Is it "safe" to jumper around an FET switch?
Started by stoneattic, March 23, 2013, 10:56:06 AM
stoneattic
Don't laugh...
I'm true bypassing a certain manufacture's pedal that I don't want to mention for fear of ridicule. The switching on this particular pedal is done with SMD transistors, specifically a pair of 2SK880GR, instead of the usual TO-92 package that I've seen in their other, older pedals.  I'm a bit worried about removing the FET for fear of damaging the PCB and was thinking that it would be easier to just put a jumper from the Source to the Drain to keep it passing signal.
Does anyone know if that might cause a problem?
It's fine if what you want is that it act like the JFET is always 'on'.
stoneattic
That's exactly want I want.  Thanks!
Not that I care about the FET itself, but I wanted to be sure it wouldn't cause any damage.
armdnrdy
stoneattic
If only they existed.  I would be happy with just a suck reduction knob.
I finished the true bypass and all is good.  The leads on the SMB FETs were so close I just put enough solder to cover both pads.
*is it safe?*
I've got a root canal scheduled for thursday morning. IT CAN"T COME SOON ENOUGH.
sorry for hi-jack
