A/B/C Loop Switcher Help
Started by SeanMiracle, April 23, 2014, 01:58:12 PM
SeanMiracle
Hello Everyone,
I'm new to DIY stompboxes, but hoping you can help me out :)
I want to create a A/B/C loop switcher that does this:
"Unit operates as 1 or 2 or 3 and NOT any two of the three. Stepping on the first switch (Loop 1-2) switches Loop 1 or Loop 2 as indicated via LEDS for you. When you step on the second switch, (Loop 3) one LED (1 or 2) will still be lit telling you that when you deselect Loop 3, you will resume back to that previous loop. When you step on Loop 3, you must step on Loop 3 again to resume back to Loop 1 or 2."
But I also want a master bypass.
I've looked around and found this schematic for the looper itself:
I'm wondering how I wire in the master bypass. Can anyone give me some pointers?
Thank you!
- Sean
Find the Master In.
Find the Master Out.
Disconnect from where they go.
Connect In to Out.
Need third 3P2T switch LED and resistor.
SeanMiracle
