Mu-Tron Phasor Potentiometer and Depth Switch
Started by RedRabbit, October 02, 2014, 04:50:38 PM
RedRabbit
Hey folks,
Just picked up a Mu-Tron Phasor (not a II) for a steal that has both the rate pot and the depth switch broken.
Thankfully it still phases and sounds great but I can't change the depth function. I don't even know where it's set now...
The rate pot snapped at shaft but it still rotates.
Now I'm trying to find replacement parts and I cannot read the schematic to save my life.
http://www.beavisaudio.com/img09/MutronPhasorFactorySchematic.jpg
Could someone please tell me what P1 is? Is that 25K log? or 10k log?
Also, has anyone fixed one of these things recently with a new rotary 3-way switch? I'm assuming anything generic should work fine?
armdnrdy
As far as the Depth switch goes...you have a couple of options.
You can use a 2 pole, 3 position rotary switch (2P3T) and use only half of the switch.
Use a 1 pole, 12 position rotary switch (1P12T) which has a "selector" washer and set it to 1 pole, 3 position.
The Rate pot looks like a 25KA. (Log)
The schematic is not very clear but...if you review the Phasor II schematic...you'll find that the LFO is very close and the Phasor II used a 25KA.
Blitz Krieg
armdnrdy
You can also measure the two outside lugs of the rate pot with a meter.
RedRabbit
I've already replaced the depth switch with a rotary switch I had left over from another project. Now all the settings are back. The previous owner just bypassed the switch.
As for the pot, it's only marked "0403, 1377532".
