Good source for 18VDC regulated PSU?
Started by karbomusic, October 19, 2014, 10:59:14 AM
karbomusic
Not having much luck with search due unrelated results for such a term. Anyone have a good source for the following?
18VDC, 500mA minimum, regulated wall-wart w/neg ground. Basically an 18VDC version of a Boss PSA120. I could make one but in this case I'd prefer to buy a few of them and move on. :D
Buy two special-designed, quiet, well tested and widely available, inexpensive 9V effects supplies and stack them with a 2:1 cable.
Otherwise, plan on testing the ones you find to be sure they're quiet.
Processaurus
#2
karbomusic
Thanks guys. I guess I'll try the Dunlop one and see how well it does.
J0K3RX
Look up Caline CP-05, not bad
Also have a look at joyo jp-02
I usually just pick up an old 18v laptop supply as they are well regulated and are usually rated at 3 or 4 amps or more...
karbomusic
#5
Quote from: J0K3RX on October 20, 2014, 04:30:44 PM
Thanks for the info. I saw the Caline yesterday but what I'm looking for is an actual wall-wart because I have a couple of builds for someone else and I wanted to have a few 18VDC adapters around if they wanted to try them. The build runs 9-18VDC so the 18 was both something I wanted to try myself (outside the breadboard) and for the couple fellows who would be getting one of the builds.
EDIT: I noticed the 18V appears to come straight from the wall wart on the Caline and Joyo, so I suppose I could just toss the main unit. Made me giggle.
