Is there a way to make a buffer into a boost, simply?
Started by acehobojoe, November 27, 2014, 09:43:57 AM
acehobojoe
So, the first buffer on. This page seems pretty simple, yes, but is there a way to give it more gain? Maybe I'm just not understanding the buffer/booster question.
antonis
antonis
TYou can go here: http://www.beavisaudio.com/techpages/HIW/HIW.png and see the  schematic differences between Buffer & Booster..
At your buffer you'll have to bias the Jfet, add a resistor (or trimmer) between 9V and Drain and a capacitor to this junction which will lead to an extra output, selectable by a switch...
acehobojoe
Based on what I was reading that seems like the only difference. I'll draw a schematic..
acehobojoe
http://i.imgur.com/VuWT2Qtl.jpg
That's what I got. Then I can either switch them or blend the 2 with a pot at the end.
Good intention. However, the signal at the drain is inverted relative to the signal at the source. A true equal-amounts mix/blend gives you cancellation and no signal out at all.
There was a recent thread where I typed in some thoughts about buffer, boosters, and the differences and overlaps. Might be a good read for you.
acehobojoe
So it'd have to be a switch, or perhaps there is a way to phase invert it. Could you link me to that thread?
knutolai
You could rearrange the circuit for something similar to the tilman preamp (second circuit under "boosters")
http://www.beavisaudio.com/techpages/blocksfragments/
by substituting R6 for a 50k (or 100k) logarithmic potentiometer you would have a circuit able to boost and dampen your signal. Setting the pot to unity gain obviously would give you a unity gain buffer (though with a slightly worse output impedance than your original circuit).
acehobojoe
Yes, I imagine it would be a little worse impedance, do you mean because of the pot?
The output from a drain of a FET amplifier fundamentally has a higher impedance than the output from a source follower.
Then the pot likely raises this a bit.
acehobojoe
Ok, I'll make another schem. Where is your other post?
midwayfair
You'd be better off doing this with an op amp. The Microamp is fine for this application:
http://www.electrosmash.com/images/tech/microamp/mxr-microamp-schematic.png\
To make it a buffer simply short the - pin and pin 1 with a switch. It won't matter where the boost pot is set; the gain will be 1.
acehobojoe
Would that not be possible with the same transistor schem? Just shorting it? Or it would phase out I guess.
acehobojoe
I also want to keep the part count low. For I am using a 1590a
knutolai
midwayfair
Quote from: acehobojoe on November 27, 2014, 04:01:35 PM
No. The transistor version you posted is a source follower. You cannot get voltage gain from the source output. The op amp is far more complicated than a single transistor on the inside.
There should be a microamp layout somewhere that will fit in a 1590A. Way more complicated stuff fits.
