Small Stone Phaser v1 pcb?
Started by LucifersTrip, August 31, 2014, 06:51:40 PM
LucifersTrip
My friend enjoyed the Madbean Kraken (Mutron Micro V) I built for him, so he asked if I could build or help him with a Small Stone Phaser v1.
The closest I could find is the Space Harp:
http://lectric-fx.com/product/spaceharp/
There's hardly any talk of that here and I haven't look for other reviews yet...
Is there anyone else who carries a pcb for a clone?  I rarely build anything from pcbs, so don't know the smaller shops that may be around.
thanx
always think outside the box
jimilee
The stage fright over at madbean. I have built the spaceharp, sounds just as good as my small stone. Haberdasher is a good guy and an excellent designer.
LucifersTrip
Quote from: jimilee on August 31, 2014, 07:51:50 PM
It said that it was the Maestro Phaser...though, I didn't compare schematics yet.
sounds cool...thanx alot for the info
jimilee
Quote from: LucifersTrip on August 31, 2014, 08:19:26 PM
[/quote]
Dammit, you're right, my bad. It sounds kick ass though.
Scruffie
The Stage Fright is the Maestro Stage Phaser yeah, the non-ramping model.
The Space Harp is what you're after, don't know of any other PCBs for it.
LucifersTrip
Quote from: Scruffie on September 01, 2014, 10:13:29 AM
sounds cool...I'll go for that one.
I did see your name attached to the harp, so I'm sure you know it well.
http://www.madbeanpedals.com/forum/index.php?topic=14400.0
thanx alot
Blitz Krieg
is there documentation on the spaceharp?
LucifersTrip
UNless you have access to a secret stash of CA3094s, probably the closest you can get is a Tonepad Ropez.  The Ropez duplicates the 6-chip circuit using LM13600s, but subs an op-amp input and mixer stage for the discrete transistor stages the SS uses.  Same LFO, though.
Scruffie
Quote from: Mark Hammer on September 02, 2014, 02:33:31 PM
Page 4 is a schematic for the V1 Small Stone using LM13600 (or similar) http://lectric-fx.com/wp-content/uploads/2014/06/SpaceHarp.pdf
The Ropez is a 4 stage OTA phaser that uses 2 OTAs for the LFO but that's about where the similarities stop, the input and output is different as you say, the feedback is different, the sweep width/range is different (well, at least in one of the modes) the filters aren't even set the same. It can be made close enough but stock it isn't anything like it IMO.
Hadn't seen that circuit.  And yes, it comes closer than the Ropez does, although the phase shift stages seem similar.  What is most different is the manner in which the feedback is routed.
Scruffie
The OTAs are set up in a standard OTA All pass filter fashion in both cases, but where the Ropez has 3n3, the Small Stone uses 6n8 so sweeps in a lower range.
The V1 Small Stone also has that low pass filter cap on the LFO to make those nice bubbly tones at higher rates, easily added to the ropez though.
Quote from: Scruffie on September 02, 2014, 06:36:36 PM
Easily fixed/modded on the Ropez board if one wants.
QuoteThe V1 Small Stone also has that low pass filter cap on the LFO to make those nice bubbly tones at higher rates, easily added to the ropez though.
Yeah, I've implemented that some years back, and it works well.  Makes the hypertriangularsweep more triangular at faster speeds.
LucifersTrip
Thanx for the replies...
I had a couple questions about the build:
First, is this a standard dip 3 that will fit the pcb?
http://www.taydaelectronics.com/dip-switch-3-positions-gold-plated-contacts-top-actuated.html
...and just wanted some clarification on the feedback mod.
Instead of a dpdt, a spdt is installed on one "side" and a pot on the other, with a couple resistor omissions/changes.
So, with this mod, what happens in the 2 positions of the switch now that only one "side" is switched and in what setting are you back to the stock circuit?
thanx
Scruffie
Quote from: LucifersTrip on September 04, 2014, 06:10:31 PM
thanx
That DIP should be fine.
The mod means that the switch will switch between the 2 LFO Widths as it always did but you'll have control of the amount of feedback applied is all.
