debugging a tokai tod-1
Started by Renegadrian, June 15, 2014, 05:08:03 AM
Renegadrian
Hey, I got this pedal for almost free...it's a non working 80s TOKAI TOD-1 - it's just a SD-1 verbatim copy...
now, this thing doesn't work...
I have 6.4v with a non fresh battery, but my multimeter reads 1.2 on the 9v trace and 0.6 at the 4.5v trace.
audioprobing, signal stops at the base of the input buffer.
any clues/suggestions?!
find the reverse polarity protection diode. lift one end, check voltages. you might get lucky.
Renegadrian
wow thanks so much!!! You were definitely right! Removed the diode and the pedal works as it should!!!
nothing special, it sounds like a SD-1 because...it's the same!!! I studied the PCB which is obviously different, but the components are verbatim! A carbon copy of the yellow one...
Thank you again!
