Quote from: Phend on April 15, 2024, 11:35:09 AMAdding black behind florescent is a good idea.
Quote from: eh la bas ma on Yesterday at 12:34:02 AMI just want a multi-fx stompbox with lots and lots of effects, in order to ease my burden when i am traveling.If this is the main goal and you don't want to set up for programming, why not buy one of the tiny commercial DSPs like Nux Mighty Plug?
Quote from: DrAlx on Yesterday at 08:50:00 AMQuote from: DIY Bass on Yesterday at 05:07:36 AMThere are a lot of patches collected together here https://mstratman.github.io/fv1-programs/
They are just collected from around the web, so they may not all work, but there are a lot here to try out
It seems those patches are in assembly language (ASM files). They need to be compiled using the spin assembler to produce hex code. Then you need another program for either PickIt or Arduino to burn the hex code to the EEPROM.
Not sure what my advice to a novice would be. You need instructions on:
1) How to compile ASM files to hex code using either the Spin assembler (which is for MS Windows only), or the alternative spin assembler (asfv1) which works on both Linux and MS Windows but its a command line program and you need install Python.
2) How to wire a Pickit or Arduino to the EEPROM.
3) What software to get on your PC to program the Pickit or Arduino so it can burn the hex code.
Maybe this is a question best asked on the Digital & DSP section of the forum.
Quote from: half_smith on April 16, 2024, 06:07:47 PMI did my best to build a "Neutron" with NOS Optocoupler but just can't get it to sound right, either misses the bias sweet spot or starts to sound overloaded, almost like feedback. I dunno...Did you fiddle with the drive pot at all?
Page created in 0.146 seconds with 16 queries.
