Dynacomp from Tonepad: Help!! It's distortioning.
Started by neo79x, September 09, 2014, 04:23:31 PM
neo79x
Hello Friends!!!
I'm new here. My name is Alberto. I'm from Argentina. Just registered but I'm a follower of this site since several months. :)
This time I need your help with a Dynacomp that I'm building from this Layout/Schematic: http://www.tonepad.com/getFile.asp?id=9
So issue is that the effect sounds with a kind of fuzzy distortion. Level knob works ok but sustain seems to do nothing.
These are my voltages:
            C       B       E
Q1       9.53   2.28   1.82
Q2       7.08   2.97   2.46
Q3       0.64   0       0
Q4       0.64   0       0
Q5       9.53   0.64  0.63
IC1 = CA3080E
Pin 2 = 4.6V
Pin 3 = 4.6V
Pin 4 = 0V
Pin 5 = 0.63V
Pin 6 = 2.6V
Pin 7 = 9.5V
I'll really appreciate your help guys!!!
Hav
from a quick look i see an incomplete solder joint toward the bottom right hand side. doubt that will be related to creating a distorted sound, but you should fix that up anyway to avoid any other problems :-)
neo79x
Quote from: Hav on September 10, 2014, 11:39:45 AM
Yes I noticed that after uploading the picture. Already corrected. Thanks! :)
So far I tried:
- Changing the 150K resistor that links 9V with collector from Q3 and Q4.
- Replacing the CA3080.
- Changed the sustain pot.
And... still same issue. :(
neo79x
SOLVED!!!  :icon_biggrin:
I had a bad joint in the area of the pin 5 in the IC. I realized that because I took off the IC and Q5 but still having voltage in pin 5. That was not possible since Q5 emitter sends voltage to that pin.
PeterPan
Quote from: neo79x on September 11, 2014, 09:23:18 AM
Thanks for the link anyway! I've had a DynaComp for probably about 40 years now, and liked it so much I built it right into one of my guitars. Always wanted another, and now I can build me one! :-)
--Randy (PeterPan)
... Second Star to the Right, and Straight on Till Morning!
