Where to buy small 1/4" jack pcb mount sockets
Started by Ice-9, January 07, 2015, 04:19:47 PM
Ice-9
I'm just wondering if anyone has any ideas on where to buy the small footprint 6.35mm jack sockets for pcb mounting, I see these as being a great space saver in a few 1590A sized pedals I want to have a go at building. Sorry I don't have a picture of them.
www.stanleyfx.co.uk
Rapidonline have some pretty skinny looking ones.
armdnrdy
Steve,
You might want to add some different keywords to that item.
I did a pretty extensive search for those jacks and Small Bear never popped up.
smallbearelec
Quote from: armdnrdy on January 08, 2015, 01:20:36 AM
You might want to add some different keywords to that item. I did a pretty extensive search for those jacks and Small Bear never popped up.
Will do. I have long had them, but I thought they were mostly for repairs of commercial gear.
Ice-9
Cheers everyone, just what I was looking for, I has done quite a long search but non of these turned up. Great links Arndnrdy, I couldn't find these at Rapid though Slacker :(
Quote from: smallbearelec on January 08, 2015, 06:04:38 AM
Yes originally I need these for a repair to a commercial pedal and those ones look exactly the same (pin outs as well) Thanks Steve. To get them from Smallbear I will need to wait until I have a decent size order to make the postage worthwhile. Which leads me to asking if you have the small Alpha type 1p8t rotary switches available ?
www.stanleyfx.co.uk
Ice-9
Quote from: peterg on January 08, 2015, 09:14:47 AM
I used these on my latest build:
http://smallbear-electronics.mybigcommerce.com/1-4-enclosed-nmj6hcd2/
The ferrule screws in from outside the box.
Also used this power jack:
http://smallbear-electronics.mybigcommerce.com/plastic-2-1-mm-pc-mount/
Thanks peterg, I use those on my normal 1590b builds but they are far to large for what I have in mind for the 1590a builds.
www.stanleyfx.co.uk
smallbearelec
Quote from: Ice-9 on January 08, 2015, 08:43:03 AM
...leads me to asking if you have the small Alpha type 1p8t rotary switches available ?
Got these:
http://smallbear-electronics.mybigcommerce.com/9mm-rotary-1p6t/
Is there an 8P that I don't know about?
Ice-9
Quote from: smallbearelec on January 08, 2015, 05:21:25 PM
Got these:
These are the switches I'm looking for, if you can source these at a decent price I might be looking to buy anywhere between 30-50 at a time. also  I could use the 1p4t versions.
www.stanleyfx.co.uk
smallbearelec
Quote from: Ice-9 on January 08, 2015, 08:09:29 PM
I gotta ask Alpha for the exact p/n. However, I would order with a full-round shaft.
Ice-9
Quote from: smallbearelec on January 08, 2015, 10:03:46 PM
I will see if I can get a part number for them and I would prefer the full round shaft as well.
@alanp, Yeah those are the exact ones I was looking for.  :icon_smile:
www.stanleyfx.co.uk
Ice-9
#14
This is the datasheet for the switch type, this one is from Alpha.
http://www.taiwanalpha.com/english/p_e_141.htm
This is the alps version SRBV181004
http://www.alps.com/prod/info/E/HTML/Switch/Rotary/SRBV/SRBV181004.html
www.stanleyfx.co.uk
