CHASM REVERB
Started by deadastronaut, November 20, 2013, 12:50:02 PM
stallik
Aw come on Rob, you're making us mere mortals look incompetent  ;)
Maik
Yes Rob, sorted it nearly.
The power supply sucks! Tried it with battery and its quiet.
Now only a little prob with the osc. But I had no time to look yesterday...
ok cool...
having a 'pop' issue with my build...hmmmmm
the fets/mosfet switching should eliminate any noise whatsoever, that's why its there ......(as it did in my diy pcb)
i'll poke around with grounds etc today....
Maik
How to wire the osc switch WITH led?
use a dpdt..
one side for switch , other side for led/s  red on/green off maybe..
_ led+.....
_  9v
_led+.....
join both - of leds to a resistor...then gnd. 8)
or stick your resistor from 9v to middle of switch...
or do it the other way with gnd going to centre lug...with leds reversed..up to you man.. :)
Maik
Thanks Rob.
I can only do paint by number... ;)
Maik
sorted my pop issue... 8)
swapped the fets, silent as a mouse now..back to lush verb.. 8) 8) 8)
here's a drill template for the CHASM in case anyone needs/wants it to make life just that little bit easier.. 8)
SVG. file (inkscape)
https://dl.dropboxusercontent.com/u/7464107/CHASMTEMPLATE.svg
Maik
Nice, what about a drill template for the delay and trem?  ;D
Ahhh, forgot, there is no pro pcb for the delay. Perhaps some day???
yeah, one day.... :)
i'll sort the trem one out ... ;)
Maik
Yep, I know, the delay thing was realy cheap... ;D
Xomby
nice nice nice. now to make it work with btd-3h and stereo output...  :icon_twisted:
Maik
How much mA needs the reverb? Could 100mA go?
samhay
Quote from: Maik on December 05, 2014, 12:07:52 PM
Probably. I think Rob uses a 100 mA regulator (78L05?) in his builds.
Maik
