Tc1044scpa for madbean nautilus
Started by Kipper4, December 31, 2013, 05:58:43 PM
I'm having trouble finding this part for the madbean nautilus. Uk based
Anybody got a scooby where I can get some please
bean
You can also use a MAX1044CPA or an ICL7660SCPA.
I was kinda hoping you'd chime in thanks Bean. I'll look em up. Happy new year all.
midwayfair
Also, you can clip (or bend away) pin 1 on an LT1054.
Thanks Jon
Tayda carry the max1044 theyre way cheaper.
midwayfair
Quote from: Kipper4 on January 01, 2014, 07:32:07 AM
Thanks Jon
There's a reason the MAX1044 is cheap.
They flake out?
I've read before of people not getting on well with them.
which ones should i go with. I dont want to go to the trouble of this big build and it flakes out on me.
Please advise
They are picky with their input voltage.  Without checking the datasheet, I seem to recall that a gnat's gonad over 10V will toast it.
Chugs
Doctor Tweek and Rapid Electronics both stock the IC7660S in the UK.
I would recommend the IC7660s over the MAX1044. The IC7660S can handle voltage supply input of up to 12V.
Thanks guys
Duly noted and saved to favorites
Cheeeeers
disabled_shredder
Rich I have extra of al flavors I shall send you one of each! Package to be mailed post haste!
The wild man with a loaded gun and no plan. I'm not held back by rules, just don't know which ones to follow
italianguy63
Tayda carries the TC1044SCPA at $.99!  -- bargain, and works.  The MAX1044 is nominal on voltage, not recommended with wall worts.  Look for the "Charge Pump Design" thread... Lot's of this discussed.  MC
Cheers Jake. email sent.
I'll do that too Italian guy.
gotta run now. Time for work.
midwayfair
NM?
you've lost me there Jon!!!!!!!!
