A reverb pedal without Belton brick or FV-1?
Started by sajy_ho, September 11, 2014, 05:59:36 AM
sajy_ho
Guys, the hand-drawn schematic worked!! I just breadboarded it and it gives a something near to reverb, but after changing pin6 resistors with trimpots and tweaking them a bit it worked great!
Life is too short for being regretful about it.
Adventure_Audio
Awesome! Can't wait to try it out!
How close did you stay to the original values? Mainly the 11.8Ks and the 4.99Ks. I was going to sub them for 12Ks and 5Ks.
Also did you end up using the Schmitt Trigger IC?
I want to hear a sound sample! Awesome work!
sajy_ho
Quote from: Adventure_Audio on September 13, 2014, 11:03:32 AM
I've used 12k and 5k1 resistors instead of 11k8 and 4k99, but used 5k trimpots in place of pin6 resistors and adjusted it to given values.
Also I used pin 1 and 2 of 74hc14 as Schmitt trigger, but don't forget to connect all the other odd number pins (3,5,7,9,11 and 13) to ground.
As for the opamp I used a 741 single opamp; the rest is exactly like the hand-drawn schematic (not the first one because it didn't work for me!)
Oh sorry! :icon_redface: I've just disassembled the breadboard for using the parts, but I'm designing a PCB for it and I will record a sample ASAP.
Adventure_Audio
[/quote]
No problem! I look forward to it and am very excited to try it myself. A friend suggested configuring a schmitt trigger from an op amp rather than trying to use that huge IC. That will be the next step...
sajy_ho
Quote from: Adventure_Audio on September 13, 2014, 03:44:03 PM
[/quote]
That's a good idea, speacially for pcb designing I can use a dual opamp, but how can an opamp be used in place of the Schmitt triger?
Adventure_Audio
Here is an awesome site that explains how the schmitt trigger works
http://www.talkingelectronics.com/pay/BEC-3/Page76.html
and according to wiki - http://en.wikipedia.org/wiki/Schmitt_trigger
the idea is "any active circuit can be made to behave as a Schmitt trigger by applying a positive feedback so that the loop gain is more than one"
So this can be done with a network of transistors or an op amp configuration explained further on the wiki page. I believe a bit of experimenting is in order though!  :D
sajy_ho
Quote from: Adventure_Audio on September 13, 2014, 04:15:15 PM
Thanks man, so I guess I need to breadboard the whole thing again ;D
Adventure_Audio
You could do that to be safe! Or just try constructing the inverting schmitt trigger and using it for a similar application. It would help if we had the exact values of the components in the 74HC14 IC. I will post my results in the next week or so and we can compare. I am very excited someone else is attempting this circuit at the same time as me!
sajy_ho
Quote from: deadastronaut on September 14, 2014, 11:43:01 AM
Add another pt2399... :icon_idea:
That's an awsome idea man; how about a new reverb project with 4 pt2399's and more knobs like decay control?
Yeah that would be cool,
control each pt delay, decay etc.... 8)
sajy_ho
How can we add a decay control to it?
I'm thinking about a variable resistor in the place of the 4th pt's pin 6 resistor...
samhay
You can do that with your 3-PT2399 design.
I spent some time thinking about building a reverb based on the patent schematic that you have used. I eventually concluded that the main benefit would be to be able to vary the delay time(s) of the PT2399(s). You can now do with the new BTDR-3 brick, so I figured that if I wasn't going to add any new functionality, then it was not going to be worth my effort. Your initial reasons for building this probably differed to mine, but I still encourage you to think about how you can make a better version of the BTDR bricks with a discrete design - more control, different filtering, different use(s) of the LFO, etc.
Adventure_Audio
I totally agree. Also a 4th 2399 with decay control would be wicked. So here's a thought:
If we were to alter the patented schematic i.e. Different filtering/values/etc. would that expel the patent? I guess what I'm trying to say is, would it make it a "free", DIY enabling circuit? I'm not a lawyer but it would be interesting to know.
sajy_ho
Quote from: Adventure_Audio on September 14, 2014, 03:04:39 PM
I think we should do this, because otherwise it would be called "Copywrite" or something like that; but what about people like me which don't have access to the reverb modules?!
My idea is: four PT's with adjustable delay switch (short/long) and a decay knob, with input and output buffer/mixer all in one PCB!
I know it will become huge, but I think it still can fit in a 1590BB enclosure; so what do you think?
samhay
Why do you want a 4th PT2399? There is plenty enough reverb in a BTDR chip for most peoples liking.
sajy_ho
Quote from: samhay on September 14, 2014, 03:46:18 PM
I just want something different so we could call it a "DIY" reverb, but 3 chips would be enough, but how can we add a decay knob to it?
Adventure_Audio
When you say decay control you mean being able to seemlessly switch between the Short, Medium, Long bricks right? I would think that would amount on the feedback trim pots you spoke about earlier. Not 100% sure though
sajy_ho
Quote from: Adventure_Audio on September 14, 2014, 04:01:32 PM
Exactly, thanks for correction. something like delay time but in the terms of reverb, if you know what I mean...
