Spyder question 15 volt output
Started by wavley, November 17, 2014, 01:58:07 PM
wavley
So I've ordered all the parts to build a Spyder x2.  I need one of the 9VAC outs for my Boomerang, but I don't really need the other and I do need a 15VDC out for my Attack Sustain.
Is it better to use one 11 Volt secondary and the 9 Volt one for 20VAC and then regulate down to 15VDC with a single regulator or is it better to use two regulators and do both of them at 7.5VDC and parallel them for 15VDC?
A friend at work happened to find these and show them to me the morning after my wife gave me the go ahead to order parts, I ordered two sets and it looks like it will save me quite a bit of work http://www.ebay.com/itm/10pcs-LM317-Adjustable-Power-Supply-Board-With-Rectified-AC-DC-Input-DIY-KIT/111379415005?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20131017132637%26meid%3D52cc036eaf7b45a293aa2ed84e7bdc91%26pid%3D100033%26prg%3D20131017132637%26rk%3D2%26rkt%3D4%26sd%3D191218579434
Bone is in the fingers.
EccoHollow Art & Sound
eccohollow.bandcamp.com
Series might be even better?
I would in general be dubious about working regs in series (or parallel!). Probably works, but they could get in a fight.
Seems you could use either 11VAC+9VAC or 9VAC+9VAC to get ~~ 26VDC, and one 7815 reg to soothe it. Mainly depends on which secondaries you need for other outputs.
One 9V winding to a voltage doubler also gets in this zone and will handle smaller currents excellently.
If you don't need dead-clean and steady or a lot of power (dunno what a Attack Sustain is), just the 11VAC rectifyed onto a big cap will give pretty near 15VDC.
wavley
Quote from: PRR on November 17, 2014, 03:21:34 PM
Oops, yes.  I was thinking about the Voodoo labs thing and remembering that they use a Y cable to get 18V from two 9V outs, in my head Y cables are parallel, but this I'm sure is wired series.
It seems like pretty common practice in multi out power supplies lately, but it just didn't seem like a good idea.
I'm planning on using one of my 9VAC secondaries, but don't have any use for the second one, that's why I was thinking 11+9
The 9V and a doubler sounds like a good plan too, I don't know what the current draw of the Pigtronix attack sustain is, but it's basically just a compressor and an improved EH Attack Decay, I don't imagine that it's a lot.
