Tonepad Wah-Wah buffered. Verified?
Started by gasmask, April 29, 2014, 07:15:48 AM
gasmask
Has anybody ever built it?
http://tonepad.com/project.asp?id=29
Some part are quite expensive. Is it worth trying?
going by the build reports it looks ok..
check em out for any tips..issues..etc
Blitz Krieg
gasmask
#3
Blitz Krieg: well, my signal gets lower when I engage 4 or more pedals in chain.
deadastronaut: where should I find them?
*nevermind, I found them
where you linked to there are build reports at the bottom.  ;)
gasmask
ok, so I decided to build it. Does anybody know where to buy cheap wah enclosure? ;)
gasmask
I realized that i would like to remove vol switch mod... I ve read that I have to make a jumper over 220k resistor... But what about 'the right side' (after Q2)? Should it be all removed?
Thanks for all replies
gas
Blitz Krieg
The buffer is only engaged when the wah is engaged.
Best place to get a shell is from a friend that bought a terrible sounding wah and they don't do anything with it.  Otherwise, get broken wahs at a certain online auction site.
Blitz Krieg
That 4.7uf must make it to ground.  That's why you need the jumper.  You are correct that you can ditch the junk on the right side.  No connection needs to be completed there.
Blitz Krieg
If you get a used Crybaby, the shell comes assembled and painted.  With an appropriate potentiometer, and very likely an inductor.  All this can be purchased for about the same price as that thing from mammoth.
Quote from: gasmask on April 29, 2014, 07:15:48 AM
