Does anyone on this site have a lead to a source for 50% center tapped potentiometers? I've looked around the net and different manufacturer's data sheets but I'm drawing a blank exept for custom orders or roll your own.
I've opened a 16mm Alpha pot to see how it could be manipulated and have found that the resistive material is a bit too close to the outer edge of the wafer to attach anything with a lasting bond.
I saw a post here by Dan N with a tutorial on using a rivet to make the attachment but the link is dead.
Any Ideas?
Thanks,
Larry
Maybe connect the two parts of a stereo pot in series and use the point where you connect them as 50% tap? Behaviour would not be the same as a 50% tap, but -depending upon your application - this might work for you?
Maarten
I recently bought some dual 100K w/center tap off Ebay. I hope this link is still good;
http://www.ebay.ca/itm/NOBLE-100K-DUAL-LINEAR-POT-LOUDNESS-TAPPING-/150557282743?pt=LH_DefaultDomain_0&hash=item230de9d1b7 (http://www.ebay.ca/itm/NOBLE-100K-DUAL-LINEAR-POT-LOUDNESS-TAPPING-/150557282743?pt=LH_DefaultDomain_0&hash=item230de9d1b7)
Hope it helps.
Cheers,
Dino
