Yellow Humper schematic and/or components
Started by peterg, September 16, 2014, 04:05:07 PM
peterg
I've done a lot of searching but can not find a Dan Armstrong Yellow Humper schematic. I understand that it is essentially the Purple Peaker with a few component substitutions for bass guitar use.
Here is the PP schematic:
http://www.tonepad.com/project.asp?id=48
I believe that the components that need to be tweaked are C1, R1, C2, R5-10 and C4-9. Is that correct? if so what alteration are needed to make it a YH?
FUZZZZzzzz
#2
http://tagboardeffects.blogspot.nl/2013/01/dan-armstrong-yellow-humper.html
well.. theres a layout with the 'right' components. I know its not the easiest thing but you also draw a schematic from this layout
ps. or just build it on vero board.
tombaker
http://audio-depot.com/dan-armstrong-dayh-yellow-humper-bass-eq-effect-module/
They're going for $39. I know half the fun is building it, but the other half is using it and this would get you to that half quicker.
Blue Box, Harmonic Perculator, Brian May Treble Boost, Klon Vero, Fuzz Face Germ/Sili, Echo Base Delay, CS-3 Monte Allums Mod, JLM 1290 Mic Pres, JLM Mono Mic Pres, Engineer's Thumb, A/B/C & A/B boxes, Tiny Giant Amp, Microamp
midwayfair
Quote from: tombaker on September 17, 2014, 06:34:41 AM
Those "Dan Armstrong" boxes are just atrociously built. They're worthless, no matter how cheap they are.
