LINE 6 DL4 BROKEN...WHY?
Started by fildubya, December 12, 2012, 04:29:07 AM
fildubya
HEY,  I have a problem with a 2-year old Line DL4 that I can not seem to figure out.
I use the pedal in a looping format with a couple other pedals (Boss RC-50/20) and yesterday it just stopped working. I was troubleshooting the obvious factors (e.g. changing adapters, power sources, instruments, cables, etc) and then I took it apart.
I noticed the red power wire was leading to the battery input and was corroded. I don't know whether the battery nodes correspond with the overall power relationship to the adapter input, but I brushed the corrosion off anyway (with baking soda). Still though..nothing going...
anyone have any idea how I could salvage this amazing musical weapon?
thanks, PHil
Processaurus
These units seem to have trouble with the power supplies, it would be worth starting your debugging there.  It is a complicated system with 3 different charge pumps and a few regulators.  It takes 9v AC and turns it into regulated +/- 5v for analog stuff, and 3.3v for the digital.
Here's one man's advice:
http://www.diystompboxes.com/smfforum/index.php?topic=41142.msg386161#msg386161
I don't necessarily agree with how he kludges the power supply (because then you need a funny adapter), but if it works, it works.  He does a good job of walking through the system, however.
Here is Mr. Huge's schematic he posted of the power supply, very helpful info:
http://www.aronnelson.com/gallery/main.php/v/MrHuge/Line+6/
I haven't been able fix mine though.  I recommend putting a cap on your repair time.  These pedals are very complicated, and failure prone.
