What do you call those 1/4 jack sockets with the end that screws in?
Started by ElectricDruid, June 26, 2014, 05:16:35 PM
...you know the ones I mean? They look like the usual black plastic PCB mounting ones with 4 or 6 legs, but instead of having a threaded part sticking out for the locking nut to screw onto, they have a threaded tube that screws into the body. The advantage of this style is that they can be PCB mounted and you can still get the PCB in the box.
If anyone knows what they're known as, who manufactures them, or where I could get some, I'd appreciate it.
Tom
armdnrdy
They are made by Neutrik and others.
Mono:
http://www.smallbearelec.com/servlet/Detail?no=1310
Stereo:
http://www.smallbearelec.com/servlet/Detail?no=793
Similar jack with slightly different footprint and size:
http://www.taydaelectronics.com/hardware/6-35mm-1-4-plugs-jacks/6-35mm-1-4-stereo-insulated-switched-socket-jack-pcb.html
If you are an Eagle user...there are packages for the first two.
One other thing of note: if you can only source the stereo version but want mono, the middle pin assembly can be taken out without too much trouble.
pappasmurfsharem
Lurco
Not sure if this is what you need, Tom (looks similar to what the other guys have posted).  The datasheet wasn't spilling the beans.  You might give Rapid a shout?
italianguy63
Ice-9
I use these a lot and there
Neutrik NYS215 for the stereo and Neutrik NYS2152
There also made by Neutriks under the Rean brand.
www.stanleyfx.co.uk
Quote from: Ice-9 on June 27, 2014, 04:03:44 AM
Ah ha!  These are the part numbers for the ones I linked to at Rapid.  Thanks Mick.
I've always known them as Rean, and called them just plain weird. that nut with a bush with a thread freaks me out.
