Building an attenuator?
Started by IanEric.com, October 30, 2014, 08:18:20 PM
IanEric.com
Happy to find this forum and the resources available!
I'm am looking to buy (build - because I can't find what I want!) an attenuator (-15dB, or adjustable) that can be used with 1/4" cables (either TRS or TS cables).
This is to step down an output.  The output has a +22dB max at peak, I need it to be +8 maximum.
For those that care WHY I'm doing this, read on.  Here's the setup:
I am a solo acoustic performer, and I use a Bose L1 Compact for my PA.  I'm going to buy a second unit (10% off sale starts November 1st for anyone interested!), so I have one for backup and also for more power when I need it.
I am NOT going to be running them stereo, because splitting my signals is a pain and I'm just not going to do that.  Bose actually recommends that a "daisy chain" arrangement is perfectly acceptable (and some users have even reported it sounds BETTER), where the 1/4" TRS/TS output from one Compact can be used to feed the 1/4" input of the second unit, amounting to a master/slave arrangement.
Now here's where the pad/attenuator comes in:
I already own a Line6 Relay G30 guitar wireless system.  It's a full 1/4"-based system.  Got my wheels turning, so I asked on the Line6 forums and YES, I CAN use the wireless to send my signal from one Bose to the other, and the consensus is it will work beautifully.  This is awesome - I can run a second PA system and send signals to it wirelessly!
BUT - the Line6 tech recommends making sure the voltage INTO the belt-pack transmitter be kept to a max of +8dB, or I will incur clipping.  The Bose system's output has a range of output from +2.2 to +20dB max.  Obviously, +20 is a bad number here.  So I need to attenuate that with a -15dB pad to send a clean, clear, unclipped signal through the wireless to the other Bose.
I am having a very hard time finding attenuators for 1/4" input/output.  Everything is XLR, or at least XLR on one end.  If all else fails, I'll do this with some adapters and one of those XLR/TRS attenuators, but it seems sloppy.  I like simple and clean.  A stomp-box style attenuator, an inline unit; I don't care.  I'd just like something that has proper 1/4" in and out if at all possible.
So that's the story.  Any ideas?
Can anyone help?
It's just two resistors.
But you need to know *impedances*........ ah, I see Bose' documentation omits any useful information.
Use a 5K linear pot. Adjust to suit.
IanEric.com
Yes, the only info I have is that the output range is +2.2 dB to +20dB peak.  And that the Line 6 belt pack should see no more than +8dB.  No impedances given for each.....but the use of -15dB was recommended by a Line 6 rep, with no other info, so I have to assume the generic "inline" style would suffice....
I was already considering a DIY with a pot, but I must admit I'm really clueless.  I grasp the concept and know I can build something, but a diagram would REALLY help if you or anyone else would care to hook a brother up....
Also:  I am still considering an inline pad.  Truth is, with the proper XLR-to-TRS cables (one XLR-F to TRS male, one XLR-M to TRS female, and XLR attenuator between them), it really wouldn't be incredibly awkward.  Any particular reason this shouldn't work if I can find a -15dB inline attenuator?
A linear pot like PRR suggested would be OK and the line capacitances should not be so high that you need to buffer the output.
GGBB
IanEric.com
The Parts Express inline is exactly what I decided to go with.
My original "concern" was going from TRS to XLR, and back again.  Not because of signal problems, but because I'm a little OCD and I like things clean and simple.  But I decided to buy the XLR attenuator, as well as some proper TRS-to-XLR cables, and just roll with that.  It should work well and won't be as cluttered up by adapters as I originally believed it might be....
IanEric.com
Well, this isn't exactly stomp box related anymore, but I did want to update:  I received all my new gear today, and the inline attenuator works perfectly well, as does the wireless setup!
Using a Line6 Relay G30 as a wireless transmitter to daisy-chain Bose L1 Compact PA systems works AMAZINGLY well.  Great sound, no delay.  This will really expand my flexibility when needing a second PA for my live performances.
