Tri-Vibe LFO for higher frequencies
Started by knutolai, November 04, 2013, 03:34:41 PM
knutolai
So I'm snooping around for a sine wave oscillator to use as the modulator in a ring modulator (too many nouns in one sentence.. sorry   :icon_lol:).
I haven't really found any circuit that easily lets me modify the frequency of the oscillator (over a broad spectrum, like 0,5Hz to 2kHz) without also changing the waveform. Is the Tri-Vibe LFO the solution to this issue? (Read: would this oscillator retain the same waveform at audio frequencies?)
here is the full circuit (from runoffgroove):
U3a and U3b makes a pretty standard square/triangle wave generator, but then there is the more magical stuff happening around U2b... I haven't really seen anything like this before. Could maybe someone point me in the right direction regarding documentation describing this circuit component? I'm eager to understand how it works  :icon_question:
A 4,000:1 range? On one knob? That is tough.
A standard pot covers about 10:1 (linear pot 100%-10%). You can do 50:1 ("audio" pot 100%-10%).
You can put in a range switch. Use one set of caps for 0.5Hz-250Hz, a smaller set of caps for 50Hz-2KHz.
And then there are LOG tricks. Voltage-controlled oscillator, VERY linear to low frequency, and put a LOG converter in front. This is how the classic Moog/ARP synths worked. One knob 20Hz to 20KHz with pitch accuracy. With the relaxed accuracy needed for vibe/trem LFO, 4,000:1 is not impossible; but will be very tricky to null all the offsets.
The OTA approach can-be naturally LOG. I don't think it is good-LOG over 4,000:1 range without lots of complications.
And there's the BFO tricks: beat 100KHz against 100.1KHz to get 100Hz. Easy to swing a "100KHz" oscillator 100KHz to 102KHz. Very difficult to set very small differences; aside from accuracy, the two oscillators tend to "lock" and give zero Hz.
National had an old plan for a somewhat simple function generator with extra wide range. AN-115. If I can find that I will post it. (It is no longer on NatSemi/TI's site.)
knutolai
#2
Quote> lets me modify the frequency of the oscillator (over a broad spectrum, like 0,5Hz to 2kHz)
Heh, yeah I guess that was quite unrealistic..
QuoteYou can put in a range switch. Use one set of caps for 0.5Hz-250Hz, a smaller set of caps for 50Hz-2KHz
Good idea, thx!
QuoteAnd there's the BFO tricks: beat 100KHz against 100.1KHz to get 100Hz. Easy to swing a "100KHz" oscillator 100KHz to 102KHz. Very difficult to set very small differences; aside from accuracy, the two oscillators tend to "lock" and give zero Hz.
This is a interesting approach, however doesn't the amplitude of the beat frequency drop as the frequency-difference between the supersonic oscillators increase? I did some experiments with this a few years back and can't really recall the results.. I'll have to dive into it again I guess.
How about a simple standard triangle wave VCO followed by a VC-LPF where the frequency of the VCO and the cut-off freq of the VCF is controlled by the same voltage (like frequency equal to cut-off frequency)? I guess it would be very hard to make the two parameters follow each other..
EDIT: Doing some research VCF seems to be very component heavy. Ill drop this option completely. Who needs complicated and hifi when you can have simple and dirty  :icon_cool:
> modify the frequency of the oscillator ...without also changing the waveform.
The waveform "should not" change. The oscillations follow the same laws at any frequency. We do have practical limits: leakage at the low end and falling gain at the high end. But practical parts and chips should work the same from sub-Hz to the top of the audio band (limited by the ~~1MHz gain-bandwidth of cheap chips).
The tri-wave you show is the basic Schmitt and integrator. The integrator is quite easy (until you get sub-sub-Hz and leakage effects). The Schmitt has to swing FAST-- otherwise the freq runs low and the tri-wave tips go soft. That particular plan uses TL062, not a real fast chip. It also has 100K:10nFd around it which probably hurts speed more. This may be "nice" for music, softening the tri-tips when the freq gets high enough to hear tip-glitch. But that's a design decision for the specific application.
There's also amplitude/shape effects due to unfortunate choice of circuit. In the classic Wein Bridge, if you change just one of two parts in the R-C-R-C network, the gain changes which will ultimately stall or overdrive. However Merlin posted a variant where the change in the one R also changes gain, so the effect is "flat" up until it runs out of gain. Using cheap chips he showed good flatness up to the top octave of audio.
The diodes before U2b do a semi-Sine round-off of the harsh triangle wave.
The 5 resistors and two diodes do something else. This plan drives the OTA gain-pin with a *voltage*. But the OTA's gain is exponential to voltage (linear to current). With voltage-drive we'd either get a very lopsided trem or we have to bend the raw trem-wave into its log form. Diode-bridges can do this. The design is a pain. (Personally I wonder if the designer got off the tracks here... on the face of it a current-drive plan seems more straightforward.)
