so i got this old mxr analog delay <heavy sigh>
Started by pinkjimiphoton, May 04, 2013, 08:25:16 PM
pinkjimiphoton
and tho it passes signal, the sad4096  chip i believe is dead.
pretty sure i'll NEVER find one, but just in case, is there some way to test this i didn't find yet?
this is one of them early plastic cased mxr's from the early 80's...worst case, it's now a buffer pedal.
or is there a sub i can pull off maybe?
Slava Ukraini!
~Jack Darr
pakrat
Hi Jimi, didn't someone make a daughter board for the ADA flanger to retrofit an MN3007?  I could be mistaken but... http://moosapotamus.net/ADAflanger-MN3007.html
Govmnt_Lacky
#2
Adapter for a MN3005?
Not many viable options other than that  :-\
EDIT: MAKE SURE you check every cotton pickin' resistor, IC, cap, trace, etc. before you call that 4096 dead! Post some voltages, check clocks, you know the drill!  ;)
pinkjimiphoton
i will post pics, voltages etc as soon as i am able.
i'm hoping it's some of the supporting stuff that's cooked, but in my experience with bbd's, when the pedal's dead, it always seems to be the dang chip!!!!
this stuff is rocket science to my fuzzy widdle bwain still... i'm not up for the learning curve i don't think!!! lol
Slava Ukraini!
~Jack Darr
Govmnt_Lacky
One step at a time Jimi... thats the way you get there!  ;D
Make sure you get a clock (or some kind of voltage around V+) at Pins 2 and 16. Then, make sure you are getting signal in at Pin 14. Then, you should see signal out on Pins 8 and 9. I can only assume that your voltages on Pins 8, 9, and 14 should be ~1/2 of V+.
pinkjimiphoton
i'm debugging a fab overdrive right now someone mailed me (failed solder... big surprise on a 15$ pedal!)
and i have to supervise my boy soldering his second fuzzbox (he gave the first one to dick wagner when he visited a couple weeks ago)
but after that, i'll take a look-see and see what's up.
the bbd and clock are socketed... i did check the voltages last nite, i got full voltage on one pin and half voltage on a couple of the others, but nada on most of the ones in the middle.
so maybe i WILL get lucky and it will be the clock greg, that's what i'm hoping!!!
Slava Ukraini!
~Jack Darr
Govmnt_Lacky
pinkjimiphoton
there's an old joke about a granny in a house of ill repute that ends like that...
lol
well, don't stay up tonite bro...
i gotta gig tomorrow afternoon, downbeat at 12:30 so i'm a going to bed as soon as i finish typing this...
i will measure voltages tomorrow nite or maybe monday tho, and see what's what....
finally getting back to "normal"... i gotta finish documenting that polyphaser, too..
Slava Ukraini!
~Jack Darr
