Tim Escobedo - More snippets!
Started by ~arph, September 18, 2014, 06:27:17 AM
~arph
Here is a little story..
Way back in I think it was 2008 I was scavenging TE's snippets as we all were.. But then I found a snippet that was not on the page. It was an image in the same folder as the other snippets and it was called sudofaze (or pseudofase.. spelling might be a bit off). If only I had the clear mind of saving this file to my HD back then. I did save the entire snippets HTML page, but yes like all copies on the web, that excluded the pseudofaze/sudofaze snippet.
What I did do then is design a simple pseudo phaser pedal around this snippet. So I sill have the basic building block of that design in Eagle. (and a working pedal)
So here I present what I think the snippet looked like. Some component values will differ and I'm not sure about the output buffer. the LDR should be controlled by an LFO and this was not in the snippet (as in other LFO controlled snippets)
If someone has the original image file, a repost would be awesome!  So everyone with snippet backups: check your folders
EDIT:
I FOUND IT! IN THE WAY BACK MACHINE
~arph
There is more..
source: http://web.archive.org/web/20091027011723/http://geocities.com/tpe123/folkurban/fuzz/
cool...never seen those..
i keep getting ''service temporarily unavailable..''   :-\
~arph
Yeh, click the go button on top of the page... this loads it
midwayfair
Augg! I was going nuts trying to find the "More Faces" picture a couple weeks ago.
Thanks for the rescue, ~arph!
~arph
No problem, it's hard looking for them as the text is all in the images.
Please do save them to your HD as they are on my dropbox and who knows how long that will stay up. (I do not intend to remove them though)
