Help with wiring a power switch + led
Started by LexNZ, October 09, 2014, 12:05:38 AM
LexNZ
Hi, i'm building a test bench and using a beavisaudio wiring guide: http://www.beavisaudio.com/techpages/SchematicToReality/fig8.1.gif
But I also need a power switch (spdt?) and LED.
I have an idea but want to make sure since i'm such a beginner  :)
Thanks,
Lex
Why?
When not in use, un-plug.
Wall-wart won't deliver power when you un-plug it from the effect.
Battery gets disconnected when you take the plug out of the Input jack.
+1  just build it as it is....no need for extra parts etc..
your led will go on/off when you use the footswitch just as a normal pedal does... 8)
LexNZ
Fair enough, I guess I just wanted more lights :P
