure on that. Here are the pics (by the way, the numbers are TINY! I had a real hard time checking! And I was using one that was not installed!).
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170122_234157.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170122_234157.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170122_234209.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170122_234209.jpg.html)
Here's the symbol (whatever it is) that's above the 41 (looks like a script T or something):
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170122_234850.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170122_234850.jpg.html)
I looked up 1N4148 in Google (images) and found many similar to mine, though, so I am now even more sure that this SHOULD be the right one...
Got it. Thought your installed one looked darker and had a 0 on it. Must have just been the lighting. Oh well.
so, what parts are common to this build and the previous?
There is a 4007 on, but thats D2...
Quote from: jfrabat on January 23, 2017, 09:11:49 AM
I was just seeing the bottom of the 8 on D1 as a 0. I can actually make out the "48" now that I've taken another look. You've got the right part.
I apologize for not taking the time to go back and reread everything you've done so far, but have you tried the following with an audio probe?
1. Check to see if your dry signal is making it to the 2399 input.
2. Check to see if you are getting a signal out of the 2399 output.
I did, but a while ago. I'll try it again and see what happens.
Quote from: duck_arse on January 23, 2017, 08:28:40 AM
Most of them. Is it time to take them all out and replace them?
no. list them, we'll see what we can pick from the list. if you keep getting the same problem with each rebuild using the same parts, logic says it's one of those parts.
Quote from: duck_arse on January 26, 2017, 08:14:09 AM
+1
You know what, when I ordered the PCB from JMK, I did not receive the PCB in a long while, so they sent me a new one. Well, it turns out that yesterday the original one arrived. So one option would be to use the new PCB and start from scratch. That way I know I am not using the same components as the previous versions!
By the way, and for the record, I already notified them that I received it yesterday, and Jacob told me to just keep the PCB. What a great service from these guys! I truly recommend them, not only because their PCB ROCK (see the picture below), but their service is impecable.
I think I have enough stock to make a new one without having to reuse components. Now, quick question, though; should I use ceramic disc capacitors again? Or should I try to find Poly film ones instead?
Watching this and rooting for you. I hope you get a working chorus pedal soon. :)
QuoteNow, quick question, though; should I use ceramic disc capacitors again? Or should I try to find Poly film ones instead?
I would suggest finding film caps, but not necessarily for the reason you might think. You are about to build this thing for the third(?) time. Anything that slows you down may also help prevent your muscle memory and/or subconscious secretly repeating a mistake we haven't spotted.
Sounds weird, but I have to imagine there are dozens of us here (with a nod to maiko chiming in with something remarkably similar to something I too posted way back) that
need you to succeed with this project, if for nothing else, to reaffirm that patient persistence and a positive attitude pays off (if you quit, we will all patiently and persistently hold you down and positively force you to keep building this thing -- just kidding :icon_razz:).
I will try to find poly film ones then. Not sure how easy they are to find in Costa rica, but I will try. By the way, it is the FOURTH try! Now, I am nlt sure what's the right adjective for me... My wife would probably not call me so much as persistent than hard headed, but one thing is for sure; I tend not to give up (failling pisses me off, and I cant shake that feeling until I succeed, so I keep doing thing until they come out right).
I will most likely finish my Vulcan Rat first, though. I had that one working, and the crappi cables I was using kept breaking, so I will do that one again. I just finished drilling the holes in the PCB I made for that one a few minutes ago (and its the best PCB I have made so far, if I do say so myself!). But this Little Angel battle is far from over! I will report back soon! And thanks to all for the words of support and the technical help! You guys ROCK!
OK, guys, I revisited the testing circuit. Remade the whole thing on the breadboard. When the pot is at 0, sound comes out, but if I turn it up, A LOT of noise comes out and no delay effect. I am about ready to start construction of the new board (now that I have the EA Tremolo and Vulcan Rat pedals all done, so this one is the only one on the building table as of now; of course, with a board for a phaser, that can rapidly change). But I am really looking forward to building a Chorus and a Delay (which I think are musts), and the Chorus is the one that has so far beaten me (but that will NOT be the end result!).
Anyway, back to the testing circuit, I tried replacing the PT and the Pot, but the result is still the same. I want to be sure the PT I use on the new board is sound, so I want to attack this problem first. Any ideas? By the way, the circuit is exactly as above, with the exception of the Pot being 50K instead of 47K.
I was happy to see you get other stuff to work. Now we can lay to rest the theory that your soldering iron shoots lightning bolts through whatever it touches. :icon_wink:
How many PT2399s do you have?
Did you find new caps?
I have about 10 from 3 sources (including Small Bear). I have not yet looked for the caps, though.
Are you at least using new (non-recycled) caps for this?
Quote from: EBK on February 12, 2017, 04:17:49 PM
Yes and no, the old pedal is still built, but these are the same caps I had on the breadboard before. I have enough to replace them, but I figured what are the odds of these caps and the ones in the pedal being all bad, right?. I will not take it apart so as not to reuse any part.
OK, finally started the new Little Angel board. Basically got everything in the board except for the 4.7K resistor (CLR), a 100uF cap (need to buy some), and the 2N3904. When I got to the last component, I started looking in my parts to find it, but I noticed I did not have any. Checked the old board, and noticed I have a 2N2222 in there. Looked at my previous post, and I did mention it before, but there were no comments on it. My question is, are they interchangeable? It seems the only difference is the current they can handle (with the 2222 having more capacity)... Is this right?
Correct. 2n2222 can handle more current. Should be fine. (And now, we know that you have working delay chips!)
Quote from: EBK on March 04, 2017, 06:59:41 AM
Right! I am keeping the breadboard (I plan to build the Deep Blue Delay as a pedal, but will not use the components on the breadboard) so that if I suspect PT2399 lockup, I can use that to test it.
Quote from: jfrabat on March 04, 2017, 01:21:25 PM
Good plan!
This is where I am at now...
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170304_183955.jpg)
As you can see, I got a 470K resistor missing. Checking my work, I noticed I had put a 470R in by mistake. Since I was all out of 470K, I went to the store, and guess what? They gave me 470R by mistake and I did not notice until I got home!!! Argh!!! Will have to get resistors on Monday now.
Anyway, I ditched the ceramic capacitors and used box capacitors instead. All components are new, no carry over from the previous pedals... The store was also out to 100uF caps, so I need to get that as well.
By the way, I am out of C500K pots; should I use A500K instead? C is not really all that common in Costa Rica (I have B and A, but the A is Alpha and the B is a cheapo Chinese pot)
Quote from: frequencycentral on November 03, 2010, 03:28:41 PM
Here are voltages just taken from my Little Angel, which sounds the same as the breadboarded version I did you soundclips on. Speed at 3 o'clock, Depth at 12 o'clock:
PT2399
1: 5
2: 2.38 to 2.42
3: 0
4: 0
5: 2.75
6: 0.61
7: 0.88
8: 0.88
9 through to 16: 2.41 (slight movement)
NE5532
1: 0.13 to 4.9
2: 2.9 to 3.2
3: 2.7 to 3.1
4: 0v
5: 4.79
6. 4.9
7: 5.14
8: 9
OK, guys. I am officially STUMPED and PO'ed! This is the THIRD time I build this pedal, this time with ALL new parts (no recycled ones from previous tries), and I have EXACTLY the same result. First time I tried etching my board. Second and third I used boards from JMK PCB. WHAT AM I DOING WRONG???
Here are my voltages:
Battery: 9.20V
TL082:
1: 4.68V
2: 4.68
3: 4.53V
4: 0V
5: 2.80 to 3.70V
6: 2.88 to 3.65V
7: 0 to 1.4V
8: 9.20V
78L05:
IN: 9.2V
GND: 0V
OUT: 5.01V
2N2222:
C: 0V
B: 0.449V
E: 2.43V
PT2399:
1: 5.01V
2: 2.5V
3: 0V
4: 0V
5: 3.40V (should be around 2.65V)
6: 2.43V (should be 0.61V)
7: 0.875V
8: 0.995V
9 to 16: around 2.5V with movements
PT2399 was tried out in the Deep Blue Delay BB, so it is working. All caps and resistors were double checked, and they are correct (same with the previous board, which is still built). here are some pics so that you can check if you see something I do not (and yes, the battery WAS plugged in when I tried it):
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170312_101957.jpg)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170312_102122.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170312_102122.jpg.html)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170312_102106.jpg)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170312_102056.jpg)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170312_102042.jpg)
Any other ideas? I cant believe I can build all other boards and not get this one to work!
Thought this was the fourth build.
Anyway, it is quite a mystery. I did laugh as I instinctively looked at the soldering first, but in a good way. I remembered where you started. Soldering looks very good now (I've told you this before). Your wiring is looking good too, but what is that black wire hanging out by itself and only connected at one end?
Quote from: EBK on March 12, 2017, 01:04:18 PM
I miscounted the grounds. It is just an extra ground. I will de-solder it (most likely, I will replace the ground on top and replace it with this one)
Actually, you are right!
BUILD 1
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20161122_193134_2.jpg)
BUILD 2
BUILD 3
BULD 4
I guess I have improved... Practice makes perfect, right? ;D
Now if I could only get this darn thing to WORK! What I cant understand is why i can get all the other pedals (Vulcan Rat, Deep Blue Delay, Screechy Cat, EA Tremolo, etc.) to work, but not this one (even after 4 tries!)...
2N2222:
C: 0V
B: 0.449V
E: 2.43V
These can't be right. E (Emitter) should be directly connected to 0v. Is board meant for 2N3904? Your 2N2222 may not be same pin order.
Anyway, I suggest you take this transistor out and see what it does then.
Quote from: jfrabat on March 12, 2017, 02:25:01 PM
What if you didn't miscount?
Perhaps try grounding that wire.
When I have more time, I'll take another look at those voltages....
Quote from: EBK on March 12, 2017, 02:48:04 PM
Just tried it in case that was the issue... No change.
Quote from: anotherjim on March 12, 2017, 02:32:22 PM
2N2222:
C: 0V
B: 0.449V
E: 2.43V
You are right: I mislabeled the ports. E is 0V and C is 2.43V. Base is correct at 0.049V. Anyway, I double checked the pinouts of both, and theydo match:
(https://encrypted-tbn2.gstatic.com/images?q=tbn:ANd9GcTFHu9uua-41L34ScZCG1AgjSDsWkcbz5lVaEDyJE9iy1PcSfzf)
(http://lampatronics.com/wp-content/uploads/2015/04/2n2222.jpg)
I also used this (http://www.learningaboutelectronics.com/Articles/2N3904-vs-2N2222.php) information before making the swap.
3904 2n2222 2n5088 2n5089 all the same pin out i use interchangeably No problems
Whatever is going on, I am pretty sure once I fix it, I will have 2 chorus... Since the other one was doing exactly the same thing, they probably have the same issue. By the way, I did not have and 500C pot, so I used a 500A wired backwards. Not optimal, but it SHOULD work, right?
i got mine to work with "b" pots or linear taper
Quote from: jfrabat on March 12, 2017, 10:26:12 PM
Err. if you wired it backwards, then it's probably working in reverse. ie when you think it's full on, its actually full off if that makes sense. I'd hate to think the pedal is working OK but you have the effect level at minimum..... sure you tried that but thought I'd mention it
I have to say that I really don't like the control current transistor arrangement. On power off, the 47uF timing capacitor is expected to discharge into the 5v rail via the reverse diode - however this diode could be 0.8Vf while we see the transistor BE is only 0.5Vf, so that diode is not really doing anything. I believe it is possible to power the chip up and down with the transistor always on so the chip has to start with 100R which we know is bad.
I repeat advice to take the transistor or 100R out!
OK, i did not get anything except try without the 100R resistor. Is that correct?
Yes, the 100R, because that is a major difference between this circuit and the delays that work.
Do I replace it, jumper it or just leave the conection open?
Remove it.
Ok. I will try it. So if I am reading the diagram right, that would take the transistor out of the equation, right? OK, I will try.
Now, quick question, to make this a richer learning experience; explain to a noob in simple words what is the purpose of that transistor (to understand why I am taking out of the loop). In my overdrive, I use them for boost (or so I understood, anyway!), but this pedal uses an OpAmp, so it should not be the source of boost, right?
It's being used as a delayed switch here, I believe.
Yes it's time delay switch using the transistor as the "switch"
On power up the 100R should be disconnected from the PT2399. The transistor should be turned off initially and that means there is no path to 0v through the transistor collector-emitter for the 100R, effectively switching it out of circuit. When the 47uF capacitor charges up sufficiently (the time delay), the transistor turns on because there is enough voltage to "forward bias" it's base-emitter junction. In your case, this appears to happen about 0.5V.
(http://s11.postimage.org/f4n92ssj7/Modded_Angel.png)
This was the easiest schematic to find - ignore the red modification notes.
Now, the time delay is how long it takes the 47uF to charge via the 68k resistor. This must be long enough for the PT2399 internals to get running normally with only the 2k2 resistor setting the delay time. Then the 100R can be switched in, making the PT2399 delay shorter to suit the chorus effect.
If you think about it, the time delay due to the 47uF capacitor only happens IF the capacitor is completely discharged before power is switched on. I'm not sure that this is always happening. Indeed the 47uF may keep a small charge for a very long time after 9v power is removed.
A cure might be to fit another 1N4148 diode in series with the transistor base. This would raise the time it takes for the capacitor charge to turn the transistor on AND negate the effect of any small charge remaining in the capacitor from the last time power was applied. I also wonder if it wouldn't be better for the existing 1N4148 diode that is meant to discharge the capacitor to have it's cathode connected to the 9v supply instead of 5v. I suspect it will be able to discharge the capacitor faster that way.
This is a bit technical, but MOS devices like the PT2399 tend to have very high resistance to the power supply once the supply voltage falls to about 1v, because none of the MOS transistors in it can be turned on at that low a voltage, so there isn't much resistive loading on the 5v supply that could discharge the 47uF capacitor below that 0.5v level. It could perhaps have 0.4v on it for quite some time.
You know, now that you mentioned the transistor, it got me wondering; I know that transistors can get damaged by heat when soldering. I did not socket my transistors. Could it be that I damaged them while soldering? Should I try removing the transistor and soldering a socket and THEN trying the pedal?
Quote from: jfrabat on March 14, 2017, 12:12:56 PM
I'd say yes. We haven't tried
everything until we tried that, right?
I'm looking at that transistor arrangement.....
Does that cap really have a discharge path other than through the transistor? I don't see the diode doing anything here.
Update: ok, I see that the 68k resistor is connected to the +5v node, which would eventually drop to ground potential upon power down, providing another discharge path. I can also see how the diode can speed up the discharge once it conducts, decreasing this effective discharge path resistance.
OK, just to be clear then, the best way to proceed for me now would be remove the transistor (2N2222) and solder the socket and try the pedal without the transistor, or do I need to take out the 100R resistor as well?
Quote from: jfrabat on March 14, 2017, 03:27:22 PM
Without the transistor, the 100R is already effectively disconnected. Leave it on your board.
OK. Will report tonight on the results.
Quote from: anotherjim on March 14, 2017, 11:17:30 AM
Upon removing the 9V supply, the 7805 provides a resistive path to ground through its output terminal. (The PT2399 possibly also provides a discharge path to ground.)
The charge would neutralize fairly quickly.
There is a resistive path to ground in the 7805 output, but I don't know what value.
I'm still not sure having the timer threshold voltage as low as the base-emitter forward voltage be a good thing. 0.5V seems a touch low for a silicon small-signal transistor base-emitter junction, maybe that particular transistor is damaged/leaky.
if we were to fit the reverse cap-discharge regulator diode (no. I dunno what to call it, the cap flyback preventorator?) across the regulator out to in, like in the datasheet, wouldn't that provide a [known] discharge for the offending cap?
I don't think we really care how fast it discharges, as long as it does.
More important to us is the charge time, which must be more than 400ms, I believe.
Capacitor charge should reach 0.5v in about 350ms. That situation is complicated by the conduction "knee" of the base-emitter, which starts to take some charging current away from the capacitor before it gets clamped at the forward voltage drop - so maybe it can take 400ms. It's bit tight though isn't it?
The problem anyway with that discharge diode is that it will be "off" until the 5V supply falls sufficiently below the capacitor voltage. If the capacitor voltage is 0.5v and the diode forward voltage is 0.6v, then the 5v supply needs to fall to -0.1v, which can't happen. It's possible that the diode never conducts.
The discharge path is then via the 68k in series with whatever else goes to 0v.
If it was only 68k, and the 5v supply falls to 0v instantly (it won't), at 5 seconds after switch off the capacitor voltage is down to 0.1v. Not 0v - so I think you can fool the circuit if power goes on and off quickly enough, which is easily done when testing.
Well, guys, we have still not found the problem. Took out the transistor tonight, but no change. Still only sending the dry signal through.
Sorry to hear that
i hope you wont mind ive taken it upon myself to check your layout against the JMK pdf all seems to
be ok but can you verify if your sockets for your ic on the solder side has continuity
to your ic legs.
If the jmk board is a dual sided board there are some soldering on your component
side that appears to be incompletly soldered. maybe you can check that speed lug 3
in your picture there is cleary a trace from that to a 220k resistor but there doesnot
appear to be solder on the component side of the board. check and verify if there is continuity
from that to the resistor
Quote from: maiko on March 17, 2017, 12:32:54 AM
to your ic legs.
I dont mind AT ALL! IN fact, thank you! It would not be the first time I misplace components or use the wrong ones! This one I have tripple checked hunting down whatever it is that it is making it not work! I will test continuity tomorrow (I'll be busy playing the guitar this evening!)
side that appears to be incompletely soldered. maybe you can check that speed lug 3
in your picture there is clearly a trace from that to a 220k resistor but there does not
I will check all soldering where there appears to be some suspect contact on the top of the board, and re-solder those that are suspect. I will also install the socket for the transistor (I simply uninstalled it last night, got frustrated, and left the whole thing as it was!).
Felipe
You know how those PT2399 are prone to stay locked up. Did you test the chip in your working delay or discharge any static after removing the transistor?
No, I did not... Let me try that first.
OK, I resoldered the spots that seemed that had no contact on the top layer, changed the PT for one on the Deep Blue Delay BB (so I could be 100% sure it worked) and tried the pedal. No change. This is REALLY frustrating! Any ideas on what to check?
What's your supply voltage measuring?
Could you double check the color bands on R8? They look off....
Did you end up socketing a replacement transistor?
Also, could you take a picture of the markings on your transistor?
Quote from: EBK on March 24, 2017, 04:22:33 PM
I checked the bands and its OK. You probably noticed on a different pic the same, right?
You probably saw this one too... But just in case. Values are:
Quote from: jfrabat on March 12, 2017, 12:35:39 PM
Battery: 9.20V
TL082:
1: 4.68V
2: 4.68
3: 4.53V
4: 0V
5: 2.80 to 3.70V
6: 2.88 to 3.65V
7: 0 to 1.4V
8: 9.20V
78L05:
IN: 9.2V
GND: 0V
OUT: 5.01V
2N2222:
C: 0V
B: 0.449V
E: 2.43V
PT2399:
1: 5.01V
2: 2.5V
3: 0V
4: 0V
7: 0.875V
8: 0.995V
Yes
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170325_181004.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170325_181004.jpg.html)
(perspective makes it look like a super tall transistor, don't it?)
Here:
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20170325_180010.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20170325_180010.jpg.html)
With power off. The transistor and the PT2399 taken out. Measure the resistance between the PT2399 socket pin 6 and pin 4.
Quote from: anotherjim on March 26, 2017, 05:16:40 AM
2.2K.
Looking at the diagram, it should be 2.2K, right? Because the other grounds get disconnected as I take out the the transistor, right?
Correct, it should be 2.2k. I was asking to prove that there couldn't be a short circuit there, since removing the transistor made no difference. The PT2399 should run with 2.2k to ground from pin6, but yours doesn't seem to want to. There could still be other reasons for the fault, but I feel this should be checked out...
...so, the next thing I would do is to remove one end of that 2k2 from the board so you can temporarily solder a higher value resistor in its place - anything from 4.7k to 47k will do, just to see if you can get some delayed sound out of it. Keep the transistor removed for this test.
The Deep Blue, has a fixed resistor of 2.7k to pin6 (it's only the 2.7k when the delay pot is set to minimum resistance). I would be surprised if the difference between 2.2k and 2.7k is enough to make it work or not work, but I'd want to prove it.
At this point, Im willing to try anything, so thanks for the pointer. How can I check if the signal (dry signal) is actually making it to the PT?
Audio probe. You should hear the input on the PT2399 pin 15. That is the point at which the input goes into the delay.
You should hear delayed signal out of its pin 12. This is where it comes out of the delay. If there is signal out of pin 12 then it is working with "some" delay.
I will test it tonight
Took a little hiatus... Already finished an Engineers Thumb Compressor, and close to finishing a Deep Blue Delay (humidity permiting my painting it!). Once that's all done, it's back to this one (the only one I have not gotten to work!).
Sent from my SM-G935F using Tapatalk
OK, guys, I still need help on this one. I took some time off (well, not really "off", just changed projects and made some more pedals; I actually made the Engineer's Thumb Compressor, and a Deep Blue Delay clone, both of which are working wonderfully), but considering I have 2 of these boards built, and that neither one has worked, I wanted to get back to them and finally get one of these suckers to actually work. Plus, I could really use a Chorus on this pedal board:
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/4c9dab8b-da1a-4b60-8b18-52c7c3ff098d.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/4c9dab8b-da1a-4b60-8b18-52c7c3ff098d.jpg.html)
Got 5 pedals working (technically, 6, but I do not like the sound of the 6th); one that is not. Not a terrible record, but lets make it better!By the way, both the Screechy Cat and the Vulcan Rat overdrives are getting a make over and will be done in 1590B size; I have a board for a Phaser that I will build soon, and between that one and this pedal, I
will need the space! I also ordered a kit to make custom length cables to neaten everything up a bit. I will not, however, use the old enclosure I made for the Little Angel because (1) I already used the same color for the Deep Blue Delay, and (2) I rather go smaller into the 1590B enclosure, but I will keep the same graphic style as the other one. I'll just probably go with a metallic violet color or something along those lines...
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/20161127_002707.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/20161127_002707.jpg.html)
Old enclosureAnyway, where do I begin to check this darned pedal? As for the PT's, I tested them all in the Deep Blue Delay (when it was in BB form; I took that apart and actually built the pedal now), and they all worked. The issue is still that the dry signal goes through, but not the wet signal (I get no chorus effect).
Battery: 9.20V
TL082:
1: 4.68V
2: 4.68
3: 4.53V
4: 0V
5: 2.80 to 3.70V
6: 2.88 to 3.65V
7: 0 to 1.4V
8: 9.20V
78L05:
IN: 9.2V
GND: 0V
OUT: 5.01V
2N2222:
C: 0V
B: 0.449V
E: 2.43V
PT2399:
1: 5.01V
2: 2.5V
3: 0V
4: 0V
7: 0.875V
8: 0.995V
Glad you still haven't given up on this!
It's been a while, so we may end up rehashing stuff from before.
As for that transistor, I'm assuming the emitter is at 0V, not the collector, as you've listed it.
Yeah, that was a typo...
Ok. Looks like you have the same voltage on either side of R12 (the 100R resistor). That suggests your transistor is not conducting. This is consistent with the base voltage being so low. Now, why isn't that base voltage getting any higher?
A test:
With the transistor out, measure the voltage at the middle pin of that socket (where the base would go). That node should reach about 0.7V 5V. if it does, then I would say you have a bad transistor.
If that voltage doesn't reach 0.7V 5V, then it could be a bad cap or diode.
There may be an error on your board. I'm going back to find the schematic....
OK, Thanks! I will test tonight.
Hmm... In the build docs for your board (http://jmkpcbs.com/wp-content/uploads/2014/10/Little-Angel.pdf), the schematic shows the diode on the base of Q1 going to ground, but other schematics show it going to +5V instead....
I've edited my test.
You know, I never actually checked the schematics of the JMK board, but you are right. It is different from what I have found online for the Little Angel. This is the one I was using when I did my own board:
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/Little%20Angel%20Miracle%203.png) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/Little%20Angel%20Miracle%203.png.html)
And this is what the build docs show:
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/Screenshot%2014.png) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/Screenshot%2014.png.html)
The diode is certainly going to GND (vs 5V). Could that be the issue?
You basically had the same exact problem with each build, whether it was your own or theirs, right?
(Their board might be correct despite their schematic error.)
Quote from: EBK on June 05, 2017, 05:45:31 PM
Yeah, but my first board was crap, and the second one, although better, I do not feel confident that the issue was not the board.
Quote from: EBK on June 05, 2017, 11:40:04 AM
A test:
Ok, new readings of Q1 at the socket:
C: 2,43V
B: 0.455V
E: 0
This is with the 2N2222 out...
Battery measured 9V
Sent from my SGPT12 using Tapatalk
By the way, the 1N4148 is in fact going to ground, in case that's important... all other readings are sa,e as above.
Hmm.. so something else (cap or diode, likely) is pulling that voltage down... We can set aside the possibility of bad transistor for now.... Edit: Hmm....
Quote from: anotherjim on March 26, 2017, 04:40:50 PM
I got signal in pins 9, 12, 14 and 15 (only checked that side) on the PT. On the TL, only on pin 1... that does not sound right, though, right?
Swaped TL082 for TL072. still only pin 1 has signal..
An inverting op-amp:-
The +input (Pin3) has the DC reference voltage. No signal.
The output (Pin1) is the signal output. We expect signal.
The -input (Pin2) is a "virtual ground" if it's working properly. Would you expect signal on a ground? No signal is correct.
The input signal will be present at the input end of any resistor feeding the -input, not at the pin.
The same will be true of all the internal op-amps in the PT2399, which are all fixed as inverting. So you find signal on pin15 (output) but not on pin16 (-input).
That 1N4148 should indeed have it's cathode tied to Vb (5v). As it is, it's a coin-toss as to whether the diode or the transistor base-emitter will have the lowest forward voltage drop. If the diode's drop is higher (they often are but NOT always), it is having no effect on the transistor and not really doing anything at all. If the diode drop is lower then it will steal current from the transistor base-emitter and prevent the transistor turning on fully or never.
Please read back for the earlier trouble shooting hints. If you remember, those earlier attempts were sabotaged by faulty PT2399's.
Quote from: anotherjim on June 06, 2017, 08:15:26 AM
That part I get; but isn't Pin 7 also an output? Should there not be any signal at Pin 7? Or am I missing something?
So, how do I test this? Do I remove the diode and jump it to 5V?
Quote from: anotherjim on June 06, 2017, 08:15:26 AMPlease read back for the earlier trouble shooting hints. If you remember, those earlier attempts were sabotaged by faulty PT2399's.
The PT's were actually all working; we thought they were faulty, but they all proved to be working when I tested them one by one in the Deep Blue Delay...
TL072 pin 7 is indeed an output. However, there is no audio signal feeding any of its inputs. This op-amp is part of the LFO sweep oscillator, without which, there cannot be a chorus effect.
You can remove that diode for now. It is not essential.
Quote from: anotherjim on June 06, 2017, 01:21:03 PM
OK, now it makes sense. I will remove the diode and give it a go tonight.
UPDATE: I was looking over everything, and I noticed for some reason or another, I had swapped one of the pot's pins. I decided to just wire the pots directly to the board instead of using wires (since I am making a new enclosure anyway, it's not really worth the trouble of using wires). Tried the board. Same thing.
So I figured the diode could be the cause. Un-soldered one pin and tried it. No change.
When I went to pick up the board, I got singed by something hot. Turns out the 78L05 was hot enough to burn. I thought maybe it was damaged, so I replaced it. Same result (and new one still gets as hot as the old one).
Somehow I think the 78L05 should get hot, but not THAT hot, right? What else could be the problem here?
Hmm.... Something is drawing too much current. This is without the transistor and without the diode?
Quote from: EBK on June 07, 2017, 09:53:49 PM
With transistor. With and without diode is the same.
I find myself wondering if you have bad transistors. Does the regulator get hot without the transistor in the circuit?
Luckily, those regulators have a thermal shutdown circuit, so they should still work after burning your fingers.
If you still get a lot of heat off that regulator without the transistor, replace the electrolytic cap that connects to that diode.
Could you take a look at R8? In two of your pics, it has this hideous, pale look, but in another, it looks fine. It's bugging me. :icon_lol:
Quote from: jfrabat on June 05, 2017, 09:30:47 PM
C: 2,43V
B: 0.455V
E: 0
This is so odd. Was this without the diode too? If so, the only thing left is that electrolytic cap, acting like a 6k7 resistor. Or, your 68k resistor is WAY out of spec.
Either way, they don't explain the regulator heating up.
Quote from: EBK on June 08, 2017, 10:23:31 AM
C: 2,43V
B: 0.455V
E: 0
Those readings I took with the Diode in place.
Quote from: EBK on June 08, 2017, 09:39:19 AM
OK, this weekend I will try it without the transistor and see if it still gets hot. I will also replace R8 (68K) and the cap (you are talking about C13, right?)
(http://i46.photobucket.com/albums/f138/jfrabat/Guitar/Pedals/Screenshot%2015_LI.jpg) (http://s46.photobucket.com/user/jfrabat/media/Guitar/Pedals/Screenshot%2015_LI.jpg.html)
Tonight, though, I plan to enjoy the football (as in the sport you play with your feet, not the
other football that's played with your hands!) game between Costa Rica (where I live) and Panama (where I am from) for the World Cup elimination round. GO PANAMA!
Quote from: jfrabat on June 08, 2017, 10:57:20 AM
Yes
Tonight, though, I plan to enjoy the football (as in the sport you play with your feet, not the other football that's played with your hands!) game between Costa Rica (where I live) and Panama (where I am from) for the World Cup elimination round. GO PANAMA!
Enjoy!
Hi, guys. I have been messing with a bunch of other pedals, but this one is still on my to do list. So after 4 unsuccessful builds, I did the only reasonable thing; I ordered ANOTHER board (different supplier this time) and gave it a shot. Unfortunately, I am getting the
SAME results. I get the dry signal coming through, but not the wet signal.
This is the board from JMKPCBs (http://jmkpcbs.com/product/little-angel/) (the one I made some time back; actually, I made 2 of these, but this is the second one):
(https://s5.postimg.org/l5ouo3vk7/20171023_213011.jpg)
This is the newer board (from DELYKPCB (http://pcb.delyk.com/modulation/10-little-angel-pcb.html)):
(https://s5.postimg.org/tnyasg9sn/20171023_212942.jpg)
I will continue troubleshooting the first one simply because I have the schematics for that one and not the new one (on these (http://jmkpcbs.com/wp-content/uploads/2014/10/Little-Angel.pdf) build docs). Here's the schematic:
(https://s5.postimg.org/qh3r8tx2f/Little_Angel_JMK_Schematic.png)
Here is what the pedal is doing (and yes, I tried it with the guitar; there is only dry signal):
Now, last time I took voltage readings, this is what I got:
Battery: 9.20V
TL082:
1: 4.68V
2: 4.68
3: 4.53V
4: 0V
5: 2.80 to 3.70V
6: 2.88 to 3.65V
7: 0 to 1.4V
8: 9.20V
78L05:
IN: 9.2V
GND: 0V
OUT: 5.01V
2N2222:
C: 0V
B: 0.449V
E: 2.43V
PT2399:
1: 5.01V
2: 2.5V
3: 0V
4: 0V
7: 0.875V
8: 0.995V
As I mentioned on the video, the 78L05 is still getting hot as well. Also, all my PT's checked out in the Deep Blue Delay, so I know they work (at least all the chips work on the delay pedal). Any ideas what I should look at?
Just quickly.
The first picture (the one with the two pots mounted directly to the board) has a LM13700N OTA where the PT2399 is supposed to go. What happens when a PT2399 is installed?
Any chance of some pictures of the solder sides as well?
Quote from: Slowpoke101 on October 24, 2017, 12:06:18 AM
Just quickly.
Oh, whao... I missed that one! Let me put the right chip in and get back to you...
I think I know what is going on here...
Thanks to my previous error, I unplugged the pedal, and changed chips. Put the new chip in, but forgot to plug the battery. Since everything was running, as soon as I plugged the battery, I put the probe on the OUT pad, and VOILA! MODULATION! So I ran over to my guitar, but NOTHING! Hmmmm... Went back to the bench, and tested the signal; no modulation. Now, the only explanation I have is that my PT's are going into lock up. The thing is that I have 16 of them, and they all act the same way! Is there a way to prevent lock up?
The odd thing is that the pots do not affect the modulation I am hearing. In all the videos I have seen when you turn the pots, the PT will make an ATARI like sound while they are moving.... But not here. I tried to make a video, but it is difficult to note the modulation sound on the video, but there IS modulation. That is a step forward!
I will post the video tomorrow (it is loading). Maybe it helps (but as I said, it is hard to hear the modulation in the video).
Just had a quick look at the smaller board. Noted the following;
R1 appears to be 68R (or is it 6R8) not 68K. D1 and Q2 may be toast.
R7 appears to be 10K not 330K
R12 is obscured and not readable. Supposed to be 4k7.
Q1 (78L05) regulator appears to be in backwards. Remove PT2399 and measure the voltage on pin1 of the socket. 5V is expected but will be much higher if in backwards.
All these observations were taken from the doco on the deluk website.
PT2399s can and do lock-up. Usually this happens when too much current is taken from pin6 before the chip has stabilized after power on. That is the reason for the delay circuit (Q2, etc) on pin6, it gives the chip a chance to stabilize.
Sometimes a locked-up chip stays that way after power down (weird but it happens). Take the chip out and short out its legs on a conductive metal plate (copper clad board is good) wait a minute and try the chip again.
Haven't checked out the first board yet (other than the LM13700 oops). I'll get there or someone else will.
Quote from: jfrabat on October 24, 2017, 12:48:35 AM
Hete's the video:
Quote from: Slowpoke101 on October 24, 2017, 01:12:18 AM
Thanks a lot!
You are absolutely right on all the wrong resistors. I will replace both of them (R12 is 4.7K, so it's good)
(https://s5.postimg.org/o2gh22llz/20171024_063822_1.jpg)
I will also rotate Q2, as I think you are correct and it is on backwards (I will measure voltage first, but I think you are right). I will also ground out the PT and then I will try the pedal. If I still get no wet signal, I will replace D1 and Q2.
Sounds about right for this board?
All the test and videos were on the other board, which was my focus for the debugging, but tonight I will focus on this one.
Felipe
Felipe, this continues to be my favorite ongoing mystery. In my head, I keep pushing back the thought that this circuit only works outside of Costa Rica. At one point, I even wondered if it had something to do with what your kitchen countertops are made out of. :icon_lol:
I'm glad you are willing to revisit this.
IT WORKS!!!!!
IT REALLY WORKS!!!
IT WASN'T JUST A CONSPIRACY TO MAKE ME WASTE ELECTRONIC COMPONENTS!!!!
IT ACTUALLY WORKS!!! And rather well, I should point out!!!
I should point out that the board that works is the last one I made (the one from DelykPCB). I still want to get the other one running as well!
Of course, I still need to do something about the way the voltage regulator is soldered on... But I had a heck of a hard time getting it soldered in even the way it is, so I have NO IDEA how I will fix it (worst case scenario, it stays like that in the pedal; I think it would fit, actually!).
(https://s5.postimg.org/mhaw8rtwn/20171024_224757.jpg)
And the required sound clip:
https://drive.google.com/open?id=0B88Re3K-59SyNmhMMklNNFBTOFU
Setting for that one is about halfway on the speed and 2/3 on depth... It just a couple of chords, BUT IT WORKS!!! LOL!
Thanks everyone for bearing with a rookie! You guys ROCK (literally!)
Well done! You have beaten the "doesn't work in Costa Rica" phenomena!
Don't worry too much about the regulator's mounting, just make sure that it can't move. It would be better to have it mounted lower on the board but it should be OK.
Take some voltage measurements before you box it up. This may be useful for the other board.
Have fun with your new toy.
Quote from: Slowpoke101 on October 25, 2017, 01:12:43 AM
Thanks, man!
Sent from my SM-G950F using Tapatalk
we knew you could do it, jfra, nice work.
if'n you wanted to lower the reg, you could cut the leads just below where they bend in the pic, then heat each lead still in the board in turn, and pull with pliers. you could use your fingers if you wanted to. then you'll have less board heat-stress and mess and worries.
good luck.
sir im sooo glad you finally got this to work
It was also baffling me as how a prebuilt board could have given you soo much problem
Ive built 2 of these from my own etchings and well had to trouble shoot them to work
but nothing like the experience youve had
I admire your perseverance and keep on building.
I got so excited that it work, that I wanted another one (I put the original into a multi - 5 - effect pedal that I built to leave at the practice room in a friend's house, and I wanted one for my pedal board, which are individual pedals). I tried troubleshooting the JMK ones, but no dice. So I ordered another board from Delyk. It is up and running as well, so you can definitely get these to work in Costa Rica! LOL! Anyway, the only thing missing from that one is the decal (the Hammond 1590B is drilled, primed and painted; decal is also printed and clear coated. Tomorrow, after it is fully dried, I will place it, and then, when that dries, I will clear coat the top of the pedal - the bottom is already clear coated). Once again, thanks to all for your patience! I will post a picture of that one once it is in my pedal board.
As promised... Here's a shot of my pedal board with the Little Angel (my second) in its Hammond 1580B case in the pedal board. Except for the Ditto Looper, all the pedals are DIY (with LOTS of help from this site!). The unmarked one is an EA Tremolo.
(https://s5.postimg.org/yfdfdcl07/Pedal_Board.jpg)
My only gripe with my pedal board is that I accidentally switched the VOLUME and GAIN labels on the Vulcan Rat Overdrive, but that's a small issue!
Quote from: jfrabat on November 19, 2017, 02:56:37 PM
Just rewire it to match your labels. :icon_wink:
Quote from: EBK on November 19, 2017, 03:09:49 PM
Pots go directly to the board...
Quote from: jfrabat on November 19, 2017, 04:14:31 PM
Ok, so one extra step:
(https://images.homedepot-static.com/productImages/f4b09a30-99a2-44c0-b7ce-4108dcffcb03/svn/stanley-all-trades-cutting-pliers-84-105-64_1000.jpg)
:icon_razz:
Quote from: EBK on November 19, 2017, 04:28:29 PM
:icon_razz:
LOL! Nah, I think I'll just leave it as it is... Fact is, if I can remember what my pots are in my DIY multi effect pedal (which has NO labels), I figure I can remember these two pots are inverted!
(https://s5.postimg.org/mvd6ynw3b/20171119_153618.jpg)
From left to right: Screechy Cat Overdrive, Vulcan Rat Overdrive, Rocket Booster, Little Angel Chorus, Tap Tempo Delay (last one I still need to get to work; all the rest are up and running). I have no issues using it...
Oh, been there, done that ::)
I have built this and it works fine, but I changed pin 2 resistor from 33k to 10k (as proposed by AMZFX site) and had to reduce both pots - depth to A100k and speed to A20k to have audible results and usable control.
However, I am experiencing some faint hiss when playing - pedal is dead quite with stings damped. I have no idea what to try, so any hint is appreciated. Hiss was there even before changing resistor and pots, so it is definitely not connected to them.
Try several different PT2399 chips.
Some are more noisy than others.
Quote from: Slowpoke101 on February 03, 2018, 03:20:21 PM
I have five of them, so I will try. But I must desolder this one first, 'cause I didn't use a socket :P
However, could it be a problem with digital/analog ground? I had very similar problem with AMZ Q&D Compressor (hiss at note decay), and I was never able to fix it. :( SM2166 also has digital ground pin.
Hello, I opened a mini pedal I bought and found that it has a 78l05 and a rs2399(I am guessing it is a renamed pt2399) .
I was a bit disappointed because I thought it would be analog
but my question is :is the output signal of it fully digital?
Ι am guessing it is a little angel circuit , it has depth, level and speed controls.
Quoteis the output signal of it fully digital?
It's so common for brand marketing to claim analog when it's not completely true, that it no longer has the power to make my blood boil.
With PT2399 circuits where you may mix the clean/dry signal with the delayed signal, only the clean part of the sound is from a completely analog path.
It is possible to engineer the PT2399 delay to sound similar to BBD based designs, and some consider that an "analog" sound. In truth, the BBD has a digital element to its workings - but musicians have come to consider the BBD as analog technology, at least compared to the purely and obviously digital ones such as from Digitech etc..
QuoteI was a bit disappointed because I thought it would be analog
why disappointed? other than it's not what you thought you were buying (gear rarely is...)
QuoteΙ am guessing it is a little angel circuit , it has depth, level and speed controls.
DIY gifts like FCUK's Little Angel have been commercialized before, it's true, but any chip that does delay can
probably work as a chorus, too, it doesn't make it a nefarious rip-off. Depth and speed are controls basically on any pedal with an LFO. Anyway, most of those cheapo delays and chorus pedals are PT2399 based, and all of them, including the Little Angel are more or less based on the app circuit from the datasheet. One more reason to build your own pedals! :)
BBD pedals might not have DACs but plenty of digital delays have filtering on them now. All things being equal I can't hear the difference between a good digi delay and an analog delay, especially when it's on a guitar playing in a group. That doesn't mean PT2399s are awesome; there are "real" digi delay ICs (and micro computers) out there.
For what it's worth, I built a Little Angel years ago and still use it live all the time, I love it. I added a 'wet/dry' tilt control, which is key to its usefulness for me.
well I was looking at this circuit
https://i.warosu.org/data/diy/img/0007/98/1429543934493.png
is the the signal completely converted to digital?
or does it go through the 10k resistor on top and the 0.1 mikrofarad capacitor and blend with what comes from the pt2399?
Quotethrough the 10k resistor on top and the 0.1 mikrofarad capacitor and blend
yes, that's it, and that's the resistor you can replace with a rheostat/potentiometer if you want.
welcome to the forum!
i eat feta almost everyday :)
I swapped few PT2399 chips and they all sound the same. Like I have some hi-freqency distortion or buzz. What could be the cause?
Check your power supply doesn't make the noise with other similar circuits?
and double check capacitor values, some of the noise is filtered externally
My power supply is very well filtered, using toroidal transformer and is very capable - up to 3A. Other pedals work fine with it. I have another one with less power, but this pedal has the same noise with both of them.
I first built it using "birthday edition" schematic, which used 100n between pins 9 and 10, 100n for 11/12, 10n for 13/14 and 3n3 for 15/16. It was noisy as described. Then I found schematic called 2.0, and replaced capacitors as shown there: 10n for 9/10, 10n fo 11/12, 1n for 13/14 and 1n for 15/16, but noise is the same as before.
I have even tried to add some more filtering - 100n between pin 1 and ground an 1u between pin 2 and ground (as proposed somewhere), but it didn't change a thing.
The noise I hear is very similar to the sound of snare resonance when playing guitar loud in the same room, but I don't have a snare around and when pedal is bypassed, the sound is pristine. I have even tried what PRR proposed in another thread, to reduce input buffer's amplification, but it didn't change a damn thing...
Could it be some kind of layout problem? This is my PCB:
(http://i67.tinypic.com/fz3k8w.jpg)
why are you using a 5532?
I had one at hand. Why not?
try a different op amp, like TL072. op amps are not all the same, different input impedance, slew rates, headroom, etc.
I know they are not the same, I used this one because it has the smallest noise rate, and the circuit is a standard op amp buffer, no reasons why it shouldn't work. I will try to see what is going on at op amp output, if there is distortion at this point, then 5532 to blame, but if signal is clean, then problem is somewhere else.
Quotethe circuit is a standard op amp buffer, no reasons why it shouldn't work
it's not a voltage follower, it's an inverting amplifier with 5VDC bias, and that's only one of the op amps. the other half of the dual package is an op amp LFO
I know that. But there's nothing special with both of them, and they both work. But I will try to replace 5532 and put TL072 and see what happens.
QuoteThe noise I hear is very similar to the sound of snare resonance when playing guitar loud in the same room
something becoming microphonic? cracked solder joint, ceramic capacitor, something like that? could the 78L05 whine for some reason?
I have checked all joints, they're fine. I will try to check LM78L05 with scope, but no, it is not microphonic, just some tiny resonance like distortion. It is faint, but it is there. I have multilayer ceramic capacitors, but they are used for DC filtering only; all audio path caps are polyester.
I will try to bypass 1M feedback resistor at op amp with 100p, maybe it will help.
I have finally found enough time to mess with this one, so I found the problem. This is complete report on what I tried, hoping it will help someone in the future. :-*
I built it a long time ago, so I forgot that I didn't have 1n capacitors at hand then, and used 680p for filter caps instead. I tried to change a lots of things - including LFO resistors (changed all to 220k as proposed by Jack Orman, it seems to make it even worse), I have added different filtering caps on PT2399's pin 2, swapped different PT's, cut PCB traces to separate AGND and DGND (and it didn't work at all after that so I had to short them again), but the noise was still there and it was actually dictated by LFO. Finally I have found a comment somewhere on Internet mentioning putting 3n3 instead of 1n between PT2399 pins 15&16, and then I found that I have 680p instead. So I removed both 680p caps, put 1n between 13&14 and 3n3 between 15&16 and, voila, almost all the noise was gone. I also left 1u capacitor between PT2399 pin 2 and ground, cause it makes LFO a little bit smoother.
Now I was left with one more issue - some kind of LFO thumping when depth pot is at minimum, and rotating it I found that it stops after approx 8k. Since I have used 9k1 (I don't know why I didn't use original 33k, perhaps found this value on some of later schematics') between pot and pin 2 of PT2399, I replaced it with 20k and now thumping is gone even when pot is at zero.
I have also found out that depth pot sounds almost the same above 250k, so I used A250k instead of 470k, and I used A100k for speed - it seems better than original B100k to me.
So, I will most probably leave it like this, but there is also a suggestion to use 10k for voltage splitter at LFO with 47k for LFO feedback resistors, so I will maybe try that too, before I box it for good ;)
At the end, I have one question for experienced Little Angel builders: I've built it with NPN anti-lock circuit. There is a resistor going from pin 6 of PT2399 to ground. I've used 2k2, but I see 4k7 on some schematics. It is even absent at Jack Orman's version (which uses JFET). Is this value important or not?
The R from pin6 to find sets the delay time. Bigger is longer time until it gets into delay territory.
Hm, interesting! But it is only 100 ohm on original schematic and on v2; 4k7 on one labelled v2.7 and 2k2 on V3 (or "Birthday Edition"). And it is completely missing at Jack Orman's schematic. Now I am totally confused with this. :o
Look at the pt2339 data sheet it has a guide to delay times v resistors
It covers only values down to 288 ohms, which gives 32.6ms. That is quite a lot for chorus. 2k2 gives 54ms, which is even more, and 4k7 is around 84ms.
I will try to put 1k pot there and listen what happens.
Quote from: frequencycentral on August 09, 2010, 08:13:21 AM
I've had the idea to try a PT2399 chorus ever since I modded my Clari into a Clari Cubed. The challenge with the PT2399 is to get the delay time as short as possible while still having some wiggle room for the LFO injected into pin 6. I've tried PNP, NPN, FET and LDR - fail! The delay time is either too short for the LFO to have any wiggle, or too long and latency is obvious.
So, screw using pin 6, just ground the MF for the shortest possible delay time and instead modulate the vref at pin2. Shortest possible delay with as much LFO wiggle as you want. In fact it has to be tamed down or you're into tape wobble type effects.
(http://i210.photobucket.com/albums/bb292/frequencycentral/LittleAngelMiracle.png)
If I understand this well (the very first post of this thread :) ), pin 6 is not important at all, since LA uses modulation of a pin 2, so maybe it will not affect anything? I'll see.
The problem you'll likely hit is that the PT2399 won't start up with a very low resistance on Pin 6. It stops the oscillator, so no sound comes out. Generally, once the chip is going, it can handle the low resistance better. Plus there's considerable between-chips variation - some do it, others don't. Some delay designs have taken measures to avoid the minimum delay setting at start-up.
HTH,
Tom
This works really nicely for such a simple circuit...all praise to the creator!
There is the latchup problem with pin 6 which was easily remedied with the following addition...
(https://s22.postimg.cc/ij08itwx9/1535400177694.jpg) (https://postimg.cc/image/ij08itwx9/)
Hi guys, I can see that this thread is quite old. I am building a chorus based on the little angel but I am having some annoying noises. Please check the little video I made.
If the resistance from pin 6 of the PT2399 is less than 1.2K, it will make some his noise that will be modulated by the LFO. If i remove the depth pot, or the buffer I am using after it, there is a continuous hiss. If I increase the resistance value, There is no noise. I don't know what causes this, and I am starting to think that the chip doesn't like to operate at really short delay times.. :(
Here is the video
João
https://www.youtube.com/watch?v=tvzi1v-HmH0&t
Little Angel works quite different from datasheet normal operation. In datasheet, you vary Rvco value to get different delay times. Here, Rvco is fixed, and reference voltage is varied to get shorter delays, e.g. in chorus domain. I use 4k7 for Rvco, together with additional circuitry that switch to 47 ohm once chip is started, and it works fine.
Also, this circuit is very sensitive to digital noise produced by PT2399, all the connections must be as close as possible to IC pins, especially filtering caps. So I suggest you build this on some kind of vero board or PCB and then experiment.
Thanks, the problem is that with breadboard I can experiment. But will probably end up doing that.
By the way, you use the 4K7 resistor on pin 6 to kick start the chip only. When the transistor start conducting it uses the 47 ohm resistor plus the resistance from the transistor itself.. My problem is only the noise, all the rest seems to work really nice.. :)
João
Then you will have to try without breadboard. :) Before that try to add 10uF tantalum or low ESR electrolytic cap across V+ and GND pins, as close as possible to PT2399.
OK, tried tantalum 47uF.. Same, no difference at all.. Still the same noise you can hear on the video. A continuous digital whining is heard even if i remove the LFO and if the delay resistor is less than 1.2K. Of course, with the LFO this noise gets modulated as you can hear on the video..
João
I had this problem: https://www.diystompboxes.com/smfforum/index.php?topic=86297.msg1117367#msg1117367 (https://www.diystompboxes.com/smfforum/index.php?topic=86297.msg1117367#msg1117367) and solved it with that power filtering cap. I also used wrong values for filter caps (pins 9 to 16).
Try those values:
(https://i.postimg.cc/G29Rtwpb/little-angel.jpg)
Yeah, it looks like this might actually get to be a pedal after all.. 8)
Managed to greatly reduce the noise by decreasing the values of the caps on the pins 9/10 and 11/12. Instead of 10nF, I now have 6.8nF, but this is still not definitive. There is still a little noise but I guess I will have to reach some compromise, after all the PT2399 is very noisy.
One thing I have noticed now is that when I increase the delay time I get some noise when the guitar sound is fading.. I believe I can tame this changing the caps on pins 15/16 and 13/14.. Still playing with them.. I do like the way the increased delay with some modulation sounds :) ;)
I have just freed some other breadboard and will try a different approach as well, which consists in using pin6 for both delay time and modulation.. ;)
João
Try with 3n3 (c5 on my schematic) between 15 and 16, it did the whole trick for me.
That is what I have at the moment.. And have 10nF between 13 and 14..
I think I have it more or less working on the breadboard. I am just adjusting values at the moment. It doesn't look like a little angel anymore.. It is an angel on steroids now :) When I'm happy with it, if i ever will :icon_mrgreen: I will post the schematics and a sound sample.. :)
What I can say is this is too much work on a pedal that will probably never make it to my pedalboard, who knows :)
João
Unbelievable, it seems I can't decrease the resistance on pin 6 to less than about 1K as I get lots of hiss that oscillates with the modulation.. No, it is not caused by the LFO. If I remove the LFO completely out of the circuit, there is a continuous hiss. I can't believe that you guys are not having the same. Perhaps this happens due to the fact I bought my PT2399 at Aliexpress, so they aren't for sure originals. But I guess there aren't anymore original chips being produced?? :o
Will try to post some sound sample tomorrow..
João
I have few PT2399 which came from Ali, and few of them which came from Tayda. Not sure if there's a difference. I have also ordered few HT8970 from Ali yesteday, hoping to get even shorter delay times with them.
Cool, please let us know how you get on with the new chip. Might get some as well.. I will see if Musikding has it as well. Actually, I might also try the pork barrel chorus. need to get some ICs for it.. I don't know why I am doing this as I am not really into chorus Ha ha ha :)
But working on this circuit I found out that if i use a pot for the delay time, I can get some really nice tones, so it might be good to have such a circuit on my pedalboard.
I didn't manage to remove the noise completely, but I did manage to reduce it a lot. That increased the chances of being actually built and perhaps go on my pedalboard :)
Again, sound sample later in a while :D
João
Try to add that "Space" mod, it really makes things interesting!
Here is the link to an mp3 file of a little demo I have made.
I originally spoke while I was recording the guitar, but the microphone wasn't loud enough, so I have edited the file to remove the speaking and leave only the guitar.
It was recorded by my Soundcraft Ui12 mixer directly onto the USB thumb drive. I then used Audacity to remove my talking and normalize the audio. No other effect was applied.
I have recorded the clean sound at the beginning and also several times during the recording. Then played with the different pots (speed, Depth, Delay and mix (Wet/dry) ). I started with the shortest Delay setting, then pot (5K) at half, then full Delay, and at the end again the shortest delay. Please don't mind my guitar playing as i wasn't trying to play anything in particular, only some loose chords.
Please let me know if you are not able to download the file..
https://drive.google.com/file/d/18wCaHOaIclLoMxWJAfujh3sX8OOrDWzn/view?usp=sharing
Constructive comments are very welcome :)
I will try to also implement a "Tone" pot.
EDIT: Didn't like the "Space" feature :) SO, less components on my board.. I already have too many :) Need to draw a schematic to have a better overview of what I have done :)
Ok guys, this is where I am at. I have only tested the Chorus circuit itself on the breadboard, but the bypass circuit is the same I use on all my other pedals, so that should be working. Didn't test it all together though.. I am designing a PCB for it. Might etch it tomorrow. it gave me a huge amount of work so far to make it fit on a 54mm x 54mm double sided PCB, but I think i managed it, I hope :) ;)
Comments and constructive criticism is welcome :)
João
(https://i.postimg.cc/VdsDnVc5/Chorus-SCH.jpg) (https://postimg.cc/VdsDnVc5)
Why do you have two linear regulators for 5V?
LFO rate LED is a cool add on!
For two reasons. I wanted to separate the 5V from the bypass switching which uses a microcontroller, so it is digital, from the 5V that supply the PT2399 chip. This chip doesn't need more noise that what already produces by itself :)
The other reason is that I have used 78L05 regulators, which have a max current supply of 100mA. as you know the PT2399 takes about 30mA, and the switching circuit with the relay takes about the same, or a bit more.. Then there are 3 LEDs. With 2 regulators sharing the load, they will run cooler :)
Let's see how this comes out.. Will print the PCB on photo paper now and etch it.. Fingers crossed that there aren't any mistakes ;)
João
Something really weird, built a PCB for that schematic and it doesn't work. I don't have modulation. On the breadboard it works. Connected a scope to both and i get exactly the same readings on several points.
Then, started changing stuff on the breadboard to try to find the problem. Found out that the second half of the LFO opamp isn't doing absolutely nothing, but on the breadboard the modulation signal somehow passes through and reaches the PT2399. This doesn't happen on the PCB. Anyway, ended up modifying the circuit using less parts and only one half of the preamp and now it is working. And it was very easy to mod the PCB as well, so, no need to etch another one. Need just to fine tune some resistor and cap values and will probably install it in an enclosure.
Sometimes there are some situations that aren't logical at all :)
João
I think I got it to behave and sound quite nice. It will be boxed tomorrow. As you can see, the original little angel values were heavily changed, and some other stuff was added.
I don't know if I can call this a chorus because the PT2399 does not like very short delay times, but it does sound quite nice and it will have a place on my pedalboard. Due to the above, I have decided to name it "Wannabe Chorus" :)
Might actually build another one for my acoustic guitar.. Or perhaps will try the "Pork Barrel" Chorus, don't know yet. :)
Here is my schematic.
João
(https://i.postimg.cc/w11L544D/Chorus-Schematic.png) (https://postimg.cc/w11L544D)
And finished.. Here are some pictures :)
João
(https://i.postimg.cc/9zw1kLQp/IMG-20190130-192048.jpg) (https://postimg.cc/9zw1kLQp)
(https://i.postimg.cc/WhM8Ntrq/IMG-20190130-192251.jpg) (https://postimg.cc/WhM8Ntrq)
(https://i.postimg.cc/bSfnWHmC/IMG-20190130-190530.jpg) (https://postimg.cc/bSfnWHmC)
Quote from: jhsa on January 30, 2019, 02:03:08 PM
João
did you shrink wrap your board? why? nice looking build.
I shrink wrap all my boards to avoid shorts. there are many metalic parts around the board, like pots, jacks, the enclosure itself. If the board touches them, it might create a short and get damaged, and if you are playing, it might ruin your night :) And keep things tidy as well.
João
Does someone have a copy of the schematics of Little Angel Mini Chorus moded by Earthscum? Care to share it with me?
Sorry to bring up an old thread, but I recently built the V2 Little Angel Chorus from TagBoard and I am having an issue with the LFO clicking (I think). I've recorded the sound to hopefully help diagnose the issue.
Audio Probe: https://www.dropbox.com/preview/Little%20Angel%20Chorus%20Click/Little%20Angel%20Chorus%20Clicking%20Probe.wav (https://www.dropbox.com/preview/Little%20Angel%20Chorus%20Click/Little%20Angel%20Chorus%20Clicking%20Probe.wav)
(This is probing pins 1, 7, 6, and 5 of the NE5532 op amp. It's definitely quieter on pin 1 (output), but still there! Don't mind the hum, that's in my DAW, not when I direct monitor the pedal)
Dry: https://www.dropbox.com/preview/Little%20Angel%20Chorus%20Click/Little%20Angel%20Chorus%20Clicking%20Dry.wav (https://www.dropbox.com/preview/Little%20Angel%20Chorus%20Click/Little%20Angel%20Chorus%20Clicking%20Dry.wav)
Wet: https://www.dropbox.com/preview/Little%20Angel%20Chorus%20Click/Little%20Angel%20Chorus%20Clicking%20Wet.wav (https://www.dropbox.com/preview/Little%20Angel%20Chorus%20Click/Little%20Angel%20Chorus%20Clicking%20Wet.wav)
(Dry and Wet were recorded at the same time using 2 channels on an audio interface)
Here are the pin voltages on the NE5532 and the PT2399:
NE5532
1: 4.85
2: 4.62
3: 4.62
4: 0
5: 2.8-3.25 cyclic
6: 3.0-3.25 cyclic
7: 1.7-4.5 cyclic
8: 9.26
PT2399
1: 5.02
2: 2.5
3: 0
4: 0
5: 5.02
6: 0.45
7: 0.25 (drops to 0 when testing)
8: 0.25 (drops to 0 when testing)
9: 2.5
10: 2.5
11: 2.5
12: 2.5
13: 2.5
14: 2.5
15: 2.5
16: 2.5
Voltages taken without any audio signal being played. Strangely (maybe) when I play something and then probe (with a multimeter) pin 2 of the PT2399, the audio signal is killed and I have to cycle the power supply off, then on, to get it to start again.
Anyone have any ideas on what to check or what could be causing this issue?
Ye olde LFO ticking. The first thing to try would be a TL072 in place of the NE5532, as it is in the original. There's a lot of misinformation online that the 5532 are "better" than the TL072. Yes, they can be better. But that's a long, long way from always better. Often enough, the 5532 is worse.
What layout are you using? If you're making your own layout, you can buffer the LFO signal with an emitter follower or another op amp, you could use a different op amp for the LFO, you can use some of the "anti-latching" tricks people have come up with to deal with the finicky PT2399, etc. Keep in mind the PT2399 is a quick & dirty karaoke machine IC, it's not intended for "professional" use, despite the legion of pedal makers and behringer type crooks using them in their designs. Some finessing is required.
Your voltages look fine.
EDIT: bravo on a great troubleshooting post, you did your homework
Welcome to the forum!
If trying a TL072 doesn't solve it maybe try a TL062, they're often used to cure LFO ticking problems as they're low current draw. I think they have more noise than the 072 but see how you get on.
Ordinarily i'd suggest providing the lfo with 'isolated' power via a low value R and high value cap to ground but since this circuit using a dual op amp for both the LFO and audio it won't work.
How is your off-board wiring?
Quote from: garcho on October 03, 2019, 05:18:22 AM
Thanks for the tips! I don't have any 072 or 062 op amps but I did have similar results with an LM833N (what I had on hand). I am using the V2 layout that IvIark posted on tag board effects.
Quote from: patrick398
Uhh, I just poked the input/output wires from the circuit through the enclosure and plugged them into jacks on a breadboard. No stomp installed yet.
If you can read wobbling voltage from the LFO, you should see wobble on the PT2399 pin2 unless the depth is turned down.
Pin 5 is the delay clock. It ought to read closer to 2.5v. That it is reading 5v suggests the delay is locked up, or at least it was when you took the measurement.
Quote from: anotherjim on October 03, 2019, 01:23:53 PM
I think it might have locked up when I touched pin 2, so when I subsequently checked pin 5, it was at 5V. I can check that again tonight. Should it be locking up when pin 2 voltage is measured?
Taking voltage readings from pin2 should not cause lockup.
If you have not included the anti-lockup circuit, I'd recommend temporarily replacing the 100R resistor between pin6 and 3 of the PT2399 with something larger like 1k until the problem with the LFO is sorted out, that way you shouldn't be troubled with the lock-up problem confusing things.
I used the V2 layout which does include anti-lock. However, after the first 5 or 10 seconds, pin 6 should be grounded. Does that change whether or not it will lock up when probing?
http://4.bp.blogspot.com/-vh39ImHNIJ0/UVSr6KhaPEI/AAAAAAAAFWA/5Zsre3f8XoU/s1600/Little+Angel+Chorus+V2.png (http://4.bp.blogspot.com/-vh39ImHNIJ0/UVSr6KhaPEI/AAAAAAAAFWA/5Zsre3f8XoU/s1600/Little+Angel+Chorus+V2.png)
Measured voltages again. This time waiting until last to measure pin 2 of the PT2399. Pin 2 starts around 1.78V and jumps up to 2.5 almost immediately, with the chip locking up and no sound being produced until the power is cycled. Pins 7 and 8 of the PT2399 don't drop to 0 when the chip is not locked up. This circuit uses an anti-lock transistor for startup, in series with a 47R to ground. There is also a 100R resistor to ground in parallel with the 47R and transistor. Admittedly, the transistor does not fit snug in it's socket, but I don't think that would cause it to lock up when probing. Thoughts?
Voltages below.
NE5532
1: 4.85
2: 4.62
3: 4.62
4: 0
5: 2.8-3.25 cyclic
6: 3.0-3.25 cyclic
7: 1.7-4.5 cyclic
8: 9.26
PT2399
1: 5.02
2: 1.78 (then straight up to 2.5 and the chip locked up)
3: 0
4: 0
5: 2.76
6: 0.45
7: 0.69
8: 0.70
9: 2.5
10: 2.5
11: 2.5
12: 2.5
13: 2.5
14: 2.5
15: 2.5
16: 2.5
It's possible that the LFO ticking and the delay lockup are two separate issues.
I would tackle the lockup first since it's not going to give any kind of effect if that keeps happening.
The chorus effect requires a very short delay time and pushes the PT2399 chip beyond its specifications to achieve this.
As I read the tag layout, the delay time control resistor to ground from pin6 is a fixed 100R. This low value already exceeds the recommended 2k for that resistance. Incidentally, I have never known a PT2399 to lock with a 1k minimum.
The anti-lockup transistor, after a time delay, adds a 47R in parallel.
The time control for that chip is intended to be done using the pin6 resistance, but because of the very low pin6 resistance, the LFO is fed to pin2. Pin2 is the chips operating reference supply voltage and will normally have a decoupling capacitor attached and nothing else. Using the LFO to wobble that reference modulates the delay time.
It all adds up to the chip being pushed beyond its design specification with a low time delay at startup that is pushed lower by the anti-lockup and lower again at one extreme of LFO sweep. The lowest delay times are achieved by making the internal timing clock oscillator go really fast - over 20Mhz and this is what it doesn't much like.
Removing the transistor and replacing the 100R pin6 resistance with 1k should stop the lockup. In addition, check that the LFO depth connection to pin2 has the correct series resistor (33k). This won't give a proper chorus effect, more like a wobbly slap-back echo, but at least you should hear something happening.
Once you can get the thing behaving, you can put things back, but I would leave the pin6 resistor as 1k and change the 47R in the anti-lockup to 100R.
Quote from: anotherjim on October 04, 2019, 04:23:04 AM
FWIW i have never had any issue with latch up using 510R at pin 6
Any advance (or is it retreat?) from 510R? :icon_biggrin:
Incidentally, I suspect that with the anti-lockup (some say latch-up, same thing) you don't need the fixed pin6 resistor at all. The chip won't mind at switch-on and as the transistor turns on, it will still get a "soft-start" from a high to low resistance. I'd still change that 47R to a 100R though.
Quote from: anotherjimIncidentally, I suspect that with the anti-lockup (some say latch-up, same thing) you don't need the fixed pin6 resistor at all. The chip won't mind at switch-on and as the transistor turns on, it will still get a "soft-start" from a high to low resistance. I'd still change that 47R to a 100R though.
Removed the 100R from pin 6 to ground. Still locks up when measuring pin 2 voltage. I did find that if I short pin 2 to pin 3 (ground), it resets it most of the time and starts working again. Not sure if that is expected behavior or not.
I wonder if your meter doesn't have a fault and is leaking voltage out. Placing a voltage higher than the chip supply on a pin will cause some chips to latch-up.
If you have any small signal diodes to hand like 1N4148, temporarily solder one between pin 1 and 2 with the cathode at pin 1 and that will prevent pin2 getting a higher voltage - but I have wondered if feeding something into pin 2 via a series capacitor (as the one from the LFO does) cannot under some conditions "pump up" voltage on pin 2 and cause lockup.
