Purple Plexi 800 Vero Build ?
Started by HOTTUBES, May 25, 2013, 12:34:18 PM
HOTTUBES
Has anyone built this vero before ?
Is it Verified ? ( I'm assuming it is ... )
I built this , but i can't get it to work for some reason , I've check everything about 10 times ... but no Dice !
Won't pass audio at all , no sound !  tried different op amp too .
By Pass does work ...
:icon_confused:
HOTTUBES
Is VOL 2 out ?
Again i assume so , as it's not mentioned on the layout .
rousejeremy
I've built that, it does work. Vol.2 is out.
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
HOTTUBES
HOTTUBES
I forgot to tie in the grounds at pins 2 & 4 of the op amp as shown in the layout ....
Now i get some sound , but it's pure white noise .... HSSSSSSSSSSSS !!!
(  scratches  head )
mth5044
Voltages may be useful. Also a schematic.
HOTTUBES
Quote from: mth5044 on May 25, 2013, 09:38:25 PM
yes , good call !!!
Here they are ....
Battery Voltage = 8.37
1= 1.326           8= 1.382
2= 0                 7= 4.106
3= 0                 6= 8.301
4= 0                 5= 5.210
The vero layout is the one shown above ...
rousejeremy
Do you have any pics of of your board?
HOTTUBES
#8
Looks like a " Dogs Breakfast " !!!     sorry !
HOTTUBES
#9
I have checked the board for solder bridges visually and with DMM .
I check and meter every component before its installed in the board , so i know all values are proper .
I have check all components are in their proper locations & orientations
I have tried a new op amp .
Unsoldered each pot , and swept the pots on the DMM to verify their operation .
Verified DC power on the circuit board
Verified all off board wiring to be correct to the layout .
Verified all cuts to the vero are correct to the layout .
HOTTUBES
rousejeremy
What is the value of the two resistors you have wired in series for R7?
rousejeremy
And where is the wire going to the "in" on the vero? (second strip from the top, second hole from the top)
HOTTUBES
Quote from: rousejeremy on May 26, 2013, 02:07:07 PM
I had unsolderd it last night and checked it to be 1.82 K cause i had thought the same as you ... ha !
HOTTUBES
Quote from: rousejeremy on May 26, 2013, 02:10:22 PM
" IN " on the board comes from the stomp switch . ( it's a purple wire , it's hard to see )
HOTTUBES
Heah  !!!!  come to think of it .... I have the INPUT on the wrong Srtip !!
I have the Guitar signal going to ground !!     DOH !!!!!!!!!!!!!!!!!!!!!!
( Trashes the room !!!)
rousejeremy
rousejeremy
Make sure to ground that top strip.
HOTTUBES
HOTTUBES
Quote from: rousejeremy on May 26, 2013, 02:28:23 PM
Yep , it is ..... the jumper that runs under the op amp takes care of that ....
Thanks again .....
