Electric Mistress mix control?
Started by theehman, August 28, 2014, 05:58:22 PM
theehman
Anybody ever tried this?  A mix control that would go from clean to flange to vibrato?
Ron Neely II
Electro-Harmonix info: http://electroharmonix.vintageusaguitars.com
Home of RonSound effects: http://www.ronsound.com
fx schematics and repairs
Crontox102098
Quote from: theehman on August 28, 2014, 05:58:22 PM
Yep. It do a strange vibrato.
I'm Carlos.
I speak spanish, just in case you do not understand what I say.
theehman
Quote from: Crontox102098 on August 28, 2014, 06:04:21 PM
Sounds interesting.  Did you have to add an active mixer?
Ron Neely II
Crontox102098
Quote from: theehman on August 28, 2014, 06:05:49 PM
No, just put some 50K pot between the 10K that go to the output (i'm sorry, dont speak english as well)
I'm Carlos.
Panning from clean to flange or from clean to vibrato is easy. Panning from one to another to another is much harder. You're into joystick territory if that's what you want to do.
StephenGiles
Could possibly do it with a dual pot and voltage control. The HSR Fader/Panner/Gate  had some tricks to alter the law of a pot, which may be of use.
Fender3D
Digital Larry
Quote from: R.G. on August 28, 2014, 11:29:26 PM
If you put dry on one side of the pot, and the modulated delay on the other side of the pot, isn't this the end result?
I.e.
Clean = all the way CCW
Vibrato (100% modulated delay) = all the way CW
Flange/chorus = halfway in between
What did I miss?
Digital Larry
DrAlx
What did I miss?
Nothing.  It is as you say.
