STRIKER SMOOTH MOD
Started by Striker Amplification, July 08, 2013, 05:30:53 PM
Jdansti
Could you please take a look at this and let me know what you think?
Quote from: Jdansti on July 14, 2013, 05:07:07 AM
I'm a little confused about our capacitance units.
>.1mfd-.47mfd are good starting points, there really is no effect with a capacitor as big as .002, thats HUGE
0.1mfd = 0.1 microfarad = 0.1 x 10-6 Farad = 0.1 uF = 0.1 μF
What are the units for 0.002? When I see 0.002 on a schematic, I assume that it means 0.002 μF (2 nF, or 2,000 pF). If that's the case, then 0.002 would be smaller than 0.1 mfd and 0.47 mfd. Am I missing something?
WaveshapeIllusions
Oh, I see what that is. I couldn't see the image in the first post. It's kind of like bypass caps for more gain at the emitter/source/cathode, except in reverse. For something similar, look at EHX's The Mole/Hog's Foot bass booster. There's a cap in parallel with the collector load. For AC, that cap is part of the collector load and gain drops accordingly when Xc drops. I think it works a bit different in this case though, because the output is take across the transformer instead of at the plate. I don't even want to try to figure out the -3dB frequency. I mean, resistive load would be easy enough. A speaker though?
0.47UF        0.002UF is actually bigger than 0.47uf , it is actually almost 3 times as large. 0.001uf is the cap i was using on my treble booster.
Builds:Plexi superlead mkll 100,plexi superlead mkll 50, 59 plexi, 59 4x10 bassman, marshall bass and PA head 100, JTM45, modded JTM45-lead,JCM800 lead 50.
R O Tiree
Quote from: Striker Amplification on July 15, 2013, 04:47:22 AM
Whatever you're smoking, mate, I want some.
...you fritter and waste the hours in an off-hand way...
DougH
I'm still not sure what "POINT B TO POINT B" means on the schematic...
pinkjimiphoton
Quote from: Striker Amplification on July 15, 2013, 03:26:14 AM
Someone really needs to try this befor iam forced to upload a live video of MASS DESTRUCTION!!! :icon_twisted:
like, wtf, dude, way to keep a hippy in suspense..
lol
unleash the dogs of war!!! video is a must!
Slava Ukraini!
~Jack Darr
Jdansti
Is 0.002UF different than 0.002uF?  Are you calling both microfarads
pinkjimiphoton
that would be .002u, 2n or 2000p all the same value j
Slava Ukraini!
~Jack Darr
puretube
Quote from: DougH on July 15, 2013, 08:58:09 AM
(B+, i.e. ...)
puretube
Quote from: aron topic=103186.msg918473#msg918473
This thread has very little info in it and all from regular posters. It has degraded in quality.
+ another 1 ...
DougH
Quote from: puretube on July 15, 2013, 01:33:48 PM
(B+, i.e. ...)
If that's the case, the circuit is broken as drawn.
Johan
Quote from: DougH on July 15, 2013, 03:44:38 PM
Quote from: DougH on July 15, 2013, 08:58:09 AMI'm still not sure what "POINT B TO POINT B" means on the schematic...
(B+, i.e. ...)
It already was all the time with that high resistance path from power tubes cathodes to ground, but I'm giving Ryan the benefit of a doubt and assume his drawing is showing a concept and not a working amp.
j
Edit.....but benefit if doubt or not, I do think its time for Ryan to give us a soundclip or a pic of his builds or just something more than just big words
DON'T PANIC
Jdansti
Quote from: pinkjimiphoton on July 15, 2013, 12:47:41 PM
+1
0.002 μF = 2nF = 2,000 pF
I'm just trying to understand this statement: 0.002 μF > 0.47 μF.
I'm pretty certain that: 0.002 μF < 0.47 μF
0.002 μF is 235 times smaller than 0.47 μF
2/1000 < 470/1000
If someone offered you a choice between $0.002 million and $0.47 million which would you take (assuming you want the larger pile of cash)?   ;D
lah! thats right, i dont know what i was thinking. majorrrrrrr mixup.   :icon_redface:
The point B to point B means connect point B to point B, point B1 is to the primary tap on your output transformer, it is lead to the B+ primary output from the rectifier.
which of those piles of cash sounds better?
this is an entertaining thread. can't wait for the punchline.
Digital Larry
"The fragile harmonics can't survive in a crystal lattice"?
Digital Larry
