25 watt stomp box amp design
Started by rring, October 02, 2014, 02:28:14 PM
rring
Okay I just misunderstood that some how you were saying the transfer function over the entire range of the filter would be altered.
So I just used linear pots because that's what I had - but there is so much variation regarding the other effects in the signal chain - guitar type, pickup type, the EQ weighting in my op amp stages.....
that when you are making adjustments, the lions share usable guitar tonal adjustment falls in a comfortable range on the knobs
I don't think it will matter much to guitar players.
Ah, interesting.
Open this image in a different window.
http://i.imgur.com/0hYjqQ2.gif
Three tone networks. All pots set at 50% rotation.
Top is a "High Fidelity" James stack using LOG 10% pots ("audio taper"). It is flat +/-1dB over the audio range. Loss is about 20dB. Minor errors due to 38K source and 1Meg load (should be zero and infinity).
Middle is a "James" but made with LINEAR taper pots set at 50% rotation. Loss at 400Hz is still about 20dB but lows and highs have less loss (are relatively boosted).
Bottom is a Fender, still all pots at 50% and using factory-like tapers. Referencing 400Hz again, lows and highs have less loss (are relatively boosted).
rring
#22
Those graphs tell an interesting story. I did a basic circuit simulation in spice and tweaked accordingly  - I should use this tool and examine further - I suspect I am compensating with the 1uF(C3) for a scoop..etc.
someone earlier wanted some gut shots here they are:
you can see my home brew heatsink made out of 1/2 inch copper pipe I split and shaped - it is made to contact the box. You can see there is room to make the board bigger and use leaded parts - if desired
tubegeek
Sweet!
Nice use of leftover plumbing, too!
Did you solder the SMD's with big fat plumber's solder?!?!
rring
Yes I wasn't sure what to use for a heat sink at first because I didn't want to deal with trying to make something fit..etc
its pretty easy to saw copper pipe and form into any shape you want.
actually I glued everything into place and then dipped the whole board into a crucible of molten alloy.. I saw Vincent price do that to one of his victims once.
J0K3RX
pretty sure you were joking about the plumbers solder :icon_lol: usually acid core.. doesn't play well with electronics. :icon_wink:
bool
Old AMD athlon heatsinks are good for chipamps.
tubegeek
Quote from: J0K3RX on October 05, 2014, 04:18:08 PM
Yeah, it was merely a plumber's crack.
