Adding an LED and 3PDT
Started by guysmiley, December 30, 2013, 10:31:38 AM
guysmiley
Am I on the right track with this?  I haven't hooked it up yet.  In theory, would this work as an on/off voltage regulator with an LED?  Thanks for any input?
GGBB
Assuming you don't mean a true voltage regulator or controller, just a dying battery simulator, looks fine.  But you can do it with an SPDT.  Excuse the bad ASCII drawing:
    +Vin       SPDT     +Vout   Pot
                 1--------X------1
      X----------2---------------2
                 3               3
                 R
                LED
                Gnd
guysmiley
Yeah, I meant a dying battery sim.  Thanks for looking it over. :icon_biggrin:
guysmiley
Hmmm, wired it up and it doesn't work.  Maybe I should move the LED to the bottom left lug on the 3PDT with the LED + and Res towards the switch and the - to the ground?  Any ideas?
mth5044
Does the whole thing not work? Does the LED not work? Do you get any voltage out at all? Please be explicit.
You can wire your 3PDT switch as a SPDT switch as GGBB has shown. His wiring is pretty clever.
Also make sure your switch is oriented properly.
guysmiley
LED doesn't light, and power doesn't go through in bypass or activated.  The way I'm looking at my switch is with the lugs horizontal like the picture I posted.  I thought that is how the 3PDT switch worked.  ???
guysmiley
Maybe I should switch the voltage in to the 2 lug of the pot and the voltage out to the 1st lug?
mth5044
Can you post a picture of your wiring?
mth5044
Do you have power coming into the input jack?
guysmiley
guysmiley
#10
Here are some photos
mth5044
Hard to tell from the pictures, but are you soldering to the correct tabs on the power jacks? I've messed that one up a few times by soldering to the switching lug.
Also, where is that orange wire off to? Connect that wire to the ground of the power jacks. Connecting it to an aluminum enclosure, when the jacks are insulated and especially when they aren't in the enclosure, isn't going to do anything.
guysmiley
I think I connected the DC correctly.
guysmiley
Quote from: mth5044 on January 02, 2014, 12:27:48 PM
I had a wire clipped to the ground on the DC but removed it in the picture.
guysmiley
Quote from: guysmiley on January 02, 2014, 12:28:06 PM
I only connected the +/- to the 1 and 2 lungs
mth5044
guysmiley
#16
Quote from: mth5044 on January 02, 2014, 12:55:59 PM
+ should go to 3!
;D  Got it!  That was the problem!  Thank you for the help.
mth5044
Not a problem, glad it worked out.
