Author Topic: Effects configuration a la EQD's Disaster Transport Sr.?  (Read 2360 times)
diablochris6
« on: June 18, 2014, 03:07:55 AM »
I have been reading up on the Earthquaker Devices's Disaster Transport Sr. delay monstrosity and how you can have two delay pedals in series, parallel, or parallel with a bleed of delay 1 into delay 2. That seems really interesting either to recreate a similar effect or as a standalone utility box that you could hook up whatever two effects you wanted. I have only seen one gut shot picture, and I am a bit baffled as to how they achieve this with a 3PDT. I might have figured out a similar method using a 4PDT though.
Not shown are the voltage and ground connections of the pedals or the 3PDT switches on the delays. The thick blue line represents the delays in series, and the orange line shows a parallel path. I figure there would have to be two buffer/splitters, one to split the dry signal, and another to split delay #1's output to allow for the bleed, which I guess could be a passive bleed pot. I figure there should be a phase switch in case things get weird, but should there be any problem with hooking up multiple inputs to the input of delay 2 or the output jack without a mixer circuit? Am I way off track?
diablochris6
Re: Effects configuration a la EQD's Disaster Transport Sr.?
« Reply #1 on: June 21, 2014, 11:15:38 AM »
Bump, with more focused questions.
1. Does the switching look reasonable, or is there a better/simpler way to do it?
2. Slightly related to #1, does anyone know how Earthquaker Devices gets away with this switching using a 3PDT?
3. Should there be any concern for multiple signals leading to delay #2 and to the output?
4. Is a mixer necessarily needed if I would rely on the dry/wet signals of each delay?
The parallel/series/bleed concept opens a lot of neat possibilities. I just need a little nudge. Thanks.
« Reply #2 on: June 22, 2014, 12:59:49 AM »
Some (many?) of us don't see the latest toys.
A link can help the discussion.
What evidence that it uses a 3P2T? The actual switching could be electronic. Without knowing what is inside, but looking at the calendar, I'd wonder if both/all delays, mixing, switching, LFOs could be done in one DSP chip (with custom programming).
diablochris6
« Reply #3 on: June 22, 2014, 06:53:03 PM »
Good call on the link. I only find out about any new stuff when I go Youtube exploring.
The product description mentions digital delay with analog switching, and the only internal shot of the pedal I found on the web is this...http://product-images.highwire.com/3273624/eqddisastertransportsr5.jpg. It looks like there are some PT2399s, a couple of op-amps, and a Belton Brick under there.
As I drew in my first post, I think I can do something similar with a 4PDT but am not sure. I would like to figure out the simplest solution possible.
aishabag23
« Reply #4 on: September 09, 2017, 11:38:19 AM »
I know this is a necro thread, but is there a layout available for this pedal?
diablochris6
« Reply #5 on: September 12, 2017, 10:18:18 PM »
I built this up, but ran into a ton of problems due to my lack of electronics experience. Later on, I developed a circuit where you could mix between three effects like the EQD pedal.
https://drive.google.com/open?id=0B7QeV_7r70dTaUlFWEd1VWNHbUN3NFVvWlVEWGJCRzZWMTY0
