Eternity Burst (Boutique Screamer) tone squealing problem
Started by Pyr0, January 05, 2013, 02:48:36 PM
Pyr0
Hi, maybe someone can help with this.
I've built an Eternity Burst based on this schematic - http://img526.imageshack.us/img526/1354/soatebsqt4.jpg
On vero using this layout by Mark
http://3.bp.blogspot.com/-g2MZA2DVMy8/T6OVUzHRURI/AAAAAAAABaw/7Hily8T3C5Q/s1600/Lovepedal+Eternity+Burst+-+SIP.png
It works fine, except when I turn the tone control almost fully clockwise I start to get some oscillations. Twiddling the guitar volume and tone controls alters the frequency of the oscillations. It happens with a battery or power supply.
Any suggestions ?
thanks
rockhorst
Check continuity with a DMM to see if you've accidentally connected something to the first lug of the tone pot that shouldn't be there.
Nucleon FX - PCBs at the core of tone
Senor Avocado
I know this is kind of a zombie thread, but i had the same exact issue with my build with this layout and i was wondering if the OP was ever able to solve the problem. Thanks!
LightSoundGeometry
Quote from: Senor Avocado on August 13, 2016, 09:18:18 PM
I have had same problems with the exact same layout, I was able to get one working by housing in enclosure, separating in/out leads as much as possible and keep the wires short; and using good parts.
to be honest its not worth it, i would try another TS style overdrive with better feedback and results.
right now I am fighting popping issues ..in almost everything. have pull down resistors on im/out and also using jack ormans little circuit. might be time for me to learn about the millennium bypass
