FuzzFace biasing, reducing variables...
Started by momo, July 06, 2014, 10:25:31 PM
momo
OK, this is yet another FF debug, I read so many here, but I still have not found the answer...been on this thing all day, long day..
So just to cut to the chase, I'm getting some fuzz.
I have a bunch of germs, did the R.G leakage thing, I think I'm in ballpark values with the germs.
I have a classic fuzz layout,
Fuzz pot: 1K
Output pot: 500K
Q1 bias resistor is still 100k,
Q1 Emmiter, follower to Q2 base is a 50k pot( not sure if this should stay at 33k and work elsewhere)
Output resistor :470r
Q2 collector resistor :1K+ a 20K trimmer pot, 10K pot was not enough..
So basically , depending on the germs, I find myself tweaking the 50k pot, trying to stay in the 33k ballpark and trimming on the 20k pot to get about -4.5 to -5v, but it does not always translate to fuzz tones. Sometimes the fuzz is at -3v or even less ....... I get from a boring real clean sound, to farty gated sounds, or at best, an OK overdrive, but nothing creamy and no sustain....
sorry for yet another debug, can't find a facepalm emoticon here, I would put a big one
:icon_mrgreen:
I'm thinking my problem is more the germs than the setup?, other than that 33k resistor which should not change?
thanks for your time...
Obviously, I have been tweaking all day in every direction with multiple germ combinations and I am still not smiling!
So
I noticed in all the modded circuits, the 33k Q2b resistor never changes....
I put a 50k pot on there.
I did that because the usual 10 pot was not getting into great fuzz.
"Alas to those who die with their song still in them."
LucifersTrip
It's seems you're a little flustered...Not sure exactly what you're saying in some of your descriptions.
Post the schematic you're using.
Here's good working voltages:
q1e: 0
q1b: 0.1
q1c: 0.578
q2e: 0.447
q2b: 0.578
q2c: 4.51
Q2C voltage doesn't have to be 4.5. Many people like it 6V+
...and you definitely shouldn't need more than 10-15K on Q2C or you've chosen the wrong transistors.
always think outside the box
Gus
momo
Hi,
So everything rocks!
The 50 k pot replacing the 33k resistor to bias was a good idea but I was not going for .5v at Q1....
Once I did that it was easy.
I will now replace the pot with whatever value it has for a resistor.
So I now have a great fuzz with nice changeover harmonics at the end of notes.
Here is what I have:
Q1: AC 451  Hfe 78 , leakage 30mv biased at -.5v
Q2: 2SB22 Hfe 138, leakage 48mv biased at -4.65v
Output cap:.047 greencap
added a germanium diode on B-E junction on Q1...
that 2SB22 is gnarly and I think is what gives the overtones...
I'm happy!
thanks for your time with me on this.
