High current dc connector >1A
Started by tca, March 28, 2014, 10:31:57 AM
tca
The typical DC panel plug for stompboxes are rated 1A max, are there any high current DC jacks?
These Neutrik powerCON (http://www.neutrik.com/en/audio/powercon/powercon-20-a/) can take 20A, but are not cheap (http://www.musikding.de/PowerCon_1). I was looking for something up to 10A (maybe less).  Some ref. in Europe?
Thanks.
Are there any DC uses beside stomp-boxes??
The car world is full of connectors; though many are not made for nightly plugging.
Computer hard-drive connectors will take massive(?) current. (? I don't know what you call "high".)
Spend a month with any full-line electronic catalog (Allied, DigiKey, Mouser, etc) and you will find more many-Amp connectors than you can fit in a truck.
Tip: if you promise not to plug it the wrong place, get the battery connector for radio-controlled cars.
Seljer
Ham radios often use a 6pin molex connector for the DC power supply often running quite a bit of current. Some googling says that the large ones are good for 8.5A per pin with appropriate wire.
Lately these have become popular http://www.andersonpower.com/products/singlepole-connectors.html
tca
#3
Thanks for your replies.
Quote from: PRR on March 28, 2014, 10:57:26 PM
ZVEX's nano head uses a "typical" DC plug, rated 1.25A?!?!? I've used these plugs to deliver 1A to my amps, but I'm not convinced they would last very long with an intensive use, although I use my small amp every day (and no problems yet).
I looked for panel laptop type plugs on the typical on-line stores, but found none, have to try again.
Cheers.
P.S.
...if you promise not to plug it the wrong place, get the battery connector for radio-controlled cars.
That's a hard promise to keep!
