Premier Guitar Black Russian Big Muff Mod.Need confirmation!
Started by soupbone, December 09, 2014, 11:45:43 PM
soupbone
I was checking out the this article in Premier Guitar; http://www.premierguitar.com/articles/Electro_Harmonix_Russian_Big_Muff_Pi_Pedal_Mods  I noticed after i did the main mods in the article(i.e.R8,R13,R18,R19,R22,C1,C9,C12) that my Black Russian Big Muff didn't work after these mods.So,i found this awesome Big Muff page; http://www.bigmuffpage.com/Big_Muff_Pi_versions_schematics_part3.html and from the same site,the V8 Wiring Diagram; http://www.bigmuffpage.com/Big_Muff_Pi_versions_schematics_part3.html I noticed the schematic and the parts layout on the Premier Guitar Article has a lot of flaws.I looked at my pedal and the info from the Big Muff Page,and the schematic and parts layout are correct.So,what i did was look at the two differn't schematics and layouts,and compare them.I'm almost 100% i'm correct i've got it right.Just need confirmation!  :icon_biggrin: The part numbers in ( ) are the premier guitar part numbers.The numbers not in ( ) are the correct value and number.Here's the parts list; (R8=10k)-->R19,(R13=10k)-->R12,(R18=22k)-->R5,(R22k=470k)-->R7,(C1=0.1uf)-->This one is actually correct.,(C9=.047uf)-->C7,(C12=0.1uf)-->C3.Look at the two schematics,and the board layouts for reference.Just need confirmation that i'm correct!Thanks!
soupbone
Quote from: soupbone on December 09, 2014, 11:45:43 PM
I was checking out the this article in Premier Guitar; http://www.premierguitar.com/articles/Electro_Harmonix_Russian_Big_Muff_Pi_Pedal_Mods  I noticed after i did the main mods in the article(i.e.R8,R13,R18,R19,R22,C1,C9,C12) that my Black Russian Big Muff didn't work after these mods.So,i found this awesome Big Muff page; http://www.bigmuffpage.com/Big_Muff_Pi_versions_schematics_part3.html and from the same site,the V8 Wiring Diagram; http://www.bigmuffpage.com/Big_Muff_Pi_versions_schematics_part3.html I noticed the schematic,and the parts layout on the Premier Guitar Article has a lot of flaws.I looked at my pedal and the info from the Big Muff Page,and the schematic and parts layout is correct.So,what i did was look at the two differn't schematics and layouts,and compare them.I'm almost 100% i'm correct i've got it right.Just need confirmation!  :icon_biggrin: The part numbers in ( ) are the premier guitar part numbers.The numbers not in ( ) should be the correct value and number.Here's the parts list; (R8=10k)-->R19,(R13=10k)-->R12,(R18=22k)-->R5,(R22k=470k)-->R7,(C1=0.1uf)-->This one is actually correct.,(C9=.047uf)-->C7,(C12=0.1uf)-->C3.Look at the two schematics,and the board layouts for reference.Just need confirmation that i'm correct!Thanks!
I just noticed I accidentally posted the Big Muff Page Schematic twice.Here's the board layout; ( scroll towards the bottom of the page.) www.kitrae.net/music/big_muff_guts.html
antonis
Maybe you should use something like this as a guide for BMπ various versions..
(you can easily trace the components on the veroboard..)
soupbone
Quote from: antonis on December 10, 2014, 06:40:01 AM
Cool!Thanks Antonis!The Premier Guitar Article has the numbers of a lot of the resistors and cap sizes wrong.I did the mods today from premier guitar after comparing them,and I had it correct!Thanks for the pic with the different versions.That comes in handy.Thanks!
soupbone
Pistones has a great big muff site too.The Triangle Big Muff Scheme parts list of the revised versions is actually version 2.There's been so many big muffs made,with little tweaks of the same circuit.The Triangle V2 is the only version that uses a 3.3k input resistor.All of the other versions use a 39k(most used),and a 33k.Not sure what that resistor does that to the sound.
antonis
Quote from: soupbone on December 13, 2014, 04:10:54 AM
It "restricts" the signal..
Increasing its value increases the input impedance and decreases the incoming signal (limits gain)
Coupled with the input capacitor creates a high pass filter (attenuates low frequencies)
