I've made framus cobra preamp, with FETs and Im running it with 12v power supply. I would like to put ROG's condor cab simulator in the same box, but condor requires 9v. Any advice?
The Condor will run fine on 12V.
use a 10v 1 watt zener diode with a 100 ohm resistor..very simple..makes a great voltage regulator....
Quote from: lonewolf on April 15, 2012, 03:47:09 PM
Do you have a diagram of this is use , or a link etc etc ...
A 78L09 provide regulated 9V without wasting as much power as a zener.
Go read geofex.com.
In this case, Power Supplies Basics (http://geofex.com/Article_Folders/Power-supplies/powersup.htm (http://geofex.com/Article_Folders/Power-supplies/powersup.htm)), from 2001.
