Unwrapping the shielded wire. Tips?
Started by Focalized, July 20, 2014, 03:11:14 AM
Focalized
Some shield is simply twisted and is easy to handle.
Some has a shield that is fully woven and hard to unwrap. Picking at it with a toothpick helps but you'll break some strands more or less. I suppose I can solder a new bit of wire to the exposed shield. Any easy way I can't think of?
italianguy63
Best way I have seen is this:
Gives you room to work.  You just need some heatshrink so it all looks pretty.
MC
Jdansti
I use a dental pick to separate one side and then work it to the opposite side and twist it. It's ok if a few strands break. Just make sure that when you tin it you don't have any stray strands sticking out.
Focalized
Nice thanks. The attached wire is a good idea as the tinned shield gets pretty thick and makes it hard to fit at mulitple point grounds.
I always unpick in two opposite places. then twist/solder into 2 pigtails, dispose of as shown ^.
greaser_au
Mark C has it right, this is the right way to do this.
This range of products is used in the manufacturing world for this job (on teflon cables).
david
Focalized
Ah pretty nice that heat shrink connection.
armdnrdy
I add a ground pad on the board next to the input/output or other pad that I plan to shield.
I connect a single wire to the shield and shrink wrap the solder connection (much like Mark's image) but I orient the tag end of the wire the same way as the shielded wire conductor so that it goes directly into the ground pad.
As for the OPs original question:
I usually use a piece of component lead cutting.
Quote from: armdnrdy on July 20, 2014, 09:53:13 AM
+1 yeah i do that.. 8)
I use  Teflon/Kapton insulated where needed for inside boxes. I just expose the shield wrap a piece of stripped wire around the base ot the exposed shield, solder and snip off the excess shield. Heatshrink, just like Mike showed, i'd guess that that's Teflon shielded as well (Basic Audio pic?).
For guitar cable tease the the braided shield apart with a dental pick, never had success pulling the core wire out through a split in the braided shield.
dave
merlinb
#10
Quote from: Focalized on July 20, 2014, 03:11:14 AM
TIP: Don't bother unwrapping the braid. Just use a pointed tool to make a hole in the side of the braid, then pull the inner wire out through the hole. See the bottom of this page:
http://theguitarweasel.blogspot.co.uk/2012/09/v-behaviorurldefaultvmlo.html
Quackzed
+1 on Merlins method. don't remember where i first saw it, but thought 'AHA!!!' easy and neat!!!  ;)
anotherjim
Same as Merlin with me too.
The wire I always have to deal with has insulation on the inner conductor that can't stand local heating (polythene?)
I use lap screen  or foil+drain wire type if I can for internal work.
Jim
Jdansti
Lots of good suggestions!  I'm going to have to change the way I do shields!   :)
