Eagle + Vref
Started by karbomusic, August 16, 2014, 06:18:50 PM
karbomusic
I have a design where I've done the schematic in Eagle and built a couple Vero board versions so both the schematic and Vero layouts are verified. Due to the number of Vrefs I diagramed the power section separately (still within the same schematic) and used labels to refer to +9V and +4.5V respectively. Do I need to actually connect these in the schematic for them to appear in the PCB view? I want to have some PCBs fabricated at some point and I'm looking for general advice as well.
as long as the 4.5v reference point labelled (usually VA or VB ) is on the power section, and is also on the rest of schemo where they should be , they should connect on the pcb...
if your not sure check you air wires..
karbomusic
I wonder if it is the labeling then. I'm flying completely blind and don't know what airwires are LOL. Sounds like a good reason to hit F1 and see what happens.  :icon_eek:
karbomusic
Quote from: deadastronaut on August 16, 2014, 09:01:03 PM
checkout:
http://www.diystompboxes.com/smfforum/index.php?topic=99864.0
vid 3..
air wires= rats nest wires...connections.
Fantastic, I'll just watch them all. Thank you!
