Another Noob Question - Film Vs Ceramic disc Caps
Started by Neta, January 09, 2015, 10:31:29 AM
midwayfair
Quote from: duck_arse on January 14, 2015, 09:03:36 AM
something like food
That modifier is indeed required if you're going to use that noun.
anotherjim
Quote from: davent on January 13, 2015, 07:17:41 PM
In this sport i don't think i've ever seen the pads/spaces for the small ceramic decoupling caps as close to the op amp pins as possible (and I believe always recommended) on any pcb or layout. I soldered then to the sockets as an easy fix/addition for the op amps going on a purchased pcb.
(Curry covered grains of rice.)
There used to be -  maybe still is, a range of IC sockets with a 100nF axial multilayer ceramic ready fitted between the power pin (assumed to be 28,20,16,14 etc) and the ground pin (14,10,8,7..). I doubt they came in 8pin size though, since they were aimed at TTL & CMOS.
...but, with a socket which has some space in the middle, you can easily fit one yourself.
On perfboard, I try to run a wire from the ground pin up, thru the middle to the first holes past the chip, and fit the ceramic cap from that to the power pin. With 8pin amp's and radial caps, a cap wire is often long enough to form the wire to ground.
Power decoupling is a bit like throwing salt over your shoulder for luck. If you always do it, you'll never know if it does any good.
tubegeek
Well, I have long experience with dogs, having had Golden Retrievers for nearly 30 years. Dogs will eat anything that vaguely resembles food.
And many things that don't vaguely resemble food.
So even if they vaguely resemble corn, the dogs don't care.
That's my story and I'm sticking to it.  :icon_biggrin:
And dogs will eat corn even if they can't digest it - corn comes out of a dog looking the same as when it went in.
GGBB
Quote from: amptramp on January 16, 2015, 10:45:09 AM
Apparently I can't digest corn either, and neither can anyone I know with whom this topic has come up in conversation (thankfully that's not a lot of people).
Makes me worry about what "corn dogs" really are:
Hopefully they are not a dog "product".
back to the topic at hand .....
sadly, it seems, we do have a similar-style food product. they appear sometime around easter, at the sydney "royal easter show". called "dagwood dogs" or sometimes "pluto pups", they are regurgitated by small children complete with stick and tomata sauce. see pic.
