A reverb pedal without Belton brick or FV-1?
Started by sajy_ho, September 11, 2014, 05:59:36 AM
sajy_ho
Hi guys, It' been a long time since I was planning to build a reverb pedal but none of reverb modules can be found here (Belton brick or FV-1). Can someone name a reverb pedal that I could build without using them?
I've built an Equinox and loved how it sound, but the delay time is very short (I mean the reverb room size!), and also I've tried build a Digital Reverb using BTDR-2 patent and didn't have success. The schematic is below:
Can someone more knowledgeable tell me what could be wrong with the schem?
Sajad
Life is too short for being regretful about it.
samhay
Quote from: sajy_ho on September 11, 2014, 05:59:36 AM
So mod the Equinox to have a longer delay.
You have 2 PT2399s to play with, so vary the resistors to pin 6 of one or both to get the delay you want.
sajy_ho
Thanks, but that wouldn't be a REVERB anymore. For a reverb chips must have delay times with clock time relationship. With two of pt2399s it won't be more than Equinox. I'm looking for something more,  maybe three chips.
knutolai
There is a schematic for the inside of the belton brick over at some russian forum. It uses 3 PT2399s. Maybe you could have a go building a modified version of that.
mth5044
Quote from: knutolai on September 11, 2014, 05:50:41 PM
I believe the schematic he posted is the 3 chip/inside of the belton brick?
Anyway, it's hard to say what could have gone wrong with your project without any pictures, voltages, information, etc.
sajy_ho
#5
Quote from: mth5044 on September 11, 2014, 08:45:27 PM
Yeah It's basically a schematic that I found from Belton brick on the web: ,
plus GGG's D-Verb as input and output buffer/mixer.
The circuit is on the breadboard for a long time and actually I was hoping someone take a look at the schem and see what is going on there.
Anyway thanks... ;)
sajy_ho
Here is a photo from the breadboard, I don't know if it comes handy:
And this is a sound sample, first the mix knob is at min then goes to the max, and with that only a noise appearing more and more and no reverb is in the sound:
https://soundcloud.com/sajy_ho/voice-002
~arph
Maybe one of the PT2399s is locked up.. try increasing all pin 6 to gnd resistors to something like 4k7 and see if it starts to verb
samhay
sajy_ho
Quote from: ~arph on September 12, 2014, 11:09:48 AM
I used 10k trimpots and tested every possible value, but still it's not working...
Quote from: samhay on September 12, 2014, 11:34:38 AM
Audio probe?
That's a good idea man!
I just noticed one more thing comparing the given schem with this one from bdtr-1 :
and the following photos:
What is that guy at top-right of the schem? Because I didn't included it according to bdtr-2 schematic(the first one).
It's a simple op-amp mixer for the signals coming from pin 12 of each PT2399, the output of which seems to be getting fed back into the PT2399s.
sajy_ho
Quote from: bluebunny on September 12, 2014, 12:37:16 PM
Ohhhh now I get it! So the "GF" marker on the first schem (btdr2) is a single opamp too?
If yes, how should I include it in the first one?
cool, good to see someone having a go at this...whats the 74hc14 for?...
samhay
No. Just connect the 3 points labelled GF together.
The LFO.  See 'Schmitt Trigger inverter Oscillator' here: http://how-to.wikia.com/wiki/How_to_build_an_oscillator_circuit
~arph
Quote from: deadastronaut on September 12, 2014, 03:42:59 PM
Modulation, but why not use the op amp in the first pt2399 ( they are using it already for the mod) and drop the silly square wave oscillator on a huge ic with all those unused inverters ..
samhay
The leftmost PT2399s are used as input buffers/filters. You could do away with one of the output op-amps I guess, but probably best to use something else - an op-amp makes as much sense as anything else for a discrete implementation of the brick.
~arph
If I look at the pencil schematic the leftmost pt2399 has one op amp buffering and filtering the modulation signal ( between pins 13 and 14)
samhay
Adventure_Audio
I've had this schematic on the calendar for a month now. I am going to give it a shot. Finally got all the parts in the other day but I am going to be incorperating it into a reverb + delay/chorus based off this french duders video:
http://www.youtube.com/watch?v=vZ136J05dCU
SO, Ive been wondering to myself...
What is the difference between the Belton Brick 1 and 2? I read on another forum that Belton "took some advice" and revised their schematic, but what did they change exactly?
~arph
At a quick glance:
Buffered mixer for internal feedback and two reverb outputs. Probably more changes
