Author Topic: Other Repurposed Stuff  (Read 46739 times)
Re: Other Repurposed Stuff
« Reply #60 on: October 31, 2013, 08:52:07 PM »
Should be a woody.
kingswayguitar
« Reply #61 on: November 16, 2013, 06:42:45 AM »
who needs 4x4 when you have tire chains
http://www.flickr.com/photos/77164433@N04/10883777936/
Luke51411
« Reply #62 on: February 22, 2014, 10:42:04 PM »
Valvecaster in a wooden soapbox found at goodwill!
Luke51411
« Reply #63 on: February 22, 2014, 10:47:09 PM »
Luke51411
« Reply #64 on: February 22, 2014, 10:48:22 PM »
Ok so I don't know how to post a photo from Dropbox...
Luke51411
« Reply #65 on: February 22, 2014, 11:03:05 PM »
Mustachio
« Reply #66 on: February 23, 2014, 01:19:52 AM »
So if you where to use this link in the img brackets it would work but it would be gigantic
https://dl.dropboxusercontent.com/sh/6aqv8e39i7724rv/rA4kQcDpz3/Photo%20Feb%2022%2C%2010%2008%2006%20PM.jpg?token_hash=AAEBCX1XHUDhS7eUf-F30tlefGmKUpSwA9fdV3OG3AaXNw
So you should probably resize and view original image and copy the link from that. Or try out photobucket its pretty easy has a one click copy link for forums .
Nice looking box! The tube glow is great too! nice work!
"Hhhhhhhnnnnnnnnnnnnngggggggg"
Jdansti
« Reply #67 on: February 23, 2014, 01:59:26 AM »
Or you can set the size by adding the "height=x" command like this:
Hit quote on this post to see how.
BTW-nice VC!
Luke51411
« Reply #68 on: February 23, 2014, 11:34:16 AM »
Cookie tin delay. It's synthrotek's pt2399 delay dev kit.
I finally figured out how to post images!!!
Jdansti
« Reply #69 on: February 23, 2014, 02:50:01 PM »
Crumby!  Just kidding- Sweet!
smurfedelic smurfberry
« Reply #70 on: February 23, 2014, 09:14:49 PM »
Ah nice, I just ordered the Synthrotek dev pt2399 kit too, how is it w/ guitar?
Hi! My name is Petter and I'm from Sweden. This is my blog: http://ptelectronics.tumblr.com
Luke51411
« Reply #71 on: February 23, 2014, 09:46:48 PM »
Its not bad. It's a little frustrating that they don't have the schematic posted or at least they didn't when I built it. You definitely need to add pull down resistors. The feedback pot is a nice mod to this circuit, though on certain settings you don't get much travel on that pot before getting oscillation, i think i added a series resistor to tame the oscillation a bit but I'm not sure. There is a bit of noise on longer repeats. I tried the warp switch mod and it basically just sped up the delay there wasn't pitch modulation like in the video so I don't know if that's just an effect of guitar vs synth or I had it wired wrong but it's hard to tell from their instructions, if you figure it out let me know because it seemed like a cool quirky effect. I removed this switch. The feed blast mod is kind of cool but much higher level the way they have it so I added a resistor and played with the value to get feedback that starts at a similar level as the regular effect and builds into oscillation. Their instructions are ok, not as good as GGG which is the only other kits I have experience with but it's still a very easy build. Overall I can't complain especially for the price of the kit. It's a fun delay to play around with!
« Reply #72 on: February 27, 2014, 08:02:55 PM »
I just found the page with the mods, will be fun to play around with ...i gotta read the datasheet for pt2399 more in detail
http://www.synthrotek.com/tech/mods/pt2399-dev-board-feedback-mod/
« Reply #73 on: March 07, 2014, 09:48:45 AM »
Repurposed Ugly Bird. Beavis 567 Modulator.
« Reply #74 on: March 07, 2014, 10:25:48 AM »
is that a toggle beak?
".... the Victoria’s Secret of pedal underwear" - Phillip H
"Who?" - Steven Toast
"No way you cna go wrong" - Juan Wayne
is the duck allowed to walk along the top of the fence?
« Reply #75 on: March 07, 2014, 10:45:35 AM »
Yep! The beak is a toggle, instead of the normal 10 uF, you can have 2.2 uF ... :D
« Reply #76 on: March 07, 2014, 10:57:58 AM »
 8)
what was it?.
http://www.youtube.com/user/100roberthenry
http://deadastronaut.wix.com/index
^ SPACE PATROL FUZZ/ NANO-8 MIDI DRUMS /CHASM REVERB / TREMSHIFTER / FAZE FILTER/ABDUCTOR II DELAY pcb's + WAH LIGHT PLATES. and sausa
tubegeek
« Reply #77 on: March 08, 2014, 12:20:45 AM »
« Reply #78 on: March 08, 2014, 01:10:35 AM »
a box a friend bought for $1.50 at a flea market.
Luke51411
« Reply #79 on: April 15, 2014, 10:29:21 PM »
Two for Tuesdy. The first is a Red Llama in a coin box the second is a cookie tin with a wooly mammoth, nurse quacky, and P45. I wanted to be able to use some of the circuits I had laying around without using up a Hammond box!
