Balgstar pics, another go
Started by mykaitch, September 11, 2014, 11:21:55 AM
mykaitch
The grille was made from alu tube and chrome tape
Great mod! O/P level goes right up to 11
I made two boards so that each could be tested on its own. This is the low volts brd
This is the valve stuff that hurts if you touch the wrong bit
Valve bd and chassis fitted
I only ever use wires on the copm side for power. This is the copper side
(except the valve bit which is all on top)
General views...
This code was used: [img height= .....
   img height=400]http://]http://www.mikehoughton.co.uk\Blagstar\top1.jpg[/img]//
mykaitch
   img height=400 ]http://www.mikehoughton.co.uk\Blagstar\top1.jpg[/img]
Nope. Don't work
Hatredman
Kirk Hammet invented the Burst Box.
Hemmel
Bââââ.
your code (after php-ing) shows like this in the source.
<img src="http://]http://www.mikehoughton.co.uk\Blagstar\top2.jpg" alt="" height="400" border="0" />
you need only one http:// for tikkety-boo-ing images, so it needs to look like this when you type it in .....
[edit :] oops. some bad slashes removed ....
[edit :] well, there you go. enter the addy w/ backslashes, and my browser reversed them for me.
Hemmel
Quote from: duck_arse on September 11, 2014, 12:41:51 PM
[img height=400]http://www.mikehoughton.co.uk\Blagstar\top2.jpg[/img]
Look out though, the link will not work with the backslashes "\"
Bââââ.
