Other Repurposed Stuff
Started by chptunes, February 18, 2013, 12:26:16 PM
kingswayguitar
Luke51411
Valvecaster in a wooden soapbox found at goodwill!
Luke51411
Ok so I don't know how to post a photo from Dropbox...
Mustachio
So if you where to use this link in the img brackets it would work but it would be gigantic
https://dl.dropboxusercontent.com/sh/6aqv8e39i7724rv/rA4kQcDpz3/Photo%20Feb%2022%2C%2010%2008%2006%20PM.jpg?token_hash=AAEBCX1XHUDhS7eUf-F30tlefGmKUpSwA9fdV3OG3AaXNw
So you should probably resize and view original image and copy the link from that. Or try out photobucket its pretty easy has a one click copy link for forums .
Nice looking box! The tube glow is great too! nice work!
"Hhhhhhhnnnnnnnnnnnnngggggggg"
Jdansti
Or you can set the size by adding the "height=x" command like this:
Hit quote on this post to see how.
BTW-nice VC!
Luke51411
Cookie tin delay. It's synthrotek's pt2399 delay dev kit.
I finally figured out how to post images!!!
Jdansti
Crumby!  Just kidding- Sweet!
smurfedelic smurfberry
Ah nice, I just ordered the Synthrotek dev pt2399 kit too, how is it w/ guitar?
Hi! My name is Petter and I'm from Sweden. This is my blog: http://ptelectronics.tumblr.com
Luke51411
Its not bad. It's a little frustrating that they don't have the schematic posted or at least they didn't when I built it. You definitely need to add pull down resistors. The feedback pot is a nice mod to this circuit, though on certain settings you don't get much travel on that pot before getting oscillation, i think i added a series resistor to tame the oscillation a bit but I'm not sure. There is a bit of noise on longer repeats. I tried the warp switch mod and it basically just sped up the delay there wasn't pitch modulation like in the video so I don't know if that's just an effect of guitar vs synth or I had it wired wrong but it's hard to tell from their instructions, if you figure it out let me know because it seemed like a cool quirky effect. I removed this switch. The feed blast mod is kind of cool but much higher level the way they have it so I added a resistor and played with the value to get feedback that starts at a similar level as the regular effect and builds into oscillation. Their instructions are ok, not as good as GGG which is the only other kits I have experience with but it's still a very easy build. Overall I can't complain especially for the price of the kit. It's a fun delay to play around with!
I just found the page with the mods, will be fun to play around with ...i gotta read the datasheet for pt2399 more in detail
http://www.synthrotek.com/tech/mods/pt2399-dev-board-feedback-mod/
Repurposed Ugly Bird. Beavis 567 Modulator.
Yep! The beak is a toggle, instead of the normal 10 uF, you can have 2.2 uF ... :D
tubegeek
a box a friend bought for $1.50 at a flea market.
Luke51411
Two for Tuesdy. The first is a Red Llama in a coin box the second is a cookie tin with a wooly mammoth, nurse quacky, and P45. I wanted to be able to use some of the circuits I had laying around without using up a Hammond box!
