SP3T from a single stompswitch?
Started by Slade, July 05, 2013, 10:17:33 PM
Slade
Is there a way to make a SP3T or better said SPXT with a single stompswitch and analog circuitry / chips?
I haven't even looked for it, it's so out of my league I had to ask you first to know if it's even possible and then learn how.
Regards,
Fernando.-
armdnrdy
earthtonesaudio
Debounce your footswitch.  Use it as a clock input to a Johnson counter (e.g. CD4022).  If you need less than 8 "poles" then wire the Nth output to the Reset input.  This makes a modulo-N counter.
Finally, use the outputs to drive CD405x analog switches (biased to half-supply voltage).
Slade
That's great news!
Thanks for the tips, guys!
