Fuzz works when on, NO CLEAN ByPASS Signal, HELP
Started by rawpower6, August 07, 2014, 07:47:54 PM
rawpower6
Hello, I have a bazz fuss that when it's On works fine, but there is no clean bypass signal. I have lug 1 of my spdt on off switch to output, second lug to board output, and third to input signal. Any help would be hugely appreciated! Thanks guys and girls!
Quote from: rawpower6 on August 07, 2014, 07:47:54 PM
Schematics, wiring drawings?
And while you're gathing informaiton and replying, read "debugging: what to do when it doesn't work".
Digital Larry
Random guess in the absence of any other info - the output jack hot lead should go to the center lug of the SPDT switch.
Digital Larry
rawpower6
Thanks guys! I'll post some pics when I get home, I figured because it's working when on that the rest of the circuit is ok, sounds like I need to switch lug 1 and lug 2, thanks again I'll try that hen I get home and I'll post any pictures that I can. I really appreciate the help
