DIY Noisegate
Started by akc1973, November 05, 2014, 01:39:10 AM
akc1973
Hey Folks,
I know this has probably been asked many times but I'm interested in recommendations for a DIY Noisegate that people have had good success with?
akc1973
Builds: Bazz Fuss, Orange Squeezer, Omega, Green Ringer, Dist+, X-Fuzz
some members made the 'decimator' with good results a while back...
I did the DOd FX30 works a treat
antonis
I used something like this sometimes ago with a BigMuff in a wooden enclosure with great results...
(but I had relative small amount of "hiss" and a reasonably excpected "hum" to eliminate..) :icon_wink:
You better bridge the pot to both ends of R14 for best results...
I suggest a value of 1M so you will not decrease much the total value of the biasing resistor...
(maybe you'll have to trimm it to a value of 100k - or less - resulting that you'll have to decrease the upper voltage divider resistor if you want to keep the same bias voltage..)
Where do you want/need to insert it into your signal chain, and what sort of "noise" are you trying to control?
Important considerations.
akc1973
Quote from: Mark Hammer on November 05, 2014, 08:01:49 AM
Hi Mark,
I've read your recommendations in the past of having two noise gates (at the start and end of the signal chain for guitar-induced and effect/gain-induced hiss/hum, respectively). My guitars are pretty quiet so I want one for the end of the chain so that I can try out some higher-gain effects.
akc1973
So you are basically wishing to tackle accumulated hiss?
akc1973
Quote from: Mark Hammer on November 06, 2014, 08:51:10 AM
Yes, that's exactly what I'm after. And one other condition I have ( ;)) is that I use vero or buy pre-etched PCBs (I don't etch my own)...I notice there is a vero layout of the MXR noise gate floating around which looks relatively feasible.
akc1973
akc1973
I guess it's going to be the MXR noisegate!  : :icon_biggrin:
akc1973
josephtrex
I bought the Collete noisegate pcb from tonepad, but I've been afraid to tackle it. There are a lot of build reports that are contradictions so that's why I'm putting it off. have a ton of other projects to do before I get to it. So if you have success with that, let me know!!!
akc1973
Quote from: josephtrex on November 10, 2014, 09:54:55 PM
Will do!  :)
