Madbean Kingslayer Squeal
Started by toddvirgil, March 14, 2014, 11:24:29 AM
toddvirgil
 I'm hoping someone can chime in and help me out here.
I've built a bunch of the madbean kingslayers with no problem. However the last four I've built have this crazy squeal when all the controls are at max. It's more of a high-pitched whistle.
Schematic: http://www.madbeanpedals.com/projects/Kingslayer/Kingslayer.pdf
Here's what I've learned so far.
1. The squeal goes away if I turn any of the controls down to about 3o'clock (75%).
2. it doesn't matter whether the OD clipping is on and it doesn't matter which signal clipping I'm using.
3. I've tested with opamps from known working circuit but still get the squeal.
4. I've tried removing and replacing the zener, neither affected the squeal.
5. I get a squeal on all of the opamp outputs on the tlc274
6. If I remove the 5n6 at C15 the squeal goes away (but effectively flattens out the Tone control)
7. If I replace the tone control with a 5K it wont squeal when pegged (no surprise there).
8. With a 10k pot on the tone, I get squeal on pin 1, but pin 2 and 3 are clean.
Any ideas what I should try next?
Thanks in advance!
mth5044
Check to make sure your charge pump is the SCPA and not the CPA type.
toddvirgil
Quote from: mth5044 on March 14, 2014, 12:16:42 PM
Yep, it is. Like I said, I've built a bunch with no problem, but for some reason this latest batch is going nuts. I've checked with IC's from a known working build.
ggedamed
Have you tried putting an 100n capacitor directly on the supply pins of IC1?
Minds are like parachutes. They only function when they are open. (Sir James Dewar, Scientist, 1877-1925)
toddvirgil
Quote from: ggedamed on March 14, 2014, 03:07:51 PM
No, I haven't -- will do -- what would that accomplish exactly (from a technical standpoint)? Would the intention be to filter out frequencies coming from the chargepump?
IvIark
Brian mentioned that you can get some oscillation because he opted for a 1M for R11, so it may be worth reducing the value and seeing if it sorts the problem.
midwayfair
Quote from: IvIark on March 14, 2014, 09:32:14 PM
That's a different sort of oscillation. When you lift the diodes and turn up the gain, about midway it freaks out the (third, I think) op amp and turns the pedal into a tremolo. It scared me the first time it happened ...
toddvirgil
Yeah, that's a different issue. I talked to Brian and he recommended swapping the 1k8 in the tone control out to a 6k8 or 10k since the treble is pretty intense/unusable that way anyway. the 10k did the trick, squeal gone. Still a mystery as to what was causing it.
ggedamed
#8
Quote from: toddvirgil on March 14, 2014, 03:55:26 PM
They're called decoupling capacitors and their job is to provide a short path to ground for the AC traveling through the supply rails. You have some info here or here. Oh, and right here, from the two guys I'm always following - R.G. and PRR.
